RockPro64 kernel v5.4 doesn't boot on eMMC (while kernel v4.4 does)
Baptiste
I have had some issues trying to boot from eMMC with the last version of Armbian (kernel v5.4) while it's working perfectly on Armbian with a v4.4 kernel.
Images not working:
https://dl.armbian.com/rockpro64/archive/Armbian_20.05.2_Rockpro64_bionic_current_5.4.43.img.xz
https://dl.armbian.com/rockpro64/archive/Armbian_20.05.4_Rockpro64_focal_current_5.4.46.img.xz
Working image:
https://dl.armbian.com/_old/rockpro64/archive/Armbian_5.98_Rockpro64_Debian_buster_default_4.4.192.7z
I though I messed up with the SPI or the eMMC card but after trying all I could, it finally worked using an old version of Armbian.
The new images are working on a SD-Card but it's much slower to boot.
On a eMMC card it get completely stuck (see attached file),  I managed to get the "Done" displayed waiting much longer (just after the "Running /scripts/local-premount" step but nothing more).
The CPU is becoming super hot while it stuck.
I have the same issue on two different RockPro64 cards and with two different eMMC cards.
I have tried the "Disable SPI while booting" step but it didn't help:
https://wiki.pine64.org/index.php/ROCKPro64#Disable_SPI_.28while_booting.29
It would be great if I could have a kernel 5.4 running on eMMC on those cards, please let me know if I can help.
Kind regards,
Baptiste
Link to comment
Share on other sites
I have tried that but the card never appeared on the network, but I just gave another try (being much more patient) and it worked, thank you for the advice!
BUT even after an update it's taking ages (around 4 minutes) to boot and the CPU get super warm (52 degres Celcius instead of 44 degres for another running server):
root@rockpro64:~# dmesg -c
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.49-rockchip64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.05.7 SMP PREEMPT Sun Jun 28 18:17:52 UTC 2020
[    0.000000] Machine model: Pine64 RockPro64
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000ed000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77e4800-0xf77e5fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]   DMA32 zone: 15864 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 1015296 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s92184 r8192 d30696 u131072
[    0.000000] pcpu-alloc: s92184 r8192 d30696 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=b560cac8-f9d6-4f1b-be96-4b0cffe4afcd rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=0ca53e42-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 3812448K/4061184K available (13052K kernel code, 1880K rwdata, 5164K rodata, 1216K init, 557K bss, 117664K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6d00000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000f6ca0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6cb0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x358/0x4e4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001536] Console: colour dummy device 80x25
[    0.001552] printk: console [tty1] enabled
[    0.001663] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001677] pid_max: default: 32768 minimum: 301
[    0.001822] LSM: Security Framework initializing
[    0.001865] Yama: becoming mindful.
[    0.002032] AppArmor: AppArmor initialized
[    0.002116] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002146] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002209] *** VALIDATE tmpfs ***
[    0.002916] *** VALIDATE proc ***
[    0.003249] *** VALIDATE cgroup1 ***
[    0.003259] *** VALIDATE cgroup2 ***
[    0.027769] ASID allocator initialised with 32768 entries
[    0.035762] rcu: Hierarchical SRCU implementation.
[    0.045989] Platform MSI: interrupt-controller@fee20000 domain created
[    0.046452] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.048555] EFI services will not be available.
[    0.056384] smp: Bringing up secondary CPUs ...
[    0.088659] Detected VIPT I-cache on CPU1
[    0.088697] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.088715] GICv3: CPU1: using allocated LPI pending table @0x00000000f6cc0000
[    0.088764] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.120744] Detected VIPT I-cache on CPU2
[    0.120774] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.120788] GICv3: CPU2: using allocated LPI pending table @0x00000000f6cd0000
[    0.120822] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.152863] Detected VIPT I-cache on CPU3
[    0.152891] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.152906] GICv3: CPU3: using allocated LPI pending table @0x00000000f6ce0000
[    0.152938] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.187745] CPU features: detected: EL2 vector hardening
[    0.188151] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.188564] Detected PIPT I-cache on CPU4
[    0.189809] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.190268] GICv3: CPU4: using allocated LPI pending table @0x00000000f6cf0000
[    0.191515] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.231527] Detected PIPT I-cache on CPU5
[    0.232722] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.233172] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d80000
[    0.234292] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.240227] smp: Brought up 1 node, 6 CPUs
[    0.240269] SMP: Total of 6 processors activated.
[    0.240293] CPU features: detected: 32-bit EL0 Support
[    0.240313] CPU features: detected: CRC32 instructions
[    0.251946] CPU: All CPU(s) started at EL2
[    0.252534] alternatives: patching kernel code
[    0.257550] devtmpfs: initialized
[    0.279541] Registered cp15_barrier emulation handler
[    0.279787] Registered setend emulation handler
[    0.281044] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.281124] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.288952] xor: measuring software checksum speed
[    0.327303]    8regs     :  1189.000 MB/sec
[    0.366582]    32regs    :    52.000 MB/sec
[    0.406784]    arm64_neon:    44.000 MB/sec
[    0.407089] xor: using function: 8regs (1189.000 MB/sec)
[    0.412795] pinctrl core: initialized pinctrl subsystem
[    0.457240] DMI not present or invalid.
[    0.477357] NET: Registered protocol family 16
[    0.592840] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.593886] audit: initializing netlink subsys (disabled)
[    0.600711] audit: type=2000 audit(0.596:1): state=initialized audit_enabled=0 res=1
[    0.672088] cpuidle: using governor menu
[    0.689044] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.748710] Serial: AMBA PL011 UART driver
[    3.024679] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    3.025132] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    3.025477] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    3.025808] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    3.150757] cryptd: max_cpu_qlen set to 1000
[    3.502636] raid6: neonx8   gen()    24 MB/s
[    3.569391] raid6: neonx8   xor()    21 MB/s
[    3.637771] raid6: neonx4   gen()    18 MB/s
[    3.705667] raid6: neonx4   xor()    17 MB/s
[    3.775848] raid6: neonx2   gen()    17 MB/s
[    3.844189] raid6: neonx2   xor()    19 MB/s
[    3.916645] raid6: neonx1   gen()    13 MB/s
[    3.984147] raid6: neonx1   xor()    15 MB/s
[    4.051911] raid6: int64x8  gen()    12 MB/s
[    4.122735] raid6: int64x8  xor()     9 MB/s
[    4.189272] raid6: int64x4  gen()    11 MB/s
[    4.259758] raid6: int64x4  xor()    10 MB/s
[    4.326162] raid6: int64x2  gen()     8 MB/s
[    4.394016] raid6: int64x2  xor()     8 MB/s
[    4.467956] raid6: int64x1  gen()     6 MB/s
[    4.536543] raid6: int64x1  xor()     6 MB/s
[    4.536825] raid6: using algorithm neonx8 gen() 24 MB/s
[    4.537083] raid6: .... xor() 21 MB/s, rmw enabled
[    4.537745] raid6: using neon recovery algorithm
[    4.617912] vcc3v3_pcie: supplied by vcc12v_dcin
[    4.694059] vcc5v0_sys: supplied by vcc12v_dcin
[    4.712419] vcc5v0_usb: supplied by vcc12v_dcin
[    4.722778] vcc3v3_sys: supplied by vcc5v0_sys
[    4.742858] iommu: Default domain type: Translated
[    4.862109] vgaarb: loaded
[    4.887513] SCSI subsystem initialized
[    4.895145] libata version 3.00 loaded.
[    4.908556] usbcore: registered new interface driver usbfs
[    4.911484] usbcore: registered new interface driver hub
[    4.917487] usbcore: registered new device driver usb
[    4.947771] pps_core: LinuxPPS API ver. 1 registered
[    4.948548] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    4.949363] PTP clock support registered
[    4.963546] EDAC MC: Ver: 3.0.0
[    5.007523] NetLabel: Initializing
[    5.007848] NetLabel:  domain hash size = 128
[    5.008055] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    5.011640] NetLabel:  unlabeled traffic allowed by default
[    5.032704] clocksource: Switched to clocksource arch_sys_counter
[   10.066877] *** VALIDATE bpf ***
[   10.081216] VFS: Disk quotas dquot_6.6.0
[   10.085662] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   10.090376] *** VALIDATE ramfs ***
[   10.091206] *** VALIDATE hugetlbfs ***
[   10.130527] AppArmor: AppArmor Filesystem Enabled
[   10.484994] thermal_sys: Registered thermal governor 'fair_share'
[   10.485204] thermal_sys: Registered thermal governor 'bang_bang'
[   10.485502] thermal_sys: Registered thermal governor 'step_wise'
[   10.485752] thermal_sys: Registered thermal governor 'user_space'
[   10.486008] thermal_sys: Registered thermal governor 'power_allocator'
[   10.517689] NET: Registered protocol family 2
[   10.561894] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[   10.571603] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[   10.601484] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[   10.639531] TCP: Hash tables configured (established 32768 bind 32768)
[   10.648621] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   10.657422] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   10.674631] NET: Registered protocol family 1
[   10.676978] NET: Registered protocol family 44
[   10.677497] PCI: CLS 0 bytes, default 64
[   10.689648] Trying to unpack rootfs image as initramfs...
