Novato Posted May 30, 2020 Posted May 30, 2020 Thanks for answering! I was reading once, but a lot of new information. Since my native language is different, sometimes my translation is a little wrong. I will read it again as post 1.
Novato Posted May 30, 2020 Posted May 30, 2020 I edited it, removed the # (remember this works in Android build.prop) but it had no effect. Is there an updated video tutorial for these new versions of Armbian?
Turgus Posted May 30, 2020 Posted May 30, 2020 ..and you forgot to place an # before all lines which are not your hw (like rk3399 section..)
Novato Posted May 30, 2020 Posted May 30, 2020 6 minutes ago, Turgus said: ..and you forgot to place an # before all lines which are not your hw (like rk3399 section..) 10 minutes ago, Novato said: sorry, i forgot to type the .dtb extension It worked, thank you very much for the information, I was very lost here. Now everything is going smoothly. 1
MrCoolAndroid Posted May 30, 2020 Posted May 30, 2020 Hello! I have a question, if I run via UPDATE&BACKUP, it will erase Android? Or it will just run trough SD?
manuti Posted May 30, 2020 Posted May 30, 2020 5 hours ago, balbes150 said: To upgrade from the old core, you need to restore the original firmware and go through all the steps for a clean installation. Or perform all the steps manually (do not wait for a detailed step-by-step guide for the manual option, you will have to solve everything yourself on the spot). Thanks @balbes150 with your hard work to prepare the images is enough for me. So no "original firmware" no way. If anyone have the "manual recipe" to install latest image on Amlogic board in the manual way I will glad to test the recipe. Thanks again.
tempuser9347598175 Posted May 31, 2020 Posted May 31, 2020 (edited) I've been able to boot into armbian via sd card without issue using the update method. Ethernet is working and nothing seems to be broken. However, trying to launch Armbian Config to install on eMMC doesn't work because after clicking to open the program a terminal pops up and disappears immediately, similar to how if you opened a command line program in windows just by clicking on it, it would close by itself. I'm not sure if this is a related problem but running terminal and trying to use su fails even though I'm certain I've got the password correct. I even reformatted and installed the image again on the sd card to make sure I set the password correctly but I always get authentication failed. Sudo also fails unless I press Control+Alt+F3 and then I can login on the new screen. Synaptic Package Manager isn't able to open at all as well. On another note, is it possible to back up the android system before installing armbian permanently? All the guides I've seen so far for backing up eMMC are to backup armbian, not the original android installed on it. Edited fix: I was able to fix sudo and config by following the steps in the fix sudo thread on this forum. The other issues still remain. Edited May 31, 2020 by Zazazas
Reddwarf Posted May 31, 2020 Posted May 31, 2020 Sorry I haven't been following this forum for a while so quick question: Can these images run on RK3229 based tv-boxes? Or be recompiled for them?
jeanrhum Posted May 31, 2020 Posted May 31, 2020 6 minutes ago, Reddwarf said: Sorry I haven't been following this forum for a while so quick question: Can these images run on RK3229 based tv-boxes? Or be recompiled for them? No, since it's not arm64. Look at this topic:
jeanrhum Posted May 31, 2020 Posted May 31, 2020 10 hours ago, Novato said: Hoow tô install a New GUI for Armbian? This not directly related to armbian. You can have a look it for instance: https://wiki.debian.org/DesktopEnvironment
Reddwarf Posted May 31, 2020 Posted May 31, 2020 6 minutes ago, jeanrhum said: No, since it's not arm64. Look at this topic: Thanks, I will
Novato Posted May 31, 2020 Posted May 31, 2020 8 hours ago, jeanrhum said: This not directly related to armbian. You can have a look it for instance: https://wiki.debian.org/DesktopEnvironment Thanks, I tried some, there is a tutorial, but in mine it did not run KDE Plasma qnd GNome, it requires more Hardware, maybe an installation in NAND but I will not try it.
fragpic Posted June 3, 2020 Posted June 3, 2020 Has anyone been able to get wifi working on their x96 mini with this image? I tried a few different ones and none of them detected wifi.
Turgus Posted June 4, 2020 Posted June 4, 2020 As usual just the newest (maybe test revisions?!) pcb version 4.x has a wifi chip working well, if you got the usual v.1.x-pcb inside with SSV6051(like I got on my first x96mini 2/16 too), just ethernet or usb wifi works.
fragpic Posted June 5, 2020 Posted June 5, 2020 8 hours ago, Turgus said: As usual just the newest (maybe test revisions?!) pcb version 4.x has a wifi chip working well, if you got the usual v.1.x-pcb inside with SSV6051(like I got on my first x96mini 2/16 too), just ethernet or usb wifi works. Oh, no wonder. I saw your previous posts that said wifi was working and that caused the confusion. Is there no way to get wifi working on this model then?
