Wireless connection using command line instead of graphical tool
I have armbian image with kernel 4.4.184-rockchip64. Now I want to connect with Wifi using commands but I dont know how to connect using commands. I am able to connect with WiFi using Graphical tool.
Below are my observations:
a) Instead of wlan0, p2p0 interface is used to connect with wireless network.
b) I am able to scan with wlan0 using below command:
       iw dev wlan0 scan
c) iw dev p2p0 scan gives output associated interface( the one connected using Graphical Tool).
d) I created wpa_supplicant.conf file and executing below command shows wpa_supplicant initialized but does not get IP address.
      wpa_supplicant -Dnl0211 -iwlan0 -c/etc/wpa_supplicant.conf -B
Can anyone please tell me how to connect to any network without using Graphical tool. In my case p2p0 interface is used for Wireless Connection instead of wlan0 interface.
  On 8/1/2019 at 6:08 PM, AVP said:
       iw dev wlan0 scan
Expand
nmtui
As I mentioned in my query I want to connect using command line not any tool or something. nmtui pops out tool for manual selection.
I want to use commands similar like wpa_supplicant and the pass a .conf file which contains ssid,password etc.
Network Manager is garbage.  We had to uninstall it and go with wpa_supplicant on our 90+ tinker boards that we have deployed.  Constant disconnects with Network Manager and wpa_supplicant works all the time.
could you please share your configuration files (interfaces and wpa_suplicant.conf) as an example on how to achieve WiFi connection using the wpa_supplicant method?
Thanks.
  On 11/6/2019 at 10:58 PM, Ravaz said:
Thanks.
Expand
create /etc/wpa_supplicant/wpa_supplicant.conf with
su -c "wpa_passphrase myssid my_very_secret_passphrase > /etc/wpa_supplicant/wpa_supplicant.conf"
myssid = your WiFi-name
my_very_secret_passphrase = you WiFi-Password
wlan0-part of /etc/network/interfaces:
# wlan0 static ip
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.6.126
netmask 255.255.255.0
gateway 192.168.6.1
dns-nameservers 8.8.8.8 8.8.4.4
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
wireless-mode Managed
wireless-power off
# or wlan0 dhcp
# auto wlan0
# iface wlan0 inet dhcp
# wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
also fill /etc/resolv.conf with
nameserver 8.8.8.8
nameserver 8.8.4.4
Basically in 99.99% use case you can configure wifi with
wpa_passphrase <your-ssid> <your-passphrase> | wpa_supplicant -B -i wlan0 -c /dev/stdin
ifconfig wlan0 <your-ip> netmask <your-netmask>
route add default gw <your-router-address>
echo "nameserver 8.8.8.8" > /etc/resolv.conf
in some old very-deprecated rc startup file.
And remove nm ifup zeroconf dhcpd ... and other "wonderfull dynamic modern"  automatic bug generators ...