[   72.352807] Freeing initrd memory: 14368K
[   72.396877] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[   72.414986] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[   72.437276] kvm [1]: IPA Size Limit: 40bits
[   72.473401] kvm [1]: vgic-v2@fff20000
[   72.474656] kvm [1]: GIC system register CPU interface enabled
[   72.484984] kvm [1]: vgic interrupt IRQ10
[   72.494818] kvm [1]: Hyp mode initialized successfully
[   72.756907] Initialise system trusted keyrings
[   72.758279] Key type blacklist registered
[   72.763187] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[   73.117131] zbud: loaded
[   73.226430] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   73.269351] fuse: init (API version 7.31)
[   73.274665] *** VALIDATE fuse ***
[   73.275157] *** VALIDATE fuse ***
[   73.345347] Platform Keyring initialized
[   74.622220] Key type asymmetric registered
[   74.622520] Asymmetric key parser 'x509' registered
[   74.625074] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[   74.629538] io scheduler mq-deadline registered
[   74.629839] io scheduler kyber registered
[   74.638673] io scheduler bfq registered
[   74.805895] vcc5v0_host: supplied by vcc5v0_usb
[   75.491194] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[   75.493143] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[   75.995597] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[   76.010470] rockchip-pcie: probe of f8000000.pcie failed with error -110
[   76.343362] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[   76.344656] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[   76.423031] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[   76.423564] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[   76.600639] pwm-regulator: supplied by regulator-dummy
[   76.613014] vcc5v0_typec: supplied by vcc5v0_usb
[   76.675507] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[   76.825093] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[   76.867221] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[   76.877101] printk: console [ttyS2] enabled
[   76.937271] Serial: AMBA driver
[   77.005938] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   77.606474] loop: module loaded
[   77.849276] spi-nor spi0.0: gd25q128 (16384 Kbytes)
[   78.459436] libphy: Fixed MDIO Bus: probed
[   78.480602] tun: Universal TUN/TAP device driver, 1.6
[   78.529277] thunder_xcv, ver 1.0
[   78.531300] thunder_bgx, ver 1.0
[   78.534336] nicpf, ver 1.0
[   78.589934] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[   78.590156] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[   78.592956] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[   78.593184] igb: Copyright (c) 2007-2014 Intel Corporation.
[   78.595147] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[   78.595379] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[   78.611460] sky2: driver version 1.30
[   78.644855] VFIO - User Level meta-driver version: 0.3
[   78.741541] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[   78.913438] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   78.914273] ehci-pci: EHCI PCI platform driver
[   78.916936] ehci-platform: EHCI generic platform driver
[   78.932818] ehci-platform fe380000.usb: EHCI Host Controller
[   78.934277] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[   78.941610] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
[   78.957456] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   78.971336] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   78.974040] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   78.974471] usb usb1: Product: EHCI Host Controller
[   78.974860] usb usb1: Manufacturer: Linux 5.4.49-rockchip64 ehci_hcd
[   78.975225] usb usb1: SerialNumber: fe380000.usb
[   79.006287] hub 1-0:1.0: USB hub found
[   79.009520] hub 1-0:1.0: 1 port detected
[   79.044466] ehci-platform fe3c0000.usb: EHCI Host Controller
[   79.045489] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[   79.052865] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000
[   79.069448] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[   79.083536] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   79.084723] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.085131] usb usb2: Product: EHCI Host Controller
[   79.085512] usb usb2: Manufacturer: Linux 5.4.49-rockchip64 ehci_hcd
[   79.085861] usb usb2: SerialNumber: fe3c0000.usb
[   79.115175] hub 2-0:1.0: USB hub found
[   79.117716] hub 2-0:1.0: 1 port detected
[   79.157214] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   79.158071] ohci-pci: OHCI PCI platform driver
[   79.161262] ohci-platform: OHCI generic platform driver
[   79.173269] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   79.174276] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[   79.181099] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
[   79.254485] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[   79.254966] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.255350] usb usb3: Product: Generic Platform OHCI controller
[   79.256397] usb usb3: Manufacturer: Linux 5.4.49-rockchip64 ohci_hcd
[   79.256760] usb usb3: SerialNumber: fe3a0000.usb
[   79.283359] hub 3-0:1.0: USB hub found
[   79.285816] hub 3-0:1.0: 1 port detected
[   79.315331] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[   79.317050] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[   79.323122] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000
[   79.394504] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[   79.394985] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.395359] usb usb4: Product: Generic Platform OHCI controller
[   79.401181] usb usb4: Manufacturer: Linux 5.4.49-rockchip64 ohci_hcd
[   79.401598] usb usb4: SerialNumber: fe3e0000.usb
[   79.428791] hub 4-0:1.0: USB hub found
[   79.430634] hub 4-0:1.0: 1 port detected
[   79.498411] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   79.499448] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[   79.506742] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[   79.508544] xhci-hcd xhci-hcd.0.auto: irq 227, io mem 0xfe800000
[   79.530832] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   79.531291] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.532396] usb usb5: Product: xHCI Host Controller
[   79.532769] usb usb5: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   79.533115] usb usb5: SerialNumber: xhci-hcd.0.auto
[   79.562294] hub 5-0:1.0: USB hub found
[   79.565665] hub 5-0:1.0: 1 port detected
[   79.586784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   79.587566] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[   79.589052] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[   79.593377] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   79.601426] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   79.601854] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.602208] usb usb6: Product: xHCI Host Controller
[   79.602561] usb usb6: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   79.602897] usb usb6: SerialNumber: xhci-hcd.0.auto
[   79.629549] hub 6-0:1.0: USB hub found
[   79.631346] hub 6-0:1.0: 1 port detected
[   79.660506] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   79.661548] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[   79.669449] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[   79.672907] xhci-hcd xhci-hcd.1.auto: irq 228, io mem 0xfe900000
[   79.699579] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   79.700911] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.701306] usb usb7: Product: xHCI Host Controller
[   79.701702] usb usb7: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   79.702056] usb usb7: SerialNumber: xhci-hcd.1.auto
[   79.727579] hub 7-0:1.0: USB hub found
[   79.729964] hub 7-0:1.0: 1 port detected
[   79.750302] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   79.751083] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[   79.752604] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[   79.757244] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[   79.765355] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   79.765829] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   79.766217] usb usb8: Product: xHCI Host Controller
[   79.766569] usb usb8: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   79.766911] usb usb8: SerialNumber: xhci-hcd.1.auto
[   79.793335] hub 8-0:1.0: USB hub found
[   79.795101] hub 8-0:1.0: 1 port detected
[   79.827335] usbcore: registered new interface driver usb-storage
[   79.970699] mousedev: PS/2 mouse device common for all mice
[   80.044640] i2c /dev entries driver
[   80.167098] rk808 0-001b: chip id: 0x0
[   80.284661] rk808-regulator rk808-regulator: there is no dvs0 gpio
[   80.286026] rk808-regulator rk808-regulator: there is no dvs1 gpio
[   80.290334] DCDC_REG1: supplied by vcc5v0_sys
[   80.317415] DCDC_REG2: supplied by vcc5v0_sys
[   80.339148] DCDC_REG3: supplied by vcc5v0_sys
[   80.355473] DCDC_REG4: supplied by vcc5v0_sys
[   80.376278] LDO_REG1: supplied by vcc5v0_sys
[   80.401269] LDO_REG2: supplied by vcc5v0_sys
[   80.424903] LDO_REG3: supplied by vcc5v0_sys
[   80.446621] LDO_REG4: supplied by vcc5v0_sys
[   80.453016] vcc_sdio: Bringing 3300000uV into 3000000-3000000uV
[   80.474248] LDO_REG5: supplied by vcc5v0_sys
[   80.495110] LDO_REG6: supplied by vcc5v0_sys
[   80.518331] LDO_REG7: supplied by vcc5v0_sys
[   80.541439] LDO_REG8: supplied by vcc5v0_sys
[   80.564658] SWITCH_REG1: supplied by vcc3v3_sys
[   80.581227] SWITCH_REG2: supplied by vcc3v3_sys
[   80.666900] rk808-rtc rk808-rtc: registered as rtc0
[   80.692622] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[   80.693907] fan53555-reg: supplied by vcc5v0_sys
[   80.718376] vcc1v8_s3: supplied by vcc_1v8
[   80.748945] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[   80.750536] fan53555-reg: supplied by vcc5v0_sys
[   81.116406] sdhci: Secure Digital Host Controller Interface driver
[   81.116669] sdhci: Copyright(c) Pierre Ossman
[   81.118369] Synopsys Designware Multimedia Card Interface Driver
[   81.191333] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[   81.193366] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[   81.193886] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[   81.197061] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[   81.205338] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO
[   81.235197] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[   81.279210] sdhci-pltfm: SDHCI platform and OF driver helper
[   81.354058] mmc1: CQHCI version 5.10
[   81.409126] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[   81.425846] random: fast init done
[   81.509278] ledtrig-cpu: registered to indicate activity on CPUs
[   81.552450] hidraw: raw HID events driver (C) Jiri Kosina
[   81.562699] usbcore: registered new interface driver usbhid
[   81.565163] usbhid: USB HID core driver
[   81.614331] mmc1: Command Queue Engine enabled
[   81.615113] mmc1: new HS200 MMC card at address 0001
[   81.645992] mmcblk1: mmc1:0001 DA4064 58.2 GiB
[   81.663568] mmcblk1boot0: mmc1:0001 DA4064 partition 1 4.00 MiB
[   81.680804] mmcblk1boot1: mmc1:0001 DA4064 partition 2 4.00 MiB
[   81.691590] mmcblk1rpmb: mmc1:0001 DA4064 partition 3 16.0 MiB, chardev (242:0)
[   81.743245]  mmcblk1: p1
[   81.770789] drop_monitor: Initializing network drop monitor service
[   81.820193] NET: Registered protocol family 10
[   82.327060] Segment Routing with IPv6
[   82.333351] NET: Registered protocol family 17
[   82.336932] 8021q: 802.1Q VLAN Support v1.8
[   82.338763] Key type dns_resolver registered
[   82.367115] registered taskstats version 1
[   82.367397] Loading compiled-in X.509 certificates
[   82.553064] Loaded X.509 cert 'Build time autogenerated kernel key: 2565b613495ac291b85be09f25a86121f1587c31'
[   82.563462] zswap: loaded using pool lzo/zbud
[   82.573718] Key type ._fscrypt registered
[   82.573990] Key type .fscrypt registered
[   82.724433] Btrfs loaded, crc32c=crc32c-generic
[   82.729179] Key type big_key registered
[   83.438401] Key type encrypted registered
[   83.439434] AppArmor: AppArmor sha1 policy hashing enabled
[   85.411039] phy phy-ff770000.syscon:usb2-phy@e450.2: charger = USB_DCP_CHARGER
[   85.983219] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   86.013788] rk808-rtc rk808-rtc: setting system clock to 2020-07-27T20:18:12 UTC (1595881092)
[   86.014168] of_cfs_init
[   86.016540] of_cfs_init: OK
[   86.103623] Freeing unused kernel memory: 1216K
[   86.109189] Run /init as init process
[  112.344165] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[  112.344196] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[  112.344514] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[  112.345067] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[  112.345106] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[  112.345124] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[  112.345152] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[  112.345290] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[  112.345299] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[  112.350368] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[  112.355911] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[  112.355928] rk_gmac-dwmac fe300000.ethernet: 	DWMAC1000
[  112.355940] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[  112.355948] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[  112.355961] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[  112.355970] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[  112.355978] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[  112.356085] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[  112.356096] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[  112.356107] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  112.398026] rockchip-vop ff8f0000.vop: Adding to iommu group 1
[  112.401248] rockchip-vop ff900000.vop: Adding to iommu group 2
[  112.413215] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[  112.415469] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[  112.416237] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[  112.420462] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[  112.420491] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[  112.420497] [drm] No driver support for vblank timestamp query.
