dolphs Posted July 10, 2020 Author Share Posted July 10, 2020 On 7/10/2020 at 12:20 AM, 5kft said: Hi @dolphs, I've checked in an updated patch for this here (in a test branch) cheers for that, since I am still learning this means a new checkout ( git clone --depth 1 https://github.com/armbian/build ) or just copy over your patch for time being " board-h6-improve-thermals.patch " , as these fail currently ( last time I built ): 1 out of 2 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-cpu-opp.dtsi.rej 1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej meaning eg " rm board-h6-improve-thermals.patch && wget https://raw.githubusercontent.com/5kft/build/86ad3c26c9f4835cd97e223223c72f0464173848/patch/kernel/sunxi-dev/board-h6-improve-thermals.patch " I did a fresh checkout , spun up a new compile job and verified the thermal patch does not throw any errors as was expected. Yet panfrost related patches to go, not sure about the "Unable to make Panfrost work on H6"-status since after May things are silent, perhaps @NicoD or @Werner have a good view of what is going on, on this one? Anyway in next attempt will exclude these to see what else is coming up. thanks @5kft [OK!] Processing file /home/armbian/patch/kernel/sunxi-dev/board-h6-improve-thermals.patch [NOK] Processing file /home/armbian/patch/kernel/sunxi-dev/board-h6-orangepi-lite2-fix-missing-all.patch 1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dts.rej Processing file /home/armbian/patch/kernel/sunxi-dev/sun50i-h6-drm_panfrost-1-missing-remove-opp-table-in-case-of-failure.patch 2 out of 3 hunks FAILED -- saving rejects to file drivers/gpu/drm/panfrost/panfrost_devfreq.c.rej Processing file /home/armbian/patch/kernel/sunxi-dev/sun50i-h6-drm_panfrost-2-add-devfreq-regulator-support.patch 2 out of 3 hunks FAILED -- saving rejects to file drivers/gpu/drm/panfrost/panfrost_devfreq.c.rej 1 out of 1 hunk FAILED -- saving rejects to file drivers/gpu/drm/panfrost/panfrost_device.h.rej So removed these three patches but alas still stuck ... make[5]: *** [scripts/Makefile.build:280: drivers/net/wireless/realtek/rtl8723cs/core/rtw_br_ext.o] Error 1 make[4]: *** [scripts/Makefile.build:497: drivers/net/wireless/realtek/rtl8723cs] Error 2 make[3]: *** [scripts/Makefile.build:497: drivers/net/wireless/realtek] Error 2 make[2]: *** [scripts/Makefile.build:497: drivers/net/wireless] Error 2 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [scripts/Makefile.build:497: drivers/net] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [Makefile:1758: drivers] Error 2 Not entirely sure if this is related to @martinayotte work done in 5.6 kernel cleanup/ fixes... Therefore added compilation.log, this is the one that FAILs. compilation.log 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted July 10, 2020 Author Share Posted July 10, 2020 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted July 12, 2020 Share Posted July 12, 2020 @dolphs see if it builds when adding EXTRAWIFI=no 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted July 12, 2020 Author Share Posted July 12, 2020 cheers @lanefu but this is how I spin up my builds usually, therefore alas no go ( summary from first page below ) I will give it another shot Tuesday earliest I guess ( hoping also for rc5 ) On 7/9/2020 at 8:41 AM, dolphs said: quick summary how to repeat things: sed -i -e 's/orange-pi-5.7/orange-pi-5.8/g' sunxi64_common.inc ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=yes EXTRAWIFI=no WIREGUARD=no BOARD=orangepioneplus 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted July 17, 2020 Author Share Posted July 17, 2020 OK new attempt but still these compilation errors In file included from drivers/net/wireless/realtek/rtl8723cs/include/drv_types.h:82, from drivers/net/wireless/realtek/rtl8723cs/core/rtw_br_ext.c:32: