madade Posted December 27, 2020 Posted December 27, 2020 HI to all, excuse me but this is my first msg. I have a OPI3 board and I try different OS (Arabian, Ubuntu, Debian) all in different release but I do not have wifi and lan. for wifi I have already try with copy firmware file but is is the same for lan I have in dmesg eth0. UP and DOWN. In my experience I have found only Ubuntu Xenial 4.9.118 on the Orange.org web site with wifi OK. can you help me? Thanks 0 Quote
Werner Posted December 27, 2020 Posted December 27, 2020 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. Use USB UART adapter or USB stick to extract the data if necessary. Which image did you use? 0 Quote
NicoD Posted December 27, 2020 Posted December 27, 2020 44 minutes ago, madade said: Arabian So that does exist. I always thought it was people missspelling Armbian. https://distrowatch.com/table.php?distribution=arabian It has been a while that I used the OPi3. But to my knowledge wifi was working. You could try to go back to an older kernel. 0 Quote
Werner Posted December 27, 2020 Posted December 27, 2020 42 minutes ago, NicoD said: You could try to go back to an older kernel. Tricky without network access. However legacy should work and 5.8.y kernel is also known to work. 0 Quote
madade Posted December 29, 2020 Author Posted December 29, 2020 HI, excuse me for my bad spell "Arabian", I am sorry. I have found : for lan I see it is all ok if I use a lan switch. wifi is broken. i have try with all Arabian version, All Ubuntu version and all Debian version. I have wifi ok only with Ubuntu Xenial 4.9.118 on the raspberry web site. It use a BRCMHD module. I hope this is important to you. Thanks 0 Quote
Werner Posted December 29, 2020 Posted December 29, 2020 If it is indeed Arabian and not Armbian I think this is not the right place for you. I also did not know that Raspberrypi deals with OrangePi devices. In this case also not the right place for your If it is Armbian however then I need to mention that broken ethernet is a known issue at the moment and might be fixed in the next release on February. Support state of internal WiFi is unknown. 0 Quote
Igor Posted December 29, 2020 Posted December 29, 2020 For LAN there is a bug https://github.com/armbian/build/issues/2315 0 Quote
madade Posted November 8, 2022 Author Posted November 8, 2022 I to all, There is any news about Wifi and Orange Pi 3? I hava try with all image on Orange web site with different Armbian but it is the same. I have verified with Armbian 22.08.2 jammy 5.15.48 for lte and it is more spidy but no wifi. I have see in so tread request for enable hot spot with Orange? Please can you help me with any news? Thanks to all 0 Quote
madade Posted November 12, 2022 Author Posted November 12, 2022 Hi to all, I have a news!. I try with LibreELEC-H6.arm-10-0-3-orangepi-3 and it is oll OK! Wifi is ok for client and hot-spot. i hope this is good news thanks 0 Quote
Igor Posted January 22, 2023 Posted January 22, 2023 On 11/8/2022 at 6:32 AM, madade said: There is any news about Wifi and Orange Pi 3? Should run better following this merge. Will be pushed to stable repository once tested - you can try by switching to nightly beta repository (armbian-config -> system). 0 Quote
Paulo12333 Posted January 24, 2023 Posted January 24, 2023 Hello I installed Armbian 22.11 Jammy XFCE and try to connect to Wi-FI without success. Also changed to nightly without success. Can anyone help pls? 0 Quote
Igor Posted January 25, 2023 Posted January 25, 2023 10 hours ago, Paulo12333 said: Hello I installed Armbian 22.11 Jammy XFCE and try to connect to Wi-FI without success. Also changed to nightly without success. (without providing complete logs we anyway don't know what you are talking about and there is not possible to provide any help. This below is a guess what you are doing wrong.) After you download images, de-freeze firmware upgrade. In command shell: sudo armbian-config -> system -> De-freeze (enable Armbian kernel upgrades) exit sudo apt update sudo apt upgrade Reboot and wifi must works. It works perfectly fine for me: https://paste.armbian.com/nolizanone With such hardware - pay attention to the wifi chip / version: If you are not having LTS board containing this chip, you need a different image: Click: https://www.armbian.com/orangepi3-lts/ Read: "Images for non LTS version can be downloaded here" 0 Quote
Paulo12333 Posted January 25, 2023 Posted January 25, 2023 Hello @Igor Thank you for you reply. I will try your suggestion. My version is the OrangePi 3 LTS (see photo attached) 0 Quote
Igor Posted January 26, 2023 Posted January 26, 2023 13 hours ago, Paulo12333 said: Doesn't work This is crazy. I have several Opi3 and they all work, while people reporting "WiFi doesn't work". Please provide everything what you did, which image you are using, how do you trying to connect and provide full logs. 0 Quote
Paulo12333 Posted January 30, 2023 Posted January 30, 2023 Hi. I'm using this image. I Flash this image Armbian_22.11.1_Orangepi3-lts_jammy_current_5.15.80_xfce_desktop.img.xz and follow your steps and still can't connect to Wi-Fi. Best, P 0 Quote
madade Posted March 9, 2023 Author Posted March 9, 2023 Hi, I have try to create a memory card with Armbian 22 with xfce and Armbian 23 with XFCE and CLI but i have only busibox. Can you help me? ThANKS 0 Quote
Igor Posted March 9, 2023 Posted March 9, 2023 7 hours ago, madade said: I have try to create a memory card with Armbian 22 with xfce and Armbian 23 with XFCE and CLI but i have only busibox. You need to provide more information: - which image (link) - which hardware revision (perhaps a photo) - where booting ends - is this the only SD card you have ... 0 Quote
madade Posted March 11, 2023 Author Posted March 11, 2023 Hi Igor, thanks for your support, at this moment i have only 1 memory card but it is good i use it for more project. I have try with Armbian_22.11.1_Orangepi3_jammy_current_5.15.80_xfce_desktop.img.xz Armbian_23.02.2_Orangepi3_jammy_current_5.15.93_xfce_desktop.img.xz Armbian_23.02.2_Orangepi3_jammy_current_5.15.93_gnome_desktop.img.xz Armbian_23.02.2_Orangepi3_jammy_current_5.15.93.img.xz and also Armbian_23.02.2_Orangepi3-lts_jammy_current_5.15.93.img.xz Do you have any idea how to fix the problem? thanks 0 Quote
SteeMan Posted March 11, 2023 Posted March 11, 2023 @madade Why do you ask for help again when you haven't provided the information that Igor asked of you. He asked you for four things: On 3/9/2023 at 11:50 AM, Igor said: You need to provide more information: - which image (link) - which hardware revision (perhaps a photo) - where booting ends - is this the only SD card you have You only provided an answer to one request. Which hardware revision (picture please)? Where does booting end? (capture of the console output of the boot) Try another sd card. (Just because a card works in some circumstances, doesn't mean it will work for this purpose, sbc's are finicky when it comes to sd cards at times) 2 Quote