[  112.420726] [drm] Cannot find any crtc or sizes
[  112.425113] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[  112.513436] libphy: stmmac: probed
[  112.513518] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[  112.513532] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[  113.444677] [drm] Cannot find any crtc or sizes
[  125.305867] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
[  137.235230] systemd[1]: Inserted module 'autofs4'
[  138.515240] systemd[1]: systemd 245.4-4ubuntu3.2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[  138.572761] systemd[1]: Detected architecture arm64.
[  139.009293] systemd[1]: Set hostname to <rockpro64>.
[  140.399257] ttyS2 - failed to request DMA
[  150.127567] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[  162.086219] random: systemd: uninitialized urandom read (16 bytes read)
[  162.323369] systemd[1]: Created slice system-modprobe.slice.
[  162.351287] random: systemd: uninitialized urandom read (16 bytes read)
[  162.441301] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  162.459656] random: systemd: uninitialized urandom read (16 bytes read)
[  162.537567] systemd[1]: Created slice User and Session Slice.
[  162.574385] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  162.609711] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  162.685926] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  162.712805] systemd[1]: Reached target Local Encrypted Volumes.
[  162.738627] systemd[1]: Reached target Remote File Systems.
[  162.761614] systemd[1]: Reached target Slices.
[  162.782433] systemd[1]: Reached target Swap.
[  162.802361] systemd[1]: Reached target System Time Set.
[  162.853549] systemd[1]: Listening on Syslog Socket.
[  162.903146] systemd[1]: Listening on fsck to fsckd communication Socket.
[  162.938324] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  163.014407] systemd[1]: Listening on Journal Audit Socket.
[  163.066137] systemd[1]: Listening on Journal Socket (/dev/log).
[  163.122571] systemd[1]: Listening on Journal Socket.
[  163.179232] systemd[1]: Listening on udev Control Socket.
[  163.223500] systemd[1]: Listening on udev Kernel Socket.
[  163.552831] systemd[1]: Mounting Huge Pages File System...
[  163.858281] systemd[1]: Mounting POSIX Message Queue File System...
[  164.159057] systemd[1]: Mounting Kernel Debug File System...
[  164.458214] systemd[1]: Mounting Kernel Trace File System...
[  164.802972] systemd[1]: Starting Restore / save the current clock...
[  165.106273] systemd[1]: Starting Set the console keyboard layout...
[  165.454650] systemd[1]: Starting Create list of static device nodes for the current kernel...
[  165.478732] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[  165.744924] systemd[1]: Started Nameserver information manager.
[  165.802487] systemd[1]: Reached target Network (Pre).
[  165.897403] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[  165.905031] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[  166.214935] systemd[1]: Starting Load Kernel Modules...
[  166.282727] systemd[1]: Starting Remount Root and Kernel File Systems...
[  166.318450] systemd[1]: Starting udev Coldplug all Devices...
[  166.348616] udc-core: couldn't find an available UDC - added [g_serial] to list of pending drivers
[  166.361781] systemd[1]: Mounted Huge Pages File System.
[  166.367023] systemd[1]: Mounted POSIX Message Queue File System.
[  166.372602] systemd[1]: Mounted Kernel Debug File System.
[  166.376810] systemd[1]: Mounted Kernel Trace File System.
[  166.390339] systemd[1]: Finished Restore / save the current clock.
[  166.409498] systemd[1]: Finished Create list of static device nodes for the current kernel.
[  166.430378] systemd[1]: Finished Load Kernel Modules.
[  166.457410] systemd[1]: Mounting FUSE Control File System...
[  166.484466] systemd[1]: Mounting Kernel Configuration File System...
[  166.523576] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[  166.526730] systemd[1]: Starting Apply Kernel Variables...
[  166.556719] systemd[1]: Mounted FUSE Control File System.
[  166.981563] systemd[1]: Finished Remount Root and Kernel File Systems.
[  167.194042] systemd[1]: Mounted Kernel Configuration File System.
[  167.411499] systemd[1]: Finished Apply Kernel Variables.
[  167.477151] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[  167.487084] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[  167.746658] systemd[1]: Starting Load/Save Random Seed...
[  168.021186] systemd[1]: Starting Create System Users...
[  168.229144] systemd[1]: Finished Set the console keyboard layout.
[  168.258853] systemd[1]: Finished udev Coldplug all Devices.
[  168.300478] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[  168.560220] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[  169.586219] systemd[1]: Finished Create System Users.
[  169.777680] systemd[1]: Starting Create Static Device Nodes in /dev...
[  169.945914] random: crng init done
[  169.946285] random: 7 urandom warning(s) missed due to ratelimiting
[  170.167899] systemd[1]: Finished Load/Save Random Seed.
[  171.250429] systemd[1]: Finished Create Static Device Nodes in /dev.
[  171.282923] systemd[1]: Reached target Local File Systems (Pre).
[  171.554318] systemd[1]: Mounting /tmp...
[  171.849861] systemd[1]: Starting udev Kernel Device Manager...
[  172.141466] systemd[1]: Mounted /tmp.
[  172.193215] systemd[1]: Reached target Local File Systems.
[  172.479296] systemd[1]: Starting Armbian ZRAM config...
[  172.784868] systemd[1]: Starting Set console font and keymap...
[  172.838769] systemd[1]: Starting Raise network interfaces...
[  172.842174] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[  172.844130] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[  172.943904] systemd[1]: Finished Set console font and keymap.
[  172.968417] zram: Added device: zram0
[  173.003488] zram: Added device: zram1
[  173.030882] zram: Added device: zram2
[  173.184475] zram1: detected capacity change from 0 to 1073741824
[  173.479725] Adding 1048572k swap on /dev/zram1.  Priority:5 extents:1 across:1048572k SSFS
[  173.670362] systemd[1]: Started udev Kernel Device Manager.
[  174.681736] zram0: detected capacity change from 0 to 52428800
[  175.141168] systemd[1]: Finished Armbian ZRAM config.
[  175.169347] systemd[1]: Starting Armbian memory supported logging...
[  175.261297] cpufreq: cpufreq_online: CPU4: Running at unlisted freq: 12000 KHz
[  175.317365] cpufreq: cpufreq_online: CPU4: Unlisted initial frequency changed to: 408000 KHz
[  175.347892] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[  175.347920] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[  175.368977] systemd[1]: Found device /dev/ttyS2.
[  175.377566] mc: Linux media interface: v0.10
[  175.406713] videodev: Linux video capture interface: v2.00
[  175.500167] panfrost ff9a0000.gpu: clock rate = 500000000
[  175.502042] rockchip-rga ff680000.rga: HW Version: 0x03.02
[  175.504682] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[  175.504692] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[  175.504699] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[  175.504703] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[  175.505730] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[  175.509116] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[  175.532362] systemd[1]: Finished Raise network interfaces.
[  175.535794] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[  175.536408] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[  175.536530] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[  175.544948] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[  175.595765] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[  175.682436] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[  175.682481] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name!
[  175.695933] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[  175.696055] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[  175.696161] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[  175.696284] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[  175.696367] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[  177.027653] systemd[1]: Finished Armbian memory supported logging.
[  177.030513] systemd[1]: Starting Journal Service...
[  177.174962] systemd[1]: Started Journal Service.
[  177.192884] systemd-journald[649]: Received client request to flush runtime journal.
[  178.088062] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet]
[  178.090229] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[  178.090249] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[  178.090261] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[  183.204062] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[  183.204108] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
I guess I will have to stick with the 4.4 kernel for now :-/
It takes only 38 seconds on the 4.4 vs 200s for the 5.4.
