Hi, I have tried to run Armbian_20.05.1_Orangepizero_focal_current_5.4.43.img.xz but it doesn't work, see here:
U-Boot SPL 2020.04-armbian (May 30 2020 - 18:49:32 +0200)
DRAM: 256 MiB
Trying to boot from MMC1
U-Boot 2020.04-armbian (May 30 2020 - 18:49:32 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero
DRAM:  256 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3789 bytes read in 4 ms (924.8 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
181 bytes read in 3 ms (58.6 KiB/s)
13650370 bytes read in 1038 ms (12.5 MiB/s)
7236248 bytes read in 552 ms (12.5 MiB/s)
29861 bytes read in 12 ms (2.4 MiB/s)
504 bytes read in 8 ms (61.5 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4185 bytes read in 8 ms (510.7 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    13650306 Bytes = 13 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
I tried both torrent and http downloads and two microSD cards, the sha checksum is correct too:
danman@silverhorse:~/Downloads$ sha256sum Armbian_20.05.1_Orangepizero_focal_current_5.4.43.img.xz
12dd233cc434435027e4756ce752b8aad40307eadda613cf2b225cb8b209da9b  Armbian_20.05.1_Orangepizero_focal_current_5.4.43.img.xz
danman@silverhorse:~/Downloads$ cat Armbian_20.05.1_Orangepizero_focal_current_5.4.43.img.xz.sha
12dd233cc434435027e4756ce752b8aad40307eadda613cf2b225cb8b209da9b *Armbian_20.05.1_Orangepizero_focal_current_5.4.43.img.xz
The Armbian_20.05.1_Orangepizero_buster_current_5.4.43.img.xz works without any problem.
Confirmed - Focal current on OPi0 is broken
Also confirmed that Buster current is booting normally
Bionic is working normal as well.
Last login: Sat May 30 22:50:08 UTC 2020 on ttyS0
  ___  ____  _   _____
 / _ \|  _ \(_) |__  /___ _ __ ___
| | | | |_) | |   / // _ \ '__/ _ \
| |_| |  __/| |  / /|  __/ | | (_) |
 \___/|_|   |_| /____\___|_|  \___/
Welcome to Armbian buster with Linux 5.4.43-sunxi
System load:   0.99 0.39 0.14   Up time:       1 min
Memory usage:  15 % of 492MB    IP:
CPU temp:      34°C
Usage of /:    7% of 15G
Last login: Sat May 30 22:51:41 UTC 2020 on ttyS0
  ___  ____  _   _____
Welcome to Armbian Bionic with Linux 5.4.43-sunxi
System load:   1.10 0.36 0.13   Up time:       1 min
Memory usage:  12 % of 492MB    IP:
CPU temp:      40°C
Usage of /:    6% of 15G
Let me check if trunk has the same issue....Yep, trunk is affected as well....
Oh boy, it is getting worse
OrangePi One Focal current is broken as well. I guess all sunxi devices on Focal are affected.
  Reveal hidden contents
Does not make sense to me since Focal is not involved in the boot process at this time...
Some Focal images are broken
and I have no clue why atm. The other day were fine, yesterday rebuild ... fail. Changed build host, fail. Build manually, failed ...
  • Igor changed the title to Armbian 20.05.1 Focal images could be broken
  • Igor pinned and featured this topic
The only hit I have so far is that I get many qemu unsupported syscall 403 when building Focal....
Expand
It is possible that its build host related. I didn't try on Ubuntu 20.04 yet.
Expand
Me neighter. Also building on 18.04 atm.
I'll get a VM running an will try this.
Aight, the debug output so far looks way cleaner than on Bionic.... Unfortunatly without success. Same issue when built on Focal...dang it.
My next try was switching U-Boot to master but was not successful either...
So to get this straight: When issuing update initramfs on Focal it does something different than on Bionic.
U-Boot tools (including mkimage) are the same for Bionic with backports and Focal.
initramfs-tools is slightly different on Bionic (0.130ubuntu3.9) than on Focal (0.136ubuntu6)
U-Boot 2020.07-rc3-armbian (Jun 01 2020 - 11:41:10 +0000) Allwinner Technology
Model: Xunlong Orange Pi One
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface0
starting USB...
scanning bus usb@1c1a400 for devices... ERROR: sohci_submit_job: EPIPE
ERROR: sohci_submit_job failed
unable to get device descriptor (error=-1)
failed, error -1
Scanning mmc 0:1...
3789 bytes read in 3 ms (1.2 MiB/s)
152 bytes read in 2 ms (74.2 KiB/s)
13299155 bytes read in 633 ms (20 MiB/s)
7236248 bytes read in 345 ms (20 MiB/s)
29463 bytes read in 6 ms (4.7 MiB/s)
   Image Name:   uInitrd
   Data Size:    13299091 Bytes = 12.7 MiB
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
ERROR: USB HC reset timed out!
device_remove: Device 'usb@1c1a400' failed to remove, but children are gone
ERROR: USB HC TakeOver failed!
device_remove: Device 'usb@1c1b400' failed to remove, but children are gone
   Loading Ramdisk to 49351000, end 49fffd93 ... OK
   Loading Device Tree to 492e1000, end 49350fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Armbian 20.08.0-trunk Focal ttyS0
orangepione login: root
Password:
You are required to change your password immediately (administrator enforced)
Changing password for root.
