My Helios64 setup has been running stable for months now (except for one MOSFET that failed and had to be replaced), however after recent updates using the OMV5 package manager I am unable to transfer files to my computer (SMB shares). When trying to transfer to a Windows computer the transfer speed immediately plummets to 0, stays there forever or File Explorer crashes/stops responding.
When transferring to an Ubuntu system the transfer time outs.
I can browse the files on the SMB share, I can play them (movies, music, etc) or run them directly with no issues.
I can transfer files using scp with no problem (just at much reduced speed/bandwidth).
Version: 5.6.7-1
Kernel: 5.10.35-rockchip64
I was hoping for new updates to fix whatever is broken, but new updates won't install because of "unmet dependencies" and "you have held broken packages". So far this is for armbian-bsp-cli-helios64 21.05.2 and linux-buster-root-current-helios64 21.05.1
Anyone know what's wrong?
Upgrade was well tested and we didn't spot the problem you are mentioning. Without logs, we know to little to do anything about https://www.armbian.com/bugs
Armbian developers also hope you will start to cover their expenses if you expect work on your behalf. Work on FREE LICENCE software is very expensive, ... but you don't. tl;dr; read rant section.
My best guess is that the network driver for the 2.5 GbE NIC is broken, of course that could be unrelated to the updates. The relevant lines from dmesg appears to be:
[   11.812340] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   11.827250] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24)
I will try to figure it out myself.
[  220.889619] ------------[ cut here ]------------
[  220.889683] NETDEV WATCHDOG: eth1 (r8152): transmit queue 0 timed out
[  220.889792] WARNING: CPU: 4 PID: 0 at net/sched/sch_generic.c:443 dev_watchdog+0x398/0x3a0
[  220.889802] Modules linked in: softdog xt_nat xt_tcpudp veth xt_conntrack xt_MASQUERADE nf_conntrack_netlink xfrm_user xfrm_algo nft_counter xt_addrtype nft_compat nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables nfnetlink br_netfilter bridge governor_performance aufs quota_v2 quota_tree snd_soc_hdmi_codec r8152 snd_soc_rockchip_i2s snd_soc_core snd_pcm_dmaengine snd_pcm panfrost leds_pwm gpu_sched snd_timer snd hantro_vpu(C) pwm_fan gpio_charger soundcore rockchip_rga rockchip_vdec(C) videobuf2_vmalloc v4l2_h264 videobuf2_dma_contig videobuf2_dma_sg v4l2_mem2mem videobuf2_memops fusb302 videobuf2_v4l2 videobuf2_common tcpm typec rockchipdrm dw_mipi_dsi videodev dw_hdmi analogix_dp drm_kms_helper mc sg cec rc_core drm drm_panel_orientation_quirks gpio_beeper cpufreq_dt lm75 sunrpc ip_tables x_tables autofs4 raid10 raid1 raid0 multipath linear raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx realtek md_mod dwmac_rk stmmac_platform stmmac pcs_xpcs
[  220.890423]  adc_keys
[  220.890449] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G         C        5.10.35-rockchip64 #21.05.1
[  220.890459] Hardware name: Helios64 (DT)
[  220.890474] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
[  220.890487] pc : dev_watchdog+0x398/0x3a0
[  220.890499] lr : dev_watchdog+0x398/0x3a0
[  220.890508] sp : ffff800011c0bd50
[  220.890518] x29: ffff800011c0bd50 x28: ffff000004116880
[  220.890542] x27: 0000000000000004 x26: 0000000000000140
[  220.890565] x25: 00000000ffffffff x24: 0000000000000004
[  220.890587] x23: ffff8000118b7000 x22: ffff0000056ff41c
[  220.890609] x21: ffff0000056ff000 x20: ffff0000056ff4c0
