Werner Posted December 6, 2020 Posted December 6, 2020 Origin: https://armbian.atlassian.net/projects/AR/issues/AR-235 Description: Add an option to armbian-config to allow editing the device tree Destination: https://github.com/armbian/config Skills required: Bash
jeanrhum Posted December 7, 2020 Posted December 7, 2020 First pull request for me: https://github.com/armbian/config/pull/123 It is a basic implementation with my humble knowledge in bash. It may be improved by experts if possible. I tested on my armbian dev config and it seems to work. I hope to have follow the right way to make a PR since it is my first one. 4
jeanrhum Posted December 20, 2020 Posted December 20, 2020 Testers needed. More especially, people with samsung, nexell or even marvell are expected. The main issue for now is the way the dtb is named and located in the boot folder. I tried to infer it using the comptible property of the device tree, but I don't own all supported hardware . I already tested sucessfully on several kernels (aml 4.20, rk and aw on 5.8, 5.9). 1
Igor Posted December 20, 2020 Posted December 20, 2020 I'll merge it inside so that the people can start testing only by changing to nightly builds or if they build from sources. And one tip - when creating a DTB, redirect those warnings away from screen. Just catch if conversion returns 1 and pop out an error in config and then show content ... Thanks!
jeanrhum Posted December 21, 2020 Posted December 21, 2020 Your welcome! It's a pleasure to contribute to armbian. I also tried your proposition with the reading of the device-tree folder with this command: dtc -I fs -O dts /sys/firmware/devicetree/base -o custom.dts But on my edge-v (kernel 5.9), pine64h-b and opi1 with kernel 5.8, it generates a segmentation fault, whereas on my gt1 ultimate running armbianTV with kernel 4.20 it works.
Igor Posted December 21, 2020 Posted December 21, 2020 On 12/21/2020 at 10:05 AM, jeanrhum said: But on my edge-v (kernel 5.9), pine64h-b and opi1 with kernel 5.8, it generates a segmentation fault Expand That's odd. I would expect the other way around. Huh. No idea why this is happening. Keep digging in, try more recent dtc package or build from sources?
jeanrhum Posted December 21, 2020 Posted December 21, 2020 Compiling from https://github.com/dgibson/dtc, I'm able to generate a dts file, but using the one installed from apt I got the following output on my pine64h-b: $ dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@480000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1704000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@720000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1080000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@888000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@816000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1800000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1608000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1320000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /cpu-opp-table/opp@1488000000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name custom.dts: Warning (clocks_property): /wifi_pwrseq:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/phy@5100400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/phy@5100400:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/gpu@1800000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/gpu@1800000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mmc@4022000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mmc@4022000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 8 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi@6000000:clocks: cell 10 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 1 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 3 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@7010000:clocks: cell 5 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pinctrl@300b000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pinctrl@300b000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pinctrl@300b000:clocks: cell 3 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pwm@300a000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pwm@300a000:clocks: cell 1 is not a phandle reference custom.dts: Warning (clocks_property): /soc/bus@1000000/mixer@100000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/bus@1000000/mixer@100000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/bus@1000000/clock@0:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/bus@1000000/clock@0:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2c@5002800:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/rtc@7000000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/phy@5210000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/lcd-controller@6515000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/lcd-controller@6515000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/spdif@5093000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/spdif@5093000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5311400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5311400:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mmc@4021000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mmc@4021000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5101400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5101400:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@3001000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@3001000:clocks: cell 1 is not a phandle reference custom.dts: Warning (clocks_property): /soc/clock@3001000:clocks: cell 3 is not a phandle reference custom.dts: Warning (clocks_property): /soc/video-codec@1c0e000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/video-codec@1c0e000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/video-codec@1c0e000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /soc/thermal-sensor@5070400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2c@7081400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/watchdog@7020400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/iommu@30f0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2c@5002400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/spi@5011000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/spi@5011000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/serial@5000800:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5311000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5311000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5311000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2c@5002c00:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2c@5002c00/mfd@10/phy:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/serial@7080000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5101000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5101000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5101000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /soc/tcon-top@6510000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/tcon-top@6510000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi-phy@6010000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/hdmi-phy@6010000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2c@5002000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/crypto@1904000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/crypto@1904000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/crypto@1904000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mmc@4020000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mmc@4020000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/mailbox@3003000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/serial@5000400:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/dma-controller@3002000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/dma-controller@3002000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/ethernet@5020000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/serial@5000c00:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/spi@5010000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/spi@5010000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pinctrl@7022000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pinctrl@7022000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/pinctrl@7022000:clocks: cell 3 is not a phandle reference custom.dts: Warning (clocks_property): /soc/ir@7040000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/ir@7040000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/watchdog@30090a0:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2s@5091000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/i2s@5091000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/dwc3@5200000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/dwc3@5200000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /soc/dwc3@5200000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /soc/usb@5100000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /soc/serial@5000000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@1:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@2:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@0:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@3:clocks: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_very_hot_limit_cpu:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_warm_limit_cpu:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_hot_limit_cpu:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_hot_pre_limit_cpu:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu-thermal/cooling-maps/cpu_very_hot_pre_limit_cpu:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /soc/spdif@5093000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /soc/spi@5011000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /soc/spi@5011000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /soc/spi@5010000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /soc/spi@5010000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /soc/i2s@5091000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /soc/i2s@5091000:dmas: cell 2 is not a phandle reference custom.dts: Warning (iommus_property): /soc/bus@1000000/mixer@100000:iommus: cell 0 is not a phandle reference custom.dts: Warning (iommus_property): /soc/video-codec@1c0e000:iommus: cell 0 is not a phandle reference custom.dts: Warning (mboxes_property): /scpi:mboxes: cell 0 is not a phandle reference custom.dts: Warning (mboxes_property): /scpi:mboxes: cell 2 is not a phandle reference custom.dts: Warning (phys_property): /soc/hdmi@6000000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /soc/usb@5311400:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /soc/usb@5311000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /soc/dwc3@5200000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /soc/usb@5100000:phys: cell 0 is not a phandle reference custom.dts: Warning (pwms_property): /ac200_clk:pwms: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/phy@5100400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/phy@5100400:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /soc/gpu@1800000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/mmc@4022000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/hdmi@6000000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/hdmi@6000000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /soc/pwm@300a000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/bus@1000000/mixer@100000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/bus@1000000/clock@0:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/i2c@5002800:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/phy@5210000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/lcd-controller@6515000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/spdif@5093000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5311400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/mmc@4021000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5101400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/video-codec@1c0e000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/thermal-sensor@5070400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/i2c@7081400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/iommu@30f0000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/i2c@5002400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/spi@5011000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/serial@5000800:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5311000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5311000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /soc/i2c@5002c00:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/serial@7080000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5101000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5101000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /soc/tcon-top@6510000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/hdmi-phy@6010000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/i2c@5002000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/crypto@1904000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/mmc@4020000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/mailbox@3003000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/serial@5000400:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/dma-controller@3002000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/ethernet@5020000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/serial@5000c00:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/spi@5010000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/ir@7040000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/i2s@5091000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/dwc3@5200000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/usb@5100000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /soc/serial@5000000:resets: cell 0 is not a phandle reference custom.dts: Warning (sound_dai_property): /hdmi-sound/simple-audio-card,cpu:sound-dai: cell 0 is not a phandle reference custom.dts: Warning (sound_dai_property): /hdmi-sound/simple-audio-card,codec:sound-dai: cell 0 is not a phandle reference custom.dts: Warning (thermal_sensors_property): /thermal-zones/cpu-thermal:thermal-sensors: cell 0 is not a phandle reference custom.dts: Warning (thermal_sensors_property): /thermal-zones/gpu-thermal:thermal-sensors: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /wifi_pwrseq:reset-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /soc/mmc@4020000:cd-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /leds/heartbeat:gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /leds/status:gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /leds/link:gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /vbus:gpio: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /gmac-3v3:gpio: cell 0 is not a phandle reference custom.dts: Warning (graph_child_address): /soc/tcon-top@6510000/ports/port@0: graph node has single child node 'endpoint@0', #address-cells/#size-cells are not necessary custom.dts: Warning (graph_child_address): /soc/tcon-top@6510000/ports/port@4: graph node has single child node 'endpoint@0', #address-cells/#size-cells are not necessary [1] 6806 segmentation fault dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts
Igor Posted December 21, 2020 Posted December 21, 2020 On 12/21/2020 at 1:49 PM, jeanrhum said: but using the one installed from apt I got the following output on my pine64h-b: Expand Warnings are fine but it's worth researching why ... while segfaulting is clearly not good. Try decompiling a few other DT by hand to narrow down where segfault is happening. Perhaps we will learn something.
