I've taken peeks at threads related to hardware decoding (of H.264 and HEVC, mainly) on Allwinner and Rockchip platforms on and off, sometimes dabbled in trying and failing to implement solutions recommended there. Being a complete amateur, I find the topic very opaque and confusing, with various different components that need to interface with each other, be patched in sync, and sometimes change drastically between kernel versions, etc. Today I sat down and read up on these subjects, scouring wikis, documentation, this forum, and assorted other sources to try and understand how this works. In this post I will attempt to compile what I've learned on the different software components involved, their relationships, their current status, and solutions to the problem. I hope people more knowledgeable will correct me when I get something wrong or cite outdated information. Stuff which I am highly uncertain of I will print in italics.
(This post is going to focus on mainline implementations of Cedrus/Allwinner, I haven't looked into Hantro/Rkvdec/Rockchip specifics yet. I will speak only of H.264 and H.265/HEVC; I don't understand the high/low stuff and didn't pay attention to other codecs.)
Components:
Basics: Video codecs like H.264, H.265/HEVC, MPEG-2, etc. are standardised methods which serve to more efficiently encode and decode videos, reducing their filesize. Software en-/decoding is very CPU-intensive. Modern GPUS and ARM SoCs therefore contain specialised hardware (VPUs) to delegate these tasks to. Working hardware decoding is particularly important for underpowered ARM CPUs.
Drivers: Topmost in the stack are the VPU drivers. These are Sunxi-Cedrus/Cedrus V4L2 M2M and Cedar [Is this the legacy one?] on Allwinner; Hantro and Rkvdec on Rockchip. These are all still in development, but Cedrus already fully supports H.264, and partially supports HEVC, and is already usable in the mainline kernel.
APIs: In order for anything (userspace APIs, libraries) to make use of the VPU drivers, you need backends/APIs. For Cedrus, there is the unmaintained libva-v4l2-request backend which implements VA-API, the legacy VDPAU implementation libvdpau-sunxi, and as of kernel version 5.11, H.264 has been merged into the uAPI headers. Different applications may make recourse to one or another of these APIs.
Libraries: FFmpeg and GStreamer. provide libraries and APIs of their own to other applications but can (importantly!) also output directly to the framebuffer. FFmpeg must be patched to access either libva-v4l2-request or the Cedrus driver headers. GStreamer directly accesses kernel headers since 1.18 (works on 5.9, not on 5.10; 1.20 will support 5.11.)
Media players: mpv and depends on FFmpeg for hardware acceleration (and must be patched together with it). VLC can be set to access libva-v4l2-request directly. Kodi 19.0+ supports hardware acceleration out of the box without any out-of-tree patches.
Display server: An additional complication is drawing the output of any of the above on screen. Most successful implementations I've seen bypass X11 and either output directly to the framebuffer or force a plane/display layer on top of any X windows. Wayland apparently makes this easier by allowing applications to use their own DRM planes, but this hasn't been explored much yet. Kodi 19.0 works with all three windowing systems (X, Wayland, and gbm).
Codec status:
6 hours ago, jernej said:
H264, MPEG2 and VP8 should be good in mainline, although api can still change until codec is promoted to uAPI. HEVC still needs out-of-tree patches for any serious work.
Taken from the LibreElec thread (which reflects LibreElec's status and is ahead of what works elsewhere, but outlines hardware limitations):
only MPEG2, H264 (AVC), H265 (HEVC) and VP8 codecs are supported in hardware, for now. Others are software decoded.
