Is there a backup and restore script on armbian using rsync and NFS for backup entire system to NAS like there is on dietpi (dietpi-backup) which is excellent?
  • JeanBonnot changed the title to Backup and restore using rsync and NFS (NAS) ?
Not that I am aware of.  Armbian is focused on much lower level things, like kernels, etc.
Have you studied the script?  Maybe you could adapt it (or even use it directly)?
That's beyond the feature-scope of Armbian.      And yes a great feature on diet-pi, which makes a very nice appliance experience for the user..... part of it's appliciance-ification approach to config management is also what lets it back up so nicely.
Posted (edited)
I'll try, but I'm a poor bash script developer
As u say 😉
This is the script dietpi-backup :
Spoiler
#!/bin/bash
	# DietPi Backup
	# Created by Daniel Knight / daniel.knight@dietpi.com / dietpi.com
	# Info:
	# - Location: /boot/dietpi/dietpi-backup
	# - Allows for a complete system back and restore of the linux filesystem (/)
	# Usage:
	# - dietpi-backup -1 = Restore
	# - dietpi-backup    = Menu
	# - dietpi-backup  1 = Backup
	# $2 = optional directory location to use with backup/restore input:
	# - dietpi-backup -1 /path/to/target = Restore
	# - dietpi-backup  1 /path/to/target = Backup
	# Import DietPi-Globals --------------------------------------------------------------
	. /boot/dietpi/func/dietpi-globals
	readonly G_PROGRAM_NAME='DietPi-Backup'
	G_CHECK_ROOT_USER
	G_CHECK_ROOTFS_RW
	G_INIT
	# Grab input
	[[ $1 =~ ^-?1$ ]] && INPUT=$1 || INPUT=0
	# Backup System
	# Backup file paths
	FP_SOURCE='/'
	FP_TARGET='/mnt/dietpi-backup'
	# Stats and transfer logs, stored to: $FP_TARGET/
	readonly FP_LOG='dietpi-backup.log'
	readonly FP_STATS='.dietpi-backup_stats'
	# Include/exclude file
	readonly FP_FILTER='.dietpi-backup_filter_inc_exc'
	readonly FP_FILTER_CUSTOM='/boot/dietpi/.dietpi-backup_inc_exc'
	# rsync options
	# - Backup: Delete files in target which are not present in source, or excluded
	readonly aRSYNC_RUN_OPTIONS_BACKUP=('-aH' '--info=name0' '--info=progress2' '--delete-excluded' "--exclude-from=$FP_FILTER")
	# - Restore: Delete files in target which are not present in source, but after the transfer has finished, and leave excluded files untouched
	readonly aRSYNC_RUN_OPTIONS_RESTORE=('-aH' '--info=name0' '--info=progress2' '--delete-after' "--exclude-from=$FP_FILTER")
	# Date format for logs
	Print_Date(){ date '+%Y-%m-%d_%T'; }
	# rsync already running error: $1=Backup/Restore
	Error_Rsync_Already_Running(){
		G_DIETPI-NOTIFY 1 'Another rsync process is already running.'
		echo -e "$1 failed: $(Print_Date). rsync is already running." >> "$FP_TARGET/$FP_STATS"
		G_WHIP_MSG "$1 Error:\n\nA $1 could not be started as rsync is already running."
		/boot/dietpi/dietpi-services start
	Check_Supported_Directory_Location(){
		# Obtain filesystem type. Create directory temporarily for this if missing.
		if [[ ! -d $FP_TARGET ]]
		then
			G_EXEC mkdir -p "$FP_TARGET"
			local fs_type=$(df -T "$FP_TARGET" | mawk 'NR==2 {print $2}')
			G_EXEC rmdir "$FP_TARGET"
		else
		fi
		# Check for supported filesystem type
		if [[ $fs_type =~ ^(ext[2-4]|(f2|btr|x|z)fs)$ ]]
		then
			return 0
		elif [[ $fs_type =~ ^nfs4?$ ]]
		then
			G_CHECK_FS_PERMISSION_SUPPORT "$FP_TARGET" && return 0
			G_DIETPI-NOTIFY 1 "NFS mount $FP_TARGET does not support UNIX permissions"
			G_WHIP_MSG "Unsupported NFS share:\n\n$FP_TARGET is an NFS share which does not support UNIX permissions.\n\nMake sure that the NFS share at the server is located on a filesystem with native symlink and UNIX permissions support."
		else
			G_DIETPI-NOTIFY 1 "Filesystem type $fs_type not supported in $FP_TARGET"
			G_WHIP_MSG "Filesystem type not supported:\n\n$FP_TARGET has a filesystem type of $fs_type, which is not supported.\n\nThe filesystem type must be ext2/3/4, F2FS, Btrfs, XFS, ZFS or a proper NFS mount with native symlink and UNIX permissions support."
		fi
		return 1
	Create_Filter_Include_Exclude(){
		cat << _EOF_ > $FP_FILTER
# Backup data, log and config
- $FP_TARGET/
- $FP_SETTINGS
# RAM dirs
- /dev/
- /proc/
- /run/
- /sys/
- /tmp/
# Swap files
- /var/swap
- .swap*
# Fake RTC timestamp
- /etc/fake-hwclock.data
# Unlinked inodes
- /lost+found/
# APT cache
- /var/cache/apt/*
_EOF_
		# Add users filter list
		[[ -f $FP_FILTER_CUSTOM ]] && cat $FP_FILTER_CUSTOM >> $FP_FILTER
	Run_Backup(){
		G_DIETPI-NOTIFY 3 "$G_PROGRAM_NAME" 'Backup'
		# Check valid FS
		Check_Supported_Directory_Location || return 1
		# Rotate backups with more than 1 shall be kept
		if (( $AMOUNT > 1 ))
		then
			G_DIETPI-NOTIFY 2 'Rotating backup archive'
			if [[ -d $FP_TARGET/data_$AMOUNT ]]
			then
				[[ -d $FP_TARGET/data_tmp ]] && G_EXEC rm -R "$FP_TARGET/data_tmp" # Failsafe
				G_EXEC mv "$FP_TARGET/data_$AMOUNT" "$FP_TARGET/data_tmp"
			fi
			if [[ -d $FP_TARGET/data ]]
			then
				for ((i=$AMOUNT-1;i>1;i--))
				do
					[[ -d $FP_TARGET/data_$i ]] && G_EXEC mv "$FP_TARGET/data_$i" "$FP_TARGET/data_$((i+1))"
				done
				G_EXEC mv "$FP_TARGET/data" "$FP_TARGET/data_2"
			fi
			[[ -d $FP_TARGET/data_tmp ]] && G_EXEC mv "$FP_TARGET/data_tmp" "$FP_TARGET/data"
		fi
		# Remove backups above selected amount
		local number
		for i in "$FP_TARGET/data_"*
		do
			number=${i#"$FP_TARGET/data_"}
			disable_error=1 G_CHECK_VALIDINT "$number" $(($AMOUNT+1)) || continue
			G_EXEC_DESC="Removing backup number $number which is above the selected amount $AMOUNT" G_EXEC rm -R "$i"
		done
		# Generate target directory if missing
		[[ -d $FP_TARGET/data ]] || G_EXEC mkdir -p "$FP_TARGET/data"
		/boot/dietpi/dietpi-services stop
		# Check if rsync is already running, while the daemon should have been stopped above
		pgrep 'rsync' &> /dev/null && { Error_Rsync_Already_Running 'Backup'; return 1; }
		# Install required rsync if missing
		G_AG_CHECK_INSTALL_PREREQ rsync
		# Generate Exclude/Include lists
		G_DIETPI-NOTIFY 2 'Checking for sufficient disk space via rsync dry-run, please wait...'
		local old_backup_size=$(du -sB1 "$FP_TARGET/data" | mawk '{print $1}') # Actual disk usage in bytes
		# - Dry run to obtain transferred data size
		rsync --dry-run --stats "${aRSYNC_RUN_OPTIONS_BACKUP[@]}" "$FP_SOURCE" "$FP_TARGET/data/" > .dietpi-backup_result
		local new_backup_size=$(grep -m1 '^Total file size:' .dietpi-backup_result | sed 's/[^0-9]*//g') # Apparent data size without block size related overhead
		local total_file_count=$(mawk '/^Number of files:/{print $6;exit}' .dietpi-backup_result | sed 's/[^0-9]*//g')
		local total_folder_count=$(mawk '/^Number of files:/{print $8;exit}' .dietpi-backup_result | sed 's/[^0-9]*//g')
		rm .dietpi-backup_result
		local target_fs_blocksize=$(stat -fc '%s' "$FP_TARGET/data")
		new_backup_size=$(( $new_backup_size + ( $total_file_count + $total_folder_count ) * $target_fs_blocksize )) # Add one block size for each file + dir as worst case result
		local end_result=$(( ( $new_backup_size - $old_backup_size ) / 1024**2 + 1 )) # bytes => MiB rounded up
		# - Perform check
		if ! G_CHECK_FREESPACE "$FP_TARGET/data" $end_result; then
			G_WHIP_BUTTON_OK_TEXT='Ignore'
			G_WHIP_BUTTON_CANCEL_TEXT='Exit'
			if ! G_WHIP_YESNO 'The backup target location appears to have insufficient free space to successfully finish the backup.
However, this check is a rough estimation in reasonable time, thus it could be marginally incorrect.
\nWould you like to override this warning and continue with the backup?'; then
				echo -e "Backup cancelled due to insufficient free space    : $(Print_Date)" >> "$FP_TARGET/$FP_STATS"
				return 1
			fi
		fi
		G_DIETPI-NOTIFY 2 "Backup to $FP_TARGET in progress, please wait..."
		# Init log file
		echo -e "Backup log from $(Print_Date)\n" > "$FP_TARGET/$FP_LOG"
		rsync "${aRSYNC_RUN_OPTIONS_BACKUP[@]}" -v --log-file="$FP_TARGET/$FP_LOG" "$FP_SOURCE" "$FP_TARGET/data/"
		EXIT_CODE=$?
		# touch target directory to show the correct last update timestamp when restoring one of multiple backups from the archive. This needs to be done after the backup since it applies the root / timestamps.
		G_EXEC touch "$FP_TARGET/data"
		G_DIETPI-NOTIFY -1 $EXIT_CODE "$G_PROGRAM_NAME: Backup"
		if (( $EXIT_CODE == 0 )); then
			echo -e "Backup completed    : $(Print_Date)" >> "$FP_TARGET/$FP_STATS"
			G_WHIP_MSG "Backup completed:\n - $FP_TARGET"
		else
			G_WHIP_MSG "Backup failed:\n - $FP_TARGET\n\nYou will see the log file on the next screen. Please check it for information and/or errors."
		fi
		log=1 G_WHIP_VIEWFILE "$FP_TARGET/$FP_LOG"
	# When restoring a backup, assure that either the UUIDs stored in the backup fstab/boot config matches the current system drive, or that we know all relevant files to adjust afterwards.
	Check_UUIDs()
		UPDATE_UUIDs=0 UPDATE_GRUB=0 UPDATE_RPI=0 UPDATE_ARMBIAN=0 UPDATE_ODROID=0 UPDATE_UBOOT=0
		UUID_ROOT=$(findmnt -Ufnro UUID -M /)
		PARTUUID_ROOT=$(findmnt -Ufnro PARTUUID -M /)
		# If the current rootfs' UUID or PARTUUID can be found in the the backups fstab, it can be assumed that it was created from the same drives.
		grep -q "^UUID=${UUID_ROOT}[[:blank:]]" "$FP_TARGET/$DATA/etc/fstab" || grep -q "^PARTUUID=${PARTUUID_ROOT}[[:blank:]]" "$FP_TARGET/$DATA/etc/fstab" && return 0
		UPDATE_UUIDs=1
		# Else check if we know how to adjust the boot config after the backup has been restored.
		# - x86_64
		if (( $G_HW_ARCH == 10 )) && command -v update-grub > /dev/null
		then
			UPDATE_GRUB=1
		# - RPi
		elif (( $G_HW_MODEL < 10 )) && [[ -f $FP_TARGET/$DATA/boot/cmdline.txt ]]
		then
			UPDATE_RPI=1
		# - Armbian
		elif [[ -f $FP_TARGET/$DATA/boot/armbianEnv.txt ]]
		then
			UPDATE_ARMBIAN=1
		# - Odroids / classic U-Boot
		elif [[ -f $FP_TARGET/$DATA/boot/boot.ini ]]
		then
			UPDATE_ODROID=1
		# - Modern U-Boot
		elif [[ -f $FP_TARGET/$DATA/boot/boot.cmd ]] && command -v mkimage > /dev/null
		then
			UPDATE_UBOOT=1
		# - Else we cannot assure that the restored image will boot.
		else
			# Let user decide, but default to "no"
			G_WHIP_YESNO '[WARNING] UUIDs of the backup and the current system differ
\nThe file systems unique identifiers, usually used to mount the drives at boot, seem to differ between the backup and the current system.
\nThis usually indicates that you try to restore an old backup onto a newly flashed DietPi system.