jeanrhum Posted December 21, 2020 Posted December 21, 2020 On 12/21/2020 at 1:57 PM, Igor said: Try decompiling a few other DT by hand Expand Sorry, I don't know how to decompile by hand. With a small script, I tested the packaged dtc with all the dtbs from the boot folders of my edge-v (allwinner, amlogic and rockchip) and got no segfaults. With this board, I have much more warnings when decompiling from fs: Reveal hidden contents $ dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts custom.dts: Warning (unit_address_vs_reg): /usb@fe900000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /usb@fe800000: node has a unit name, but no reg property custom.dts: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name custom.dts: Warning (avoid_unnecessary_addr_size): /mipi@ff960000: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property custom.dts: Warning (avoid_unnecessary_addr_size): /mipi@ff968000: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property custom.dts: Warning (clocks_property): /i2c@ff150000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff150000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /pwm@ff420020:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /phy@ff7c0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /phy@ff7c0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /pwm@ff420010:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff660480:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff660480:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1d0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1d0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /i2s@ff880000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2s@ff880000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /pwm@ff420000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /pinctrl/gpio4@ff790000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /pinctrl/gpio2@ff780000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /pinctrl/gpio0@ff720000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /pinctrl/gpio1@ff730000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /pinctrl/gpio3@ff788000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc0@8:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc0@8:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_sdioaudio@28:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_edp@25:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc1@9:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_tcpc1@9:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_emmc@23:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_gmac@22:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_gmac@22:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_gpu@35:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_iep@34:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_iep@34:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vcodec@31:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vcodec@31:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_sd@27:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_sd@27:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_rga@33:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_rga@33:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vdu@32:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vdu@32:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_usb3@24:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp1@20:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp1@20:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopb@17:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopb@17:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopl@18:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_vo@16/pd_vopl@18:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp0@19:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_isp0@19:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_hdcp@21:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_hdcp@21:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /power-management@ff310000/power-controller/pd_vio@15/pd_hdcp@21:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /gpu@ff9a0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff3e0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff3e0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /pcie@f8000000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /rktimer@ff850000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /rktimer@ff850000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff1a0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff1a0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3a0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3a0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3a0000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /saradc@ff100000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /saradc@ff100000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3e0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3e0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3e0000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff120000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff120000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe320000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/mipi-dphy-rx0:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/mipi-dphy-rx0:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/mipi-dphy-rx0:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/pcie-phy:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/usb2-phy@e460:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/usb2-phy@e450:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /syscon@ff770000/phy@f780:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /efuse@ff690000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff160000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff160000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /dp@fec00000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /rng@ff8b8000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /rng@ff8b8000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff670800:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff670800:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1e0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1e0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /rga@ff680000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /rga@ff680000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /rga@ff680000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /i2s@ff890000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2s@ff890000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /video-codec@ff650000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /video-codec@ff650000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff914000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff914000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff200000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff200000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff903f00:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff903f00:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff1b0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff1b0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /watchdog@ff848000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff130000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff130000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /tsadc@ff260000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /tsadc@ff260000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 8 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000:clocks: cell 10 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000/usb@fe900000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000/usb@fe900000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe900000/usb@fe900000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff180000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff180000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff180000/bluetooth:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe380000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe380000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe380000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 