thanxx Posted November 4, 2019 Share Posted November 4, 2019 I run several boxes with armbian, most are s905x and one is s912. Mostly running home services like openhab, zm, etc. on s912 I run builds with Java (for my work) and from time to time I get strange segfaults while never had them on s905x. The issue is persistent on different builds for s912. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x0000ffff8f7817d0, pid=11561, tid=11590 # # JRE version: OpenJDK Runtime Environment (11.0.4+11) (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3) # Java VM: OpenJDK 64-Bit Server VM (11.0.4+11-post-Ubuntu-1ubuntu218.04.3, mixed mode, tiered, compressed oops, g1 gc, linux-aarch64) # Problematic frame: # V [libjvm.so+0x46e7d0] # # No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /home/alex/hs_err_pid11561.log # # If you would like to submit a bug report, please visit: # https://bugs.launchpad.net/ubuntu/+source/openjdk-lts # I was thinking about overheating, but never seen temp above 55 Time big.LITTLE load %cpu %sys %usr %nice %io %irq CPU 15:26:41: 1000/1512MHz 3.12 19% 0% 17% 0% 1% 0% 49.0°C Has anyone faced similar issues? Link to comment Share on other sites More sharing options...
Ceteris_Paribus Posted November 11, 2019 Share Posted November 11, 2019 Hi Everyone, I have spent a lot time and effort but could not manage to Beelink GT1 running. Once I boot the device with SD card, it stucks in Beelink logo for a while (waited around 10 mins) Is this problem might be due to current Android version ? (v6.0) Can you advise which armbian version (kernel version as well) and DTB to use ? Full specs : Beelink GT1 2GB / 32GB (G912) Link to comment Share on other sites More sharing options...
balbes150 Posted November 12, 2019 Share Posted November 12, 2019 9 hours ago, Ceteris_Paribus said: Can you advise which armbian version (kernel version as well) and DTB to use ? If when you connect the media with Armbian, the regular firmware does not start, then the universal multi-boot works and you need to setup the DTB setting (select the working dtb file). Link to comment Share on other sites More sharing options...
Jamboa Posted November 14, 2019 Share Posted November 14, 2019 Look's like there is not right dtb file for the Tanix TX9s for now. The box has 2GB of ram and 8GB rom so it's quite unique at the moment. Any idea is there any change to get TX9s and Armbian working together with using dtb file from another S912 device (maybe 16GB rom version)? Link to comment Share on other sites More sharing options...
Ceteris_Paribus Posted November 16, 2019 Share Posted November 16, 2019 On 11/12/2019 at 7:32 AM, balbes150 said: If when you connect the media with Armbian, the regular firmware does not start, then the universal multi-boot works and you need to setup the DTB setting (select the working dtb file). Which DTB file should I use for BeeLink GT1 2gb/16 G912 ? I tried several files but non of them worked Link to comment Share on other sites More sharing options...
Ceteris_Paribus Posted November 16, 2019 Share Posted November 16, 2019 On 11/12/2019 at 7:32 AM, balbes150 said: If when you connect the media with Armbian, the regular firmware does not start, then the universal multi-boot works and you need to setup the DTB setting (select the working dtb file). I got it working with Armbian_5.76_Aml-s912_Ubuntu_bionic_default_4.20.5_desktop_20190224 image even without putting any dtb file. Is theresomething wrong with Kernel 5 for my box : However, wifi is not working Link to comment Share on other sites More sharing options...
Alex83 Posted December 16, 2019 Share Posted December 16, 2019 Hi, i have an CSA93 device with S912 chipset and AP6339 3GB DDR3 RAM and 32 GB Flash. It's this device: Link to explain which device I use Could someone tell me which .dtb file I need to use and if I can boot this device by SD-Card and/or USB-Sticks? Thank you very much in advance! Link to comment Share on other sites More sharing options...
Nuno Cruz Posted January 1, 2020 Share Posted January 1, 2020 (edited) I'm trying to install armbin on an s10 tv box, same as xgody 912. It has 3g ddr4, 1000Mb ethernet. but no sucess to boot. I tried to decompile dtb from a original rom, hope I didnt made any mistake in all process to unpack, split the meson.dtb and then decompile the meson-gxm-q201-3g.dtb this is the decompilation, maybe for some people it can make sense why it does but any other system that uses dtb with same name. https://gist.github.com/nmocruz/a0baaf537808335ddc8bab2042131624 I was able to install once using an old generic armbian for s912 after a few reboot I was able to install, and the /proc/device-tree/model is saying Khadas VIM2, maybe was the first with conditions to boot. Edited January 1, 2020 by Nuno Cruz Link to comment Share on other sites More sharing options...