- R40 doesn't support H265 (HEVC) - hardware limitation
- 10-bit H265 videos are supported only on H6 (H3, H5 and A64 don't support 10-bit - hardware limitation)
- 10-bit H264 is not supported (hardware limitation)
Approaches:
Many people have managed to make it work on their machines using different approaches. Note that some of these solutions are one or two years old, and kernel developments since may have changed the situation. Ordered from newer to older:
LibreElec – kernel + ffmpeg + Kodi: LibreElec is a Just-Enough-OS with the sole purpose of running Kodi, a media player. It's at the bleeding edge and usually implements codecs and features well before mainline or other distros. It achieves this by heavily patching everything up and down the stack, from the Linux kernel over FFmpeg to Kodi itself. These patches could all be applied to an Armbian build, but there are a lot of them, they're poorly documented, and you'd need to dig into their github to understand what they all do. LibreElec runs Kodi directly without a desktop. kodi-gbm is a package that can be installed on Armbian and functions similarly.
Key contributors to the project are @jernej and @Kwiboo, who sometimes post about their work here (and have been very helpful with questions, thank you). @balbes150 includes some of LibreElec's patches in his Armbian-TV builds, but I don't know which.
Kodi 19.0:
Further clarification: Kodi 19.0 (released recently) is highly recommended for all this - it doesn't require any out of tree patch for video decoding (LE uses patch for HW deinterlacing). Additionally, with version 19.0, there is single binary for all 3 windowing systems (gbm, X11, wayland). Depends on build options. Not sure if this version is available on Armbian but PPA exists, so I guess it should not be hard to test.
LibreElec patches + mpv:
On 8/22/2019 at 8:14 PM, jernej said:
@Alerino Reis If you're using ffmpeg patches from LibreELEC, then you need only this additional patch to make it compatible with mpv. I tested yesterday and it works for me when running without any window manager running with either of these commands:
mpv --vo=gpu --gpu-context=drm --hwdec=auto video.mkv
mpv --vo=drm --hwdec=auto video.mkv
You can append "-v" parameter to check if mpv really uses HW decoding.
@megous Kernel 5.11 + GStreamer: This implementation, done here on a PinePhone (A64), patches the 5.9 kernel and uses a recent version of GStreamer (1.18 and up), whose output is rendered directly to a DRM plane via kmssink. (No X or Wayland.)
GStreamer 1.18 works with the 5.9 kernel. It does not work with 5.10, because of numerous changes to the kernel headers in this version. In 5.11 the H.264 headers were moved into the uAPI; the master branch of GStreamer reflects this, but there haven't been any releases with these patches yet. It'll probably be in repositories with GStreamer 1.20; until then you can build it from source.
@Sash0k – patched libva-v4l2-request + VLC: This updates bootlin's libva-v4l2-request and follows the Sunxi wiki's instructions for enabling VLC to make use of it. It works on the desktop. This only works for H.264 and breaks HEVC. When I tried to replicate this approach on a recent Armbian build, I discovered that the h264.c files in the kernel (that libva-v4l2-request draws on) have changed considerably between 5.8 and 5.10, and I lack the understanding to reconcile libva-v4l2-request with them.
On 7/20/2020 at 4:38 PM, Sash0k said:
Finally got it! No kernel modifications needed, only v4l2-request.