Here are the 4.4 logs:
@rockpro64:~$ sudo dmesg -c
[sudo] password for :
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.192-rockchip64 (root@builder) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02) ) #1 SMP Tue Oct 8 18:39:24 CEST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000]   DMA zone: 15864 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 1015296 pages, LIFO batch:31
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ed4000 s46312 r8192 d31512 u86016
[    0.000000] pcpu-alloc: s46312 r8192 d31512 u86016 alloc=21*4096
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 999432
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 no_console_suspend=1 usbcore.autosuspend=-1 root=UUID=4040ffcc-f88d-4df4-ac04-46de49eb752e rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=4975449b-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0xf7e8c000-0xf7ecc000] (0MB)
[    0.000000] Memory: 3961520K/4061184K available (11518K kernel code, 1488K rwdata, 4160K rodata, 1216K init, 699K bss, 99664K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
                   vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
                     .init : 0xffffff8008fe0000 - 0xffffff8009110000   (  1216 KB)
                     .text : 0xffffff8008080000 - 0xffffff8008bc0000   ( 11520 KB)
                   .rodata : 0xffffff8008bc0000 - 0xffffff8008fe0000   (  4224 KB)
                     .data : 0xffffff8009110000 - 0xffffff8009284008   (  1489 KB)
                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
                             0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
                   fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
                   PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
                   memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @f2900000 (psz 64K, shr 0)
[    0.000000] GIC: using LPI property table @0x00000000f2890000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x00000000f28a0000
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_mmc_get_phase: invalid clk rate
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001382] Console: colour dummy device 80x25
[    0.001397] console [tty1] enabled
[    0.001405] bootconsole [uart0] disabled
[    0.001430] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001443] pid_max: default: 32768 minimum: 301
[    0.001561] Security Framework initialized
[    0.001572] Yama: becoming mindful.
[    0.001598] AppArmor: AppArmor disabled by boot time parameter
[    0.001651] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001663] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002446] Initializing cgroup subsys io
[    0.002465] Initializing cgroup subsys memory
[    0.002497] Initializing cgroup subsys devices
[    0.002512] Initializing cgroup subsys freezer
[    0.002525] Initializing cgroup subsys net_cls
[    0.002537] Initializing cgroup subsys perf_event
[    0.002550] Initializing cgroup subsys net_prio
[    0.002567] Initializing cgroup subsys hugetlb
[    0.002578] Initializing cgroup subsys pids
[    0.002620] ftrace: allocating 43805 entries in 172 pages
[    0.120112] sched-energy: Sched-energy-costs installed from DT
[    0.120131] CPU0: update cpu_capacity 401
[    0.120189] ASID allocator initialised with 32768 entries
[    0.121107] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.121571] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.122861] Detected VIPT I-cache on CPU1
[    0.122893] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.122924] CPU1: using LPI pending table @0x00000000f2b40000
[    0.122969] CPU1: update cpu_capacity 401
[    0.122973] CPU1: Booted secondary processor [410fd034]
[    0.123522] Detected VIPT I-cache on CPU2
[    0.123543] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.123571] CPU2: using LPI pending table @0x00000000f2b60000
[    0.123598] CPU2: update cpu_capacity 401
[    0.123602] CPU2: Booted secondary processor [410fd034]
[    0.124128] Detected VIPT I-cache on CPU3
[    0.124148] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.124176] CPU3: using LPI pending table @0x00000000f2ba0000
[    0.124202] CPU3: update cpu_capacity 401
[    0.124205] CPU3: Booted secondary processor [410fd034]
[    0.124749] Detected PIPT I-cache on CPU4
[    0.124775] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.124814] CPU4: using LPI pending table @0x00000000f2bf0000
[    0.124851] CPU4: update cpu_capacity 1024
[    0.124855] CPU4: Booted secondary processor [410fd082]
[    0.125417] Detected PIPT I-cache on CPU5
[    0.125435] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.125471] CPU5: using LPI pending table @0x00000000f2030000
[    0.125498] CPU5: update cpu_capacity 1024
[    0.125501] CPU5: Booted secondary processor [410fd082]
[    0.125590] Brought up 6 CPUs
[    0.125676] SMP: Total of 6 processors activated.
[    0.125686] CPU features: detected feature: GIC system register CPU interface
[    0.125696] CPU features: detected feature: 32-bit EL0 Support
[    0.125707] CPU: All CPU(s) started at EL2
[    0.125754] alternatives: patching kernel code
[    0.127169] devtmpfs: initialized
[    0.143938] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.143962] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.144472] xor: measuring software checksum speed
[    0.183097]    8regs     :  2855.000 MB/sec
[    0.223157]    8regs_prefetch:  2560.000 MB/sec
[    0.263218]    32regs    :  3203.000 MB/sec
[    0.303279]    32regs_prefetch:  2845.000 MB/sec
[    0.303286] xor: using function: 32regs (3203.000 MB/sec)
[    0.303311] pinctrl core: initialized pinctrl subsystem
[    0.303536] regulator-dummy: no parameters
[    0.304085] NET: Registered protocol family 16
[    0.313737] cpuidle: using governor ladder
[    0.325760] cpuidle: using governor menu
[    0.325784] Registered FIQ tty driver
[    0.326123] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff8009114000)
[    0.326152] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.327173] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.343305] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.343381] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.343457] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.343531] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.343605] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[    0.435575] raid6: int64x1  gen()   452 MB/s
[    0.503617] raid6: int64x1  xor()   356 MB/s
[    0.571768] raid6: int64x2  gen()   799 MB/s
[    0.639800] raid6: int64x2  xor()   590 MB/s
[    0.707902] raid6: int64x4  gen()  1083 MB/s
[    0.776010] raid6: int64x4  xor()   672 MB/s
[    0.844120] raid6: int64x8  gen()   857 MB/s
[    0.912207] raid6: int64x8  xor()   636 MB/s
[    0.980369] raid6: neonx1   gen()   913 MB/s
[    1.048434] raid6: neonx1   xor()   617 MB/s
[    1.116537] raid6: neonx2   gen()  1539 MB/s
[    1.184650] raid6: neonx2   xor()   994 MB/s
[    1.252757] raid6: neonx4   gen()  2068 MB/s
[    1.320835] raid6: neonx4   xor()  1216 MB/s
[    1.388951] raid6: neonx8   gen()  1698 MB/s
[    1.457055] raid6: neonx8   xor()  1263 MB/s
[    1.457061] raid6: using algorithm neonx4 gen() 2068 MB/s
[    1.457067] raid6: .... xor() 1216 MB/s, rmw enabled
[    1.457073] raid6: using intx1 recovery algorithm
[    1.458067] of_get_named_gpiod_flags: parsed 'rockchip,power-ctrl' property of node '/rockchip-suspend[0]' - status (0)
[    1.458107] of_get_named_gpiod_flags: parsed 'rockchip,power-ctrl' property of node '/rockchip-suspend[1]' - status (0)
[    1.458378] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/dc-12v[0]'
[    1.458400] dc_12v: 12000 mV
[    1.458578] reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[    1.458741] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[    1.458787] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    1.458832] vcc3v3_pcie: supplied by dc_12v
[    1.458841] dc_12v: could not add device link regulator.2 err -2
[    1.458881] vcc3v3_pcie: 3300 mV
[    1.459034] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[    1.459104] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc1v8-s0[0]'
[    1.459120] vcc1v8_s0: 1800 mV
[    1.459278] reg-fixed-voltage vcc1v8-s0: vcc1v8_s0 supplying 1800000uV
[    1.459331] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-sys[0]'
[    1.459348] reg-fixed-voltage vcc-sys: Looking up vin-supply from device tree
[    1.459385] vcc_sys: supplied by dc_12v
[    1.459394] dc_12v: could not add device link regulator.4 err -2
[    1.459420] vcc_sys: 5000 mV
[    1.459559] reg-fixed-voltage vcc-sys: vcc_sys supplying 5000000uV
[    1.459607] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.459621] vcc_phy: no parameters
[    1.459773] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[    1.459823] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
[    1.459843] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[    1.459881] vcc3v3_sys: supplied by vcc_sys
[    1.459889] vcc_sys: could not add device link regulator.6 err -2
[    1.459915] vcc3v3_sys: 3300 mV
[    1.460060] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    1.460201] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
[    1.460241] vcc5v0_host: no parameters
[    1.460402] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    1.461028] iommu: Adding device ff650000.vpu_service to group 0
[    1.461112] iommu: Adding device ff660000.rkvdec to group 1
[    1.461190] iommu: Adding device ff670000.iep to group 2
[    1.461304] iommu: Adding device ff8f0000.vop to group 3
[    1.461387] platform ff8f0000.vop: iommu /iommu@ff8f3f00 not found
[    1.461393] iommu: Removing device ff8f0000.vop from group 3
[    1.461445] iommu: Adding device ff900000.vop to group 3
[    1.461935] rk_iommu ff650800.iommu: can't get sclk
[    1.462208] rk_iommu ff660480.iommu: can't get sclk
[    1.462309] rk_iommu ff670800.iommu: can't get aclk
[    1.462318] rk_iommu ff670800.iommu: can't get hclk
[    1.462327] rk_iommu ff670800.iommu: can't get sclk
[    1.462512] rk_iommu ff903f00.iommu: can't get sclk
[    1.462879] SCSI subsystem initialized
[    1.463041] libata version 3.00 loaded.
[    1.463247] usbcore: registered new interface driver usbfs
[    1.463292] usbcore: registered new interface driver hub
[    1.463373] usbcore: registered new device driver usb
[    1.463471] media: Linux media interface: v0.10
[    1.463504] Linux video capture interface: v2.00
[    1.463592] pps_core: LinuxPPS API ver. 1 registered
[    1.463598] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.463615] PTP clock support registered
[    1.464733] Advanced Linux Sound Architecture Driver Initialized.