drivers/net/wireless/realtek/rtl8723cs/include/rtw_security.h:241:8: error: redefinition of ‘struct sha256_state’ struct sha256_state { ^~~~~~~~~~~~ In file included from ./include/linux/filter.h:23, from ./include/net/sock.h:59, from ./include/net/inet_sock.h:22, from ./include/net/ip.h:27, from drivers/net/wireless/realtek/rtl8723cs/core/rtw_br_ext.c:24: ./include/crypto/sha.h:84:8: note: originally defined here struct sha256_state { ^~~~~~~~~~~~ make[5]: *** [scripts/Makefile.build:281: drivers/net/wireless/realtek/rtl8723cs/core/rtw_br_ext.o] Error 1 make[4]: *** [scripts/Makefile.build:497: drivers/net/wireless/realtek/rtl8723cs] Error 2 make[4]: *** Waiting for unfinished jobs.... make[3]: *** [scripts/Makefile.build:497: drivers/net/wireless/realtek] Error 2 make[3]: *** Waiting for unfinished jobs.... make[2]: *** [scripts/Makefile.build:497: drivers/net/wireless] Error 2 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [scripts/Makefile.build:497: drivers/net] Error 2 make[1]: *** Waiting for unfinished jobs.... drivers/usb/typec/anx7688.c: In function ‘anx7688_connect’: drivers/usb/typec/anx7688.c:489:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement] const u8 dp_snk_identity[16] = { ^~~~~ drivers/usb/typec/anx7688.c:502:2: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement] const u8 svid[4] = { ^~~~~ make: *** [Makefile:1758: drivers] Error 2 Can be repeated this way: - fresh checkout - manual intervention cd ~/armbian/config/sources/families/include sed -i -e 's/orange-pi-5.7/orange-pi-5.8/g' sunxi64_common.inc cd ~/armbian/patch/kernel/sunxi-dev rm -v board-h6-improve-thermals.patch wget https://raw.githubusercontent.com/5kft/build/86ad3c26c9f4835cd97e223223c72f0464173848/patch/kernel/sunxi-dev/board-h6-improve-thermals.patch rm -v board-h6-orangepi-lite2-fix-missing-all.patch rm -v sun50i-h6-drm_panfrost-1-missing-remove-opp-table-in-case-of-failure.patch rm -v sun50i-h6-drm_panfrost-2-add-devfreq-regulator-support.patch - compile rc5 cd ~/armbian ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=yes EXTRAWIFI=no WIREGUARD=no BOARD=orangepioneplus load saved " .config-h6-default " 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted July 17, 2020 Author Share Posted July 17, 2020 OK I took a closer look in the patch directory ( which I should have done earlier ) . Yet I found these patches ( below ), but till now I was convinced flag " EXTRAWIFI=no " would bypass these. Anyway after removing these two I succeeded to build my first 5.8 image ( with most patches ) -wifi-4001-add-realtek-8723cs-kconfig-makefile.patch -wifi-4002-add-realtek-8723cs.patch :~/armbian/output/images$ ls -l total 674496 -rw-rw-r-- 1 root root 792723456 Jul 17 08:53 Armbian_20.08.0-trunk_Orangepioneplus_buster_dev_5.8.0-rc5_minimal.img -rw-rw-r-- 1 root sudo 137 Jul 17 08:53 Armbian_20.08.0-trunk_Orangepioneplus_buster_dev_5.8.0-rc5_minimal.img.sha -rw-rw-r-- 1 root sudo 19667 Jul 17 08:53 Armbian_20.08.0-trunk_Orangepioneplus_buster_dev_5.8.0-rc5_minimal.img.txt ___ ____ _ ___ / _ \| _ \(_) / _ \ _ __ ___ _ | | | | |_) | | | | | | '_ \ / _ \_| |_ | |_| | __/| | | |_| | | | | __/_ _| \___/|_| |_| \___/|_| |_|\___| |_| Welcome to Armbian buster with Linux 5.8.0-rc5-sunxi64 No end-user support: built from trunk System load: 0.00 0.00 0.00 Up time: 1:50 Memory usage: 9 % of 986MB IP: 192.168.10.122 CPU temp: 51°C Usage of /: 18% of 3.5G :~# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 1: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 2: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 3: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. root@orangepioneplus:~# lsmod Module Size Used by rfkill 32768 1 snd_soc_hdmi_codec 20480 0 snd_soc_core 180224 1 snd_soc_hdmi_codec snd_pcm_dmaengine 20480 1 snd_soc_core