Hey everyone...
I have an Orange pi zero Plus2 h5. The SD card load and boot is working fine.
However, i just realized i have no way to connect a keyboard  and mouse to it to finish the setup.
Is there a way around this like possibly inserting the armbian formated sd card into a linux system and changing config files??
If not, how can i attach a usb port to it??
Thanks.
41 minutes ago, ironmantis7x said:
The orange pi zero Plus2 h5 does not have onboard USB port:
I cant get the expansion port in Egypt.
Sorry - my fault. The Plus2 isnt the Zero from the Zero Pinout-Picture - so no USB onboard, but the onboard Pinout is the same.
OK, then try to get USB-Extension cable and cut it in the middle to get the female USB-A Port
or cut a USB-Header cable for a Desktop PC
and connect it to the connector on the Plus2:
5V                 ==> VCC
GND                ==> Ground
USB-DP2 or USB-DP3 ==> Data+
USB-DM2 or USB-DM3 ==> Data-
Use together USB-DP2 & USB-DM2 for USB-Port No.2
Use together USB-DP3 & USB-DM3 for USB-Port No.2
5V and GND is the same for both ports.
USB_Pinout_female.jpg.ba14da66decff7453995ab0271887f23.jpgUSB_Mainboard.gif.22a69c9a3c142b6a70947bf4bb979775.gifUSB_Header_Cable_DesktopPC.jpgUSB_female_Breakout_PCB.jpg.041a0496c08d13ab0c5a8a6bb95cd9da.jpg
5V                 ==> VCC
GND                ==> Ground
What is this called (specific product name)?
which one/picture?
black or yellow = usb header cable
orange = usb breakout board
Yes there is. It's called serial gadget console. Power the board via mUSB/computer and a standard serial console will showed up when the system is up. Works on Windows and Linux.