Turgus Posted June 5, 2020 Posted June 5, 2020 ..but I always mentioned that wifi only works on 4.x versions of HW and on other just eth(or usb wifi). If you would find sources for this chip, you might be able to build the needed modules for this kernel, but I simply prefer using ethernet or usb-wifi (with better connection since antenna is outside the box on other standard x96 mini )which is -if you use the usb ports already- with a 3-Port mini hub plus the usb-wifi under 7-10$/€ shipped from CN.
balbes150 Posted June 5, 2020 Author Posted June 5, 2020 Version 20200605. Added WiFi support for Allwinner Tanix TX6 (H6). 3
Povl H. Pedersen Posted June 5, 2020 Posted June 5, 2020 My H96max crashed today. Would not boot. is there any way, apart from full reinstall to get it bootable again ? it would only come up with the android recovery. could reboot from SD and create data backup. But still takes time to get the rest of what I need installed. HomeAssistant, so mostly docker containers. But my HA backup is a bit old. But I do have the data dirs but it is not the same.
Turgus Posted June 6, 2020 Posted June 6, 2020 Armbian_20.05.6_Arm-64_focal_current_5.7.0-rc7_desktop_20200605.img.xz works on my collection of x96 mini 2/16 as expected. Wifi & BT work only on the 4.x revision boards, on standard versions just ethernet(or usb wifi). No issues with the image so far, installed it already on internal of 3 boxes...
Turgus Posted June 6, 2020 Posted June 6, 2020 ..but on two x96minis I just went back to Armbian_20.08.0_Arm-64_bionic_current_5.7.0-rc7_desktop_20200531.img.xz because there is camorama still available, which gives me the best performance of all webcamviewers with 720p video(on focal with cheese, guvcview, kamoso etc. I always got around 15° higher temperatures and much higher cpu load) without using active cooling system or reducing cam resolution. So I'd appreciate if there were also bionic releases of the images in future to avoid using a noisy fan. On the box without cams focal works pretty normal, cool and smooth.
tediwildan Posted June 6, 2020 Posted June 6, 2020 Version 20200605. Added WiFi support for Allwinner Tanix TX6 (H6).No sound card found ??Sent from my SM-C9000 using Tapatalk
balbes150 Posted June 7, 2020 Author Posted June 7, 2020 17 hours ago, tediwildan said: No sound card found ?? Sound card found and working
gilberto Posted June 7, 2020 Posted June 7, 2020 staff can help me ?, I have a project in Brazil(www.sistemafenix.com.br) and replace my raspberry with amlogic s905. I have had many problems with wifi. I bought 30 boxes. Below I present the information find the wifi but do not find any wifi network. With the ifconfig command I was able to view wlan0 but found nothing with the command: This is the last version: root@arm-64:/home/fenix# uname -aLinux arm-64 5.7.0-rc7-arm-64 #20.05.6 SMP PREEMPT Fri Jun 5 20:29:42 MSK 2020 aarch64 aarch64 aarch64 GNU/Linux root@arm-64:/home/fenix# root@arm-64:/home/fenix# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.3 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 2804:14c:87c0:c3ca:736a:38aa:be2a:14c8 prefixlen 64 scopeid 0x0<global> inet6 fe80::43d9:c6e0:4c88:1d03 prefixlen 64 scopeid 0x20<link> inet6 2804:14c:87c0:c3ca:1192:5116:ca74:fa2c prefixlen 64 scopeid 0x0<global> ether 00:15:18:01:81:31 txqueuelen 1000 (Ethernet) RX packets 12444 bytes 10137349 (10.1 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 6605 bytes 1048422 (1.0 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 25 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 425 bytes 35625 (35.6 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 425 bytes 35625 (35.