\nMoreover are we not able to find the boot configuration, where those UUIDs would need to be adjusted, to assure that the system will boot.
\nWe hence do not recommend to restore this backup on this system. If you continue, you will need to assure yourself that fstab and boot configurations match the UUIDs, else the system may not boot.
\nDo you want to restore this backup?' && return 0 || return 1
		fi
		G_WHIP_DEFAULT_ITEM='ok' G_WHIP_YESNO '[WARNING] UUIDs of the backup and the current system differ
\nBut we were able to find the boot configuration, where those UUIDs would need to be adjusted, to assure that the system will boot.
\nIt should be hence safe to restore this backup, but if the UUIDs were used elsewhere, you might need to adjust it manually.
	Update_UUIDs()
		# fstab
		while read -r mountpoint
		do
			[[ $mountpoint ]] || continue
			local uuid=$(findmnt -Ufnro UUID -M "$mountpoint")
			[[ $uuid ]] && G_EXEC sed -i "\|[[:blank:]]${mountpoint}[[:blank:]]|s|^[[:blank:]]*UUID=[^[:blank:]]*|UUID=$uuid|" /etc/fstab
			local partuuid=$(findmnt -Ufnro PARTUUID -M "$mountpoint")
			[[ $partuuid ]] && G_EXEC sed -i "\|[[:blank:]]${mountpoint}[[:blank:]]|s|^[[:blank:]]*PARTUUID=[^[:blank:]]*|PARTUUID=$partuuid|" /etc/fstab
		done < <(lsblk -no MOUNTPOINT "$(lsblk -npo PKNAME "$G_ROOTFS_DEV")")
		# boot configs
		# - x86_64
		if (( $UPDATE_GRUB == 1 ))
		then
			G_EXEC update-grub
			command -v update-tirfs > /dev/null && G_EXEC update-tirfs && return
			command -v dracut > /dev/null && G_EXEC dracut --force && return
			command -v update-initramfs > /dev/null && G_EXEC update-initramfs -u
		# - RPi
		elif (( $UPDATE_RPI == 1 ))
		then
			G_EXEC sed -Ei "s/(^|[[:blank:]])root=[^[:blank:]]*/\1root=PARTUUID=$PARTUUID_ROOT/" /boot/cmdline.txt
		# - Armbian
		elif (( $UPDATE_ARMBIAN == 1 ))
		then
			grep -q '^[[:blank:]]*rootdev=UUID=' /boot/armbianEnv.txt && G_CONFIG_INJECT 'rootdev=UUID=' "rootdev=UUID=$UUID_ROOT" /boot/armbianEnv.txt && return
			grep -q '^[[:blank:]]*rootdev=PARTUUID=' /boot/armbianEnv.txt && G_CONFIG_INJECT 'rootdev=PARTUUID=' "rootdev=PARTUUID=$PARTUUID_ROOT" /boot/armbianEnv.txt
		elif (( $UPDATE_ODROID == 1 ))
		then
			G_EXEC sed -Ei "s/(\"|root=)UUID=[^[:blank:]\"]*/\1UUID=$UUID_ROOT/" /boot/boot.ini
			G_EXEC sed -Ei "s/(\"|root=)PARTUUID=[^[:blank:]\"]*/\1PARTUUID=$PARTUUID_ROOT/" /boot/boot.ini
		# - Modern U-Boot
		elif (( $UPDATE_UBOOT == 1 ))
		then
			G_EXEC sed -Ei "s/(\"|root=)UUID=[^[:blank:]\"]*/\1UUID=$UUID_ROOT/" /boot/boot.cmd
			G_EXEC sed -Ei "s/(\"|root=)PARTUUID=[^[:blank:]\"]*/\1PARTUUID=$PARTUUID_ROOT/" /boot/boot.cmd
			G_EXEC mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
		fi
	# $1: Optional restore point from the archive
	Run_Restore(){
		local DATA='data'
		(( ${1:-1} > 1 )) && DATA="data_$1"
		G_DIETPI-NOTIFY 3 "$G_PROGRAM_NAME" 'Restore'
		# Check valid FS
		# Error: Backup not found
		[[ -f $FP_TARGET/$FP_STATS ]] || { G_WHIP_MSG "Restore failed:\n\n$FP_TARGET/$FP_STATS does not exist\n\nHave you created a backup?"; return 1; }
		# Check for matching filesystem UUIDs of backup and running system
		Check_UUIDs || return 1
		pgrep 'rsync' &> /dev/null && { Error_Rsync_Already_Running 'Restore'; return 1; }
		G_DIETPI-NOTIFY 2 "Restore from $FP_TARGET in progress, please wait..."
		# Init log file
		echo -e "Restore log from $(Print_Date)\n" > "$FP_TARGET/$FP_LOG"
		rsync "${aRSYNC_RUN_OPTIONS_RESTORE[@]}" -v --log-file="$FP_TARGET/$FP_LOG" "$FP_TARGET/$DATA/" "$FP_SOURCE"
		EXIT_CODE=$?
		hash -r # Clear PATH cache
		(( $UPDATE_UUIDs )) && Update_UUIDs
		G_DIETPI-NOTIFY -1 $EXIT_CODE "$G_PROGRAM_NAME: Restore"
			echo -e "Restore completed    : $(Print_Date)" >> "$FP_TARGET/$FP_STATS"
			G_WHIP_MSG "Restore completed:\n - $FP_TARGET\n\nNB: A Reboot is highly recommended."
		else
			G_WHIP_MSG "Restore failed:\n - $FP_TARGET\n\nYou will see the log file on the next screen. Please check it for information and/or errors."
		fi
	# Settings
	readonly FP_SETTINGS='/boot/dietpi/.dietpi-backup_settings'
	DAILY_BACKUP=0
	AMOUNT=1
	Write_Settings_File()
		cat << _EOF_ > $FP_SETTINGS
FP_TARGET=$FP_TARGET
DAILY_BACKUP=$DAILY_BACKUP
AMOUNT=$AMOUNT
_EOF_
	Read_Settings_File(){ [[ -f $FP_SETTINGS ]] && . $FP_SETTINGS; }
	# Menus
	MENU_LASTITEM='Help' # Select "Help" by default
	TARGETMENUID=0 # Main menu
	EXIT_CODE=-1 # Relevant for automated calls "dietpi-backup -1" and "dietpi-backup 1" e.g. via G_PROMPT_BACKUP
	# TARGETMENUID=0
	Menu_Main(){
		local backup_last_completed='Backup not found. Please create one.'
		local daily_backup_text='Off'
		(( $DAILY_BACKUP )) && daily_backup_text='On'
		G_WHIP_MENU_ARRAY=(
			'' '●─ Info '
			'Help' ": What does $G_PROGRAM_NAME do?"
		[[ -f $FP_TARGET/$FP_LOG ]] && G_WHIP_MENU_ARRAY+=('Last log' ': Review last backup/restore log for current location')
			'' '●─ Options '
			'Location' ': Change where your backup will be saved and restored from.'
			'Filter' ': Modify include/exclude filter for backups.'
			'Daily Backup' ": [$daily_backup_text] Daily backups via cron job"
			'Amount' ": [$AMOUNT] The amount of backups to keep"
		if [[ -f $FP_TARGET/$FP_STATS ]]
		then
			G_WHIP_MENU_ARRAY+=('Delete' ": Remove backup ($FP_TARGET)")
			backup_last_completed=$(grep 'ompleted' "$FP_TARGET/$FP_STATS" | tail -1)
		fi
			'' '●─ Run '
			'Backup' ': Create (or update) a backup of this device.'
			'Restore' ': Restore this device from a previous backup.'
		G_WHIP_DEFAULT_ITEM=$MENU_LASTITEM
		if G_WHIP_MENU "Current backup and restore location:\n - $FP_TARGET\n - $backup_last_completed"; then
			MENU_LASTITEM=$G_WHIP_RETURNED_VALUE
			case "$G_WHIP_RETURNED_VALUE" in
				'Help') G_WHIP_MSG 'DietPi-Backup is a program that allows you to Backup and Restore your DietPi system.
\nIf you have broken your system, or want to reset your system to an earlier date, this can all be done with DietPi-Backup.
\nSimply choose a location where you want to save and restore your backups from, then, select Backup or Restore.
\nEnable a daily system backup to run it once a day via daily cron job. The execution time can be changed in "dietpi-cron". Note that this temporarily stops server services. Also we recommend to configure and test the backup with a manual call before enabling this feature.
\nMore information: https://dietpi.com/docs/dietpi_tools/#dietpi-backup-backuprestore';;
				'Last log') log=1 G_WHIP_VIEWFILE "$FP_TARGET/$FP_LOG";;
				'Location') TARGETMENUID=1;;
				'Filter') nano $FP_FILTER_CUSTOM;;
				'Daily Backup') DAILY_BACKUP=$(( ! $DAILY_BACKUP ));;
				'Amount') G_WHIP_DEFAULT_ITEM=$AMOUNT G_WHIP_INPUTBOX 'Please enter the amount of backups to keep.\n - Needs to be 1 or greater.' && G_CHECK_VALIDINT "$G_WHIP_RETURNED_VALUE" 1 && AMOUNT=$G_WHIP_RETURNED_VALUE;;
				'Delete') G_WHIP_YESNO "Do you wish to DELETE the following backup?\n - $FP_TARGET" && G_EXEC_NOEXIT=1 G_EXEC rm -R "$FP_TARGET";;
				'Backup') G_WHIP_YESNO "The system will be backed up to:\n - $FP_TARGET\n\nDo you wish to continue and start the backup?" && Run_Backup;;
				'Restore')
					then
						G_WHIP_MENU_ARRAY=('1' "$(stat -c '%y' "$FP_TARGET/data")")
						for ((i=2;i<=$AMOUNT;i++))
						do
							[[ -d $FP_TARGET/data_$i ]] && G_WHIP_MENU_ARRAY+=("$i" "$(stat -c '%y' "$FP_TARGET/data_$i")")
						done
						if (( ${#G_WHIP_MENU_ARRAY[@]} > 2 ))
						then
							G_WHIP_MENU 'Please select the backup from the archive you wish to restore:' && Run_Restore "$G_WHIP_RETURNED_VALUE"
							return
						fi
					fi
					G_WHIP_YESNO "The system will be restored from:\n - $FP_TARGET\n\nDo you wish to continue and start the restore?" && Run_Restore
			esac
		else
			Menu_Exit
		fi
	Menu_Exit(){ G_WHIP_SIZE_X_MAX=50 G_WHIP_YESNO "Exit $G_PROGRAM_NAME?" && TARGETMENUID=-1 EXIT_CODE=0; }
	# TARGETMENUID=1
	Menu_Set_Directory(){
		G_WHIP_MENU_ARRAY=(
			'Search' ': Find previous backups'
			'List' ': Select from a list of available mounts/drives'
			'Manual' ': Manually type a directory to use'
		if G_WHIP_MENU "Please select the location where the backup will be saved, and restored from.\n\nYour current location:\n$FP_TARGET"; then
			local current_directory=$FP_TARGET
				'Search')
					G_DIETPI-NOTIFY 2 'Searching for previous backups, please wait...'
					local alist=()
					mapfile -t alist < <(find / -type f -name "$FP_STATS")
					# Do we have any results?
					if [[ ${alist[0]} ]]; then
						# Create List for Whiptail
						G_WHIP_MENU_ARRAY=()
						for i in "${alist[@]}"
						do
							local last_backup_date=$(sed -n '/ompleted/s/^.*: //p' "$i" | tail -1) # Date of last backup for this backup
							local backup_directory=${i%"/$FP_STATS"} # Backup directory (minus the backup file), that we can use for target backup directory.