snd_pcm 114688 3 snd_soc_hdmi_codec,snd_soc_core,snd_pcm_dmaengine snd_timer 45056 1 snd_pcm snd 81920 4 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm soundcore 16384 1 snd zstd 16384 4 sunxi_cir 20480 0 sunxi_cedrus 36864 0 rc_core 53248 2 sunxi_cir videobuf2_dma_contig 24576 1 sunxi_cedrus v4l2_mem2mem 32768 1 sunxi_cedrus videobuf2_memops 20480 1 videobuf2_dma_contig videobuf2_v4l2 28672 2 sunxi_cedrus,v4l2_mem2mem dw_hdmi_cec 16384 0 dw_hdmi_i2s_audio 16384 0 videobuf2_common 53248 3 sunxi_cedrus,videobuf2_v4l2,v4l2_mem2mem videodev 249856 4 sunxi_cedrus,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem mc 53248 5 sunxi_cedrus,videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem panfrost 65536 0 sun8i_ce 28672 0 gpu_sched 32768 1 panfrost display_connector 20480 0 crypto_engine 20480 1 sun8i_ce zram 36864 3 realtek 24576 1 i2c_mv64xxx 24576 0 dwmac_sun8i 28672 0 mdio_mux 16384 1 dwmac_sun8i This means now things drill down to go thru the patches which need to be either removed or updated for kernel 5.8 ( and u-boot ) 2 Quote Link to comment Share on other sites More sharing options...
dolphs Posted July 23, 2020 Author Share Posted July 23, 2020 Hi - Was about to spin up a new build (rc6), but it seems MakeFile has not been updated yet? @megous @megi will you wait for rc7 which will be released coming Sunday (Monday) most likely, or could orange-pi-5.8 branch be updated please? TiA! 0 Quote Link to comment Share on other sites More sharing options...
megi Posted July 24, 2020 Share Posted July 24, 2020 On 7/23/2020 at 12:40 PM, dolphs said: Hi - Was about to spin up a new build (rc6), but it seems MakeFile has not been updated yet? @megous @megi will you wait for rc7 which will be released coming Sunday (Monday) most likely, or could orange-pi-5.8 branch be updated please? TiA! I'll probably only udpate on final v5.8 release. 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted July 25, 2020 Author Share Posted July 25, 2020 Hmm, in reply to this topic @Werner: " sun50i-cpufreq-nvmem: probe of sun50i-cpufreq-nvmem failed with error -2 " Looks like similar in 5.8 , cpufreq broken, while DVFS should have been added to kernel 5.8, to be honest did not do a "dmesg' perhaps @5kft can help out both for 5.7 and 5.8 ? ( DVFS is planned for H5 in 5.9 ) 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 25, 2020 Share Posted July 25, 2020 2 minutes ago, dolphs said: Looks like similar in 5.8 , cpufreq broken, Was broken in 5.7 too but has been fixed. Was due to missing dts entries. If it is broken in 5.8 again it is most likely for the same reason. 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted August 3, 2020 Author Share Posted August 3, 2020 Hi, thanks @megi , for bumping dev to 5.8 ! @all - Therefore please let's update dev branch to 5.8 as 5.7 will be phased out somewhere in August. First glance showed : 1/ duplicate labels ( sun50i-h6.dtsi ): to be found in: " ./cache/sources/u-boot/v2020.04/arch/arm/dts " -sun50i-h6-beelink-gs1.dtb -sun50i-h6-orangepi-one-plus.dtb -sun50i-h6-orangepi-3.dtb -sun50i-h6-orangepi-lite2.dtb -sun50i-h6-pine-h64-model-b.dtb -sun50i-h6-pine-h64.dtb -sun50i-h6-tanix-tx6.dtb Which reminds me u-boot can be updated to 2020.07. Wasn't there a JIRA story for this already ( rgd 20.08 Caple release ? ) 2/ patches in 5.8 that need attention This one can be used still for 5.7. and 5.8 ? - general-packaging-5.6.y.patch Further took out these that FAILED, see full logs attached of three attempts till image got built : cd ~/armbian/patch/kernel/sunxi-dev rm board-h6-improve-thermals.patch wget https://raw.githubusercontent.com/5kft/build/86ad3c26c9f4835cd97e223223c72f0464173848/patch/kernel/sunxi-dev/board-h6-improve-thermals.patch rm 0001-Revert-leds-axp20x-Support-charger-LED-on-AXP20x-lik.patch rm 