Current password:
New password:
Retype new password:
  ___  ____  _    ___
 / _ \|  _ \(_)  / _ \ _ __   ___
| | | | |_) | | | | | | '_ \ / _ \
| |_| |  __/| | | |_| | | | |  __/
 \___/|_|   |_|  \___/|_| |_|\___|
Welcome to Armbian Focal with Linux 5.4.43-sunxi
No end-user support: built from trunk
System load:   1.71 0.49 0.17   Up time:       0 min
Memory usage:  16 % of 492MB    IP:
CPU temp:      36°C
New to Armbian? Check the documentation first: https://docs.armbian.com
Thank you for choosing Armbian! Support: www.armbian.com
Creating a new user account. Press <Ctrl-C> to abort
Please provide a username (eg. your forename): ^C
Disabling user account creation procedure
orangepione login:
Nailed it!
Basically what I did was plugging the sd card with the broken Focal image with an USB adapter into my OrangePi One Plus running Focal (dev branch but should not matter), chrooted into the sd card and ran update-initramfs -u. Thats it.
I guess I can have a beer now after five hours of try n error :P
  On 6/1/2020 at 1:30 PM, Werner said:
I wished you would not have asked because I have no freakin clue...
Expand
Have you recreate image on x86 machine?
I just created a VirtualBox VM and built NanoPi Duo and NanoPi M1 fine. Duo working fine, still need to test M1 image.
Two things we tried and 2/2 builds were successful. Not sure if this is fix yet, but before I rebuild all focal images, need some tests.
- give more memory for initrd, rebuilding kernel https://github.com/armbian/build/tree/master/config/kernel with changed
+CONFIG_BLK_DEV_RAM_COUNT=16
+CONFIG_BLK_DEV_RAM_SIZE=8192
- creating initrd with
https://github.com/armbian/build/blob/master/lib/debootstrap.sh#L551
QEMU_BINARY="qemu-aarch64-static"
I was able to get the M1 focal image to boot with local build as well. So are you still having issues with automated builds or just this one?
Expand
Yes, it seems like a random problem :wacko: We wasted literally a day on this ... getting nowhere.:(
https://github.com/EvilOlaf/build/commit/a2957ca8aa6c89d5af52cfa612aa471f630ed258
With this rather ugly workaround and no idea how and why it worked I could build multiple working images (boot confirmed):
  • OrangePi One Focal current  (Bionic build host)
  • OrangePi Zero Focal current  (Bionic build host)
  • OrangePi One Focal current  (Focal build host)
(The build host is just informational, does not make a difference (yet).)
If anybody has armhf based boards and got some spare time please use this workaround, build an image for your board with Focal as target OS and let us know if it boots.
In short I do the update-initramfs twice, once again after removing all the mounts and force both through the QEMU static emulator binary. Throws tons of "unsupported syscall" errors on Bionic but works.
Bullseye should be tested as well since both Focal and Bullseye most likely have nearly identical package versions.
@Igor I know you probably tried this, but focal builds were work around mid-May. Can you see any deltas to your build scripts after that?
Expand
I also experienced this issue on OrangePi boards this week.
I just built images (build host Focal) using the @Werner a2957ca8 commit for:
OrangePi PC
OrangePi PC+
Olimex Lime 2
All booted successfully.  All failed to boot with the images currently on the Armbian download page.
Thanks for your work on this.  Let me know if I can help.
Expand
Thanks!!!
We were not sure if hack actually holds and still not really since nobody can explain (yet) why this seems actually working.
Hello, is this issue fixed now ? I'm using OrangePi One Plus server, and three days ago I did apt -y upgrade. After that, it wont boot -- drops to initramfs ( UUID does not exist ).
I did a peek here, and tried to qemu chroot to sdcard from a Focal running VM, and issued " update-initramfs -u ", but that did not solve my problem -- still wont boot.
12 hours ago I restored to a month old backup, and it booted fine ofc, but then I tried to upgrade again, as there is no more warning about broken Focal images, but sure enough, dropped to initramfs :(
Is there something else I can try ? :D
Armbian_20.05.2_Orangepizero_focal_current_5.4.43.img.xz works without any problem. Thank you
  ___  ____  _   _____
System load:   1.03 1.49 0.70  	Up time:       4 min
Memory usage:  30 % of 239MB  	Zram usage:    19 % of 119Mb  	IP:            192.168.1.129
CPU temp:      56°C
Usage of /:    13% of 7.3G
[ General system configuration (beta): armbian-config ]
Last login: Fri Jun  5 07:17:01 2020 from 192.168.1.137
  • Igor unpinned and unfeatured this topic
After kernel update to 20.05.3 my cubietruck stopped booting again. 20.05.1 images were broken, 20.05.1 was OK. Does anybody have similar issues?
Expand
I assume 20.05.2 was okay?
Did you retry with a fresh image on another sd card?
