Werner Posted September 3, 2020 Share Posted September 3, 2020 Common issues and peer to peer support have been merged since they mostly cover the same Bugtracker forums for A64 & H5 has been merged with H6 since they share the same board family Link to comment Share on other sites More sharing options...
Werner Posted September 5, 2020 Author Share Posted September 5, 2020 Another minor update. Contact information has been updated. You can access and edit these information by clicking on your avatar at the very top right corner, click on Profile and then hit the Edit Profile button. 1 Link to comment Share on other sites More sharing options...
Werner Posted September 7, 2020 Author Share Posted September 7, 2020 It is no longer possible to add tags, either custom or pre-defined, to topics in all Bug Tracker forums and TV boxes. Existing tags are kept. Prefixes have been adjusted and fixed in those forums to fit actual needs and reduce uncontrolled growth. 1 Link to comment Share on other sites More sharing options...
Werner Posted September 10, 2020 Author Share Posted September 10, 2020 It is no longer possible to add tags, either custom or pre-defined, to topics in General Chit Chat and Feature Requests (already existing tags are kept). Latter received the option to add a "solved" prefix for fulfilled feature requests. Btw. if you want to see more "solved" prefixes consider getting involved . Announcements forums tags have been replaced with proper prefixes (the first page at least, older topics most likely nobody reads anyways ) 1 Link to comment Share on other sites More sharing options...
Werner Posted September 19, 2020 Author Share Posted September 19, 2020 We added acronyms to the forums. Commonly used abbreviation like SoC are now marked and their meaning can be highlighted by simply moving the cursor over it. If you do have ideas for missing acronyms feel free to comment here: 3 Link to comment Share on other sites More sharing options...
Werner Posted September 25, 2020 Author Share Posted September 25, 2020 Sub-Forums for Reviews, Tutorials and Hardware hacks have been merged into a new common forum which can be found here: https://forum.armbian.com/forum/40-reviews-tutorials-hardware-hacks/ Topics still can be divided by their prefixes. Some topics have been manually reviewed and processed as needed. It is no longer possible to add tags, either custom or pre-defined, to topics in Common issues / peer to peer technical support. Topics can optionally be marked with a solved prefix if capable. Link to comment Share on other sites More sharing options...
Werner Posted October 13, 2020 Author Share Posted October 13, 2020 Github has been added to the profile. Link to comment Share on other sites More sharing options...
Werner Posted October 19, 2020 Author Share Posted October 19, 2020 Links to external pages which do not belong to armbian (github is an exception) are now marked with a small symbol at their end. Example: link to google Exclusive dark theme has been adjusted from fixed to fluid width. Also removed post count, reputation and other unneeded noise from the topic view. Link to comment Share on other sites More sharing options...
Werner Posted October 25, 2020 Author Share Posted October 25, 2020 TV boxes forums is now located in the clubs. The old forum has been replaced with a redirect. Link to comment Share on other sites More sharing options...
Werner Posted October 31, 2020 Author Share Posted October 31, 2020 Since it is Helloween the exclusive dark theme mentioned here will be available for everyone until November 1st. Simply select it via theme selector at the bottom of the website. Happy dark surfing 1 Link to comment Share on other sites More sharing options...
Werner Posted November 3, 2020 Author Share Posted November 3, 2020 Forum software has been upgraded to 4.5.4 After a few minutes of hickups everything should be good again. Link to comment Share on other sites More sharing options...
Werner Posted November 12, 2020 Author Share Posted November 12, 2020 To strengthen the symbiosis between Kobol and Armbian a new dedicated club has been created for Kobol products with Armbian support. It will be maintained directly by Kobol associates @gprovost and @aprayoga. Check it out: 3 Link to comment Share on other sites More sharing options...
Werner Posted November 21, 2020 Author Share Posted November 21, 2020 Link to comment Share on other sites More sharing options...
Werner Posted September 15, 2021 Author Share Posted September 15, 2021 H616 has been added to Bug Tracker forums for existing sunxi64 family. Take note that this SoC is still kind a semi-supported: Quote Legacy kernel based images are using improved and updated stock kernel. If you care that things works (wireless, Bluetooth, CPU frequency scaling, power off, reboot, …) but it uses proprietary boot loader and it comes without our support, use it. Mainline kernel has experimental support only Link to comment Share on other sites More sharing options...