0002-Add-leds-axp20-x-charger.patch rm add-missing-H6-gpu-opp-in-5.7.y.patch rm olimex_0020-arm-sun7i-a20-Add-support-for-A20-OLinuXino-LIME-eMM.patch rm olimex_0023-drm-sun4i-hdmi-Add-support-for-sun4i-HDMI-encoder-au.patch rm olimex_0038-dts-fix-lime-emmc-compatible-string.patch rm board-h6-orangepi-lite2-fix-missing-all.patch rm sun50i-h6-drm_panfrost-1-missing-remove-opp-table-in-case-of-failure.patch rm sun50i-h6-drm_panfrost-2-add-devfreq-regulator-support.patch rm wifi-4001-add-realtek-8723cs-kconfig-makefile.patch rm wifi-4002-add-realtek-8723cs.patch This results in an image, but did not flash it yet as these above need attention and should be fixed first varying from just deleting to updates imho : @armbian:~/armbian$ ls -l /home/armbian/output/images/ total 620180 -rw-rw-r-- 1 root root 725614592 Aug 3 08:06 Armbian_20.08.0-trunk_Orangepioneplus_buster_dev_5.8.0_minimal.img -rw-rw-r-- 1 root sudo 133 Aug 3 08:06 Armbian_20.08.0-trunk_Orangepioneplus_buster_dev_5.8.0_minimal.img.sha -rw-rw-r-- 1 root sudo 19639 Aug 3 08:06 Armbian_20.08.0-trunk_Orangepioneplus_buster_dev_5.8.0_minimal.img.txt compilation.zip output.zip patching.zip 1 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 3, 2020 Share Posted August 3, 2020 It is not important to bump dev to 5.8 since dev branch is usually not a part of any release. Btw @Igor is already working on a branch to make the bump happen: https://github.com/armbian/build/commits/sunx_megi_58 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted August 3, 2020 Author Share Posted August 3, 2020 @Werner as well @Igor hope I could contribute to initial stage identifying which patches need to be reviewed, so 5.8 can be build for h6 ( and h3/ h5 ) clean and properly 1 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 5, 2020 Share Posted August 5, 2020 On 8/3/2020 at 1:18 PM, dolphs said: hope I could contribute to initial stage identifying which patches need to be reviewed, so 5.8 can be build for h6 ( and h3/ h5 ) clean and properly If you have time, DEV branch is safe for bumping to 5.8.y with a pull request (we merge after release). regardless of the release ... just keep it build-able and make sure to include all the patches that are in and yet to come to 5.7.y if they are needed. Edit: probably we need to adjust all / many wireless drivers for 5.8.y Some already are. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 5, 2020 Share Posted August 5, 2020 1 hour ago, Igor said: DEV branch is safe for bumping to 5.8.y I've started the task ... But not all my Allwinner garden is tested ... 1 hour ago, Igor said: probably we need to adjust all / many wireless drivers for 5.8.y Some already are. Yes ! I've done a patch to tweak sha256_state structure clashes for tons of Realtek drivers as well as API changes to cfg80211. BTW, I've done some tests with BullEyes desktop on my OPi3, and Panfrost is freezing easily while it was working fine under 5.7.y. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 6, 2020 Share Posted August 6, 2020 11 hours ago, martinayotte said: BTW, I've done some tests with BullEyes desktop on my OPi3, and Panfrost is freezing easily while it was working fine under 5.7.y. Did you apply the GPU clock fix? 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 6, 2020 Share Posted August 6, 2020 8 hours ago, Werner said: Did you apply the GPU clock fix? If you mean this patch/kernel/sunxi-dev/add-missing-H6-gpu-opp-in-5.7.y.patch, Yes it is still applied, although I had to remove CPU OPP since it became a duplicate. But it most probably related to those ones since I had to disabled them completely (I could not easily fix them) : patch/kernel/sunxi-dev/sun50i-h6-drm_panfrost-1-missing-remove-opp-table-in-case-of-failure.patch patch/kernel/sunxi-dev/sun50i-h6-drm_panfrost-2-add-devfreq-regulator-support.patch 