pianisteg Posted January 5, 2020 Share Posted January 5, 2020 Hello! Trying to set up Armbian on my Meecool M8S PRO L, based on S912 SoC. Looks like it is supported and balbes150 build should work fine. At least it worked well for my friend in 2018, but old Armbian builds based on 3.14 kernel were removed by balbes150 Ok, I look latest build with meson-gxm-q201.dtb at least loads fine and I get the working device: Working USB, mouse/keyboard XFCE starts well, video output works well Audio hdmi output works fine on my TV, but analog output is silent (why? Android sound) ethernet works but only 100 Mb, and completely do not work with other dtb (I tried vega-s96 and s912-kiii-pro) no wifi no bluetooth mouse pointer (cursor) is blinking while playing video, looks like video drivers are not Can you help me to build Armbian for my board? At least a working draft version of config will be helpfull. Any ways to get bluetooth working? Link to comment Share on other sites More sharing options...
balbes150 Posted January 17, 2020 Share Posted January 17, 2020 The topic is detached, since the main system is now shared and discussed in the corresponding topic. Link to comment Share on other sites More sharing options...
Ceteris_Paribus Posted February 1, 2020 Share Posted February 1, 2020 On 11/16/2019 at 1:50 PM, Ceteris_Paribus said: I got it working with Armbian_5.76_Aml-s912_Ubuntu_bionic_default_4.20.5_desktop_20190224 image even without putting any dtb file. Is theresomething wrong with Kernel 5 for my box : However, wifi is not working Hi everyone ! Can somebody upload this version ? I need it desperately Armbian_5.76_Aml-s912_Ubuntu_bionic_default_4.20.5_desktop_20190224 Link to comment Share on other sites More sharing options...
mmss Posted March 8, 2020 Share Posted March 8, 2020 On 2/1/2020 at 1:08 PM, Ceteris_Paribus said: Hi everyone ! Can somebody upload this version ? I need it desperately Armbian_5.76_Aml-s912_Ubuntu_bionic_default_4.20.5_desktop_20190224 HI, did you find this version? I also have the same problem with the GT1, I have tried all the images without success. Thanks. Link to comment Share on other sites More sharing options...
Siraj Posted March 28, 2020 Share Posted March 28, 2020 On 12/5/2016 at 3:42 AM, lvmc said: @balbes150 and @chocho I learnt how to extract the dtb and dts file from Beelink Android images. I will be documenting it here to help other users, but it is the exactly process @chocho already did. 1) update your GT1 device with GT1_104M0.img or GT1_104M0_AP6255.img 2) power-up, boot GT1; 3) copy boot.img from running Android image adb pull /dev/block/boot boot.img 4) download split_bootimg.pl tool and run it over boot.img wget -c http://www.enck.org/tools/split_bootimg_pl.txt -O split_bootimg.pl chmod a+x split_bootimg.pl split_bootimg.pl boot.img Result: -rw-r--r-- 1 lvmc staff 32M Dec 4 19:28 boot.img -rw-r--r-- 1 lvmc staff 7.0M Dec 4 20:08 boot.img-kernel -rw-r--r-- 1 lvmc staff 898K Dec 4 20:08 boot.img-ramdisk.gz -rw-r--r-- 1 lvmc staff 82K Dec 4 20:08 boot.img-second.gz 5) find the hex addresses of "d0 0d fe ed" hexdump -C -v boot.img-second.gz |less Results (hex and decimal addresses): gxm_q201_1g: 00000800 (2048) gxm_q201_2g: 0000a800 (43008) 6) extract available dtb sections from boot.img-second.gz gxm_q201_1g dd if=boot.img-second.gz of=gxm_q201_1g.dtb bs=2048 skip=1 gxm_q201_2g dd if=boot.img-second.gz of=gxm_q201_2g.dtb bs=43008 skip=1 7) convert dtb (binary format) to dts (readable) dtc -I dtb -O dts -o gxm_q201_201_1g.dts gxm_q201_201_1g.dtb dtc -I dtb -O dts -o gxm_q201_201_2g.dts gxm_q201_201_2g.dtb *dtc command is available on GNU/Linux There is only one difference between gxm_q201_201_1g.dts and gxm_q201_201_2g.dts memory@00000000 { device_type = "memory"; linux,usable-memory = <0x0 0x1000000 0x0 0x3f000000>; }; memory@00000000 { device_type = "memory"; linux,usable-memory = <0x0 0x1000000 0x0 0x7f000000>; }; boot.img, dtb and dts files from previous steps are available at: https://dl.dropboxusercontent.com/u/11164079/GT1/beelink_gt1.tar.gz beelink_gt1/boot -rw-r--r-- 1 lvmc staff 32M Dec 4 19:28 boot.img -rw-r--r-- 1 lvmc staff 7.0M Dec 4 20:08 boot.img-kernel -rw-r--r-- 1 lvmc staff 898K Dec 4 20:08 boot.img-ramdisk.gz -rw-r--r-- 1 lvmc staff 82K Dec 4 20:08 boot.img-second.gz beelink_gt1/dtb_dts -rw-r--r-- 1 lvmc staff 80K Dec 4 20:24 gxm_q201_1g_00000800.dtb -rw-r--r-- 1 lvmc staff 48K Dec 4 20:25 gxm_q201_1g_00000800.dts -rw-r--r-- 1 lvmc staff 40K Dec 4 20:18 gxm_q201_2g_0000a800.dtb -rw-r--r-- 1 lvmc staff 48K Dec 4 20:21 gxm_q201_2g_0000a800.dts i am using above mentioned commands but split_bootimg.pl does not produce boot.img-second.gz file Link to comment Share on other sites More sharing options...