[    1.465565] NetLabel: Initializing
[    1.465572] NetLabel:  domain hash size = 128
[    1.465577] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.465613] NetLabel:  unlabeled traffic allowed by default
[    1.466453] clocksource: Switched to clocksource arch_sys_counter
[    1.520527] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    1.520644] NET: Registered protocol family 2
[    1.521124] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.521385] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    1.522198] TCP: Hash tables configured (established 32768 bind 32768)
[    1.522315] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    1.522529] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    1.522919] NET: Registered protocol family 1
[    1.523263] RPC: Registered named UNIX socket transport module.
[    1.523270] RPC: Registered udp transport module.
[    1.523276] RPC: Registered tcp transport module.
[    1.523281] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.523309] PCI: CLS 0 bytes, default 64
[    1.524013] Trying to unpack rootfs image as initramfs...
[    1.851894] Freeing initrd memory: 6680K
[    1.852505] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.852595] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.853802] kvm [1]: 8-bit VMID
[    1.853809] kvm [1]: Hyp mode initialized successfully
[    1.853931] kvm [1]: interrupt-controller@fff20000 IRQ10
[    1.854159] kvm [1]: timer IRQ12
[    1.857510] audit: initializing netlink subsys (disabled)
[    1.857564] audit: type=2000 audit(1.776:1): initialized
[    1.857964] Initialise system trusted keyring
[    1.858337] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.866066] VFS: Disk quotas dquot_6.6.0
[    1.866223] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.867699] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.868946] NFS: Registering the id_resolver key type
[    1.868974] Key type id_resolver registered
[    1.868981] Key type id_legacy registered
[    1.869002] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.869023] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.869678] fuse init (API version 7.23)
[    1.870404] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.876428] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.878123] Key type big_key registered
[    1.878139]
               TEE Core Framework initialization (ver 1:0.1)
[    1.878165] TEE armv7 Driver initialization
[    1.878720] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    1.878731] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    1.878920] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    1.883194] NET: Registered protocol family 38
[    1.883225] Key type asymmetric registered
[    1.883236] Asymmetric key parser 'x509' registered
[    1.883428] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.883572] io scheduler noop registered
[    1.883585] io scheduler deadline registered (default)
[    1.883625] io scheduler cfq registered
[    1.884652] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply from device tree
[    1.884756] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.0 err -2
[    1.885061] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply from device tree
[    1.885072] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[    1.885288] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up vbus-supply from device tree
[    1.885301] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[    1.885316] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[    1.887199] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply from device tree
[    1.887211] phy phy-ff770000.syscon:phy@f780.2: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[    1.888241] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree
[    1.888255] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed
[    1.888492] phy phy-ff800000.phy.3: Looking up phy-supply from device tree
[    1.888502] phy phy-ff800000.phy.3: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[    1.888607] phy phy-ff800000.phy.4: Looking up phy-supply from device tree
[    1.888617] phy phy-ff800000.phy.4: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[    1.888719] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree
[    1.888731] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed
[    1.892004] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.892017] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.893457] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.893468] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.893827] pwm-regulator vdd-log: GPIO lookup for consumer enable
[    1.893836] pwm-regulator vdd-log: using device tree for GPIO lookup
[    1.893846] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
[    1.893854] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
[    1.893862] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[    1.893870] pwm-regulator vdd-log: lookup for GPIO enable failed
[    1.893893] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.893958] pwm-regulator: supplied by vcc_sys
[    1.893967] vcc_sys: could not add device link regulator.8 err -2
[    1.894034] vdd_log: 800 <--> 1400 mV at 896 mV
[    1.894643] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    1.895309] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[    1.895785] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[    1.896439] console [ttyS2] enabled
[    1.897490] [drm] Initialized drm 1.1.0 20060810
[    1.901981] [drm] Rockchip DRM driver version: v1.0.1
[    1.902604] usbcore: registered new interface driver udl
[    1.904238] Unable to detect cache hierarchy for CPU 0
[    1.905049] brd: module loaded
[    1.910327] loop: module loaded
[    1.910728] lkdtm: No crash points registered, enable through debugfs
[    1.912171] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    1.912667] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[    1.912696] 3 ofpart partitions found on MTD device spi32766.0
[    1.912703] Creating 3 MTD partitions on "spi32766.0":
[    1.912712] 0x000000000000-0x0000003f8000 : "loader"
[    1.913571] 0x0000003f8000-0x000000400000 : "env"
[    1.914390] 0x0000007c0000-0x000000800000 : "vendor"
[    1.916862] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[    1.916945] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.916956] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    1.916966] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    1.916989] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.917177] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    1.917185] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.922199] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.922332] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.922338]  Ring mode enabled
[    1.922344]  DMA HW capability register supported
[    1.922348]  Normal descriptors
[    1.922354]  RX Checksum Offload Engine supported (type 2)
[    1.922359]  TX Checksum insertion supported
[    1.922365]  Enable RX Mitigation via HW Watchdog Timer
[    1.922493] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[    2.027178] libphy: stmmac: probed
[    2.027197] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    2.027206] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[    2.029546] Rockchip WiFi SYS interface (V1.00) ...
[    2.029659] usbcore: registered new interface driver cdc_ether
[    2.029702] usbcore: registered new interface driver rndis_host
[    2.031283] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    2.031377] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree
[    2.031390] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed
[    2.035836] rockchip-dwc3 usb1: fail to get drvdata hcd
[    2.037568] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.037587] ehci-pci: EHCI PCI platform driver
[    2.037670] ehci-platform: EHCI generic platform driver
[    2.041793] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.041998] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[    2.042127] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    2.050499] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.050641] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.050652] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.050661] usb usb1: Product: EHCI Host Controller
[    2.050669] usb usb1: Manufacturer: Linux 4.4.192-rockchip64 ehci_hcd
[    2.050677] usb usb1: SerialNumber: fe3c0000.usb
[    2.051123] hub 1-0:1.0: USB hub found
[    2.051152] hub 1-0:1.0: 1 port detected
[    2.051728] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.051753] ohci-platform: OHCI generic platform driver
[    2.052267] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    2.052422] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[    2.052510] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    2.110709] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.110723] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.110735] usb usb2: Product: Generic Platform OHCI controller
[    2.110745] usb usb2: Manufacturer: Linux 4.4.192-rockchip64 ohci_hcd
[    2.110756] usb usb2: SerialNumber: fe3e0000.usb
[    2.111416] hub 2-0:1.0: USB hub found
[    2.111456] hub 2-0:1.0: 1 port detected
[    2.113022] usbcore: registered new interface driver cdc_acm
[    2.113031] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.113090] usbcore: registered new interface driver cdc_wdm
[    2.113199] usbcore: registered new interface driver usbserial
[    2.113243] usbcore: registered new interface driver usbserial_generic
[    2.113281] usbserial: USB Serial support registered for generic
[    2.114166] usbcore: registered new interface driver iforce
[    2.114242] usbcore: registered new interface driver xpad
[    2.114647] usbcore: registered new interface driver usbtouchscreen
[    2.115030] .. rk pwm remotectl v1.1 init
[    2.115469] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    2.116772] i2c /dev entries driver
[    2.117834] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[    2.117847] fan53555-regulator 0-0040: using device tree for GPIO lookup
[    2.117887] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr827@40[0]' - status (0)
[    2.118307] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.118337] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[    2.118420] fan53555-reg: supplied by vcc_sys
[    2.118433] vcc_sys: could not add device link regulator.9 err -2
[    2.119665] vdd_cpu_b: 712 <--> 1500 mV at 825 mV
[    2.120441] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[    2.120452] fan53555-regulator 0-0041: using device tree for GPIO lookup
[    2.120490] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr828@41[0]' - status (0)
[    2.120872] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.120891] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[    2.120953] fan53555-reg: supplied by vcc_sys
[    2.120964] vcc_sys: could not add device link regulator.10 err -2
[    2.122292] vdd_gpu: 712 <--> 1500 mV at 1000 mV
[    2.123431] rk808 0-001b: Pmic Chip id: 0x0
[    2.126112] rk808 0-001b: GPIO lookup for consumer dvs
[    2.126124] rk808 0-001b: using device tree for GPIO lookup
[    2.126137] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    2.126148] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    2.126158] rk808 0-001b: using lookup tables for GPIO lookup
[    2.126169] rk808 0-001b: lookup for GPIO dvs failed
[    2.126180] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.126191] rk808 0-001b: GPIO lookup for consumer dvs
[    2.126200] rk808 0-001b: using device tree for GPIO lookup
[    2.126211] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]'
[    2.126221] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]'
[    2.126231] rk808 0-001b: using lookup tables for GPIO lookup
[    2.126241] rk808 0-001b: lookup for GPIO dvs failed
[    2.126251] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.126304] rk808 0-001b: Looking up vcc1-supply from device tree
[    2.126380] DCDC_REG1: supplied by vcc_sys
[    2.126392] vcc_sys: could not add device link regulator.11 err -2
[    2.126877] vdd_center: 750 <--> 1350 mV at 900 mV
[    2.127204] rk808 0-001b: Looking up vcc2-supply from device tree
[    2.127262] DCDC_REG2: supplied by vcc_sys
[    2.127273] vcc_sys: could not add device link regulator.12 err -2
[    2.127620] vdd_cpu_l: 750 <--> 1350 mV at 850 mV
[    2.127917] rk808 0-001b: Looking up vcc3-supply from device tree
[    2.127968] DCDC_REG3: supplied by vcc_sys
[    2.127979] vcc_sys: could not add device link regulator.13 err -2
[    2.128021] vcc_ddr: at 5000 mV
[    2.128323] rk808 0-001b: Looking up vcc4-supply from device tree
[    2.128373] DCDC_REG4: supplied by vcc_sys
[    2.128384] vcc_sys: could not add device link regulator.14 err -2
[    2.128576] vcc_1v8: 1800 mV