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 6, 2020 Share Posted August 6, 2020 54 minutes ago, martinayotte said: If you mean I meant the devfreq hack: https://armbian.atlassian.net/browse/AR-374 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 6, 2020 Share Posted August 6, 2020 16 minutes ago, Werner said: I meant the devfreq hack Oh ! I've completely forgot about the hack, I've forgot to add it in /etc/rc.local of the 5.8.y build ... I will check now ... EDIT: Thanks for the reminder : it is not freezing any more, at least until now ! 1 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 7, 2020 Share Posted August 7, 2020 The DEV branch is now 5.8.y, commmitted this morning ... 2 Quote Link to comment Share on other sites More sharing options...
5kft Posted August 7, 2020 Share Posted August 7, 2020 52 minutes ago, martinayotte said: The DEV branch is now 5.8.y, commmitted this morning ... Very nice work! Since I've been messing with the overclock overlays of late, I just dropped them in and everything works great (initial testing on a NEO2), including thermal management. dmesg seems clean as well! Seems super solid with cursory testing so far 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 11, 2020 Share Posted August 11, 2020 I've almost forgot one during my Allwinner garden tour : Pinebook-A64 ! Unfortunately, it seems that 5.8.y is broken somehow, the screen doesn't work after "starting kernel" ... It is not a DT issue, since I've tried to exchange DTB with my previous 5.7.6, so it must be in kernel binary. If someone else have time to test, I will be glad to get help to figure what is broken. 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted August 11, 2020 Author Share Posted August 11, 2020 will build tomorrow 5.8.1 for my h6 orangepioneplus ( if @megi ) has updated the megous branch and see about its status. thanks @martinayotte and others that contribute 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 11, 2020 Share Posted August 11, 2020 33 minutes ago, dolphs said: will build tomorrow 5.8.1 for my h6 orangepioneplus ( if @megi ) has updated the megous branch and see about its status. thanks @martinayotte and others that contribute Or you could simply add this patch to the patches folder and see if it works and give feedback https://cdn.kernel.org/pub/linux/kernel/v5.x/patch-5.8.1.xz 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted August 19, 2020 Author Share Posted August 19, 2020 hurah 5.8.2 came in at last ... so running a new compile job ( without kernel being modified / KERNEL_CONFIGURE=no ) learnt: - YES! it builds, however - are patches still needed for 5.8, eg can these be removed or do they need to be optimised for 5.8? - lots of WIFI misery around, even with EXTRAWIFI=no flag - Uboot on v2020.04 Things are improving but still lots of improvement needed, nevertheless thanks chaps that spend time on fixing things! Processing file /home/armbian/patch/misc/general-packaging-5.6.y.patch #still in and needed for 5.8 ? Processing file /home/armbian/patch/kernel/sunxi-dev/add-missing-H6-cpu-opp-in-5.7.y.patch #as is or to be optimised for 5.8 ? Processing file /home/armbian/patch/kernel/sunxi-dev/add-missing-H6-gpu-opp-in-5.7.y.patch 2 out of 2 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej WIFI and realtek misery all over see below ( even with extrawifi=no ) Processing file /home/armbian/patch/kernel/sunxi-dev/0001-Revert-leds-axp20x-Support-charger-LED-on-AXP20x-lik.patch Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file drivers/leds/leds-axp20x.c.rej Processing file /home/armbian/patch/kernel/sunxi-dev/board-h6-improve-thermals.patch 1 out of 2 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-cpu-opp.dtsi.rej 1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej Processing file /home/armbian/patch/kernel/sunxi-dev/board-h6-orangepi-lite2-fix-missing-all.patch 1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dts.rej Processing file /home/armbian/patch/kernel/sunxi-dev/disable-debug-rtl8723ds.patch The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8723ds/include/autoconf.h b/drivers/net/wireless/rtl8723ds/include/autoconf.h |index 9dd1a3e..ed1d27e 100644 |--- a/drivers/net/wireless/rtl8723ds/include/autoconf.h |+++ b/drivers/net/wireless/rtl8723ds/include/autoconf.