Key notes:
  • Use bootlin code, latest master (not release-2019.03 tag)
  • I merged just one small patch from https://github.com/bootlin/libva-v4l2-request/pull/30/files (seems, it's unecessary)
  • Download kernel sources with corresponding version. For my armbian is: https://cdn.kernel.org/pub/linux/kernel/v5.x/linux-5.4.45.tar.xz
  • Extract 2 files from kernel/include/media mpeg2-ctrls.h and h264-ctrls.h and replace ones in v4l2-request
  • Replace V4L2_PIX_FMT_H264_SLICE_RAW to V4L2_PIX_FMT_H264_SLICE in v4l2-request source code
  • Compile and install (instruction is as 2 posts above)
  • Don't forget to set VLC as in https://linux-sunxi.org/Sunxi-Cedrus
      Reveal hidden contents
    Tools > Preferences > Input / Codecs > Codecs > Hardware-accelerated decoding > VA-API video decoder
    Tools > Preferences > Video > Display > Output > X11 video output (XCB)
Tested with VLC, usable with issues:
  • Artifacts in some videos h264 720p and higher, for example: https://imgur.com/nYFArT4 (360/480 works fine)
  • Scaling (fullscreen, resizing) not works, slowdown with message
    [a310cb88] main filter error: Failed to create video converter
  • Minor issues in console output on playback (see bold)
    $ vlc 3-big_buck_bunny_480p_H264_AAC_25fps_1800K.MP4
    VLC media player 3.0.9.2 Vetinari (revision 3.0.9.2-0-gd4c1aefe4d)
    [02287b98] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
    libEGL warning: DRI2: failed to authenticate
    libva info: VA-API version 1.7.0
    libva info: User environment variable requested driver 'v4l2_request'
    libva info: Trying to open /usr/lib/arm-linux-gnueabihf/dri/v4l2_request_drv_video.so
    libva info: Found init function __vaDriverInit_1_7
    libva info: va_openDriver() returns 0
    [a272d350] avcodec decoder: Using v4l2-request for hardware decoding
    [a3018b98] blend blend error: no matching alpha blending routine (chroma: YUVA -> VAOP)
    [a3018b98] main blend error: blending YUVA to VAOP failed
Thanks to: @jernej for this post:
@ubobrov – old kernel + libcedrus + libvdpau-sunxi + ffmpeg + mpv: This approach, which supports encoding decoding of H.264 uses the libvdpau-sunxi API and ports the legacy driver to mainline as a loadable kernel module and if I understand it correctly, ubobrov ported a legacy feature to mainline. In the post quoted below the kernel is 4.20, but the same method has been successfully applied to 5.7.8 by another user. It requires that the board's device tree be patched, as documented in ubobrov's github repository.
On 4/23/2020 at 4:41 PM, ubobrov said:
Decoding H264 and X11 rendering using vdpau_sunxi, libcedrus, kernel 4.20.17, mpv, vncserver and Armbian Bionic on Orange PI Zero
libvdpau: https://github.com/uboborov/libvdpau-sunxi-H3.git
libcedrus: https://github.com/uboborov/libcedrus-H3.git
cedar_dev: https://github.com/uboborov/sunxi-cedar-mainline.git
mpv, ffmpeg, x11 installed using apt
It works extremely slow but it's just a beginning  )
video: https://www.youtube.com/watch?v=9O7L_kaEDdk
UPD:
video on Orange PI One 1280x720 HDMI (works pretty fine)
https://www.youtube.com/watch?v=8qPyOG-yJIw
The summary seems to be that none of the current implementations on Allwinner boards really play nice with X or desktop sessions, and it's best to output directly to the framebuffer. Kwiboo has forked FFmpeg and mpv to make good use of new and unstable kernel features/hardware acceleration which will take a while to make their way upstream. The recent 5.11 move of stateless H.264 out of staging and into the uAPI should facilitate further developments.
I intend to try some of these things in the nearer future. Thanks to everyone who works on mainlining all of this VPU stuff, and to users here who contribute solutions and readily & patiently answer questions (Jernej especially). I hope I didn't post any falsehoods out of ignorance, and welcome any corrections.
Other related threads here:
https://forum.armbian.com/topic/11551-4kp30-video-on-orange-pi-lite-and-mainline-hardware-acceleration/
https://forum.armbian.com/topic/16804-orange-pi-pc-h3-armbian-focal-5104-sunxi-av-tv-out-cvbs-enable/page/2/
https://forum.armbian.com/topic/11184-hardware-graphicvideo-acceleration-in-h3-mainline/
https://forum.armbian.com/topic/13622-mainline-vpu/
Edited by P.P.A.
Edits, corrections and additions to reflect Jernej's and ubobrov's input below.
  • P.P.A. changed the title to Understanding Hardware-Accelerated Video Decoding
Good summary, let me clear some things.
