OrangePi Zero2 - Allwinner H616
Werner
8 minutes ago, Igor said:
HDMI could have troubles. Did you try serial console?
ย
I don't have serial console. It works on another monitorย  tough. I just found it odd it didn't on my main one.
Link to comment
Share on other sites
ย
ย
How can i get a serial console cable? I'm very new to this small board world :)
I mean, i suppose it's a kind of usb cable that connects to some of the pins?
Link to comment
Guys, i'm running version 22.02.0-trunk.0046, from the download page. System load is always above 1. CPU temp is 53ยบ. Is this normal? I have nothing running on it. Completely idle.ย  I notice these processes take the most cpu:
ย
systemd-udevd
cec thread
hdmi proc
ย
Is this normal?
ย
EDIT: Nothing connected to the HDMI port.
Link to comment
I have quit on this board. Temps were reaching 70+ Cยบ yesterday and even 82ยบ today! Completely iddle. The NIC stopped working. I always used a standard charger or connected it to the router via a usb cable. No idea what might have caused this. To me orange pi is just a low quality clone board. I'll get a raspberry pi when it comes available.
Link to comment
This load-when-idle thing is kind a persistent issue. When the first images from xulong for OPi1+ with H6 SoC were released they had the very same issue.
Later somewhen on mainline kernel it re-appeared and was gone again somewhen.
Now it is back with the H616 which is kind a small brother of the H6 chip....
Link to comment
ย
ย
Is there any image i can download without that issue? To see if i can resuscitate it.
Link to comment
4 minutes ago, FilSan said:
ย
ย
I don't know. I'm not much into H616 stuff...
Link to comment
Good day,
ย
Thanks to all participants here, some great insightโ€™s when starting journeys with orangepizero2.
ย
I choose not to download the stable Focal 5.16.y image, which could have suited my use case.
ย
Essentially Iโ€™ve done two working builds of Armbian 22.05.0-trunk Bullseye with bleeding edge Linux 5.17.5-sunxi64, one which applied the reboot patch editing during the build. I had satisfied my basic criteria, and had already moved along to look into the issues of my builds more thoroughly. ย For myself with the images Iโ€™ve built so far, properly functioning ledโ€™s, cpu frequency, and basic use of some pins would suffice. This venture would also deepen my understanding of here eco-system.
ย
Iโ€™ve noticed as of yesterday that there is a jammy(autobuild) 5.17.5 in the download variants.
ย
My question is there a specific reason the maintainer/s are not bumping the bullseye images?
ย
Thanks
Link to comment
Not exactly sure what you after, or what version you using, (UART) serial is enabled you don't need to activate it.
ย
alistair@orangepizero2:~$ dmesg | grep ttyS
[ ย  ย 0.000000] Kernel command line: root=UUID=bd87b5aa-cec1-4440-a5bf-9887cc6626a8 rootwait rootfstype=ext4 console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=98cd8c29-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u ย  cgroup_enable=memory swapaccount=1
[ ย  ย 1.558847] printk: console [ttyS0] disabled
[ ย  ย 1.558931] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 32, base_baud = 1500000) is a 16550A
[ ย  ย 1.559090] printk: console [ttyS0] enabled
ย
Link to comment
Orange Pi has released new debian images this week : https://drive.google.com/drive/folders/1Xk7b1jOMg-rftowFLExynLg0CyuQ7kCM
I haven't tested it yet but it says 5.16.17 which should be a nice step from the previous 4.9 images if they managed to make all features to work.
ย
They also updated their ubuntu images https://drive.google.com/drive/folders/1ohxfoxWJ0sv8yEHbrXL1Bu2RkBhuCMup
but still with 4.9 kernel
Link to comment
Does the latest Orange Pi distro allow the user to change the repositories/mirrors so that updates can be pulled from other apt repositories other than the ones included in the distro? I have found that to be a challenge in versions of Ubuntu and Debian that I have downloaded from Orange Pi's site. It seems to fail when source.list is edited to replace the repositories.
Link to comment
ร—
ร—