							G_WHIP_MENU_ARRAY+=("$backup_directory" ": $last_backup_date")
						done
						G_WHIP_MENU 'Please select a previous backup to use:' || return 0
						FP_TARGET=$G_WHIP_RETURNED_VALUE
					else
						G_WHIP_MSG 'No previous backups were found.'
						return 0
					fi
				'Manual')
					G_WHIP_DEFAULT_ITEM=$FP_TARGET
					G_WHIP_INPUTBOX 'Please enter the absolute path to the backup directory.\nE.g.: /mnt/dietpi-backup\n - Must be a filesystem which supports symlinks and UNIX permissions, like ext4, F2FS, Btrfs, XFS, ZFS or a proper NFS mount' || return 0
				'List')
					/boot/dietpi/dietpi-drive_manager 1 || return 0
					FP_TARGET=$(</tmp/dietpi-drive_manager_selmnt)
					rm /tmp/dietpi-drive_manager_selmnt
					[[ $FP_TARGET == '/' ]] && FP_TARGET='/mnt'
					FP_TARGET+='/dietpi-backup'
			esac
			# If not supported, reset directory target to previous
			Check_Supported_Directory_Location || FP_TARGET=$current_directory
		else
			TARGETMENUID=0 # Return to main menu
		fi
	# Main Loop
	# Read settings
	Read_Settings_File
	# $2 Optional directory input
	[[ $2 ]] && FP_TARGET=$2
	# Create default filter file, if not yet present
	[[ -f $FP_FILTER_CUSTOM ]] || cat << '_EOF_' > $FP_FILTER_CUSTOM
# DietPi-Backup include/exclude filter
# Prefix "-" exclude items, "+" include items which would match a wildcard exclude rule.
# Suffix "/" match directories only, no files or symlinks.
# Using wildcard "*" matches any item name or part of it.
# Since the list is processed from top to bottom and the first match defines the result,
#   includes need to be defined before their wildcard exclude rule
#   and in case excludes before their wildcard include rule.
# Symlinks are handled as such and never processed recursively.
# Excluded directories are not processed recursively, so contained items cannot be included.
# Hence, to include items within an excluded directory:
# - Do not exclude the directory itself, but contained items via wildcard.
# - Define includes first, to override the wildcard exclude rule.
# - See the below default rules, how we exclude all items below /mnt
#   but include the dietpi_userdata directory, if it is no symlink.
# To prevent loops, the backup target dir, log and config are excluded internally.
+ /mnt/dietpi_userdata/
- /mnt/*
- /media/
_EOF_
	# Run Backup
	if (( $INPUT == 1 )); then
		Run_Backup
	# Run Restore
	elif (( $INPUT == -1 )); then
		Run_Restore
	# Run menu, if interactive
	elif (( $G_INTERACTIVE )); then
		until (( $TARGETMENUID < 0 ))
		do
			G_TERM_CLEAR
			if (( $TARGETMENUID == 1 )); then
				Menu_Set_Directory
			else
				Menu_Main
			fi
		done
		# Save settings
		Write_Settings_File
	fi
	exit $EXIT_CODE
And ditepi-global:
Spoiler
#!/bin/bash
	# DietPi-Globals
	# Info:
	# - Provides shared/global DietPi variables and functions for current bash session and DietPi scripts
	# - CRITICAL: Use local index variables in for/while loops, or unset them afterwards, else havoc: https://github.com/MichaIng/DietPi/issues/1454
	# - Sourced/Loaded in interactive bash sessions via /etc/bashrc.d/dietpi.bash
	# - Sourced/Loaded at start of most DietPi script
	# Core variables, functions and environment, used at start of most DietPi scripts
	# Script/Program name
	# - Set this in originating script, after loading globals and before calling G_INIT()
	# - Used in G_EXEC, G_WHIP and G_DIETPI-NOTIFY functions
	unset -v G_PROGRAM_NAME
	# Debug mode
	# - Set G_DEBUG=1 to enable additional debug output for some DietPi scripts and functions
	# - This variable is not pre-generated but checked via: [[ $G_DEBUG == 1 ]]
	#[[ $G_DEBUG == [01] ] || G_DEBUG=0
	# Non-interactive mode
	# - Set G_INTERACTIVE=0 to disable interactive G_EXEC and G_WHIP dialogues
	# - Set G_INTERACTIVE=1 to force interactive G_EXEC and G_WHIP dialogues
	# - Default is based on whether STDIN is attached to an open terminal or not: [[ -t 0 ]]
	#	OK | systemd	= [[ -t 0 ]] is false
	#	OK | Cron	= [[ -t 0 ]] is false
	#	NB | /etc/profile, ~/.profile, /etc/profile.d/, /etc/bash.bashrc, ~/.bashrc and /etc/bashrc.d/ are usually interactive since those are sourced from originating shell/bash session.
	if [[ $G_INTERACTIVE != [01] ]]; then
		[[ -t 0 ]] && G_INTERACTIVE=1 || G_INTERACTIVE=0
	fi
	# Disable DietPi-Services
	# - Set G_DIETPI_SERVICES_DISABLE=1 to disable DietPi-Services
	# - This variable is not pre-generated but checked via: [[ $G_DIETPI_SERVICES_DISABLE == 1 ]]
	#[[ $G_DIETPI_SERVICES_DISABLE == [01] ]] || G_DIETPI_SERVICES_DISABLE=0
	# DietPi first boot setup stage: -2 = PREP_SYSTEM/Unknown | -1 = 1st boot | 0 = 1st run dietpi-update | 1 = 1st run dietpi-software | 2 = completed | 10 = Pre-installed image, converts to 2 during 1st boot
	[[ -f '/boot/dietpi/.install_stage' ]] && G_DIETPI_INSTALL_STAGE=$(</boot/dietpi/.install_stage) || G_DIETPI_INSTALL_STAGE=-2
	# Hardware details
	[[ -f '/boot/dietpi/.hw_model' ]] && . /boot/dietpi/.hw_model
	# DietPi version and Git branch
	[[ -f '/boot/dietpi/.version' ]] && . /boot/dietpi/.version
	# - Assign defaults/code version as fallback
	[[ $G_DIETPI_VERSION_CORE ]] || G_DIETPI_VERSION_CORE=8
	[[ $G_DIETPI_VERSION_SUB ]] || G_DIETPI_VERSION_SUB=2
	[[ $G_DIETPI_VERSION_RC ]] || G_DIETPI_VERSION_RC=2
	[[ $G_GITBRANCH ]] || G_GITBRANCH='master'
	[[ $G_GITOWNER ]] || G_GITOWNER='MichaIng'
	# - Save current version and Git branch
	G_VERSIONDB_SAVE(){
		echo "G_DIETPI_VERSION_CORE=$G_DIETPI_VERSION_CORE
G_DIETPI_VERSION_SUB=$G_DIETPI_VERSION_SUB
G_DIETPI_VERSION_RC=$G_DIETPI_VERSION_RC
G_GITBRANCH='$G_GITBRANCH'
G_GITOWNER='$G_GITOWNER'" > /boot/dietpi/.version
	# Init function for originating script
	# - Stuff we can't init in main globals/funcs due to /etc/bashrc.d/dietpi.bash load into interactive bash sessions.
	# - Optional environment variables:
	#	G_INIT_ALLOW_CONCURRENT=1	= Allow concurrent DietPi script execution (default: 0)
	#	G_INIT_WAIT_CONCURRENT=<int>	= Max time to wait for concurrent execution to exit before user prompt (default: 5)
	G_INIT(){
		# Set locale to prevent incorrect scraping due to translated command outputs
		# Set PATH to expected default to rule out issues due to broken environment, e.g. in combination with "su" or "sudo -E"
		export LC_ALL='C.UTF-8' LANG='C.UTF-8' PATH='/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
		# Set G_PROGRAM_NAME to originating script file (or shell executable) name if it was not set by originating script
		[[ $G_PROGRAM_NAME ]] || readonly G_PROGRAM_NAME=${0##*/}
		# HIERARCHY system for G_DIETPI-NOTIFY 3 to reduce highlight or sub script output
		# shellcheck disable=SC2015
		[[ $HIERARCHY =~ ^[0-9]+$ ]] && export HIERARCHY=$((HIERARCHY+1)) || export HIERARCHY=0
		# Concurrent execution handling
		local i=0
		if [[ $G_INIT_ALLOW_CONCURRENT == 1 ]]
		then
			# Concurrency allowed: Use next free suffix for working directory, avoid race condition by checking via "mkdir" success
			until mkdir "/tmp/${G_PROGRAM_NAME}_$i" &> /dev/null
			do
				# If the directory does not exist, its creation failed, probably due to R/O filesystem, hence break loop!
				[[ -d /tmp/${G_PROGRAM_NAME}_$i ]] || break
				((i++))
			done
			readonly G_WORKING_DIR="/tmp/${G_PROGRAM_NAME}_$i"
		else
			# Concurrency not allowed: Use existing working directory as flag
			local limit=${G_INIT_WAIT_CONCURRENT:-5}
			while [[ -d /tmp/$G_PROGRAM_NAME ]]
			do
				if (( $i < $limit ))
				then
					((i++))
					G_DIETPI-NOTIFY 2 "Concurrent execution of $G_PROGRAM_NAME detected, retrying... ($i/$limit)"
					sleep 1
				else
					G_WHIP_BUTTON_OK_TEXT='Retry'
					# shellcheck disable=SC2009
					G_WHIP_YESNO "WARNING: Concurrent execution of $G_PROGRAM_NAME detected\n
Please check if one of the following applies:
 - This script already runs on another terminal/SSH session.
 - Currently a cron or systemd background job executes the script.
 - You started this script from within another DietPi program, causing a loop.\n
Please assure that the concurrent execution has finished, before retrying, otherwise cancel this instance.\n
The following info might help:
$(ps f -eo pid,user,tty,cmd | grep -i '[d]ietpi')" && continue
					G_DIETPI-NOTIFY 1 "Cancelled $G_PROGRAM_NAME due to concurrent execution"
					exit 1
				fi
			done
			readonly G_WORKING_DIR="/tmp/$G_PROGRAM_NAME"
		fi
		# Declare exit trap which runs on EXIT signals, including SIGINT and SIGTERM but not SIGKILL!
		G_EXIT(){
			# Execute custom exit function if declared
			declare -F G_EXIT_CUSTOM &> /dev/null && G_EXIT_CUSTOM
			# Navigate to /tmp before removing working directory
			cd /tmp || G_DIETPI-NOTIFY 1 'Failed to navigate to /tmp'
			# Purge working directory if existent
			[[ ! -d $G_WORKING_DIR ]] || rm -R "$G_WORKING_DIR" || G_DIETPI-NOTIFY 1 "Failed to remove scripts working directory: $G_WORKING_DIR"
		trap 'G_EXIT' EXIT
		# Create and navigate to scripts working directory or users home if available: https://github.com/MichaIng/DietPi/issues/905#issuecomment-298223705
		mkdir -p "$G_WORKING_DIR" && cd "$G_WORKING_DIR" && return
		G_DIETPI-NOTIFY 1 "Failed to create or enter scripts working directory: $G_WORKING_DIR"
		if [[ $HOME && -d $HOME ]]
		then
			cd "$HOME" && { G_DIETPI-NOTIFY 2 "Entered users home directory: $HOME"; return; }
			G_DIETPI-NOTIFY 1 "Failed to enter users home directory: $HOME"
		fi
		G_DIETPI-NOTIFY 2 "Will stay in current directory: $PWD"
	# Clear terminal by moving content into scrollback buffer: https://github.com/MichaIng/DietPi/issues/1615
	G_TERM_CLEAR(){
		# Without an input terminal, there is no point in doing this.
		[[ -t 0 ]] || return
		# Printing terminal height - 1 newlines seems to be the fastest method that is compatible with all terminal types.
		local lines=$(tput lines) i newlines
		for ((i=1;i<${lines% *};i++)); do newlines+='\n'; done
		echo -ne "\e[0m$newlines\e[H"
	# DietPi-Notify
	# $1:
	#	-2 = Processing
	#		$2+ = message
	#	-1 = Autodetect ok or failed
	#		$2  = exit code
	#		$3+ = message
	#	0  = Ok
	#		$2+ = message
	#	1  = Failed
	#		$2+ = message
	#	2  = Info
	#		$2+ = message
	#	3  = Header
	#		$2  = program name
	#		$3+ = message, prefixed with "${G_NOTIFY_3_MODE}: ", defaults to "Mode: "
	G_DIETPI-NOTIFY(){
		local i ainput_string=("$@") output_string grey green red reset yellow dietpi_green
		# If this is a terminal, it understands ANSI escape sequences, so use colour, always start left-aligned with colour reset and clear screen from cursor to end.
