jgauthier Posted July 22, 2020 Posted July 22, 2020 Is anyone else running their build environment in a VM? Specifically hosted by QEMU? I'm running into some strange things, and wondering if anyone has seen it. I'm running an Ubuntu (20.04) in a VM using QEMU as the hypervisor. Basically, the build generally works fine. However, as I add more features/processes to the customization script, I am starting to see segmentation faults. I see this with sudo and when I try to git pull something. This is what I get: qemu: uncaught target signal 11 (Segmentation fault) - core dumped Segmentation fault (core dumped) I got here by dumping into a bash script from 'customize-image.sh', so it's an arm-based chroot environment. I can work around some things, by doing them on the board. and them moving over the directories (or whatever), but I can't always do that. Interested if anyone else is doing this with this system platform. QEMU emulator version 4.2.0 (qemu-4.2.0-7.fc32) Copyright (c) 2003-2019 Fabrice Bellard and the QEMU Project developers
Werner Posted July 22, 2020 Posted July 22, 2020 Not sure if I get that right. You are using QEMU to kind of nativly build armbian on arm?
jgauthier Posted July 22, 2020 Author Posted July 22, 2020 On 7/22/2020 at 12:23 PM, Werner said: Not sure if I get that right. You are using QEMU to kind of nativly build armbian on arm? Expand I'm using QEMU as my host VM platform and run several VMs in it for my own use. One of those is an Ubuntu VM intended for building armbian. I'm going to edit my post for clarification on that.
jgauthier Posted July 23, 2020 Author Posted July 23, 2020 I built a quick Focal system on VirtualBox and ran into the same issue. So, I realized it's not the qemu host that I was using previously, but the qemu instance running on the build environment. /usr/bin/qemu-arm-static /bin/bash /tmp/customize-image.sh buster sunxi bananapim2zero no I'm not sure this is an easily solvable problem.
lanefu Posted July 23, 2020 Posted July 23, 2020 By chance can you share the customization script that is failing?
lanefu Posted July 24, 2020 Posted July 24, 2020 I spun up a focal VM on my qemu-kvm host.. ran into same issue....but I believe it's because you may be missing the binfmt kernel module that qemu requires for executing arm binaries during the customization process. root@armbian-test-builder-qemu:/lib/modules# modprobe binfmt_misc modprobe: FATAL: Module binfmt_misc not found in directory /lib/modules/5.4.0-1009-kvm I switched kernels to linux-image-virtual-hwe-20.04 and then I was able to build successfulyl lane@armbian-test-builder-qemu:~/GIT/build$ uname -a Linux armbian-test-builder-qemu 5.4.0-42-generic #46-Ubuntu SMP Fri Jul 10 00:24:02 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux lane@armbian-test-builder-qemu:~/GIT/build$ sudo lsmod|fgrep binfmt binfmt_misc 24576 1 Reveal hidden contents chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error [ .... ] Installing [ linux-u-boot-current-orangepizero_20.08.0-trunk_armhf.deb ] [ .... ] Installing [ linux-image-current-sunxi_20.08.0-trunk_armhf.deb ] [ .... ] Installing [ linux-dtb-current-sunxi_20.08.0-trunk_armhf.deb ] [ .... ] Installing [ armbian-firmware_20.08.0-trunk_all.deb ] chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error [ o.k. ] Enabling serial console [ ttyS0 ] [ o.k. ] Enabling serial console [ ttyGS0 ] cp: cannot stat '/home/lane/GIT/build/.tmp/rootfs-current-orangepizero-bionic-no-yes/etc/armbian-release': No such file or directory [ o.k. ] Building kernel splash logo [ bionic ] chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error chroot: failed to run command ‘/bin/bash’: Exec format error [ .... ] Installing additional packages [ EXTERNAL_NEW ] chroot: failed to run command ‘/bin/bash’: Exec format error [ o.k. ] Calling image customization script [ customize-image.sh ] chroot: failed to run command ‘/bin/bash’: Exec format error [ error ] ERROR in function customize_image [ image-helpers.sh:117 ] [ error ] customize-image.sh exited with error (rc: 126) [ o.k. ] Process terminated [ o.k. ] Unmounting [ /home/lane/GIT/build/.tmp/rootfs-current-orangepizero-bionic-no-yes/ ] [ error ] ERROR in function unmount_on_exit [ image-helpers.sh:66 ] [ error ] debootstrap-ng was interrupted
lanefu Posted July 24, 2020 Posted July 24, 2020 See It's noted right there in the documentation: https://docs.armbian.com/Developer-Guide_Build-Preparation/#what-do-i-need ...Just kidding I just updated the document.
jgauthier Posted July 24, 2020 Author Posted July 24, 2020 It's not all executables, just specific ones. It's reproducible by putting a "bash" in your customization script and then running at least: sudo git There may be others. It can also be tested by mounting an existing disk image (say /mnt) then chroot'ing to /mnt. The OS automatically runs /usr/bin/qemu-arm-static /bin/bash -i when the chroot is executed. Then it's like being in the build environment. # sudo ls qemu: uncaught target signal 11 (Segmentation fault) - core dumped Segmentation fault (core dumped) So it's not the build environment at all, but an issue with qemu. I'm just surprised no one has seen this much. But maybe people aren't trying to highly customize and mass produce armbian images.
lanefu Posted July 24, 2020 Posted July 24, 2020 right /usr/bin/qemu-arm-static /bin/bash -i requires the `binfmt_misc` kernel module... can you confirm your build vm has that module. I literally replicated your issue by not having that module, and then switched to a kernel with that module, and built successful. Please at least consider investigating the binfmt_misc module 1
jgauthier Posted July 24, 2020 Author Posted July 24, 2020 Sorry about that. I actually loaded the module before I posted. Since it didn't resolve anything I assumed that it didn't make a difference so I didn't mention it. Linux armbianbuild 5.4.0-42-generic #46-Ubuntu SMP Fri Jul 10 00:24:02 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux lsmod|fgrep binfmt binfmt_misc 24576 1 Then I mounted the raw image on /mnt # chroot /mnt # sudo ls qemu: uncaught target signal 11 (Segmentation fault) - core dumped Segmentation fault (core dumped)
Przemysław Sztoch Posted March 2, 2021 Posted March 2, 2021 I have similar problem if I want to build debian bullseye armbian image under virtualized ubuntu (host). Problem is in ldconfig arm64 binary launched by "Installing base system [ Stage 2/2 ]" (/debootstrap/debootstrap) There is not problem if I want to build image for debian buster.
Igor Posted March 2, 2021 Posted March 2, 2021 On 3/2/2021 at 5:54 PM, Przemysław Sztoch said: There is not problem if I want to build image for debian buster. Expand For Debian Bullseye / SID and Ubuntu Hirsute target you need to run build system on Ubuntu 21.04. There is a bug in Qemu which is out of possible for us to do anything about. Upgrading that on Focal is probably nightmare. Also we never tried to support targets that are full of bugs / still in development. Workaround: build on Ubuntu 21.04 or build natively on ARM64. But this part is again very experimental - just a few images can be build natively. 1
Technicavolous Posted March 3, 2021 Posted March 3, 2021 on this page https://docs.armbian.com/Developer-Guide_Build-Preparation/ links an 'mini.iso' for the official supported build system. Do you have such for 21.04?
Werner Posted March 3, 2021 Posted March 3, 2021 We do not provide those isos. And it seems there are no mini isos for Hirsute available already. https://www.google.com/search?q=ubuntu+hirsute+server+iso
Przemysław Sztoch Posted March 3, 2021 Posted March 3, 2021 After upgrade to hirsute armbian builder works ok.