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored Processing file /home/armbian/patch/kernel/sunxi-dev/olimex_0020-arm-sun7i-a20-Add-support-for-A20-OLinuXino-LIME-eMM.patch Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file arch/arm/boot/dts/Makefile.rej Processing file /home/armbian/patch/kernel/sunxi-dev/olimex_0023-drm-sun4i-hdmi-Add-support-for-sun4i-HDMI-encoder-au.patch Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/sun4i/Kconfig.rej Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/sun4i/Makefile.rej Reversed (or previously applied) patch detected! Skipping patch. 4 out of 4 hunks ignored -- saving rejects to file drivers/gpu/drm/sun4i/sun4i_hdmi.h.rej 2 out of 4 hunks FAILED -- saving rejects to file drivers/gpu/drm/sun4i/sun4i_hdmi_enc.c.rej Processing file /home/armbian/patch/kernel/sunxi-dev/wifi-4003-fix-sha256_state-clashes.patch The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8189es/include/rtw_security.h b/drivers/net/wireless/rtl8189es/include/rtw_security.h |index 5820a55..3e8e428 100644 |--- a/drivers/net/wireless/rtl8189es/include/rtw_security.h |+++ b/drivers/net/wireless/rtl8189es/include/rtw_security.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8189es/core/rtw_security.c b/drivers/net/wireless/rtl8189es/core/rtw_security.c |index 8dac771..9b3a1f9 100644 |--- a/drivers/net/wireless/rtl8189es/core/rtw_security.c |+++ b/drivers/net/wireless/rtl8189es/core/rtw_security.c -------------------------- No file to patch. Skipping patch. 5 out of 5 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8189fs/include/rtw_security.h b/drivers/net/wireless/rtl8189fs/include/rtw_security.h |index 5820a55..3e8e428 100644 |--- a/drivers/net/wireless/rtl8189fs/include/rtw_security.h |+++ b/drivers/net/wireless/rtl8189fs/include/rtw_security.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8189fs/core/rtw_security.c b/drivers/net/wireless/rtl8189fs/core/rtw_security.c |index 8dac771..9b3a1f9 100644 |--- a/drivers/net/wireless/rtl8189fs/core/rtw_security.c |+++ b/drivers/net/wireless/rtl8189fs/core/rtw_security.c -------------------------- No file to patch. Skipping patch. 5 out of 5 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8811cu/include/rtw_security.h b/drivers/net/wireless/rtl8811cu/include/rtw_security.h |index ac8432e..5f74fb7 100755 |--- a/drivers/net/wireless/rtl8811cu/include/rtw_security.h |+++ b/drivers/net/wireless/rtl8811cu/include/rtw_security.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8811cu/core/rtw_security.c b/drivers/net/wireless/rtl8811cu/core/rtw_security.c |index b537a26..f8c42f4 100755 |--- a/drivers/net/wireless/rtl8811cu/core/rtw_security.c |+++ b/drivers/net/wireless/rtl8811cu/core/rtw_security.c -------------------------- No file to patch. Skipping patch. 5 out of 5 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8188eu/include/rtw_security.h b/drivers/net/wireless/rtl8188eu/include/rtw_security.h |index 0adc700..2a9cf9d 100644 |--- a/drivers/net/wireless/rtl8188eu/include/rtw_security.h |+++ b/drivers/net/wireless/rtl8188eu/include/rtw_security.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8188eu/core/rtw_security.c b/drivers/net/wireless/rtl8188eu/core/rtw_security.c |index 5807521..0b3eed2 100644 |--- a/drivers/net/wireless/rtl8188eu/core/rtw_security.c |+++ b/drivers/net/wireless/rtl8188eu/core/rtw_security.c -------------------------- No file to patch. Skipping patch. 