		# - Assume if STDIN is a terminal that STDOUT is one as well, e.g. covered by "tee"
		if [[ -t 0 || -t 1 ]]
		then
			output_string='\e[0m\r\e[J' grey='\e[90m' green='\e[32m' red='\e[31m' reset='\e[0m' yellow='\e[33m' dietpi_green='\e[38;5;154m'
			# Kill existing process animation if this is not a processing message
			if [[ $1 != '-2' && -w '/tmp/dietpi-process.pid' ]]
			then
				kill -9 "$(</tmp/dietpi-process.pid)" &> /dev/null
				rm -f /tmp/dietpi-process.pid &> /dev/null
			fi
		# Else remove all colour codes from input string
		else
			shopt -s extglob
			for i in "${!ainput_string[@]}"
			do
				ainput_string[$i]=${ainput_string[$i]//\\e[[0-9]*([;0-9])m}
			done
			shopt -u extglob
		fi
		local bracket_l="${grey}[$reset" bracket_r="$grey]$reset"
		local ok="$bracket_l$green  OK  $bracket_r " failed="$bracket_l${red}FAILED$bracket_r "
		# Print input array from index $1
		Print(){
			[[ $1 == 1 && $G_PROGRAM_NAME ]] && output_string+="$grey$G_PROGRAM_NAME |$reset "
			for ((i=$1; i<${#ainput_string[@]}; i++))
			do
				output_string+=${ainput_string[$i]}
			done
			echo -ne "$output_string$reset"
		# Main Loop
		# Autodetect ok or failed
		# $2 = exit code
		# $3+ = message
		# - Use this at end of DietPi scripts, e.g. G_DIETPI-NOTIFY -1 ${EXIT_CODE:=0}
		if (( $1 == -1 )); then
			if (( $2 )); then
				output_string+=$failed
				ainput_string+=(' | Exited with error\n')
			else
				output_string+=$ok
				ainput_string+=(' | Completed\n')
			fi
			Print 2
		# Processing
		# $3+ = message
		# NB: Do not use this with newlines, literally or "\n", as this would cause parts of the processing message not being overwritten as intended.
		elif (( $1 == -2 )); then
			# If this is a terminal, it understands control codes, so make any next output overwrite the processing message.
			if [[ ( -t 0 || -t 1 ) && $TERM != 'dumb' ]]
			then
				# Calculate the amount of output lines and in case move cursor up for correct animation position and to allow overwriting the whole output.
				local input_string="${G_PROGRAM_NAME:+$G_PROGRAM_NAME | }$*"
				# - Remove colour codes: Use extended globbing
				shopt -s extglob
				input_string=${input_string//\\e[[0-9]*([;0-9])m}
				shopt -u extglob
				local screen_width=$(tput cols)
				local output_lines=$(( ( ${#input_string} + 5 ) / $screen_width )) # +5 = [ .... ] - $1
				(( $output_lines )) && ainput_string+=("\e[${output_lines}A")
				# If we do not print the animation, move the cursor left as well to allow overwriting the whole first line.
				[[ -t 0 ]] || ainput_string+=('\r')
			# Else, we add a newline to leave processing message complete.
			else
				ainput_string+=('\n')
			fi
			# Print animation only if this is the terminal control process as otherwise foreign output might cause a mess and we might be not able to kill the animation.
			if [[ -t 0 && $TERM != 'dumb' ]]
			then
				output_string+="$bracket_l      $bracket_r "
				Print 1
				# If redirect to existent PID file fails due to noclobber, don't start processing animation.
				# - This method prevents a tiny condition race from checking file existence until creating it, when doing: [[ ! -e file ]] && > file
				set -C
				if { > /tmp/dietpi-process.pid; } &> /dev/null
				then
					set +C
					Start_Process_Animation(){
						local bright_dot='\e[1;33m.'
						local dimmed_dot='\e[0;33m.'
						# Alternative: \u23F9
						local aprocess_string=(
							"$bright_dot     "
							"$dimmed_dot$bright_dot    "
							" $dimmed_dot$bright_dot   "
							"    $dimmed_dot$bright_dot"
							"     $bright_dot"
							"    $bright_dot$dimmed_dot"
							"   $bright_dot$dimmed_dot "
							"$bright_dot$dimmed_dot    "
						for (( i=0; i<=${#aprocess_string[@]}; i++ ))
						do
							(( i == ${#aprocess_string[@]} )) && i=0
							[[ -w '/tmp/dietpi-process.pid' ]] && echo -ne "\e[2G${aprocess_string[$i]}$reset\e[C" || return
							sleep 0.15
						done
					{ Start_Process_Animation & echo $! > /tmp/dietpi-process.pid; disown; } 2> /dev/null
					unset -f Start_Process_Animation
				else
					set +C
				fi
			else
				output_string+="$bracket_l $yellow.... $bracket_r "
				Print 1
			fi
		# Ok
		# $2+ = message
		elif (( $1 == 0 )); then
			output_string+=$ok
			Print 1
		# Failed
		# $2+ = message
		elif (( $1 == 1 )); then
			# Print error messages to STDERR
			Print 1 >&2
		# Info
		# $2+ = message
		elif (( $1 == 2 )); then
			output_string+="$bracket_l INFO $bracket_r "
			# Keep info messages in grey, even if "$G_PROGRAM_NAME | \e[0m" is added:
			ainput_string[1]="$grey${ainput_string[1]}"
			Print 1
		# Header
		# $2 = program name
		elif (( $1 == 3 )); then
			if disable_error=1 G_CHECK_VALIDINT "$HIERARCHY" 1; then
				local status_subfunction="$HIERARCHY "
				# > 9 should never occur, however, if it is, lets make it line up regardless
				(( $HIERARCHY > 9 )) && status_subfunction=$HIERARCHY
				output_string+="$bracket_l$yellow SUB$status_subfunction$bracket_r $2 > "
			else
				output_string+="
 $dietpi_green$2$reset
$grey─────────────────────────────────────────────────────
 ${G_NOTIFY_3_MODE:-Mode}:$reset "
				ainput_string+=('\n\n')
			fi
			Print 2
		fi
		# Unset internal functions, otherwise they are accessible from terminal
		unset -f Print
	# $1 = mode
	#	2	= Silent check, only returning error code if non-root
	#	1	= Kill current script only, excluding the shell.
	#	else	= Exit all linked scripts (kill all)
	G_CHECK_ROOT_USER(){
		(( $UID )) || return 0
		[[ $1 == 2 ]] && return 1
		G_DIETPI-NOTIFY 1 'Root privileges required. Please run the command with "sudo" or "G_SUDO".'
		if [[ $1 == 1 ]]
		then
			kill -INT $$
		else
			exit 1
		fi
	G_CHECK_ROOTFS_RW(){
		[[ $G_CHECK_ROOTFS_RW_VERIFIED == 1 ]] && return 0
		if grep -q '[[:blank:]]/[[:blank:]].*[[:blank:]]ro,' /proc/mounts
		then
			G_DIETPI-NOTIFY 1 'RootFS is currently Read Only (R/O) mounted. Aborting...'
			G_DIETPI-NOTIFY 2 'DietPi requires RootFS to be Read/Write (R/W) mounted. Please run "dietpi-drive_manager" to re-enable.'
			exit 1
		else
			export G_CHECK_ROOTFS_RW_VERIFIED=1
		fi
	# Shortcut functions
	# sudo wrapper that ensures DietPi-Globals with G_* commands are loaded
	G_SUDO(){ local input=$*; sudo bash -c ". /boot/dietpi/func/dietpi-globals && $input"; }
	# ownCloud/Nextcloud CLI: Implemented as functions to make then available in scripts
	[[ -f '/var/www/owncloud/occ' ]] && occ(){ sudo -u www-data php /var/www/owncloud/occ "$@"; }
	[[ -f '/var/www/nextcloud/occ' ]] && ncc(){ sudo -u www-data php /var/www/nextcloud/occ "$@"; }
	# Whiptail (Whippy-da-whip-whip-whip tail!)
	# - Automatically detects/processes for G_INTERACTIVE
	# Input:
	# - G_WHIP_DEFAULT_ITEM		| Optional, to set the default selected/menu item or inputbox entry
	# - G_WHIP_SIZE_X_MAX=50	| Optional, limits width [in chars], if below available screen width
	# - G_WHIP_BUTTON_OK_TEXT	| Optional, change as needed, defaults to "Ok"
	# - G_WHIP_BUTTON_CANCEL_TEXT	| Optional, change as needed, defaults to "Cancel"
	# - G_WHIP_MENU_ARRAY		| Required for G_WHIP_MENU to set available menu entries, 2 array indices per line: ('item' 'description')
	# - G_WHIP_CHECKLIST_ARRAY	| Required for G_WHIP_CHECKLIST set available checklist options, 3 array indices per line: ('item' 'description' 'on'/'off')
	# Output:
	# - G_WHIP_RETURNED_VALUE 	| Returned value from inputbox/menu/checklist based whiptail items
	# G_WHIP_DESTROY | Clear vars after run of whiptail
	G_WHIP_DESTROY(){ unset -v G_WHIP_DEFAULT_ITEM G_WHIP_SIZE_X_MAX G_WHIP_BUTTON_OK_TEXT G_WHIP_BUTTON_CANCEL_TEXT G_WHIP_MENU_ARRAY G_WHIP_CHECKLIST_ARRAY; }
	# Run once, to be failsafe in case any exported/environment variables are left from originating shell
	G_WHIP_DESTROY
	# G_WHIP_INIT
	# - Update target whiptail size, based on current screen dimensions
	# - $1 = input mode | 2: Z=G_WHIP_MENU_ARRAY 3: Z=G_WHIP_CHECKLIST_ARRAY
	G_WHIP_INIT(){
		# Automagically set size of whiptail box and contents according to screen size and whiptail type
		local input_mode=$1
		# Update backtitle
		WHIP_BACKTITLE=$G_HW_MODEL_NAME
		local active_ip=$(G_GET_NET -q ip)
		[[ $active_ip ]] && WHIP_BACKTITLE+=" | IP: $active_ip"
		# Set default button text, if not defined
		G_WHIP_BUTTON_OK_TEXT=${G_WHIP_BUTTON_OK_TEXT:-Ok}
		G_WHIP_BUTTON_CANCEL_TEXT=${G_WHIP_BUTTON_CANCEL_TEXT:-Cancel}
		# Get current screen dimensions
		WHIP_SIZE_X=$(tput cols)
		WHIP_SIZE_Y=$(tput lines)
		# - Limit and reset non-valid integer values to 120 characters per line
		(( $WHIP_SIZE_X <= 120 )) || WHIP_SIZE_X=120
		# - If width is below 9 characters, the text field starts to cover the internal margin, regardless of content or button text, hence 9 is the absolute minimum.
		(( $WHIP_SIZE_X >= 9 )) || WHIP_SIZE_X=9
		# - G_WHIP_SIZE_X_MAX allows to further reduce width, e.g. to keep X/Y ratio in beautiful range.
		disable_error=1 G_CHECK_VALIDINT "$G_WHIP_SIZE_X_MAX" 0 $WHIP_SIZE_X && WHIP_SIZE_X=$G_WHIP_SIZE_X_MAX
		# - If height is below 7 lines, not a single line of text can be shown, hence 7 is the reasonable minimum.
		(( $WHIP_SIZE_Y >= 7 )) || WHIP_SIZE_Y=7
		# Calculate lines required to show all text content
		local whip_lines_text=6 # Due to internal margins, the available height is 6 lines smaller
		local whip_chars_text=$(( $WHIP_SIZE_X - 4 )) # Due to internal margins, the available width is 4 characters smaller
		WHIP_SCROLLTEXT= # Add "--scrolltext" automatically if text height exceeds max available
		Process_Line(){
			local split line=$1
			# Split line by "\n" newline escape sequences, the only one which is interpreted by whiptail, in a strict way: "\\n" still creates a newline, hence the sequence cannot be escaped!