18 hours ago, P.P.A. said:
as of kernel version 5.11, H.264 has been merged into the uAPI headers which, as I understand it, obsoletes libva-v4l2-request.
Having proper uAPI by no means makes libva-v4l2-request obsolete. If this lib is updated to latest uAPI, it still could serve as intermediate layer for all apps that don't support new interface but they support VA-API.
There are also VA-API and VDPAU, which the libraries below usually interface with. As far as I can tell, despite their frequent mention and similarly named things, these are irrelevant to present implementations of ARM hardware acceleration.
Before you talked about libva-v4l2-request, which implements VA-API, so I wouldn't say it's irrelevant to ARM HW accel. libvdpau-sunxi implements VDPAU, but that works only on BSP kernels and it is not relevant for mainline.
kodi-gbm is a package that can be onstalled on Armbian and functions similarly.
Recent mainlining efforts may mean that patching the kernel is no longer necessary and it works with 5.11 out of the box.
Maybe you can update your text, so we have current state overview in single post.
Thanks for your reply.
That's the idea. I've edited the post, corrected erroneous statements and added your information. (And added some of the information on GStreamer from IRC.)
22 hours ago, P.P.A. said:
his approach, which supports encoding of H.264 uses the libvdpau-sunxi API
This is a bit incorrect. libvdpau-sunxi is using for decoding only.
The Cedrus legacy driver has been supported to run on mainline kernel as KLM.
Thanks to the very patient support from jernej and ndufresne on the linux-sunxi IRC channel, I could confirm that GStreamer 1.19+ works out of the box on the 5.11 kernel (sunxi-dev), tested with Hirsute and Bullseye, at least on the H3/Orange Pi PC. (I haven't been able to build or run a 5.11 image on a H6 device, so I couldn't test it there yet.)
Kernel:
Build 5.11.y with this patch, must be included as a userpatch. 5.11.6 includes it from the getgo, but below that you need to add it yourself:
<jernej> PPA: kernel 5.11.6 is released with Cedrus patch
Requirements:
sudo apt update
sudo apt install meson ninja-build pkg-config libmount-dev libglib2.0-dev libgudev-1.0-dev libxml2-dev libasound2-dev
Building & installing GStreamer:
git clone https://gitlab.freedesktop.org/gstreamer/gst-build.git
cd gst-build
meson -Dgst-plugins-bad:v4l2codecs=enabled -Dgst-plugins-base:playback=enabled -Dgst-plugins-base:alsa=enabled build
ninja -C build
cd build
sudo meson install
sudo /sbin/ldconfig -v
You can play videos from the command line to the framebuffer. At least on the OPiPC there is a problem where it doesn't automatically play on the correct DRM layer and the video is hidden. To fix this, it needs to be ran once per boot with “plane-properties=s,zpos=3”:
gst-play-1.0 --use-playbin3 --videosink="kmssink plane-properties=s,zpos=3" video.file
Afterwards it should be fine with just gst-play-1.0 --use-playbin3 input.video (until the next reboot).
h.264 (except for 10-bit, which the hardware cannot handle) decodes smoothly with CPU load across all cores around 2%–5%.
Thanks; the OP was edited accordingly.
Edited by P.P.A.
Patch added to 5.11.6
  • lanefu pinned and featured this topic
Fantastic topic, thanks.
As I get
meson.build:1:0: ERROR:  Meson version is 0.49.2 but project requires >= 0.54.0.
I guess I should switch to 5.11 kernel (sunxi-dev). I tried other kernels, switched to nightly builds, but I'm still in 5.10.21-sunxi.
If only someone could do the same for video encoding. :unsure:
As I get
It must be 5.11, so you need to build from source.
Something I forgot to mention (going to edit the post now): the kernel must be built with this patch: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=7072db89572135f28cad65f15877bf7e67cf2ff8
It's been accepted for upstreaming and will be included in 5.11 later, but up until 5.11.3 at least, you need to include it as a userpatch.