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether e0:76:d0:d6:3d:4d txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 root@arm-64:/home/fenix# I can see wlan0, but....... root@arm-64:/home/fenix# iwlist wlan0 scan wlan0 No scan results root@arm-64:/home/fenix# lsmod Module Size Used by fuse 139264 3 bnep 28672 2 zram 45056 2 nls_ascii 16384 1 brcmfmac 389120 0 joydev 28672 0 hci_uart 126976 0 brcmutil 24576 1 brcmfmac btqca 16384 1 hci_uart btrtl 20480 1 hci_uart btbcm 24576 1 hci_uart btintel 32768 1 hci_uartcfg80211 417792 1 brcmfmac crct10dif_ce 20480 1 meson_vdec 81920 0 lima 69632 0 gpu_sched 36864 1 lima ir_nec_decoder 16384 0 bluetooth 446464 13 btrtl,btqca,btintel,hci_uart,btbcm,bnep v4l2_mem2mem 45056 1 meson_vdec videobuf2_dma_contig 24576 1 meson_vdec videobuf2_memops 20480 1 videobuf2_dma_contig rc_khadas 16384 0 videobuf2_v4l2 36864 2 meson_vdec,v4l2_mem2mem ecdh_generic 16384 1 bluetooth ecc 32768 1 ecdh_generic meson_ir 16384 0 videobuf2_common 65536 3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem rfkill 40960 6 bluetooth,cfg80211 dw_hdmi_cec 16384 0 rc_core 57344 4 rc_khadas,ir_nec_decoder,meson_ir videodev 294912 4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem ao_cec 16384 0 mc 61440 4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem snd_soc_simple_amplifier 16384 1 display_connector 16384 0 sch_fq_codel 20480 3 ip_tables 32768 0 x_tables 45056 1 ip_tables ipv6 622592 50 nf_defrag_ipv6 24576 1 ipv6 gpio_keys_polled 16384 0 adc_keys 16384 0 armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/2ozF Please post the URL in the forum where you've been asked for. I need to produce many boxes with armbian but I need security because wifi chipsets change all the time, I would like to be able to buy hardware compatible with Armbian and its versions. it has been very difficult. Guys can give me a help. I will be very grateful and desperate because I have many boxes of this model. I saw that on Android the module used by the kernel and dhd.ko on kernel 3.14. What should I do? The last time I returned 5 box s905 with a problematic wifi SV6051P driver, I changed and got this model. This time I'm 30 and I was sure the wifi would be compatible and I can't return it. help me people!
dbsharpe Posted June 7, 2020 Posted June 7, 2020 32 minutes ago, gilberto said: staff can help me ?, I have a project in Brazil(www.sistemafenix.com.br) and replace my raspberry with amlogic s905. I have had many problems with wifi. I bought 30 boxes. Below I present the information find the wifi but do not find any wifi network. With the ifconfig command I was able to view wlan0 but found nothing with the command: Try this page to start with
tediwildan Posted June 7, 2020 Posted June 7, 2020 Sound card found and working How to fix my problem with soundcard?Sent from my SM-C9000 using Tapatalk
tempuser9347598175 Posted June 7, 2020 Posted June 7, 2020 (edited) How do you disable sleep? I can't wake it up and it's still on since the light is on. How do you install it to emmc? I can never find actual instructions for this distro. Edited June 7, 2020 by Zazazas
gilberto Posted June 8, 2020 Posted June 8, 2020 1 hour ago, dbsharpe said: Try this page to start with thank you very much for responding, I did the procedure below for my wlan0 device is gone(disapear) To fix, use mv /lib/firmware/brcm/brcmfmac4330-sdio.txt /lib/firmware/brcm/brcmfmac4330-sdio.txt.old ln -s /lib/firmware/brcm/nvram_ap6330.txt /lib/firmware/brcm/brcmfmac4330-sdio.txt in a shell on the target as root. Not sure where this Ubuntu distribution fault has crept in. nvram_ap6330.txt is actually the same file as android system:/etc/wifi/40183/nvram.txt and although not perfect, works better! root@arm-64:/home/fenix# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.3 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 2804:14c:87c0:c3ca:215:18ff:fe01:8131 prefixlen 64 scopeid 0x0<global> inet6 2804:14c:87c0:c3ca:736a:38aa:be2a:14c8 prefixlen 64 scopeid 0x0<global> inet6 fe80::215:18ff:fe01:8131 prefixlen 64 scopeid 0x20<link> ether 00:15:18:01:81:31 txqueuelen 1000 (Ethernet) RX packets 6409 bytes 6392279 (6.3 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 3300 bytes 498137 (498.1 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 22 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 26 bytes 3529 (3.5 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 26 bytes 3529 (3.5 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 I will restore it as it was before. If you know of something or how to buy box s905 compatible with armbian. the driver of this wifi is active in the kernel tree, but in the last version of this post it doesn't work. I think it's important to be able to make it work .....