			while [[ $line == *'\n'* ]]
			do
				# Grab first line
				split=${line%%\\n*}
				# Add required line + additional lines due to automated line breaks, if text exceeds internal box
				(( whip_lines_text += 1 + ( ${#split} - 1 ) / $whip_chars_text ))
				# Stop counting if required size exceeds screen already
				(( $whip_lines_text > $WHIP_SIZE_Y )) && return 1
				# Cut away handled line from string
				line=${line#*\\n}
			done
			# Process remaining line
			(( whip_lines_text += 1 + ( ${#line} - 1 ) / $whip_chars_text ))
			(( $whip_lines_text <= $WHIP_SIZE_Y )) || return 1
		# - WHIP_MESSAGE
		if [[ $WHIP_ERROR$WHIP_MESSAGE ]]; then
			while read -r line; do Process_Line "$line" || break; done <<< "$WHIP_ERROR$WHIP_MESSAGE"
		# - WHIP_TEXTFILE
		elif [[ $WHIP_TEXTFILE ]]; then
			while read -r line; do Process_Line "$line" || break; done < "$WHIP_TEXTFILE"
		fi
		unset -f Process_Line
		# Process menu and checklist
		# - G_WHIP_MENU
		if [[ $input_mode == 2 ]]; then
			# Requires 1 additional line for text
			((whip_lines_text++))
			# Lines required for menu: ( ${#array} + 1 ) to round up on uneven array entries
			WHIP_SIZE_Z=$(( ( ${#G_WHIP_MENU_ARRAY[@]} + 1 ) / 2 ))
			# Auto length for ─
			# - Get max length of all lines in array indices 1 + 2n | '' 'this one'
			local i character_count_max=0
			for (( i=1; i<${#G_WHIP_MENU_ARRAY[@]}; i+=2 ))
			do
				(( ${#G_WHIP_MENU_ARRAY[$i]} > $character_count_max )) && character_count_max=${#G_WHIP_MENU_ARRAY[$i]}
			done
			((character_count_max--)) # -1 for additional ●
			# - Now add the additional required lines
			do
				[[ ${G_WHIP_MENU_ARRAY[$i]} == '●'* ]] || continue
				while (( ${#G_WHIP_MENU_ARRAY[$i]} < $character_count_max ))
				do
					G_WHIP_MENU_ARRAY[$i]+='─'
				done
				G_WHIP_MENU_ARRAY[$i]+='●'
			done
		elif [[ $input_mode == 3 ]]; then
			# Lines required for checklist: ( ${#array} + 2 ) to round up single+double array entries
			WHIP_SIZE_Z=$(( ( ${#G_WHIP_CHECKLIST_ARRAY[@]} + 2 ) / 3 ))
			# Auto length for ─
			# - Get max length of all lines in array indices 1 + 3n 1st | '' 'this one' ''
			for (( i=1; i<${#G_WHIP_CHECKLIST_ARRAY[@]}; i+=3 ))
			do
				(( ${#G_WHIP_CHECKLIST_ARRAY[$i]} > $character_count_max )) && character_count_max=${#G_WHIP_CHECKLIST_ARRAY[$i]}
			done
			do
				[[ ${G_WHIP_CHECKLIST_ARRAY[$i]} == '●'* ]] || continue
				while (( ${#G_WHIP_CHECKLIST_ARRAY[$i]} < $character_count_max ))
				do
					G_WHIP_CHECKLIST_ARRAY[$i]+='─'
				done
				G_WHIP_CHECKLIST_ARRAY[$i]+='●'
			done
		fi
		# Adjust sizes to fit content
		# - G_WHIP_MENU/G_WHIP_CHECKLIST needs to hold text + selection field (WHIP_SIZE_Z)
		if [[ $input_mode == [23] ]]; then
			# If required lines would exceed screen, reduce WHIP_SIZE_Z
			if (( $whip_lines_text + $WHIP_SIZE_Z > $WHIP_SIZE_Y )); then
				WHIP_SIZE_Z=$(( $WHIP_SIZE_Y - $whip_lines_text ))
				# Assure at least 2 lines to have the selection field scroll bar identifiable
				if (( $WHIP_SIZE_Z < 2 )); then
					WHIP_SIZE_Z=2
					# Since text is partly hidden now, add text scroll ability and info to backtitle
					WHIP_SCROLLTEXT='--scrolltext'
					WHIP_BACKTITLE+=' | Use up/down buttons to scroll text'
				fi
			# else reduce WHIP_SIZE_Y to hold all content
			else
				WHIP_SIZE_Y=$(( $whip_lines_text + $WHIP_SIZE_Z ))
			fi
		# - Everything else needs to hold text only
		elif (( $whip_lines_text > $WHIP_SIZE_Y )); then
		else
			WHIP_SIZE_Y=$whip_lines_text
		fi
	# G_WHIP_MSG "message"
	# - Display a message from input string
	G_WHIP_MSG(){
		local WHIP_MESSAGE=$*
		if [[ $G_INTERACTIVE == 1 ]]; then
			local WHIP_ERROR WHIP_BACKTITLE WHIP_SCROLLTEXT WHIP_SIZE_X WHIP_SIZE_Y
			G_WHIP_INIT
			whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE" --msgbox "$WHIP_MESSAGE" --ok-button "$G_WHIP_BUTTON_OK_TEXT" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X"
		else
			G_DIETPI-NOTIFY 2 "$WHIP_MESSAGE"
		fi
		G_WHIP_DESTROY
	# G_WHIP_VIEWFILE "/path/to/file"
	# - Display content from input file
	# - Exit code: 1=file not found, else=file shown or noninteractive
	G_WHIP_VIEWFILE(){
		local result=0
			local WHIP_ERROR WHIP_MESSAGE WHIP_BACKTITLE WHIP_SCROLLTEXT WHIP_SIZE_X WHIP_SIZE_Y WHIP_TEXTFILE=$1 header='File viewer'
			[[ $log == 1 ]] && header='Log viewer'
			if [[ -f $WHIP_TEXTFILE ]]; then
				G_WHIP_INIT
				whiptail --title "${G_PROGRAM_NAME:+$G_PROGRAM_NAME | }$header" --backtitle "$WHIP_BACKTITLE" --textbox "$WHIP_TEXTFILE" --ok-button "$G_WHIP_BUTTON_OK_TEXT" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X"
			else
				result=1
				WHIP_ERROR="[FAILED] File does not exist: $WHIP_TEXTFILE"
				G_WHIP_INIT
				whiptail --title "${G_PROGRAM_NAME:+$G_PROGRAM_NAME | }$header" --backtitle "$WHIP_BACKTITLE" --msgbox "$WHIP_ERROR" --ok-button "$G_WHIP_BUTTON_OK_TEXT" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X"
			fi
		fi
		G_WHIP_DESTROY
		return $result
	# G_WHIP_YESNO "message"
	# - Prompt user for Yes/No | Ok/Cancel choice and return result
	# - Exit code: 0=Yes/Ok, else=No/Cancel or noninteractive
	G_WHIP_YESNO(){
		local result=1 default_no='--defaultno'
		[[ ${G_WHIP_DEFAULT_ITEM,,} == 'yes' || ${G_WHIP_DEFAULT_ITEM,,} == 'ok' ]] && result=0 default_no=
			local WHIP_ERROR WHIP_BACKTITLE WHIP_SCROLLTEXT WHIP_SIZE_X WHIP_SIZE_Y WHIP_MESSAGE=$*
			G_WHIP_INIT
			whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE" --yesno "$WHIP_MESSAGE" --yes-button "$G_WHIP_BUTTON_OK_TEXT" --no-button "$G_WHIP_BUTTON_CANCEL_TEXT" "$default_no" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X"
			result=$?
		fi
		G_WHIP_DESTROY
		return $result
	# G_WHIP_INPUTBOX "message"
	# - Prompt user to input text and save it to G_WHIP_RETURNED_VALUE
	# - Exit code: 0=input done, else=user cancelled or noninteractive
	G_WHIP_INPUTBOX(){
		local result=1
		unset -v G_WHIP_RETURNED_VALUE # in case left from last G_WHIP
			while :
			do
				G_WHIP_INIT
				G_WHIP_RETURNED_VALUE=$(whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE" --inputbox "$WHIP_ERROR$WHIP_MESSAGE" --ok-button "$G_WHIP_BUTTON_OK_TEXT" --cancel-button "$G_WHIP_BUTTON_CANCEL_TEXT" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X" "$G_WHIP_DEFAULT_ITEM" 3>&1 1>&2 2>&3-; echo $? > /tmp/.G_WHIP_INPUTBOX_RESULT)
				result=$(</tmp/.G_WHIP_INPUTBOX_RESULT); rm -f /tmp/.G_WHIP_INPUTBOX_RESULT
				[[ $result == 0 && -z $G_WHIP_RETURNED_VALUE ]] && { WHIP_ERROR='[FAILED] An input value was not entered, please try again...\n\n'; continue; }
				break
			done
		fi
		G_WHIP_DESTROY
		return "$result"
	# G_WHIP_PASSWORD "message"
	# - Prompt user to input password and save it in variable "result"
	# - Originating script must "unset result" after value has been handled for security reasons!
	# - Exit code: 0=input done + passwords match, else=noninteractive (Cancelling is disabled since no password in originating script can cause havoc!)
	G_WHIP_PASSWORD(){
		local return_value=1
		unset -v result # in case left from last call
			while :
			do
				G_WHIP_INIT
				local password_0=$(whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE" --passwordbox "$WHIP_ERROR$WHIP_MESSAGE" --ok-button "$G_WHIP_BUTTON_OK_TEXT" --nocancel $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X" 3>&1 1>&2 2>&3-)
				[[ $password_0 ]] || { WHIP_ERROR='[FAILED] No input made, please try again...\n\n'; continue; }
				local password_1=$(whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE" --passwordbox 'Please retype and confirm your input:' --ok-button "$G_WHIP_BUTTON_OK_TEXT" --nocancel 7 "$WHIP_SIZE_X" 3>&1 1>&2 2>&3-)
				[[ $password_0 == "$password_1" ]] || { WHIP_ERROR='[FAILED] Inputs do not match, please try again...\n\n'; continue; }
				result=$password_0
				return_value=0
				break
			done
		fi
		G_WHIP_DESTROY
		return $return_value
	# G_WHIP_MENU "message"
	# - Prompt user to select option from G_WHIP_MENU_ARRAY and save choice to G_WHIP_RETURNED_VALUE
	# - Exit code: 0=selection done, else=user cancelled or noninteractive
	G_WHIP_MENU()
		local result=1
		unset -v G_WHIP_RETURNED_VALUE # in case left from last call
		[[ $G_INTERACTIVE == 1 ]] && until [[ $G_WHIP_RETURNED_VALUE ]] # Stay in menu if empty option was selected (separator line)
		do
			local WHIP_ERROR WHIP_BACKTITLE WHIP_SCROLLTEXT WHIP_SIZE_X WHIP_SIZE_Y WHIP_SIZE_Z WHIP_MESSAGE=$*
			G_WHIP_INIT 2
			G_WHIP_RETURNED_VALUE=$(whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE" --menu "$WHIP_MESSAGE" --ok-button "$G_WHIP_BUTTON_OK_TEXT" --cancel-button "$G_WHIP_BUTTON_CANCEL_TEXT" --default-item "$G_WHIP_DEFAULT_ITEM" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X" $WHIP_SIZE_Z "${G_WHIP_MENU_ARRAY[@]}" 3>&1 1>&2 2>&3-; echo $? > /tmp/.WHIP_MENU_RESULT)
			result=$(</tmp/.WHIP_MENU_RESULT); rm -f /tmp/.WHIP_MENU_RESULT
			[[ ${result:=1} == 0 ]] || break # Exit loop in case of cancel button selection or error or if .WHIP_MENU_RESULT could not be created
		done
		G_WHIP_DESTROY
		return "$result"
	# G_WHIP_CHECKLIST "message"
	# - Prompt user to select multiple options from G_WHIP_CHECKLIST_ARRAY and save choice to G_WHIP_RETURNED_VALUE
	G_WHIP_CHECKLIST()
		local result=1
		then
			G_WHIP_INIT 3
			G_WHIP_RETURNED_VALUE=$(whiptail ${G_PROGRAM_NAME:+--title "$G_PROGRAM_NAME"} --backtitle "$WHIP_BACKTITLE | Use spacebar to toggle selection" --checklist "$WHIP_MESSAGE" --separate-output --ok-button "$G_WHIP_BUTTON_OK_TEXT" --cancel-button "$G_WHIP_BUTTON_CANCEL_TEXT" --default-item "$G_WHIP_DEFAULT_ITEM" $WHIP_SCROLLTEXT "$WHIP_SIZE_Y" "$WHIP_SIZE_X" $WHIP_SIZE_Z "${G_WHIP_CHECKLIST_ARRAY[@]}" 3>&1 1>&2 2>&3-; echo $? > /tmp/.WHIP_CHECKLIST_RESULT)
			G_WHIP_RETURNED_VALUE=$(echo -e "$G_WHIP_RETURNED_VALUE" | tr '\n' ' ')
			result=$(</tmp/.WHIP_CHECKLIST_RESULT); rm -f /tmp/.WHIP_CHECKLIST_RESULT
		fi
		G_WHIP_DESTROY
		return "${result:-1}"
	# Error handled command execution wrapper
	# IMPORTANT:
	# - Never pipe G_EXEC! "G_EXEC command | command" leads to G_EXEC not being able to unset G_EXEC_* variables and functions from originating shell or kill the originating script in case of error.
	# Required input:
	# - $@=<command>		| Command to execute
	# Optional input:
	# - $G_EXEC_DESC=<text>		| Command description to print instead of raw command string
	# - $G_EXEC_RETRIES=<int>	| Amount of non-interactive retries in case of error, before doing interactive error prompt
	# - G_EXEC_PRE_FUNC(){}		| Function to call before every input command attempt, e.g. to re-evaluate variables
	# - G_EXEC_POST_FUNC(){}	| Function to call after every input command attempt, e.g. to handle errors without error exit code
	# - $G_EXEC_OUTPUT=1		| Print full command output instead of animated processing message
	# - $G_EXEC_OUTPUT_COL='\e[90m'	| Override colour of command output via console colour code, requires $G_EXEC_OUTPUT=1
	# - $G_EXEC_NOFAIL=1		| On error, override as success, only useful to replace verbose output by animated processing message, inherits $G_EXEC_NOHALT=1 and $G_EXEC_NOEXIT=1
	# - $G_EXEC_NOHALT=1		| On error, print short error message only, skip error handler menu and do not exit script, inherits $G_EXEC_NOEXIT=1
	# - $G_EXEC_NOEXIT=1		| On error, do not exit script, inherited by $G_EXEC_NOHALT=1
	# - $G_EXEC_ARRAY_TEXT[]	| Add additional entries to error handler menu
	# - $G_ECEC_ARRAY_ACTION[]	| Associative array, containing uneven $G_EXEC_ARRAY_TEXT[] values as keys and related commands as values
	G_EXEC(){
		local exit_code fp_log='/tmp/G_EXEC_LOG' attempt=1 acommand=("$@") ecommand=${*//\\/\\\\}
		# Enter retry loop
		while :
		do
			declare -F G_EXEC_PRE_FUNC &> /dev/null && G_EXEC_PRE_FUNC
			# Execute command, store output to $fp_log file and store exit code to $exit_code variable
			# - Print full command output if $G_EXEC_OUTPUT=1 is given
			if [[ $G_EXEC_OUTPUT == 1 ]]; then
				# Print $G_EXEC_DESC if given, else raw input command string and show current non-interactive attempt count if $G_EXEC_RETRIES is given
				G_DIETPI-NOTIFY 2 "${G_EXEC_DESC:-$ecommand}, please wait...${G_EXEC_RETRIES:+ ($attempt/$((G_EXEC_RETRIES+1)))}"
				[[ $G_EXEC_OUTPUT_COL ]] && echo -ne "$G_EXEC_OUTPUT_COL"
				"${acommand[@]}" 2>&1 | tee $fp_log
				exit_code=${PIPESTATUS[0]}
				[[ $G_EXEC_OUTPUT_COL ]] && echo -ne '\e[0m'
			# - Else print animated processing message only
			else
				G_DIETPI-NOTIFY -2 "${G_EXEC_DESC:-$ecommand}${G_EXEC_RETRIES:+ ($attempt/$((G_EXEC_RETRIES+1)))}"
				"${acommand[@]}" &> $fp_log
				exit_code=$?