5 out of 5 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl88x2bu/include/rtw_security.h b/drivers/net/wireless/rtl88x2bu/include/rtw_security.h |index ac8432e..5f74fb7 100644 |--- a/drivers/net/wireless/rtl88x2bu/include/rtw_security.h |+++ b/drivers/net/wireless/rtl88x2bu/include/rtw_security.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl88x2bu/core/rtw_security.c b/drivers/net/wireless/rtl88x2bu/core/rtw_security.c |index b537a26..f8c42f4 100644 |--- a/drivers/net/wireless/rtl88x2bu/core/rtw_security.c |+++ b/drivers/net/wireless/rtl88x2bu/core/rtw_security.c -------------------------- No file to patch. Skipping patch. 5 out of 5 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8723ds/include/rtw_security.h b/drivers/net/wireless/rtl8723ds/include/rtw_security.h |index 83c06a5..bcea21a 100644 |--- a/drivers/net/wireless/rtl8723ds/include/rtw_security.h |+++ b/drivers/net/wireless/rtl8723ds/include/rtw_security.h -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8723ds/core/rtw_security.c b/drivers/net/wireless/rtl8723ds/core/rtw_security.c |index 88033df..11aa9a4 100644 |--- a/drivers/net/wireless/rtl8723ds/core/rtw_security.c |+++ b/drivers/net/wireless/rtl8723ds/core/rtw_security.c -------------------------- No file to patch. Skipping patch. 5 out of 5 hunks ignored Processing file /home/armbian/patch/kernel/sunxi-dev/wifi-4004-fix-cfg80211-for-5.8.patch The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c |index d77cc17..32cc240 100644 |--- a/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c |+++ b/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c -------------------------- No file to patch. Skipping patch. 3 out of 3 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8189fs/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8189fs/os_dep/linux/ioctl_cfg80211.c |index e894e97..e594cdf 100644 |--- a/drivers/net/wireless/rtl8189fs/os_dep/linux/ioctl_cfg80211.c |+++ b/drivers/net/wireless/rtl8189fs/os_dep/linux/ioctl_cfg80211.c -------------------------- No file to patch. Skipping patch. 3 out of 3 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c |index c0df148..9bff924 100755 |--- a/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c No file to patch. Skipping patch. 3 out of 3 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c |index 721723e..62fd530 100644 |--- a/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c |+++ b/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c -------------------------- No file to patch. Skipping patch. 3 out of 3 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c |index 2fd4e28..b463e55 100755 |--- a/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c |+++ b/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c -------------------------- No file to patch. Skipping patch. 3 out of 3 hunks ignored The text leading up to this was: -------------------------- |diff --git a/drivers/net/wireless/rtl8723ds/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8723ds/os_dep/linux/ioctl_cfg80211.c |index 564c2c5..921a452 100644 |--- a/drivers/net/wireless/rtl8723ds/os_dep/linux/ioctl_cfg80211.c |+++ b/drivers/net/wireless/rtl8723ds/os_dep/linux/ioctl_cfg80211.c -------------------------- No file to patch. Skipping patch. 3 out of 3 hunks ignored 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 19, 2020 Share Posted August 19, 2020 2 hours ago, dolphs said: - lots of WIFI misery around, even with EXTRAWIFI=no flag When I've switched sunxi-dev to 5.8, I've provided the following patches which solves those WiFi glitches, did you have done a "git pull" to get them ? patch/kernel/sunxi-dev/wifi-4003-fix-sha256_state-clashes.patch patch/kernel/sunxi-dev/wifi-4004-fix-cfg80211-for-5.8.patch EDIT: what about leaving EXTRAWIFI=yes ? 0 Quote Link to comment Share on other sites More sharing options...