This happens on all SoCs with DE2 or newer (A83t or newer SoC). Most SoCs have only one capable plane which can display YUV formats and it's always below current framebuffer, so that "workaround" (which imo is not workaround, but just part of configuration) is always needed in your use case. Note that having video plane below UI plane is actually desired for video players - UI plane has alpha channel which makes window with video transparent.
I don't want to hijack this thread, but could someone point me to a thread or documentation on how to rebuild and install the kernel on the machine itself?
I tried linux-5.11.6 and it looks like the patch is already there:
cp /proc/config.gz linux-5.11.6/ && cd linux-5.11.6/ && gunzip config.gz
curl -sSL https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/patch/?id=7072db89572135f28cad65f15877bf7e67cf2ff8 >cedrus.patch
patch -p1 < cedrus.patch
patching file drivers/staging/media/sunxi/cedrus/cedrus.c
Reversed (or previously applied) patch detected!  Assume -R? [n] y
patching file drivers/staging/media/sunxi/cedrus/cedrus.h
Thanks.
Thanks.
The patch was very recently added in 5.11.6.
I'm not sure how you install the kernel after the fact—I simply built a new bootable image with armbian-build (choosing sunxi-dev as the kernel with ./compile.sh EXPERT="yes") and flashed that to µSD.
Dear All, do we have cedrus h264 decode in kernel 5.12.x ? i also applied recent patch
it tested on allwinner a20 but get following error:
0:00:00.427616833   429   0x491400 ERROR     v4l2codecs-decoder gstv4l2decoder.c:697:gst_v4l2_decoder_get_controls:<v4l2decoder1> VIDIOC_G_EXT_CTRLS failed: Invalid argument
0:00:00.427836417   429   0x491400 WARN      v4l2codecs-h264dec gstv4l2codech264dec.c:134:gst_v4l2_codec_h264_dec_open:<v4l2slh264dec0> error: Driver did not report framing and start code method.
0:00:00.427968208   429   0x491400 WARN      v4l2codecs-h264dec gstv4l2codech264dec.c:134:gst_v4l2_codec_h264_dec_open:<v4l2slh264dec0> error: gst_v4l2_decoder_get_controls() failed: Invalid argument
0:00:00.428132625   429   0x491400 INFO        GST_ERROR_SYSTEM gstelement.c:2234:gst_element_message_full_with_details:<v4l2slh264dec0> posting message: Driver did not report framing and start code method.
ERROR: from element /GstPipeline:pipeline0/v4l2slh264dec:v4l2slh264dec0: Driver did not report framing and start code method.
Additional debug info:
../gst-plugins-bad-1.18.4/sys/v4l2codecs/gstv4l2codech264dec.c(134): gst_v4l2_codec_h264_dec_open (): /GstPipeline:pipeline0/v4l2slh264dec:v4l2slh264dec0:
ERROR: pipeline doesn't want to preroll.
Hi there,
I am newbie to the Armbian.
Yesterday I tried to flash Armbian 21.11.0-trunk.35 Hirsute with bleeding edge Linux 5.14 into OrangePi Win Plus.
Then tried to compile the gstreamer as below:
cd gst-build
ninja -C build cd build
sudo meson install
After that, I play mp4 file and the system got hang. Must hard reset the board to recover only.
Even I set cma=128M in the bootargs
gst-play-1.0 --use-playbin3 --gapless --videosink="kmssink plane-properties=s,zpos=3" /file
Any one has been solved the issue?
Regards,
Tan
I believe Kernel 5.18 (just landed today) will have VP9 and Hevc support on rk3399 via v4l2request api. There are ffmpeg patches that make use of it. I tried making it work, but couldn't manage to build the kernel headers properly for 5.18.
Once patches catch up to 5.18 and upstream ffmpeg get through the patchset, it's possible that finally everything will just work.