			fi
			declare -F G_EXEC_POST_FUNC &> /dev/null && G_EXEC_POST_FUNC
			# Override exit code if $G_EXEC_NOFAIL=1 is given
			[[ $G_EXEC_NOFAIL == 1 ]] && exit_code=0
			### Success: Print OK and exit retry loop
			[[ $exit_code == 0 ]] && { G_DIETPI-NOTIFY 0 "${G_EXEC_DESC:-$ecommand}"; break; }
			### Error
			# Retry non-interactively if current $attempt is <= $G_EXEC_RETRIES
			[[ $attempt -le $G_EXEC_RETRIES ]] && { ((attempt++)) && continue; }
			# Print FAILED, append raw command string if $G_EXEC_DESC is given
			G_DIETPI-NOTIFY 1 "${G_EXEC_DESC:+$G_EXEC_DESC\n - Command: }$ecommand"
			# Exit retry loop if $G_EXEC_NOHALT=1 is given
			[[ $G_EXEC_NOHALT == 1 ]] && break
			# Prepare error handler menu and GitHub issue template
			local fp_error_report='/tmp/G_EXEC_ERROR_REPORT' log_content=$(<$fp_log) image_creator preimage_name dietpi_version="v$G_DIETPI_VERSION_CORE.$G_DIETPI_VERSION_SUB.$G_DIETPI_VERSION_RC ($G_GITOWNER/$G_GITBRANCH)" last_whip_menu_item sent_bug_report
			if [[ -f '/boot/dietpi/.prep_info' ]]; then
				image_creator=$(mawk 'NR==1' /boot/dietpi/.prep_info)
				[[ $image_creator == 0 ]] && image_creator='DietPi Core Team'
				preimage_name=$(mawk 'NR==2' /boot/dietpi/.prep_info)
			fi
			# Create GitHub issue template if error was produced by one of our scripts
			[[ ${G_PROGRAM_NAME,,} == 'dietpi-'* ]] && echo -e "\e[41m
- DietPi has encountered an error                                   -
- Please create a ticket: https://github.com/MichaIng/DietPi/issues -
- Copy and paste only the BLUE lines below into the ticket          -
---------------------------------------------------------------------\e[44m
#### Details:
- Date           | $(date)
- DietPi version | $dietpi_version
- Image creator  | $image_creator
- Pre-image      | $preimage_name
- Hardware       | $G_HW_MODEL_NAME (ID=$G_HW_MODEL)
- Kernel version | \`$(uname -a)\`
- Distro         | $G_DISTRO_NAME (ID=$G_DISTRO${G_RASPBIAN:+,RASPBIAN=$G_RASPBIAN})
- Command        | \`$*\`
- Exit code      | $exit_code
- Software title | $G_PROGRAM_NAME
#### Steps to reproduce:
<!-- Explain how to reproduce the issue -->
1. ...
2. ...
#### Expected behaviour:
<!-- What SHOULD happen? -->
#### Actual behaviour:
<!-- What IS happening? -->
#### Extra details:
<!-- Please post any extra details that might help solve the issue -->
#### Additional logs:
$log_content
\`\`\`\e[41m
---------------------------------------------------------------------\e[0m" > $fp_error_report
			# Enter error handler menu loop in interactive mode
			[[ $G_INTERACTIVE == 1 ]] && while :
			do
				G_WHIP_MENU_ARRAY=('Retry' ': Re-run the last command that failed')
				# Add targeted solution suggestions, passed via $G_EXEC_ARRAY_TEXT[] and $G_EXEC_ARRAY_ACTION[${G_EXEC_ARRAY_TEXT[]}]
				[[ $G_EXEC_ARRAY_TEXT ]] && G_WHIP_MENU_ARRAY+=("${G_EXEC_ARRAY_TEXT[@]}")
				# Allow to open DietPi-Config if this error was not produced within DietPi-Config
				pgrep -cf 'dietpi-config' &> /dev/null || G_WHIP_MENU_ARRAY+=('DietPi-Config' ': Edit network, APT/NTP mirror settings etc')
				G_WHIP_MENU_ARRAY+=('Open subshell' ': Open a subshell to investigate or solve the issue')
				# Allow to send bug report, if it was produced by one of our scripts
				[[ ${G_PROGRAM_NAME,,} == 'dietpi-'* && $G_PROGRAM_NAME != 'DietPi-PREP' ]] && G_WHIP_MENU_ARRAY+=('Send report' ': Uploads bugreport containing system info to DietPi')
				G_WHIP_MENU_ARRAY+=('' '●─ Devs only ')
				G_WHIP_MENU_ARRAY+=('Change command' ': Adjust and rerun the command')
				# Show "Ignore" on cancel button if $G_EXEC_NOEXIT=1 is given, else "Exit"
				[[ $G_EXEC_NOEXIT == 1 ]] && G_WHIP_BUTTON_CANCEL_TEXT='Ignore' || G_WHIP_BUTTON_CANCEL_TEXT='Exit'
				G_WHIP_DEFAULT_ITEM=${last_whip_menu_item:-Retry}
				G_WHIP_MENU "${G_EXEC_DESC:+$(mawk '{gsub("\\\e[[0-9][;0-9]*m","");print}' <<< "$G_EXEC_DESC")\n} - Command: $*
 - Exit code: $exit_code
 - DietPi version: $dietpi_version | HW_MODEL: $G_HW_MODEL | HW_ARCH: $G_HW_ARCH | DISTRO: $G_DISTRO
${image_creator:+ - Image creator: $image_creator\n}${preimage_name:+ - Pre-image: $preimage_name\n} - Error log:
$log_content" || break # Exit error handler menu loop on cancel
				last_whip_menu_item=$G_WHIP_RETURNED_VALUE
				if [[ $G_WHIP_RETURNED_VALUE == 'Retry' ]]; then
					# Reset current $attempt and continue retry loop
					attempt=1
					continue 2
				elif [[ $G_WHIP_RETURNED_VALUE == 'DietPi-Config' ]]; then
					/boot/dietpi/dietpi-config
				elif [[ $G_WHIP_RETURNED_VALUE == 'Open subshell' ]]; then
					G_WHIP_MSG 'A bash subshell will now open which allows you to investigate and/or fix the issue.
\nPlease use the "exit" command when you are finished, to return to this error handler menu.'
					# Prevent dietpi-login call in subshell
					local reallow_dietpi_login=1
					[[ $G_DIETPI_LOGIN ]] && reallow_dietpi_login=0
					export G_DIETPI_LOGIN=1
					bash &> /dev/tty < /dev/tty
					(( $reallow_dietpi_login )) && unset -v G_DIETPI_LOGIN
				elif [[ $G_WHIP_RETURNED_VALUE == 'Send report' ]]; then
					/boot/dietpi/dietpi-bugreport 1 && sent_bug_report=1
					read -rp '
Press any key to continue...'
				elif [[ $G_WHIP_RETURNED_VALUE == 'Change command' ]]; then
					G_WHIP_DEFAULT_ITEM=$*
					if G_WHIP_INPUTBOX 'Please enter/alter the command to be executed.
\nNB: Please only use this solution if you know for sure that it will not cause follow up issues from the originating script. It will e.g. allow you to continue a certain software install, but if you edit the download link, the originating script might expect files which are not present.
\nUse this work caution!'; then
						G_DIETPI-NOTIFY 2 "Executing alternative command: ${G_WHIP_RETURNED_VALUE//\\/\\\\}"
						exit_code=$?
						G_DIETPI-NOTIFY -1 $exit_code 'Alternative command execution'
						# Exit retry loop if alternative command succeeded, else stay in menu loop and wait for key press to allow reviewing alternative command output
						[[ $exit_code == 0 ]] && break 2 || read -rp 'Press any key to return to error handler menu...'
					fi
				# Attempt targeted solution, passed via $G_EXEC_ARRAY_TEXT[] and $G_EXEC_ARRAY_ACTION[${G_EXEC_ARRAY_TEXT[]}]
				elif [[ $G_WHIP_RETURNED_VALUE ]]; then
					${G_EXEC_ARRAY_ACTION[$G_WHIP_RETURNED_VALUE]}
				fi
			done
			# Error has not been solved, print GitHub issue template if it was produced and exit error handler menu loop
			if [[ -f $fp_error_report ]]; then
				# Add bug report ID if it was sent
				[[ $sent_bug_report == 1 ]] && sed -i "/^- Date           | /a\- Bug report     | $G_HW_UUID" $fp_error_report
				cat $fp_error_report
			fi
			break
		done
		# Do not exit originating script if $G_EXEC_NOEXIT=1 or $G_EXEC_NOHALT=1 is given
		local noexit
		[[ $G_EXEC_NOEXIT == 1 || $G_EXEC_NOHALT == 1 ]] && noexit=1
		# Cleanup
		rm -f $fp_log $fp_error_report
		unset -v G_EXEC_DESC G_EXEC_RETRIES G_EXEC_OUTPUT G_EXEC_OUTPUT_COL G_EXEC_NOFAIL G_EXEC_NOHALT G_EXEC_NOEXIT G_EXEC_ARRAY_TEXT G_EXEC_ARRAY_ACTION
		unset -f G_EXEC_PRE_FUNC G_EXEC_POST_FUNC
		# In case of unresolved error when exiting originating script, inform user and kill via SIGINT to prevent exiting from interactive shell session
		[[ $exit_code == 0 || $noexit == 1 ]] || { G_DIETPI-NOTIFY 1 "Unable to continue, ${G_PROGRAM_NAME:-command} will now terminate."; kill -INT $$; }
		# Else return exit code
		return $exit_code
	# Multithreading handler
	# Not yet compatible with dietpi global commands. single bash commands only with no error handling.
	G_THREAD_START(){
		# Run in blocking mode
		if [[ $G_THREADING_ENABLED == 0 ]]; then
			G_DIETPI-NOTIFY 2 "G_THREADING disabled, running command in blocking mode | $*"
		# Launch as background process
		else
			[[ $G_THREAD_COUNT =~ ^[0-9]+$ ]] || G_THREAD_COUNT=-1
			((G_THREAD_COUNT++))
			G_THREAD_COMMAND[$G_THREAD_COUNT]=$* # Store for later output with G_THREAD_WAIT
			echo -1337 > "/tmp/.G_THREAD_EXITCODE_$G_THREAD_COUNT"
			{ { G_INTERACTIVE=0 "$@" &> "/tmp/.G_THREAD_COMMAND_$G_THREAD_COUNT"; echo $? > "/tmp/.G_THREAD_EXITCODE_$G_THREAD_COUNT"; } & disown; } &> /dev/null
			G_DIETPI-NOTIFY 2 "G_THREAD_START_$G_THREAD_COUNT | $*"
		fi
	G_THREAD_WAIT(){
		#local wait_for_specific_thread_pid=-1
		#[[ $1 ]] && wait_for_specific_thread_pid=$1
		local i waiting_for exit_code
		# Wait until all threads finished
		while :
		do
			for i in "${!G_THREAD_COMMAND[@]}"
			do
				[[ -f /tmp/.G_THREAD_EXITCODE_$i && $(<"/tmp/.G_THREAD_EXITCODE_$i") == '-1337' ]] || continue
				# Print what we are waiting for, update processing message if thread changed since last loop
				[[ $waiting_for == "$i" ]] || G_DIETPI-NOTIFY -2 "G_THREAD_WAIT_$i | ${G_THREAD_COMMAND[$i]}"
				waiting_for=$i
				sleep 1
				continue 2
			done
			break
		done
		G_DIETPI-NOTIFY 0 'G_THREAD: All threads finished'
		# Check all thread's exit codes for issues
		do
			if [[ -r /tmp/.G_THREAD_EXITCODE_$i ]]; then
				exit_code=$(<"/tmp/.G_THREAD_EXITCODE_$i")
				(( $exit_code )) && G_WHIP_MSG "G_THREAD ERROR:\n - Command = ${G_THREAD_COMMAND[$i]}\n - Exit code = $exit_code\n\n$(<"/tmp/.G_THREAD_COMMAND_$i")"
			else
				G_DIETPI-NOTIFY 2 "DEBUG: /tmp/.G_THREAD_EXITCODE_$i does not exist or is not readable"
			fi
		done
		rm -f /tmp/.G_THREAD*
		unset -v G_THREAD_COUNT G_THREAD_COMMAND
	# Network connection checks
	# General network connection check
	# - Checks general network connectivity by pinging a raw IP that must be publicly reachable at all time.
	# - Uses the given input argument as IP to test against, else CONFIG_CHECK_CONNECTION_IP from dietpi.txt, else defaults to 9.9.9.9 (Quad9 DNS IP).