[  220.890630] x19: 0000000000000000 x18: ffff8000118ded48
[  220.890651] x17: 0000000000000000 x16: 0000000000000000
[  220.890672] x15: 0000000000000294 x14: ffff800011c0ba10
[  220.890693] x13: 00000000ffffffea x12: ffff80001194ed80
[  220.890714] x11: 0000000000000003 x10: ffff800011936d40
[  220.890736] x9 : ffff800011936d98 x8 : 0000000000017fe8
[  220.890758] x7 : c0000000ffffefff x6 : 0000000000000003
[  220.890779] x5 : 0000000000000000 x4 : 0000000000000000
[  220.890800] x3 : 0000000000000103 x2 : 0000000000000102
[  220.890822] x1 : 7f083c788958b700 x0 : 0000000000000000
[  220.890844] Call trace:
[  220.890858]  dev_watchdog+0x398/0x3a0
[  220.890877]  call_timer_fn+0x30/0x1f8
[  220.890891]  run_timer_softirq+0x290/0x540
[  220.890905]  efi_header_end+0x160/0x41c
[  220.890922]  irq_exit+0xb8/0xd8
[  220.890935]  __handle_domain_irq+0x98/0x108
[  220.890953]  gic_handle_irq+0xc0/0x140
[  220.890965]  el1_irq+0xc0/0x180
[  220.890982]  arch_cpu_idle+0x18/0x28
[  220.890994]  default_idle_call+0x44/0x1bc
[  220.891008]  do_idle+0x204/0x278
[  220.891019]  cpu_startup_entry+0x28/0x60
[  220.891036]  secondary_start_kernel+0x170/0x180
[  220.891047] ---[ end trace 70adf4164f23c02e ]---
[  220.891106] r8152 4-1.4:1.0 eth1: Tx timeout
[  220.894064] xhci-hcd xhci-hcd.0.auto: bad transfer trb length 16744300 in event trb
[  220.894138] r8152 4-1.4:1.0 eth1: Tx status -2
[  220.894222] xhci-hcd xhci-hcd.0.auto: bad transfer trb length 16744300 in event trb
[  220.894265] r8152 4-1.4:1.0 eth1: Tx status -2
[  220.894337] xhci-hcd xhci-hcd.0.auto: bad transfer trb length 16744300 in event trb
[  220.894451] r8152 4-1.4:1.0 eth1: Tx status -2
[  220.894525] xhci-hcd xhci-hcd.0.auto: bad transfer trb length 16744300 in event trb
[  220.894567] r8152 4-1.4:1.0 eth1: Tx status -2
[  223.095841] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 3 using xhci-hcd
That "Tx status -2" don't look right.
The 1 GbE connection seems to work fine.
Same problem for me: impossible to install update: the following packages have unmet dependencies: armbian-bsp-cli-helios64
So what can we do to fix this bug ?
Thank you.
Pierre
4 hours ago, pierre said:
Thank you.
Pierre
I had the same issue, I had to uncheck CLI and the linux-buster-root-current, then installed updates, followed by the CLI alone, after installing the CLI the root-current 21.05.1 went away/was no longer available for me to attempt an install..
Those are a few of options:
- you can fix it and submit a patch https://github.com/armbian/build
- always report bugs how it is requests (other options - just ranting that something is wrong or providing only logs you suspect are important - are wasting our time. We don't look them.) https://forum.armbian.com/bugs and developers you support will help you when and if they find time.
- wait that random person fix this problem and submits a patch.
- after problem is fixed wait that staff that maintains repository create a bugfix release, which again adds costs to the bill.
The installation of the package armbian-bsp-cli-helios64 did not cause any trouble on my system (Armbian 21.05.2 Buster with Linux 5.10.35-rockchip64).
(-> OMV5 issue)
Same issue here, it's quite frustrating. Unfortunately, I have no idea where to even start an attempt at a fix. Can anyone confirm that this problem does not persist when using the 1Gbit NIC?
Edit:
Can confirm that on the 1G NIC it works just fine. As @Ammonia said, the driver for the 2.5G must be broken. This reminds me of the time that the driver was removed, @Igor probably remembers.
Edited by toti
Update