Werner Posted October 31, 2021 Author Share Posted October 31, 2021 Market place forums have been removed due to lack of activity. Link to comment Share on other sites More sharing options...
Werner Posted November 1, 2021 Author Share Posted November 1, 2021 A few forums have been shifted around. They represent a first glance at upcoming further changes. Armbian build framework forum is now marked deprecated and read only. Discussions regarding should take place at Github. Link to comment Share on other sites More sharing options...
Werner Posted May 3, 2022 Author Share Posted May 3, 2022 As you may have probably noticed we have shifted a few forums around. I know it looks a bit incomplete and inconsistent for now but we are unfortunately stuck due to a bug in 3rd party software and need to wait for fixing until we can continue. Stay tuned 1 Link to comment Share on other sites More sharing options...
Werner Posted May 15, 2022 Author Share Posted May 15, 2022 We could continue moving things around The bug tracker forums you knew for a long time now have been retired and are now both collapsed to reduce space and read-only for archiving purpose. They still can be searched and you can download attachments. Since you would not be able to answer to an existing topic anymore please create a fresh one in the appropriate section and leave a link to the old in your posting. These forums have been replaced by new, per board and support status divided sections. Boards that have active support status (standard support and up) have their own sub-forums within their respective SoC family. Also each topic needs to get a proper tag in order to make it easier to find them later on via search function which will more and more rely on these tags. Having both a tag and a forum name on a support board topic seem to be a bit doubly but I will explain below why this is necessary Boards with status CSC and below have their separate section but without dedicated forums but family categorized. It is still easy to find topics to a specific board here since, as mentioned above, all topics need to have a proper tag. Also when the support status of a board changes (like an older one gets EOL) the contents of its own forum will be moved to their respective unsupported family forums but are still easily searchable via tags. Aight I hope this wasn't too confusing, still kind a early sunday here at my place😁 Anyway if you have questions feel free to state them in off-topic or drop me a messages. The Kobol club (featuring support forums for Helios4 and Helios64 boards) have been closed and their topics have been moved to the appropriate sections. PS: A new forums theme is also in the works. Stay tuned Link to comment Share on other sites More sharing options...
Werner Posted June 13, 2022 Author Share Posted June 13, 2022 To prevent abusive behavior by editing older postings this is no longer possible after a certain period of time. Exception is granted for contributors, maintainers and frequently active members of the community. 2 Link to comment Share on other sites More sharing options...
Werner Posted June 28, 2022 Author Share Posted June 28, 2022 A new theme has been set as default. It is simply called Armbian. It replaces the outdated Haze theme which has not been maintained for years now. Hopefully this one will do longer Also a Discord widget box has been added to the sidebar on the right. Link to comment Share on other sites More sharing options...
Werner Posted June 30, 2022 Author Share Posted June 30, 2022 A fixed width version of the new forums theme has been added. It can be enabled by everybody who does not enjoy having the forums stretched to browser edges. Link to comment Share on other sites More sharing options...
Werner Posted July 4, 2022 Author Share Posted July 4, 2022 Post count and location display have been removed from topic view. Irrelevant information that can be checked in user profile if somebody cares . 1 Link to comment Share on other sites More sharing options...
Werner Posted July 5, 2022 Author Share Posted July 5, 2022 Discord handle has been added to profile information. To add/edit go to your profile... ...click Edit Profile... ...and find the field in Contact Methods Link to comment Share on other sites More sharing options...
Werner Posted July 9, 2022 Author Share Posted July 9, 2022 ROCK Pi 5B has been added to upcoming hardware. @rpardini@amazingfate A few upcoming hardware forums have been "demoted" to sub-forums within News due to lack of activity 2 Link to comment Share on other sites More sharing options...
Werner Posted July 12, 2022 Author Share Posted July 12, 2022 TV boxes which were used to be in "Clubs" have been migrated into forums. Topics in other clubs have been transferred into their respective forums as well. Link to comment Share on other sites More sharing options...
Werner Posted October 26, 2022 Author Share Posted October 26, 2022 We fixed an issue that lead into unavailability of private messaging. This has been resolved. Link to comment Share on other sites More sharing options...