	# - Uses G_CHECK_URL_TIMEOUT and G_CHECK_URL_ATTEMPTS variables, else CONFIG_G_CHECK_URL_TIMEOUT + CONFIG_G_CHECK_URL_ATTEMPTS from dietpi.txt, else defaults to 10 seconds and 2 attempts (1 retry).
	# - Optional arguments:
	#	$* = IP + optional ping arguments
	# - Optional variables:
	#	G_CHECK_URL_TIMEOUT to override default and dietpi.txt set timeout
	#	G_CHECK_URL_ATTEMPTS to override default and dietpi.txt set attempts
	G_CHECK_CON(){
		# Obtain IP
		local ip
		if [[ ! $* ]]; then
			ip=$(sed -n '/^[[:blank:]]*CONFIG_CHECK_CONNECTION_IP=/{s/^[^=]*=//p;q}' /boot/dietpi.txt)
			[[ $ip ]] || ip='9.9.9.9'
		fi
		# Obtain timeout
		if ! disable_error=1 G_CHECK_VALIDINT "$G_CHECK_URL_TIMEOUT" 0; then
			G_CHECK_URL_TIMEOUT=$(sed -n '/^[[:blank:]]*CONFIG_G_CHECK_URL_TIMEOUT=/{s/^[^=]*=//p;q}' /boot/dietpi.txt)
			disable_error=1 G_CHECK_VALIDINT "$G_CHECK_URL_TIMEOUT" 0 || G_CHECK_URL_TIMEOUT=10
		fi
		# Obtain attempts
		if ! disable_error=1 G_CHECK_VALIDINT "$G_CHECK_URL_ATTEMPTS" 1; then
			G_CHECK_URL_ATTEMPTS=$(sed -n '/^[[:blank:]]*CONFIG_G_CHECK_URL_ATTEMPTS=/{s/^[^=]*=//p;q}' /boot/dietpi.txt)
			disable_error=1 G_CHECK_VALIDINT "$G_CHECK_URL_ATTEMPTS" 1 || G_CHECK_URL_ATTEMPTS=2
		fi
		G_EXEC_RETRIES=$(( $G_CHECK_URL_ATTEMPTS - 1 )) # 2 attempts = 1 retry
		# Re-assign timeout ($5 => acommand[4]) on every retry, in case it is changed as solution attempt
		declare -F G_EXEC_PRE_FUNC &> /dev/null && eval "G_EXEC_PRE_FUNC_ORIG()$(declare -f G_EXEC_PRE_FUNC | tail -n +2)"
		G_EXEC_PRE_FUNC(){ acommand[4]=$G_CHECK_URL_TIMEOUT; declare -F G_EXEC_PRE_FUNC_ORIG &> /dev/null && G_EXEC_PRE_FUNC_ORIG; }
		G_EXEC_DESC='Checking network connectivity' G_EXEC ping -nc 1 -W $G_CHECK_URL_TIMEOUT ${ip:-"$@"}
		local exit_code=$?
		unset -v G_CHECK_URL_TIMEOUT G_CHECK_URL_ATTEMPTS
		unset -f G_EXEC_PRE_FUNC_ORIG
		return $exit_code
	# General DNS resolver check
	# - Checks general DNS capabilities by pinging a domain that must be publicly reachable at all time.
	# - Uses the given input argument as domain to test against, else CONFIG_CHECK_DNS_DOMAIN from dietpi.txt, else defaults to dns9.quad9.net (Quad9 DNS domain).
	#	$* = domain + optional ping arguments
	G_CHECK_DNS(){
		# Obtain IP
		local domain
		if [[ ! $* ]]; then
			domain=$(sed -n '/^[[:blank:]]*CONFIG_CHECK_DNS_DOMAIN=/{s/^[^=]*=//p;q}' /boot/dietpi.txt)
			[[ $domain ]] || domain='dns9.quad9.net'
		fi
		# Obtain timeout
		fi
		# Obtain attempts
		fi
		G_EXEC_DESC='Checking DNS resolver' G_EXEC ping -nc 1 -W $G_CHECK_URL_TIMEOUT ${domain:-"$@"}
		local exit_code=$?
		return $exit_code
	# URL connection test
	# - Checks a specific HTTP/HTTPS/FTP online resource via its URL
	# - Required arguments:
	#	$* = URL + optional curl arguments
	G_CHECK_URL(){
		# Obtain timeout
		fi
		# Obtain attempts
		fi
		# Re-assign timeout ($3 => acommand[2]) on every retry, in case it is changed as solution attempt
		G_EXEC_PRE_FUNC(){ acommand[2]=$G_CHECK_URL_TIMEOUT; declare -F G_EXEC_PRE_FUNC_ORIG &> /dev/null && G_EXEC_PRE_FUNC_ORIG; }
		# "--retry" only applies on "a timeout, an FTP 4xx response code or an HTTP 5xx response code", hence we loop ourself.
		G_EXEC_DESC="Checking URL: $*" G_EXEC curl -ILfvm $G_CHECK_URL_TIMEOUT "$@"
		local exit_code=$?
		return $exit_code
	# Print network details
	# Commands:
	#	"gateway": Print the default gateway IP
	#	"iface": Print the interface name
	#	"ip": Print the IP address
	# Options:
	#	"-q": Hide all error messages that are not related to invalid arguments
	#	"-4": Print info for interfaces with an IPv4 address only if available, else return 1
	#	"-6": Print info for interfaces with an IPv6 address only if available, else return 1
	#	"-t TYPE": Print info for interfaces of type TYPE only if available, else return 1
	#		TYPE can be one of "eth" and "wlan".
	#	"-i IFACE": Print info for the network interface named IFACE only it present, else return 1
	# Notes:
	#	Info is shown for the one matching interface, following the following priorities:
	#	- 1. the interface which has the default gateway assigned
	#	- 2. the first interface with state "UP"
	#	- 3. the first interface with an IP address assigned
	#	- 4. the first available interface
	#	- If no interface exists, the function returns error 1.
	#	If not defined, IPv4 addresses are shown if available, else IPv6 addresses if available.
	G_GET_NET()
		# Grab input
		local quite=0 fam type iface command
		while (( $# ))
		do
			case "$1" in
				'-q') quite=1;;
				'-'[46]) fam=$1;;
				'-t') shift; type=$1;;
				'-i') shift; iface=$1;;
				'gateway'|'iface'|'ip') command=$1;;
				*) G_DIETPI-NOTIFY 1 "An invalid argument \"${1:-<empty>}\" was given."; return 1;;
			esac
			shift
		done
		# A command is required
		[[ $command ]] || { G_DIETPI-NOTIFY 1 "No command was given."; return 1; }
		# Early return if given interface does not exists or does not match given type
		if [[ $iface ]]
		then
			if [[ ! -e /sys/class/net/$iface ]]
			then
				(( $quite )) || G_DIETPI-NOTIFY 1 "The given interface \"$iface\" does not exist."
				return 1
			elif [[ $type && $iface != $type* ]]
			then
				(( $quite )) || G_DIETPI-NOTIFY 1 "The given interface \"$iface\" is not of type \"$type\"."
				return 1
			fi
		fi
		# Get default gateway if requested or no interface given
		local ip if
		if [[ $command == 'gateway' || ! $iface ]]
		then
			local gateway
			[[ $fam != '-6' ]] && read -r gateway if < <(ip r l 0/0 ${iface:+dev "$iface"} | mawk '{print $3,$5;exit}')
			[[ ! $gateway && $fam != '-4' ]] && read -r gateway if < <(ip -6 r l ::/0 ${iface:+dev "$iface"} | mawk '{print $3,$5;exit}')
			# ip r does not print the interface name if one was given, so used the given one to check for type.
			[[ $iface ]] && if=$iface
			# Print default gateway if requested
			if [[ $command == 'gateway' ]]
			then
				if [[ $gateway ]]
				then
					# Check for interface type
					if [[ $type && $if != $type* ]]
					then
						(( $quite )) || G_DIETPI-NOTIFY 1 "The default gateway is not assigned to any interface of type \"$type\"."
						return 1
					fi
					echo "$gateway"
				else
					(( $quite )) || G_DIETPI-NOTIFY 1 "A default gateway${fam:+ for IPv${fam#-}}${iface:+ on interface \"$iface\"} does not exist."
					return 1
				fi
				return 0
			fi
			# Print interface/IP address if matching default gateway was found
			if [[ $gateway && ( ! $type || $if == $type* ) ]]
			then
				iface=$if
				# shellcheck disable=SC2086
				[[ $command == 'ip' ]] && ip=$(ip -br $fam a s dev "$iface" | mawk '{print $3;exit}') ip=${ip%/*}
				echo "${!command}"
				return 0
			fi
		fi
		local state if_final ip_final
		while read -r if state ip
		do
			[[ $if == 'lo' ]] && continue
			[[ $type && $if != $type* ]] && continue
			# Cut off secondary IP addresses and CIDR mask
			ip=${ip%%/*}
			# Return state UP
			if [[ $state == 'UP' ]]
			then
				iface=$if
				echo "${!command}"
				return 0
			fi
			# Store info in separate variables to return if no UP state interface was found
			if [[ $ip && ! $ip_final ]]
			then
				if_final=$if
				ip_final=$ip
			elif [[ ! $if_final ]]
			then
				if_final=$if
			fi
		done < <(ip -br $fam a ${iface:+s dev "$iface"})
		# Return final values
		iface=$if_final
		ip=$ip_final
		if [[ $command == 'ip' && ! $ip ]]
		then
			(( $quite )) || G_DIETPI-NOTIFY 1 "An interface${iface:+ named \"$iface\"}${type:+ of type \"$type\"} with an IP${fam:+v${fam#-}} address does not exist."
			return 1
		elif [[ $command == 'iface' && ! $iface ]]
		then
			(( $quite )) || G_DIETPI-NOTIFY 1 "An interface${iface:+ named \"$iface\"}${type:+ of type \"$type\"}${fam:+ with an IPv${fam#-} address} does not exist."
			return 1
		fi
		echo "${!command}"
		return 0
	# Print public IP address and location info
	#	-t <timeout>: Set timeout in seconds, supports floats, default: 3
	G_GET_WAN_IP()
		# Defaults
		local timeout=3
		# Inputs
		while (( $# ))
		do
			case $1 in
				'-t') shift; (( ${1/.} )) && timeout=$1 || { G_DIETPI-NOTIFY 1 "Invalid timeout \"$1\", aborting..."; return 1; };;
				*) G_DIETPI-NOTIFY 1 "Invalid argument \"$1\", aborting..."; return 1;;
			esac
			shift
		done
		curl -sSfLm "$timeout" 'https://dietpi.com/geoip'
	# $1 = directory to test permissions support
	# Returns 0=ok >=1=failed
	G_CHECK_FS_PERMISSION_SUPPORT(){
		local input=$1 exit_code=1
		while :
		do
			if ! mkdir -p "$input"; then
				G_WHIP_MSG "Error creating directory $input, unable to check filesystem permissions"
				break
			fi
			local fp_target="$input/.test"
			if ! > "$fp_target"; then
				G_WHIP_MSG "Error creating test file $fp_target, unable to check filesystem permissions"
				break
			fi
			# Apply and check permissions support, twice (just in case the current value is already set)
			local permissions_failed=0
			chmod 600 "$fp_target"
			if [[ $(stat -c "%a" "$fp_target") != '600' ]]; then
				permissions_failed=1
			else
				chmod 644 "$fp_target"
				[[ $(stat -c "%a" "$fp_target") != '644' ]] && permissions_failed=1
			fi
			if (( $permissions_failed )); then
				G_WHIP_MSG "ERROR: Filesystem does not support permissions (e.g.: FAT16/32):\n\n$fp_target\n\nPlease select a different drive and/or format it with ext4, ensuring support for filesystem permissions.\n\nUnable to continue, aborting..."
				break
			fi
			# Else ok
			exit_code=0
			break
		done
		[[ -f $fp_target ]] && rm -f "$fp_target"
		return $exit_code
	# APT: Non-interactive and error-handled wrappers for apt-get commands
	# Check for missing kernel modules, e.g. after a kernel upgrade, and in case create a flag
	G_CHECK_KERNEL()
		[[ -d /lib/modules/$(uname -r) ]] || systemd-detect-virt -c > /dev/null || return 1
		return 0
	# apt-get install
	G_AGI(){
		# Return if no argument given
		(( $# )) || { G_DIETPI-NOTIFY 2 'No input package given. Aborting...'; return 0; }
		G_CHECK_ROOT_USER 1
		G_EXEC_DESC="\e[0mAPT install for: \e[33m$*\e[0m"
		DEBIAN_FRONTEND=noninteractive G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -qq --allow-change-held-packages install "$@"
		return $?