8 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 10 is not a phandle reference custom.dts: Warning (clocks_property): /ethernet@fe300000:clocks: cell 12 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff350000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff350000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1f0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1f0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff960000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff8f3f00:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff8f3f00:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /video-codec@ff660000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /sdio-pwrseq:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff924000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff924000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /bus/dma-controller@ff6e0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /bus/dma-controller@ff6d0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff3c0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff3c0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /hdmi@ff940000:clocks: cell 8 is not a phandle reference custom.dts: Warning (clocks_property): /phy@ff800000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /phy@ff800000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 8 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000:clocks: cell 10 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000/usb@fe800000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000/usb@fe800000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe800000/usb@fe800000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3c0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3c0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /usb@fe3c0000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /i2s@ff8a0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2s@ff8a0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /edp@ff970000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /edp@ff970000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /edp@ff970000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /sdhci@fe330000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /sdhci@fe330000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff140000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff140000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /vop@ff900000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /vop@ff900000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /vop@ff900000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff190000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff190000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff650800:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /iommu@ff650800:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1c0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spi@ff1c0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /mipi@ff968000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@1:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@101:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@2:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@0:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@100:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /cpus/cpu@3:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff3d0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff3d0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /vop@ff8f0000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /vop@ff8f0000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /vop@ff8f0000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff370000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /serial@ff370000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /spdif@ff870000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /spdif@ff870000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff110000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /i2c@ff110000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 0 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 2 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 4 is not a phandle reference custom.dts: Warning (clocks_property): /mmc@fe310000:clocks: cell 6 is not a phandle reference custom.dts: Warning (clocks_property): /pwm@ff420030:clocks: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/gpu/cooling-maps/map2:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/gpu/cooling-maps/map0:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/gpu/cooling-maps/map1:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map2:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map0:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map0:cooling-device: cell 3 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map3:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 0 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 3 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 6 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 9 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 12 is not a phandle reference custom.dts: Warning (cooling_device_property): /thermal-zones/cpu/cooling-maps/map1:cooling-device: cell 15 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1d0000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1d0000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /i2s@ff880000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /i2s@ff880000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1e0000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1e0000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /i2s@ff890000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /i2s@ff890000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff200000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff200000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1f0000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1f0000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /i2s@ff8a0000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /i2s@ff8a0000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1c0000:dmas: cell 0 is not a phandle reference custom.dts: Warning (dmas_property): /spi@ff1c0000:dmas: cell 2 is not a phandle reference custom.dts: Warning (dmas_property): /spdif@ff870000:dmas: cell 0 is not a phandle reference custom.dts: Warning (io_channels_property): /adc-keys:io-channels: cell 0 is not a phandle reference custom.dts: Warning (iommus_property): /video-codec@ff650000:iommus: cell 0 is not a phandle reference custom.dts: Warning (iommus_property): /video-codec@ff660000:iommus: cell 0 is not a phandle reference custom.dts: Warning (iommus_property): /vop@ff900000:iommus: cell 0 is not a phandle reference custom.dts: Warning (iommus_property): /vop@ff8f0000:iommus: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 2 is not a phandle reference custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 4 is not a phandle reference custom.dts: Warning (phys_property): /pcie@f8000000:phys: cell 6 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe3a0000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe3e0000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /dp@fec00000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /dp@fec00000:phys: cell 1 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe900000/usb@fe900000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe900000/usb@fe900000:phys: cell 1 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe380000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe800000/usb@fe800000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe800000/usb@fe800000:phys: cell 1 is not a phandle reference