That being said, h264 already works pretty well even with armbian mainline 5.15 kernel and patched ffmpeg. It all works very well with moonlight-qt, streaming 4k at 80-100mpbs bandwidth with reasonable cpu usage on a rockpi-4b.
Check output/debug folder for clues.
VP9 is stable already and it's covered on more SoCes than RK3399. It works on Allwinner H6, for example. HEVC is not yet stable, you still need external patches.
LE has already patches for 5.18:
- kernel: https://github.com/LibreELEC/LibreELEC.tv/pull/6423
- ffmpeg: https://github.com/jernejsk/FFmpeg/commits/v4l2-request-hwaccel-4.4
Thanks jernej, I was just playing with your patches for pre-5.18 kernels and it all worked very well up to commit https://github.com/jernejsk/FFmpeg/commit/1cd61e5730acc12c39c964bcf13c73a54203a390. I saw the patches for 5.18, but I was not able to make my armbian rock4 work with 5.18 kernel due to missing realtek drivers. I was able to make the kernel compile and and boot but the ffmpeg code did not see the private kernel headers after installing the headers package. And then I noticed that my docker bridge networking is somehow broken, so I gave up and wait for 5.18 to land in armbian for rockchip64. Granted, this was with 5.18-rc7 and I had been deleting a bunch of patches to make it all compile so it's very likely I messed it up as I'm new to the armbian build process...
Do you have an idea when upstream ffmpeg will incorporate all these patches?
When someone sends patches to ffmpeg ML and goes through all requests made by ffmpeg devs. Before that, patches need to be consolidated with RPI HEVC ones (also request api based). Another issue is that Kodi doesn't support ffmpeg 5.0, so patches will stay on 4.4 until that happens. Needless to say, upstream takes patches only on top of last version.
Since nobody works on that, I would say not in near future.
Sounds like a mess 🙂
I was able to boot a patched armbian kernel that has the v4l2 kernel patches, and built a patched ffmpeg. Moonlight-qt now starts and attempts to initialize HEVC, and gets pretty far. Right now it's failing with "v4l2_request_hevc_set_controls: unsupported max slices, 32". Full logs are at https://pastebin.com/3j96JcMs. Is this something that moonlight is doing wrong? FWIW I built ffmpeg with:
./configure --enable-v4l2-request --enable-libdrm --enable-libv4l2 --enable-libudev
I guess I should try some file decoding first to see if it even works. It's quite possible that I messed up the kernel patch because I had to manually pick which files/hunks to apply from the libreelec patchset since I didn't want to break any armbian patches.
Edited by hege
Clarified that kernel patches were applied manually
For those who don't closely follow development, certainly.
I don't work on RK drivers, so I'm not sure if this is some kernel/driver quirk or userspace issue, but I know that v4l2 supports max. 32 buffers. Since your number is on the upper limit, it's not clear where the issue lies. I heard that RPi4 devs have issue with HEVC support on VLC, because VLC wants to allocate more than 32 buffers.
Thanks -- turns out the current limit is 16 as defined by https://github.com/jernejsk/FFmpeg/blob/v4l2-request-hwaccel-4.4/libavcodec/v4l2_request_hevc.c#L24. I increased that in my ffmpeg build to 32 and that made HEVC work with moonlight-qt! At I was able to stream for a few minutes; I didn't see much difference between HEVC and H.264 in moonlight streaming (and had no luck forcing HDR), so for now I went back to the better supported H.264 codec. I'll definitely give this another try once the kernel APIs + userspace code stabilizes.
I have same Problem. Ich habe camera ov5640 on bpim2z. Kernel 6.1. Make for camera overlay. Comera Work. :) I can use gsteamer. But  will use Cedrus. Und load cedrus Modelle. Have new /Dev/video2. how to set up gsteamer to use the accelerator?
Edited by Andrew Buckin
Encoding is not supported by mainline driver. There are some hacks posted on this forum how to make it work using vendor driver, but you need to patch kernel and ffmpeg and you can only have encoding or decoding working, not both.
