Hi all,
I'd just like to share a problem I experienced and what solved after a bit of Googling. Basically, I have Nextcloud installed on my Nanopi M4 (v1) with Armbian:
$ uname -a
Linux nanopim4 4.4.192-rk3399
When I sync files from my Android phone via local wifi, often the transfers were just failed. Not always but usually, it's when a directory contains lot of large files. After a bit of Googling and came across this: https://unix.stackexchange.com/questions/494290/nanopi-m4-rk3399-apache2-ssl-large-download-hangs/495378#495378
It works. The problem's solved after:
ethtool -K eth0 rx off tx off
and put the command in /etc/network/if-up.d/ethtool
Just wondering if anyone knows the root cause and have better solution than disabling things.
Thanks,
Yes, TCP/UDP offloading MUST be disabled for NanoPi, NanoPC.
With offloading enabled, Samba becomes completely useless, as you will find that transfers to a Windows PC freeze randomly (usually on large files).
Disabling offloading should be the default for RK3399 Armbian builds, as I spent months thinking there existed a bug with Samba/ARM64 before finding this post.
For the record, this is what I added to my NanoPC Armbian installation as /etc/network/if-up.d/disable-rk3399-eth-offloading:
#!/bin/bash
[ "$IFACE" == "eth0" ] || exit 0
ETHTOOL=/sbin/ethtool
[ -f $ETHTOOL ] || exit 2
[ -d /sys/devices/platform/fe300000.ethernet/net/$IFACE ] || exit 6
$ETHTOOL -K eth0 rx off tx off
exit 0
On a second thought though these properties may not be available in legacy :(
If so then going with the ethtool may indeed be the only option.
  On 7/3/2020 at 9:38 PM, piter75 said:
I did not try to fix it in legacy as I thought it was not a problem there ;-)
Expand
I also don't tend to use / pay much attention to / legacy anymore ... So we add one more IF sentence to check kernel version so that it won't touch modern kernels ... since there, its not needed, right?
Expand
I think I would go this route.
In modern kernel it's not needed in standard environments (MTU 1500).