custom.dts: Warning (phys_property): /usb@fe3c0000:phys: cell 0 is not a phandle reference custom.dts: Warning (phys_property): /sdhci@fe330000:phys: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /phy@ff7c0000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /iommu@ff660480:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /i2s@ff880000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /gpu@ff9a0000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /mmc@fe320000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /syscon@ff770000/mipi-dphy-rx0:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /dp@fec00000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /rga@ff680000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /i2s@ff890000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /video-codec@ff650000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /iommu@ff914000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /spi@ff200000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /iommu@ff903f00:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /usb@fe900000/usb@fe900000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /ethernet@fe300000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /mipi@ff960000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /iommu@ff8f3f00:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /video-codec@ff660000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /iommu@ff924000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /hdmi@ff940000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /phy@ff800000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /usb@fe800000/usb@fe800000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /i2s@ff8a0000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /edp@ff970000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /sdhci@fe330000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /vop@ff900000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /iommu@ff650800:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /mipi@ff968000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /vop@ff8f0000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /spdif@ff870000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (power_domains_property): /mmc@fe310000:power-domains: cell 0 is not a phandle reference custom.dts: Warning (pwms_property): /vdd-log:pwms: cell 0 is not a phandle reference custom.dts: Warning (pwms_property): /pwm-fan:pwms: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /phy@ff7c0000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /phy@ff7c0000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /phy@ff7c0000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 6 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 8 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 10 is not a phandle reference custom.dts: Warning (resets_property): /pcie@f8000000:resets: cell 12 is not a phandle reference custom.dts: Warning (resets_property): /saradc@ff100000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /mmc@fe320000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /syscon@ff770000/pcie-phy:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /dp@fec00000:resets: cell 6 is not a phandle reference custom.dts: Warning (resets_property): /rga@ff680000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /rga@ff680000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /rga@ff680000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /tsadc@ff260000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /usb@fe900000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /ethernet@fe300000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /mipi@ff960000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /phy@ff800000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /phy@ff800000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /phy@ff800000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /usb@fe800000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /edp@ff970000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /vop@ff900000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /vop@ff900000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /vop@ff900000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /mipi@ff968000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /vop@ff8f0000:resets: cell 0 is not a phandle reference custom.dts: Warning (resets_property): /vop@ff8f0000:resets: cell 2 is not a phandle reference custom.dts: Warning (resets_property): /vop@ff8f0000:resets: cell 4 is not a phandle reference custom.dts: Warning (resets_property): /mmc@fe310000:resets: cell 0 is not a phandle reference custom.dts: Warning (sound_dai_property): /hdmi-sound/simple-audio-card,cpu:sound-dai: cell 0 is not a phandle reference custom.dts: Warning (sound_dai_property): /hdmi-sound/simple-audio-card,codec:sound-dai: cell 0 is not a phandle reference custom.dts: Warning (thermal_sensors_property): /thermal-zones/gpu:thermal-sensors: cell 0 is not a phandle reference custom.dts: Warning (thermal_sensors_property): /thermal-zones/cpu:thermal-sensors: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /pcie@f8000000:ep-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /mmc@fe320000:cd-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /vcc5v0-host-regulator:gpio: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /leds/led-1:gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /leds/led-0:gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /gpio-keys/power:gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /serial@ff180000/bluetooth:device-wakeup-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /serial@ff180000/bluetooth:shutdown-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /serial@ff180000/bluetooth:host-wakeup-gpios: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /ethernet@fe300000:snps,reset-gpio: cell 0 is not a phandle reference custom.dts: Warning (gpios_property): /sdio-pwrseq:reset-gpios: cell 0 is not a phandle reference custom.dts: Warning (graph_child_address): /mipi@ff960000/ports: graph node has single child node 'port@0', #address-cells/#size-cells are not necessary custom.dts: Warning (graph_child_address): /edp@ff970000/ports: graph node has single child node 'port@0', #address-cells/#size-cells are not necessary custom.dts: Warning (graph_child_address): /mipi@ff968000/ports: graph node has single child node 'port@0', #address-cells/#size-cells are not necessary [1] 4065 segmentation fault dtc -I fs /sys/firmware/devicetree/base -O dts -o custom.dts
Igor Posted December 21, 2020 Posted December 21, 2020 On 12/21/2020 at 3:18 PM, jeanrhum said: Sorry, I don't know how to decompile by hand. Expand I mean with dtc command ... like you did. Well, I would propose to finish with the tool functionality, so it can be used where it doesn't fail ... just properly report error if segfault is happened.
jeanrhum Posted December 21, 2020 Posted December 21, 2020 ok, the only problem I face was when using dtc with the fs as input.
Christos Posted January 19, 2021 Posted January 19, 2021 Hi @Igor @jeanrhum Just seen this thread, I also tried to decompile DT on a H3 OPiPC running Armbian (21.02) Got exactly that behavior first a bunch of warnings and then segfault, on Debian builds desktop or console. On Ubuntu Focal it was giving the warnings too but at the end it decompiled successfully and showing the dts. Just letting you know if you still going on with this project. Christos
jeanrhum Posted January 19, 2021 Posted January 19, 2021 Hi Christos, Thanks for reporting this issue too. What is your kernel? I suppose that you tried to decompile from fs, but have you tried to decompile from the dtb in use from /boot/dtb ?
Christos Posted January 19, 2021 Posted January 19, 2021 Hi @jeanrhum For my case I wanted to examine the running DT so I executed dtc -I fs -O dts /proc/device-tree which was segfault in Debian. The plain decompile of a specific dtb works though eg dtc -I dtb -O dts /boot/dtb/sun8i-h3-orangepi-pc.dtb My kernel in both Debian and Ubuntu is the same 'current', 5.10.8 Christos