[    2.128906] rk808 0-001b: Looking up vcc6-supply from device tree
[    2.128957] LDO_REG1: supplied by vcc_sys
[    2.128968] vcc_sys: could not add device link regulator.15 err -2
[    2.129843] vcc1v8_dvp: 1800 mV
[    2.130180] rk808 0-001b: Looking up vcc6-supply from device tree
[    2.130231] LDO_REG2: supplied by vcc_sys
[    2.130242] vcc_sys: could not add device link regulator.16 err -2
[    2.130968] vcc3v0_touch: 3000 mV
[    2.131304] rk808 0-001b: Looking up vcc7-supply from device tree
[    2.131355] LDO_REG3: supplied by vcc_sys
[    2.131366] vcc_sys: could not add device link regulator.17 err -2
[    2.132099] vcc1v8_pmu: 1800 mV
[    2.132437] rk808 0-001b: Looking up vcc9-supply from device tree
[    2.132488] LDO_REG4: supplied by vcc_sys
[    2.132498] vcc_sys: could not add device link regulator.18 err -2
[    2.133228] vcc_sd: 1800 <--> 3300 mV at 3300 mV
[    2.133545] rk808 0-001b: Looking up vcc9-supply from device tree
[    2.133595] LDO_REG5: supplied by vcc_sys
[    2.133606] vcc_sys: could not add device link regulator.19 err -2
[    2.134359] vcca3v0_codec: 3000 mV
[    2.134711] rk808 0-001b: Looking up vcc10-supply from device tree
[    2.134763] LDO_REG6: supplied by vcc_sys
[    2.134774] vcc_sys: could not add device link regulator.20 err -2
[    2.135529] vcc_1v5: 1500 mV
[    2.135855] rk808 0-001b: Looking up vcc7-supply from device tree
[    2.135905] LDO_REG7: supplied by vcc_sys
[    2.135916] vcc_sys: could not add device link regulator.21 err -2
[    2.136644] vcca1v8_codec: 1800 mV
[    2.136999] rk808 0-001b: Looking up vcc11-supply from device tree
[    2.137050] LDO_REG8: supplied by vcc_sys
[    2.137061] vcc_sys: could not add device link regulator.22 err -2
[    2.137786] vcc_3v0: 3000 mV
[    2.138146] rk808 0-001b: Looking up vcc8-supply from device tree
[    2.138198] SWITCH_REG1: supplied by vcc3v3_sys
[    2.138210] vcc3v3_sys: could not add device link regulator.23 err -2
[    2.138252] vcc3v3_s3: at 3300 mV
[    2.138602] rk808 0-001b: Looking up vcc12-supply from device tree
[    2.138654] SWITCH_REG2: supplied by vcc3v3_sys
[    2.138665] vcc3v3_sys: could not add device link regulator.24 err -2
[    2.138706] vcc3v3_s0: at 3300 mV
[    2.142493] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    2.142982] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093d4000
[    2.143891] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80093d6000
[    2.145011] fusb302 4-0022: GPIO lookup for consumer int-n
[    2.145023] fusb302 4-0022: using device tree for GPIO lookup
[    2.145063] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[    2.145099] fusb302 4-0022: GPIO lookup for consumer vbus-5v
[    2.145109] fusb302 4-0022: using device tree for GPIO lookup
[    2.145142] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[    2.145173] fusb302 4-0022: GPIO lookup for consumer vbus-other
[    2.145183] fusb302 4-0022: using device tree for GPIO lookup
[    2.145194] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.145205] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.145215] fusb302 4-0022: using lookup tables for GPIO lookup
[    2.145225] fusb302 4-0022: lookup for GPIO vbus-other failed
[    2.145237] fusb302 4-0022: GPIO lookup for consumer discharge
[    2.145246] fusb302 4-0022: using device tree for GPIO lookup
[    2.145256] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.145267] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
[    2.145276] fusb302 4-0022: using lookup tables for GPIO lookup
[    2.145286] fusb302 4-0022: lookup for GPIO discharge failed
[    2.145545] fusb302 4-0022: Can't get property of role, set role to default DRP
[    2.153917] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    2.153959] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80093d8000
[    2.154694] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80093da000
[    2.155791] IR NEC protocol handler initialized
[    2.155805] IR RC5(x/sz) protocol handler initialized
[    2.155817] IR RC6 protocol handler initialized
[    2.155829] IR JVC protocol handler initialized
[    2.155840] IR Sony protocol handler initialized
[    2.155852] IR SANYO protocol handler initialized
[    2.155864] IR Sharp protocol handler initialized
[    2.155876] IR MCE Keyboard/mouse protocol handler initialized
[    2.155888] IR XMP protocol handler initialized
[    2.157116] usbcore: registered new interface driver uvcvideo
[    2.157123] USB Video Class driver (1.1.1)
[    2.157872] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[    2.158259] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[    2.158335] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[    2.158407] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[    2.158590] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[    2.161611] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    2.161847] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[    2.163599] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.164367] cpu cpu0: leakage=20
[    2.164407] cpu cpu0: Looking up cpu-supply from device tree
[    2.166009] cpu cpu0: Failed to get pvtm
[    2.166522] cpu cpu4: leakage=34
[    2.166561] cpu cpu4: Looking up cpu-supply from device tree
[    2.168712] cpu cpu4: Failed to get pvtm
[    2.169093] cpu cpu0: Looking up cpu-supply from device tree
[    2.169497] cpu cpu0: Looking up cpu-supply from device tree
[    2.170568] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    2.172974] cpu cpu4: Looking up cpu-supply from device tree
[    2.173633] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    2.175799] sdhci: Secure Digital Host Controller Interface driver
[    2.175805] sdhci: Copyright(c) Pierre Ossman
[    2.175813] Synopsys Designware Multimedia Card Interface Driver
[    2.176781] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.176807] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.176819] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.176869] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.176891] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.176901] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    2.176909] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[    2.176941] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    2.176948] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[    2.176960] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.176966] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.176980] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[    2.176986] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[    2.176993] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[    2.176999] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[    2.177005] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[    2.177012] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[    2.177235] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree
[    2.177244] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed
[    2.177758] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.177776] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.177785] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.177816] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.177828] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.177835] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[    2.177842] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe320000 failed
[    2.177856] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[    2.177927] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.177941] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[    2.177947] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    2.177953] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
[    2.177959] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
[    2.177965] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    2.177971] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[    2.177977] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[    2.177982] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    2.177988] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
[    2.177994] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
[    2.177999] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    2.178005] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[    2.178139] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    2.178148] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    2.190569] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.207578] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    2.207917] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.208501] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[    2.208508] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[    2.208515] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
[    2.208521] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
[    2.208526] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[    2.208533] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[    2.209618] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[    2.209626] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[    2.209651] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[    2.209659] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[    2.209671] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    2.209676] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    2.242570] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.245028] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/work-led[0]' - status (0)
[    2.246321] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/standby-led[0]' - status (0)
[    2.246825] hidraw: raw HID events driver (C) Jiri Kosina
[    2.247356] usbcore: registered new interface driver usbhid
[    2.247370] usbhid: USB HID core driver
[    2.247944] ashmem: initialized
[    2.250231] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[    2.252142] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[    2.252166] rockchip-saradc ff100000.saradc: Looking up vref-supply property in node /saradc@ff100000 failed
[    2.252220] ff100000.saradc supply vref not found, using dummy regulator
[    2.252434] rockchip-saradc ff100000.saradc: failed to get voltage
[    2.252624] rockchip-saradc: probe of ff100000.saradc failed with error -22
[    2.254098] usbcore: registered new interface driver snd-usb-audio
[    2.255728] of_get_named_gpiod_flags: can't parse 'spk-con-gpio' property of node '/i2c@ff110000/es8316@11[0]'
[    2.255746] es8316 1-0011: Can not read property spk_ctl_gpio
[    2.255815] of_get_named_gpiod_flags: parsed 'hp-det-gpio' property of node '/i2c@ff110000/es8316@11[0]' - status (0)
[    2.265326] u32 classifier
[    2.265583] Initializing XFRM netlink socket
[    2.266698] NET: Registered protocol family 10
[    2.268586] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.269147] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    2.269247] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[    2.269258] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    2.269269] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    2.269283] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    2.269296] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    2.269309] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    2.269382] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    2.269395] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    2.269413] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    2.269423] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    2.269437] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    2.269544] [BT_RFKILL]: Enter rfkill_rk_init
[    2.270277] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0)
[    2.270291] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    2.270309] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]'
[    2.270352] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[    2.270364] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    2.270405] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[    2.270416] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 91.
[    2.270530] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0)
[    2.270543] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    2.270962] [BT_RFKILL]: Request irq for bt wakeup host
[    2.271057] [BT_RFKILL]: ** disable irq
[    2.271299] [BT_RFKILL]: bt_default device registered.
[    2.271451] Key type dns_resolver registered
[    2.271485] Error: Driver 'ov4689' is already registered, aborting...
[    2.271505] Error: Driver 'ov7750' is already registered, aborting...
[    2.271524] Error: Driver 'ov13850' is already registered, aborting...
[    2.271544] Error: Driver 'sc031gs' is already registered, aborting...
