We have nightly images built available for the boards below.   Please help us test and report your experience via This Google Form.
Images are available via our normal Armbian download page.  Just scroll to the bottom to the "nightly build" section.
  • Bananapi
  • Bananapim2plus
  • Bananapim2zero
  • Bananapipro
  • Clearfogbase
  • Clearfogpro
  • Cubietruck
  • Espressobin
  • Helios4
  • Lepotato
  • Lime-a64
  • Nanopct4
  • Nanopiair
  • Nanopim4
  • Nanopim4v2
  • Nanopi-r1
  • Nanopi-r2s
  • Odroidc2
  • Odroidc4
  • Odroidn2
  • Odroidxu4
  • Orangepi3
  • Orangepi4
  • Orangepione
  • Orangepipc
  • Orangepipc2
  • Orangepipcplus
  • Orangepizero
  • Orangepizeroplus2-h3
  • Orangepizeroplus2-h5
  • Pine64
  • Pinebook-a64
  • Pineh64
  • Pineh64-b
  • Rock64
  • Rockpi-4a
  • Rockpi-4b
  • Rockpi-e
  • Teres-a64
  • Tinkerboard
  • Tritium-h3
  • Tritium-h5
Is there any link/page (like on the last tests) where we can see which images are already tested?
So we do not double/tripple-test the same images and not the other ones ;)
On the form the h3/h5 is cut of the Orange Pi Zero Plus2 :(
Why we need "supersecure" passwords? :( My SBCs only run locally - so nobody can access them.
For the locale I only do get TR because Iam in Istanbul/Europe - but I need the DE locale :(
I tested the h5-version, but the speadsheet doesnt show the h5 :(
12 minutes ago, Tido said:
to let the machine run the first tests themselves, then look what didn't work.  Spoiler (false positive), the script is not perfect but it helps:  https://github.com/armbian/autotests
Yeah Igor is running that on his big test rig for most.. it is a great script....   Honestly I'm hoping people can just spend a lot of time on a single image and really identify the weird stuff.
just lately I searched the forum about it.
There was a PR that fixed the bigger trouble we had.
However, I guess this automatic feature was built in in good faith, but I guess the script should ask/support the user like: You seem to live in TR, do want to set this as ur locale?
And if the user says no, give him the standard ncurser  selector.
What do u think  @igor?
// sent from mobile phone //
@Igor, @lanefu - In testing sunxi-current on the NanoPi R1, I found a problem with the maximum CPU clock frequency not being properly limited; the R1 by default was getting overclocked, which led to instability.  The problem occurred because the VDD CPU regulator fix I made previously (now in sunxi-legacy) didn't make it to sunxi-current.  I've made the fix in sunxi-current and have pushed it to build and have confirmed that this corrects the issue (see https://github.com/armbian/build/commit/fbaf7562c05c841036b45ec1c22575684759834).
Password security is set to minimum so you really don't need to be very creative. My simple password is accepted :)
Yeah, I'll change to ask about setting locale.
Nice catch.
No. This process must be trap less. In case you select all locales ... you are good for 1h + before it will finish. This can be selected later if one wish to do that.
Thanks, fixed.
I also adjusted your answer in the sheet (H5)
Beta repository with latest armbian trunk:
- support for N2+
- sunxi/sunxi64 DEV kernel 5.8.y, most of others stays at 5.7.y.
Images will also be rebuild, but update should bring the same experience.
  • Igor unpinned this topic
How can I upgrade my Rock Pi 4 from 20.05 to 20.08? I have focal-current installed. I have updated all the packages with `apt update && apt dist-upgrade`.
Now I'm trying to update the kernel from `armbian-config`, but I don't see any 20.08 kernels there:
        linux-image-current-rockchip64=20.05. 5.4.45-rockchip64
        linux-image-current-rockchip64=20.05. 5.4.43-rockchip64
        linux-image-dev-rockchip64=20.05.7    5.7.6-rockchip64
        linux-image-dev-rockchip64=20.05.3    5.6.17-rockchip64
        linux-image-legacy-rockchip64=20.05.3 4.4.213-rockchip64
        linux-image-legacy-rockchip64=20.05.2 4.4.213-rockchip64
        linux-image-legacy-rockchip64=20.05.1 4.4.213-rockchip64
1 hour ago, Vladimir Korenev said:
How can I upgrade
You can't. Upgrade packages are not yet available.
Maybe the mirror you were randomly assigned is not fully synced yet. Retry a bit later.
Or grab manually: https://us.mirrors.fossho.st/armbian/apt/pool/main/l/linux-5.7.15-rockchip64/
I wasn't updating index file until all files are present on all mirrors. Now I pushed index update which will take up to 24-48h (not sure since we are doing 1st time) to update all mirrors. If we would update all at once, people will be receiving errors - file not found - all the time ... updating index from server one, then redirector points to another mirror - where files are not yet - error. Now files are everywhere, but index is somewhere still old.
Anyway, things are in automated motion now.
There isnt a nightly build section at the bottom of the above link? Ive also looked in the nightly build section of my board (NanoPC-T4) and that is also empty?
Am I looking in the wrong place?
Nightly became stable ;)
  • Werner unfeatured this topic
I don't know if the login and creating a user can be automated... maybe.
I was thinking of, while waiting on a reboot to login to the device for example:$  ssh root@192.168.1.20   and if your password is as you say not important to you, this could be automated from Linux in the bash:
repeat()
	while true
	do
		$@ && return
	done
but there is more, this can be added to your :  nano ~/.bash_aliases   like:
repeat() { while true; do $@ && return; done }
With a quick abbreviation just like my ll:
# **** DIRECTORY LISTING in human-readable units ****
alias ll="ls -lhAF"