dolphs Posted August 19, 2020 Author Share Posted August 19, 2020 @martinayotte I actually did a fresh check out ( sudo rm -rf armbian && git clone --depth 1 https://github.com/armbian/build armbian ) before actually compiling with these parameters : ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no EXTRAWIFI=no WIREGUARD=no BOARD=orangepioneplus Sure I could leave out the wireguard ( obsolete now ) and extrawifi parameters ... Will spin up a new one ( thus clean checkout ) and compile with EXTRAWIFI=yes #though no need for it in my situation and will report back shortly EDIT: Indeed that shows less misery :-) Processing file /home/armbian/patch/kernel/sunxi-dev/0001-Revert-leds-axp20x-Support-charger-LED-on-AXP20x-lik.patch Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file drivers/leds/leds-axp20x.c.rej Processing file /home/armbian/patch/kernel/sunxi-dev/add-missing-H6-gpu-opp-in-5.7.y.patch 2 out of 2 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej Processing file /home/armbian/patch/kernel/sunxi-dev/board-h6-improve-thermals.patch 1 out of 2 hunks FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-cpu-opp.dtsi.rej 1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi.rej Processing file /home/armbian/patch/kernel/sunxi-dev/board-h6-orangepi-lite2-fix-missing-all.patch 1 out of 1 hunk FAILED -- saving rejects to file arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dts.rej Processing file /home/armbian/patch/kernel/sunxi-dev/olimex_0020-arm-sun7i-a20-Add-support-for-A20-OLinuXino-LIME-eMM.patch Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file arch/arm/boot/dts/Makefile.rej Processing file /home/armbian/patch/kernel/sunxi-dev/olimex_0023-drm-sun4i-hdmi-Add-support-for-sun4i-HDMI-encoder-au.patch Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/sun4i/Kconfig.rej Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file drivers/gpu/drm/sun4i/Makefile.rej Reversed (or previously applied) patch detected! Skipping patch. 4 out of 4 hunks ignored -- saving rejects to file drivers/gpu/drm/sun4i/sun4i_hdmi.h.rej 2 out of 4 hunks FAILED -- saving rejects to file drivers/gpu/drm/sun4i/sun4i_hdmi_enc.c.rej Earlier wrote about the improve thermals.patch already ( @5kft provided fix for 5.8 ) so that could be committed imho . Anyway a "fork" if " extrawifi=no " is being used would be nice. Building own kernel is guess only option for a "KERNEL_MINIMAL=yes " ( and a "KERNEL_HEADLESS ) meaning no WiFi, no BLutooth, no amateur radio, no multimedia, etc etc: meant for headless server purposes thanks! 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted August 19, 2020 Share Posted August 19, 2020 3 hours ago, dolphs said: Indeed that shows less misery :-) Even less misery since all the one seen as "Reversed patch detected! Skipping patch." means the patch already present in Megous branch, so I will do the clean up by removing them. So, I will check how to fix the only remining ones ... 0 Quote Link to comment Share on other sites More sharing options...
5kft Posted August 27, 2020 Share Posted August 27, 2020 So 5.7 has gone EOL...should we consider switching -current to 5.8 and -dev to 5.9-rc? How much work is left to be done for 5.8? I've been running 5.8 for a few weeks now on all of my boards and it works great. However I don't have an H6, and I think there are still some patch issues with the H6...? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 27, 2020 Share Posted August 27, 2020 Since 5.9 is ahead I'd suggest to focus on that since this will become next LTS kernel. 2 Quote Link to comment Share on other sites More sharing options...