[    2.273169] Registered cp15_barrier emulation handler
[    2.273575] Registered setend emulation handler
[    2.277131] registered taskstats version 1
[    2.277174] Loading compiled-in X.509 certificates
[    2.281437] Btrfs loaded, integrity-checker=on
[    2.281619] BTRFS: selftest: Running btrfs free space cache tests
[    2.281663] BTRFS: selftest: Running extent only tests
[    2.281697] BTRFS: selftest: Running bitmap only tests
[    2.281736] BTRFS: selftest: Running bitmap and extent tests
[    2.281782] BTRFS: selftest: Running space stealing from bitmap to extent
[    2.283601] BTRFS: selftest: Free space cache tests finished
[    2.283612] BTRFS: selftest: Running extent buffer operation tests
[    2.283620] BTRFS: selftest: Running btrfs_split_item tests
[    2.283691] BTRFS: selftest: Running find delalloc tests
[    2.301512] mmc1: MAN_BKOPS_EN bit is not set
[    2.312572] mmc1: new HS200 MMC card at address 0001
[    2.313761] mmcblk1: mmc1:0001 NCard  57.6 GiB
[    2.314166] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
[    2.315104] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
[    2.316172] mmcblk1rpmb: mmc1:0001 NCard  partition 3 4.00 MiB
[    2.317982]  mmcblk1: p1
[    2.688477] BTRFS: selftest: Running btrfs_get_extent tests
[    2.688879] BTRFS: selftest: Running hole first btrfs_get_extent test
[    2.688953] BTRFS: selftest: Running outstanding_extents tests
[    2.689058] BTRFS: selftest: Running qgroup tests
[    2.689071] BTRFS: selftest: Qgroup basic add
[    2.689179] BTRFS: selftest: Qgroup multiple refs test
[    2.736397] Key type encrypted registered
[    2.736933] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up phy-supply from device tree
[    2.737011] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.5 err -2
[    2.737408] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply from device tree
[    2.737415] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    2.737674] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up vbus-supply from device tree
[    2.737682] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    2.737696] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[    2.738413] phy phy-ff7c0000.phy.7: Looking up phy-supply from device tree
[    2.738420] phy phy-ff7c0000.phy.7: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[    2.738542] phy phy-ff7c0000.phy.8: Looking up phy-supply from device tree
[    2.738548] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[    2.739260] rockchip-drm display-subsystem: devfreq is not set
[    2.739472] rockchip-vop ff900000.vop: missing rockchip,grf property
[    2.739652] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c93cf0)
[    2.739682] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    2.739794] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c93cf0)
[    2.740177] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    2.740206] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.740287] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.741334] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c88628)
[    2.741678] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[    2.741874] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008c895c8)
[    2.741881] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.741884] [drm] No driver support for vblank timestamp query.
[    2.741952] rockchip-drm display-subsystem: failed to parse display resources
[    2.741966] rockchip-drm display-subsystem: No connectors reported connected with modes
[    2.741973] [drm] Cannot find any crtc or sizes - going 1024x768
[    2.745647] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    2.749616] Console: switching to colour frame buffer device 128x48
[    2.753190] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.770338] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    2.771291] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
[    2.771530] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    2.771626] xhci-hcd xhci-hcd.6.auto: irq 231, io mem 0xfe800000
[    2.772074] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.772092] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.772106] usb usb3: Product: xHCI Host Controller
[    2.772120] usb usb3: Manufacturer: Linux 4.4.192-rockchip64 xhci-hcd
[    2.772134] usb usb3: SerialNumber: xhci-hcd.6.auto
[    2.773222] hub 3-0:1.0: USB hub found
[    2.773277] hub 3-0:1.0: 1 port detected
[    2.773781] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    2.774087] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
[    2.774201] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.774380] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    2.774397] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.774411] usb usb4: Product: xHCI Host Controller
[    2.774425] usb usb4: Manufacturer: Linux 4.4.192-rockchip64 xhci-hcd
[    2.774439] usb usb4: SerialNumber: xhci-hcd.6.auto
[    2.775545] hub 4-0:1.0: USB hub found
[    2.775595] hub 4-0:1.0: 1 port detected
[    2.777874] xhci-hcd xhci-hcd.6.auto: remove, state 1
[    2.777911] usb usb4: USB disconnect, device number 1
[    2.795098] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds.
[    2.795115] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset.
[    2.795177] xhci-hcd xhci-hcd.6.auto: USB bus 4 deregistered
[    2.795674] xhci-hcd xhci-hcd.6.auto: remove, state 1
[    2.795703] usb usb3: USB disconnect, device number 1
[    2.796733] xhci-hcd xhci-hcd.6.auto: USB bus 3 deregistered
[    2.802862] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.803400] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3
[    2.803602] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    2.803684] xhci-hcd xhci-hcd.7.auto: irq 232, io mem 0xfe900000
[    2.804093] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.804111] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.804126] usb usb3: Product: xHCI Host Controller
[    2.804140] usb usb3: Manufacturer: Linux 4.4.192-rockchip64 xhci-hcd
[    2.804154] usb usb3: SerialNumber: xhci-hcd.7.auto
[    2.805084] hub 3-0:1.0: USB hub found
[    2.805137] hub 3-0:1.0: 1 port detected
[    2.805623] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.805955] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4
[    2.806085] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.806262] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    2.806279] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.806294] usb usb4: Product: xHCI Host Controller
[    2.806308] usb usb4: Manufacturer: Linux 4.4.192-rockchip64 xhci-hcd
[    2.806322] usb usb4: SerialNumber: xhci-hcd.7.auto
[    2.807450] hub 4-0:1.0: USB hub found
[    2.807500] hub 4-0:1.0: 1 port detected
[    2.812751] ehci-platform fe380000.usb: EHCI Host Controller
[    2.813194] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[    2.813408] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    2.826530] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.826655] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.826663] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.826670] usb usb5: Product: EHCI Host Controller
[    2.826676] usb usb5: Manufacturer: Linux 4.4.192-rockchip64 ehci_hcd
[    2.826682] usb usb5: SerialNumber: fe380000.usb
[    2.827098] hub 5-0:1.0: USB hub found
[    2.827121] hub 5-0:1.0: 1 port detected
[    2.827898] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.828044] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[    2.828145] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    2.886997] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    2.887033] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.887055] usb usb6: Product: Generic Platform OHCI controller
[    2.887076] usb usb6: Manufacturer: Linux 4.4.192-rockchip64 ohci_hcd
[    2.887097] usb usb6: SerialNumber: fe3a0000.usb
[    2.888365] hub 6-0:1.0: USB hub found
[    2.888441] hub 6-0:1.0: 1 port detected
[    2.891643] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.891694] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.891712] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.891752] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.891778] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.891793] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    2.891807] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[    2.891852] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    2.891865] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[    2.891888] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.891898] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.891920] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
[    2.891930] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
[    2.891943] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
[    2.891954] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
[    2.891964] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
[    2.891976] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[    2.892274] platform sdio-pwrseq: GPIO lookup for consumer reset
[    2.892284] platform sdio-pwrseq: using device tree for GPIO lookup
[    2.892318] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    2.892358] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    2.906805] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.922645] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    2.923368] rockchip-dmc dmc: Looking up center-supply from device tree
[    2.923754] rockchip-dmc dmc: Failed to get leakage
[    2.923807] rockchip-dmc dmc: Looking up center-supply from device tree
[    2.923844] vdd_center: could not add device link dmc err -17
[    2.923858] vdd_center: Failed to create debugfs directory
[    2.923871] rockchip-dmc dmc: Failed to get pvtm
[    2.924529] rockchip-dmc dmc: failed to get vop pn to msch rl
[    2.925819] rockchip-dmc dmc: could not find power_model node
[    2.928629] of_get_named_gpiod_flags: parsed 'simple-audio-card,hp-det-gpio' property of node '/headphones-sound[0]' - status (0)
[    2.928642] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/headphones-sound[0]'
[    2.946681] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    2.990566] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    3.059929] asoc-simple-card headphones-sound: ASoC: DAPM unknown pin Headphones
[    3.059971] gpio-8 (hp det): gpiod_request: status -16
[    3.062413] asoc-simple-card headphones-sound: ES8316 HiFi <-> ff890000.i2s mapping ok
[    3.062915] es8316 1-0011: ASoC: Failed to create Left Hp mixer debugfs file
[    3.062947] es8316 1-0011: ASoC: Failed to create Right Hp mixer debugfs file
[    3.062999] es8316 1-0011: ASoC: Failed to create HPCP L debugfs file
[    3.063027] es8316 1-0011: ASoC: Failed to create HPCP R debugfs file
[    3.063077] es8316 1-0011: ASoC: Failed to create HPVOL L debugfs file
[    3.063106] es8316 1-0011: ASoC: Failed to create HPVOL R debugfs file
[    3.066187] input: rk-es8316-hp-sound Headphones as /devices/platform/headphones-sound/sound/card0/input1
[    3.068951] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.068975] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.069933] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[    3.073862] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/power[0]' - status (0)
[    3.073895] gpio-5 (Power): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.074057] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[    3.074160] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply from device tree
[    3.074168] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply property in node /power-management@ff310000/power-controller failed
[    3.074215] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree
[    3.074221] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed
[    3.074251] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree
[    3.074256] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed
[    3.074297] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree
[    3.074302] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed
[    3.074324] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[    3.074330] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed
[    3.074359] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree
[    3.074365] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed
[    3.074544] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree
[    3.074550] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed
[    3.075561] rk808-rtc rk808-rtc: setting system clock to 2020-07-27 20:36:02 UTC (1595882162)
[    3.075605] of_cfs_init
[    3.075735] of_cfs_init: OK
[    3.106804] vcc3v3_pcie: disabling
[    3.106892] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply from device tree
[    3.106908] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopb-supply property in node /power-management@ff310000/power-controller failed
[    3.106999] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply from device tree
[    3.107009] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vo-supply property in node /power-management@ff310000/power-controller failed
[    3.107059] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree
[    3.107069] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed
[    3.107120] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree
[    3.107130] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed
[    3.107187] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '18:38:01', on 'Oct  8 2019'.