psxsnake Posted April 1, 2020 Share Posted April 1, 2020 Hello I try to put Armbian on my H96+ S912 but i got same error with sd car or usb Install /sdcard/aml_autoscript.zip Finding update package... Opening update package... failed to map file Installation aborted Link to comment Share on other sites More sharing options...
psxsnake Posted April 1, 2020 Share Posted April 1, 2020 I did update: it works with update inside menu of android tv box, but not install, it's like live distro only on SD can i make it permanent on box? sorry for my english is not my native language Link to comment Share on other sites More sharing options...
malloc32 Posted April 8, 2020 Share Posted April 8, 2020 Hello, I use my H96 Pro+ 3GB (S912) for many things, "download station", VPN, hosting .... all these work fine, but... I have the H96 connected to a televison and sometimes I like to play some games. I have installed mame, it works, but I have to reduce the resolution if I want to play at decent speed, but some games (Golden Axe) has a very very low frame rate. The H96 moves very well Golden Axe in Android, so I supose that there is a problem with mali drivers, no? Any solution? I have tried to install retropie from its git repository but not works. I have installed a MSX emulator and it works, but again I have to reduce the resolution and even with the lowest resolution not works at full speed. I have installed in sd Bionic 5.5.0-rc6-aml-s9xxx, works very well, but very very slow in mame. Note: if I disabled cores 4-7 works better, but it is not enough, still slow even at lowest resolution Thank you. Link to comment Share on other sites More sharing options...
Eduard Posted April 9, 2020 Share Posted April 9, 2020 Hi I tried to install de bionic_current_5.5.0 in my H96+ S912 Armlogic Mali 820 3G but I couldn't find the right dtb file. Can anybody help me? Thanks Link to comment Share on other sites More sharing options...
Nikeb Posted May 28, 2020 Share Posted May 28, 2020 Hi , same issue here, i tried some dtb , i can manage to make it run but the ethernet and wifi doesn't work (it's not blinking), it detects some eth0 but can't connect (even on boot is not blinkin anything). I m using a Beelink Ultimate GT1 (s912 3 gb) i m running 5.7.0-rc1-arm-64 bionic desktop Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200423 the dtb i use is gtx-200 if i recall good. It's like the eth0 it's been recognized (but not entirely) but even forcing a good IP it's not connecting/blinking. This is the sudo ethtool eth0 Settings for eth0: Supported ports: [TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: Unknown! Duplex: Unknown! (255) Port: MII PHYAD: 8 Transceiver: internal Auto-negotiation: on Supports Wake-on: ug Wake-on: d Current message level: 0x0000003f (63) dry probe link time ifdown ifup Link detected: no What should i do to make it work? Would be easier if i change the image? i try some but whenever i manage to make it run the eth0 (and wifi) doesn t work. Thanks for any suggestion. Link to comment Share on other sites More sharing options...
cedd-77 Posted July 5, 2020 Share Posted July 5, 2020 On 5/28/2020 at 10:27 AM, Nikeb said: Hi , same issue here, i tried some dtb , i can manage to make it run but the ethernet and wifi doesn't work (it's not blinking), it detects some eth0 but can't connect (even on boot is not blinkin anything). I m using a Beelink Ultimate GT1 (s912 3 gb) i m running 5.7.0-rc1-arm-64 bionic desktop Armbian_20.05.2_Arm-64_bionic_current_5.7.0-rc1_desktop_20200423 the dtb i use is gtx-200 if i recall good. It's like the eth0 it's been recognized (but not entirely) but even forcing a good IP it's not connecting/blinking. This is the sudo ethtool eth0 meson-gxm-vega-s96.dtb Settings for eth0: Supported ports: [TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: Unknown! Duplex: Unknown! (255) Port: MII PHYAD: 8 Transceiver: internal Auto-negotiation: on Supports Wake-on: ug Wake-on: d Current message level: 0x0000003f (63) dry probe link time ifdown ifup Link detected: no What should i do to make it work? Would be easier if i change the image? i try some but whenever i manage to make it run the eth0 (and wifi) doesn t work. Thanks for any suggestion. hello, I don't have the ultimate version of GT1 but I use the meson-gxm-vega-s96.dtb everything ok and ETH0 ! Just the CPU Temp at 55° but the box work great (home-asssitant). Link to comment Share on other sites More sharing options...