[    3.107758] Mali: Mali device driver loaded
[    3.108410] ALSA device list:
[    3.108416]   #0: rk-es8316-hp-sound
[    3.108421]   #1: rk-spdif-sound
[    3.109103] Freeing unused kernel memory: 1216K
[    3.383682] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[    3.383699] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[    3.384725] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    3.384738] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    3.384773] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    3.385072] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    3.385175] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    3.385187] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    3.385217] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    3.385225] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    3.385235] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    3.385256] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    3.385266] rockchip-pcie f8000000.pcie: bus-scan-delay-ms in device tree is 1000 ms
[    3.385275] rockchip-pcie f8000000.pcie: missing "memory-region" property
[    3.385296] PCI host bridge /pcie@f8000000 ranges:
[    3.385316]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[    3.385326]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[    3.430534] rockchip-pcie f8000000.pcie: invalid power supply
[    3.750574] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    3.835279] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.930642] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    3.930666] rockchip-pcie f8000000.pcie: deferred probe failed
[    3.930896] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    4.153480] systemd[1]: Inserted module 'autofs4'
[    4.161343] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.166171] cgroup: cgroup2: unknown option "nsdelegate"
[    4.176238] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    4.177181] systemd[1]: Detected architecture arm64.
[    4.184532] systemd[1]: Set hostname to <rockpro64>.
[    4.186233] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    4.334338] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    4.334360] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    4.524827] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    4.531980] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.532527] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.533159] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.533388] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    4.533698] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.533731] systemd[1]: Reached target Remote File Systems.
[    4.534038] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.534198] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.534666] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.534698] systemd[1]: Reached target Swap.
[    4.535242] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.535532] systemd[1]: Listening on Journal Audit Socket.
[    4.535861] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.536037] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.536361] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.536679] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.536963] random: systemd: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[    4.536995] systemd[1]: Reached target Paths.
[    4.537527] systemd[1]: Listening on udev Kernel Socket.
[    4.539476] systemd[1]: Created slice User and Session Slice.
[    4.542384] systemd[1]: Listening on Syslog Socket.
[    4.544562] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.545722] systemd[1]: Created slice system-getty.slice.
[    4.546434] systemd[1]: Listening on udev Control Socket.
[    4.547239] systemd[1]: Listening on Journal Socket.
[    4.550694] systemd[1]: Starting Set the console keyboard layout...
[    4.554968] systemd[1]: Mounting POSIX Message Queue File System...
[    4.559161] systemd[1]: Starting udev Coldplug all Devices...
[    4.564216] systemd[1]: Starting Restore / save the current clock...
[    4.568599] systemd[1]: Starting Journal Service...
[    4.573543] systemd[1]: Mounting Huge Pages File System...
[    4.577604] systemd[1]: Starting Nameserver information manager...
[    4.582665] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.588266] systemd[1]: Mounting Kernel Debug File System...
[    4.607818] systemd[1]: Starting Load Kernel Modules...
[    4.611026] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    4.611254] systemd[1]: Reached target System Time Synchronized.
[    4.611802] systemd[1]: Reached target Local Encrypted Volumes.
[    4.612177] systemd[1]: Reached target Slices.
[    4.612979] systemd[1]: Listening on fsck to fsckd communication Socket.
[    4.613486] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    4.617137] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.624129] systemd[1]: Mounted POSIX Message Queue File System.
[    4.628453] systemd[1]: Mounted Huge Pages File System.
[    4.636950] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    4.642390] systemd[1]: Mounted Kernel Debug File System.
[    4.647833] systemd[1]: Started Restore / save the current clock.
[    4.653544] systemd[1]: Started Load Kernel Modules.
[    4.659669] systemd[1]: Started Nameserver information manager.
[    4.668260] systemd[1]: Starting Apply Kernel Variables...
[    4.680727] systemd[1]: Mounting Kernel Configuration File System...
[    4.690037] systemd[1]: Mounting FUSE Control File System...
[    4.696963] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[    4.707109] systemd[1]: Started Remount Root and Kernel File Systems.
[    4.714707] systemd[1]: Started Apply Kernel Variables.
[    4.718671] systemd[1]: Mounted Kernel Configuration File System.
[    4.722293] systemd[1]: Mounted FUSE Control File System.
[    4.738702] systemd[1]: Starting Load/Save Random Seed...
[    4.743887] systemd[1]: Starting Create System Users...
[    4.748314] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    4.769764] systemd[1]: Started Load/Save Random Seed.
[    4.784491] systemd[1]: Started Create System Users.
[    4.792483] systemd[1]: Starting Create Static Device Nodes in /dev...
[    4.827934] systemd[1]: Started Set the console keyboard layout.
[    4.833745] systemd[1]: Started Create Static Device Nodes in /dev.
[    4.840872] systemd[1]: Starting udev Kernel Device Manager...
[    4.844193] systemd[1]: Reached target Local File Systems (Pre).
[    4.851266] systemd[1]: Mounting /tmp...
[    4.861293] systemd[1]: Mounted /tmp.
[    4.865101] systemd[1]: Reached target Local File Systems.
[    4.871621] systemd[1]: Starting Set console font and keymap...
[    4.879700] systemd[1]: Starting Armbian ZRAM config...
[    4.883666] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    4.886127] systemd[1]: Started udev Coldplug all Devices.
[    4.892237] systemd[1]: Started Set console font and keymap.
[    4.901861] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    4.915517] systemd[1]: Started Helper to synchronize boot up for ifupdown.
[    4.920631] systemd[1]: Starting Raise network interfaces...
[    4.932069] systemd[1]: Started udev Kernel Device Manager.
[    4.976757] systemd[1]: Started Journal Service.
[    5.011145] cfg80211: World regulatory domain updated:
[    5.011157] cfg80211:  DFS Master region: unset
[    5.011162] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    5.011170] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    5.011177] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    5.011183] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    5.011190] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    5.011196] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    5.011201] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    5.011206] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    5.011211] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    5.023920] systemd-journald[272]: Received request to flush runtime journal from PID 1
[    5.030242] zram: Added device: zram0
[    5.031242] zram: Added device: zram1
[    5.032130] zram: Added device: zram2
[    5.098330] zram1: detected capacity change from 0 to 1073741824
[    5.174425] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
[    5.174439] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[    5.174570] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    5.177799] rk-vcodec ff650000.vpu_service: probe device
[    5.178087] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    5.188168] rk-vcodec ff650000.vpu_service: could not find power_model node
[    5.188185] rk-vcodec ff650000.vpu_service: init success
[    5.188631] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
[    5.188644] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[    5.188684] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    5.194942] rk-vcodec ff660000.rkvdec: probe device
[    5.195361] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    5.200139] rk-vcodec ff660000.rkvdec: could not find power_model node
[    5.200151] rk-vcodec ff660000.rkvdec: init success
[    5.200496] rk-hdmi-dp-sound hdmi-sound: control 3:0:0:ELD:0 is already present
[    5.200510] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: Failed to add ELD: -16
[    5.201011] rk-hdmi-dp-sound hdmi-sound: multicodec <-> ff8a0000.i2s mapping ok
[    5.201053] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: Failed to create Playback debugfs file
[    5.203811] input: rk-hdmi-dp-sound /hdmi@ff940000 Jack as /devices/platform/hdmi-sound/sound/card2/input3
[    5.204047] input: rk-hdmi-dp-sound /dp@fec00000 Jack as /devices/platform/hdmi-sound/sound/card2/input4
[    5.391676] [BT_RFKILL]: bt shut off power
[    5.755773] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    6.141339] Adding 1048572k swap on /dev/zram1.  Priority:5 extents:1 across:1048572k SS
[    6.221152] zram0: detected capacity change from 0 to 52428800
[    8.396567] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[    9.758545] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[   10.170559] random: nonblocking pool is initialized
[   11.122648] nr_pdflush_threads exported in /proc is scheduled for removal
[   11.484582] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.559212] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.563115] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.595341] NET: Registered protocol family 17
[   15.535245] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   15.535321] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   17.762679] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[   33.695856] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
Edited by TRS-80
put long output inside spoiler
Link to comment
Share on other sites
19 minutes ago, baptiste said:
It takes only 38 seconds on the 4.4 vs 200s for the 5.4.
This is a known issue with rk3399 boards using mainline kernel and it was mitigated for all other boards using mainline u-boot some time ago.
RockPro64 is the last one that is uses u-boot v2017.09 but I am planning to switch it to mainline for the next Armbian release (v20.11).
For now you need to either be patient or stay with 4.4.y.
Link to comment
I'm having this issue, and sadly it seems like for my use case I need the newer Linux kernel (some Docker images).
Currently I'm getting the behaviour as follows.
Micro SD
Debian 4.4.y - boots
Debian 5.10.y - boots
eMMC
Debian 5.10.y - blank screen never even seen any boot logs
I do hope this gets fixed in the future as I would like to keep using my eMMC module but I know the Armbian team doesn't get paid and sadly the Pine64 team does not do any software support (sadly I've made the mistake of buying from them twice now). When the NAS box works it is good but there is just so much trial and error to get to a working and supported Linux going on it. 😞
Link to comment
This error was common on my nanopim4v2 and i did have to start it manually all the time.  Did fix it by adding
rootdelay=5 in /boot/armbianEnv.txt and with the help of serial adapter did  apply this method to u-boot.
Stop u-boot, printenv (inspecting),  setenv bootdelay 5, saveenv (printenv to see if bootdelay shanged), reset.
Side issue.  The gparted icon did not start gparted on "Armbian 22.02.1 Focal with Linux 5.15.25-rockchip64" rockpro64.   Installing poicykit-1-gnome did fix that after reboot.   Now it ask for password while starting.
Link to comment