	# apt-get purge
	G_AGP(){
		G_CHECK_ROOT_USER 1
		# Attempt to purge only installed packages, check on every G_EXEC loop, force succeed if none were found, to avoid related apt-get error
		G_EXEC_PRE_FUNC(){
			local apackages=()
			mapfile -t apackages < <(dpkg --get-selections "${acommand[@]:4}" 2> /dev/null | mawk '{print $1}')
			[[ ${apackages[0]} ]] && acommand=("${acommand[@]::4}" "${apackages[@]}") || acommand=(G_DIETPI-NOTIFY 2 'None of the requested packages are currently installed. Aborting...')
		G_EXEC_DESC="\e[0mAPT purge for: \e[33m$*\e[0m"
		DEBIAN_FRONTEND=noninteractive G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -qq --allow-change-held-packages autopurge "$@"
		local exit_code=$?
		return $exit_code
	# apt-get autopurge
	G_AGA(){
		G_CHECK_ROOT_USER 1
		G_EXEC_DESC='\e[0mAPT autopurge'
		DEBIAN_FRONTEND=noninteractive G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -qq autopurge
		return $?
	# apt-get -f install
	G_AGF(){
		G_CHECK_ROOT_USER 1
		G_EXEC_DESC='\e[0mAPT fix'
		DEBIAN_FRONTEND=noninteractive G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -qq --allow-change-held-packages -f install
		return $?
	# apt-get clean + update
	# - $1 = -f: Store number of available APT upgrades to file, which defaults to: /run/dietpi/.apt_updates
	#	$2 = Optional file path to store number of available APT upgrades to
	# - $1 = -v: Store number of available APT upgrades to variable, which defaults to: G_AGUP_COUNT
	#	$2 = Optional variable name to store number of available APT upgrades to
	# shellcheck disable=SC2120
	G_AGUP(){
		G_CHECK_ROOT_USER 1
		# Clean cache before every update, which can corrupt and gets fully rewritten anyway
		G_EXEC_PRE_FUNC(){ apt-get clean; declare -F G_EXEC_PRE_FUNC_ORIG &> /dev/null && G_EXEC_PRE_FUNC_ORIG; }
		# Fail when some index files couldn't be downloaded, e.g. due to DNS failure. Currently apt-get update prints a warning but does not return an error code.
		declare -F G_EXEC_POST_FUNC &> /dev/null && eval "G_EXEC_POST_FUNC_ORIG()$(declare -f G_EXEC_POST_FUNC | tail -n +2)"
		G_EXEC_POST_FUNC(){ [[ $exit_code == 0 && $(<$fp_log) == *'W: Some index files failed to download.'* ]] && exit_code=255; declare -F G_EXEC_POST_FUNC_ORIG &> /dev/null && G_EXEC_POST_FUNC_ORIG; }
		G_EXEC_DESC='\e[0mAPT update'
		G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -q update
		local exit_code=$?
		unset -f G_EXEC_{PRE,POST}_FUNC_ORIG
		if [[ $1 == '-'[fv] ]]
		then
			local count=0
			(( $exit_code )) || count=$(apt -qq list --upgradeable 2> /dev/null | wc -l) # Mute "apt" CLI warning
			if [[ $1 == '-f' ]]
			then
				local file=${2:-/run/dietpi/.apt_updates}
				if (( $count ))
				then
					G_DIETPI-NOTIFY 2 "Storing number of available APT upgrades to file: $file"
					echo "$count" > "$file"
				else
					G_DIETPI-NOTIFY 2 "No APT upgrades were found, not creating file: $file"
					[[ -f $file ]] && rm "$file"
				fi
			elif [[ $1 == '-v' ]]
			then
				local var=${2:-G_AGUP_COUNT}
				if (( $count ))
				then
					G_DIETPI-NOTIFY 2 "Storing number of available APT upgrades to variable: $var"
					declare -g "$var=$count"
				else
					G_DIETPI-NOTIFY 2 "No APT upgrades were found, not creating variable: $var"
					unset -v "$var"
				fi
			fi
		fi
		return $exit_code
	# apt-get upgrade
	G_AGUG(){
		G_CHECK_ROOT_USER 1
		G_EXEC_DESC='\e[0mAPT upgrade'
		DEBIAN_FRONTEND=noninteractive G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -qq upgrade
		return $?
	# apt-get dist-upgrade
	G_AGDUG(){
		G_CHECK_ROOT_USER 1
		G_EXEC_DESC='\e[0mAPT dist-upgrade'
		DEBIAN_FRONTEND=noninteractive G_EXEC_OUTPUT=1 G_EXEC_OUTPUT_COL='\e[90m' G_EXEC apt-get -qq --allow-change-held-packages dist-upgrade
		return $?
	# Checks for required APT packages, installs if needed.
	# $@ = list of required packages
	#	NB: automatically error handled (G_EXEC)
	G_AG_CHECK_INSTALL_PREREQ(){
		(( $# )) || return 0
		G_DIETPI-NOTIFY 2 "Checking for required APT packages: \e[33m$*"
		G_CHECK_ROOT_USER 1
		local i apackages=()
		for i in "$@"
		do
			dpkg-query -s "$i" &> /dev/null && continue
			apackages+=("$i")
		done
		[[ ${apackages[0]} ]] || return 0
		G_AGUP
		G_AGI "${apackages[@]}"
		exit_code=$?
		return $?
	# MISC: Commands
	# Treesize
	# - $1 = Optional input directory, e.g.: G_TREESIZE /var/cache/apt
	G_TREESIZE(){
		du -B 1 -d 1 ${1:+"$1"} | sort -nr | mawk '
		BEGIN { split("bytes,KiB,MiB,GiB,TiB", unit, ",") }
			u=1
			while ($1>=1024) { $1=$1/1024; u+=1 }
			$1=sprintf("%.1f %s", $1, unit[u])
			print $0
	# Returns current CPU temp 'C
	# - print_full_info=1	Optional input to print full colour text output and temp warnings
	G_OBTAIN_CPU_TEMP()
		# Read CPU temp from file
		local temp
		# - Odroid N2/ASUS/Sparky: Requires special case as in other array this would break SBC temp readouts with 2 zones
		if [[ ( $G_HW_MODEL == 15 || $G_HW_MODEL == 52 || $G_HW_MODEL == 70 ) && -f '/sys/class/thermal/thermal_zone1/temp' ]]
		then
			temp=$(</sys/class/thermal/thermal_zone1/temp)
		# - Others
		else
			# Array to store possible locations for temp read
			local i afp_temperature=(
				'/sys/devices/platform/coretemp.*/hwmon/hwmon*/temp*_input' # Intel Mini PCs: https://github.com/MichaIng/DietPi/issues/3172, https://github.com/MichaIng/DietPi/issues/3412
				'/sys/class/thermal/thermal_zone0/temp'
				'/sys/devices/platform/sunxi-i2c.0/i2c-0/0-0034/temp1_input'
				'/sys/class/hwmon/hwmon0/device/temp_label'
				'/sys/class/hwmon/hwmon0/temp2_input'
				'/sys/class/hwmon/hwmon0/temp1_input' # Odroid C1 Armbian legacy Linux 5.4.40: https://dietpi.com/phpbb/viewtopic.php?p=24860#p24860
				'/sys/class/thermal/thermal_zone1/temp' # Roseapple Pi, probably OrangePi's: https://dietpi.com/phpbb/viewtopic.php?t=8677
			# Coders NB: Do NOT quote the array to allow coretemp file paths glob expansion!
			# shellcheck disable=SC2068
			for i in ${afp_temperature[@]}
			do
				[[ -f $i ]] || continue
				temp=$(<"$i")
				[[ $temp -gt 0 ]] && break # Trust only positive temperatures for now (strings are treated as "0")
			done
		fi
		# Format output
		# - Check for valid value: We must always return a value, due to VM lacking this feature + benchmark online
		if [[ $temp -lt 1 ]]
		then
			temp='N/A'
		else
			# 2/5 digit output?
			(( $temp >= 200 )) && temp=$(( $temp / 1000 ))
			if [[ $print_full_info == 1 ]]
			then
				local temp_f=$(( $temp * 9/5 + 32 ))
				if (( $temp >= 70 ))
				then
					temp="\e[1;31mWARNING: $temp °C / $temp_f °F : Reducing the life of your device\e[0m"
				elif (( $temp >= 60 ))
				then
					temp="\e[38;5;202m$temp °C / $temp_f °F \e[90m: Running hot, not recommended\e[0m"
				elif (( $temp >= 50 ))
				then
					temp="\e[1;33m$temp °C / $temp_f °F \e[90m: Running warm, but safe\e[0m"
				elif (( $temp >= 40 ))
				then
					temp="\e[1;32m$temp °C / $temp_f °F \e[90m: Optimal temperature\e[0m"
				elif (( $temp >= 30 ))
				then
					temp="\e[1;36m$temp °C / $temp_f °F \e[90m: Cool runnings\e[0m"
				else
					temp="\e[1;36m$temp °C / $temp_f °F \e[90m: Who put me in the freezer!\e[0m"
				fi
			fi
		fi
		echo -e "$temp"
	# Returns current CPU usage in %
	G_OBTAIN_CPU_USAGE(){
		local usage=0
		# ps: inaccurate but fast
		while read -r line # Aside reading raw, -r removes leading and trailing white spaces each line
		do
			line=${line/.} # Remove decimal dot
			((usage+=${line#0})) # Remove leading zero, if present, then sum up
		done < <(ps --no-headers -eo %cpu) # Single core usage in xy.z
		# ps returns single core usage, so we divide by core count
		usage=$(printf '%.1f' "$(($usage*10/$G_HW_CPU_CORES+1))e-2") # Divide by 10 to compensate decimal dot removal, re-add decimal dot via printf conversion but assure last digit is rounded correctly
		echo "$usage"
	# Check available free space on path, against input value (MiB)
	# - Returns 0=Ok, 1=insufficient space available
	#	If $2 is not used, returns available space in MiB | info_autoscale=1 # Scales MiB to GiB if required and prints unit
	# - $1 = path
	# - $2 = Optional, free space (MiB)
	#	EG: if (( $(G_CHECK_FREESPACE /path 100) )); then
	G_CHECK_FREESPACE(){
		local info_autoscale=${info_autoscale:-0}
		local input_path=$1
		local input_required_space=$2
		local available_space=$(df -m --output=avail "$input_path" | mawk 'NR==2 {print $1}')
		if ! disable_error=1 G_CHECK_VALIDINT "$available_space"; then
			G_WHIP_MSG 'G_CHECK_FREESPACE: Invalid integer from df result'
		elif [[ ! $input_required_space ]]; then
			(( $info_autoscale )) && { (( $available_space > 9999 )) && available_space="$(( $available_space / 1024 )) GiB" || available_space+=' MiB'; }
			echo "$available_space"
			return_value=0
		else
			(( $available_space > $input_required_space )) && return_value=0
			G_DIETPI-NOTIFY $return_value "Free space check: path=$input_path | available=$available_space MiB | required=$input_required_space MiB"
		fi
	# G_CHECK_VALIDINT | Simple test to verify if a variable is a valid integer.
	# $1=input
	# $2=Optional Min value range
	# $3=Optional Max value range
	#	disable_error=1 to disable notify/whiptail invalid value when received
	# 1=no | scripts killed automatically
	# 0=yes
	# Usage = if G_CHECK_VALIDINT input; then
	G_CHECK_VALIDINT(){
		local input=$1 min=$2 max=$3 return_value=1
		if [[ $input =~ ^-?[0-9]+$ ]]; then
			if [[ $min =~ ^-?[0-9]+$ ]]; then
				if (( $input >= $min )); then
					if [[ $max =~ ^-?[0-9]+$ ]]; then
						if (( $input <= $max )); then
							return_value=0
						elif [[ $disable_error != 1 ]]; then
							G_WHIP_MSG "Input value \"$input\" is higher than allowed \"$max\". No changes applied."
						fi
					else
						return_value=0
					fi
					G_WHIP_MSG "Input value \"$input\" is lower than allowed \"$min\". No changes applied."
				fi
			else
				return_value=0
			fi
			G_WHIP_MSG "Invalid input value \"$input\". No changes applied."
		fi
		unset -v disable_error
	# Verifies the integrity of the DietPi userdata folder/symlink, based on where it should be physically. Basically, checks if user removed the USB drive with userdata on it.
	#	NB: As this is considered a critical (if failed), current scripts will be exited automatically
	# 1=fail
	# 0=ok
	G_CHECK_USERDATA(){
		local return_value=0 fp_actual='/mnt/dietpi_userdata'
		# Symlinked?
		if [[ -L '/mnt/dietpi_userdata' ]]
		then
			# Check physical location exists (is mounted)
			fp_actual=$(readlink -f /mnt/dietpi_userdata)
			[[ -d $fp_actual ]] || return_value=1
		fi
		G_DIETPI-NOTIFY $return_value "DietPi-Userdata validation: $fp_actual"
		(( $return_value )) || return 0
		G_WHIP_MSG "[FAILED] DietPi-Userdata validation\n\nDietPi was unable to verify the existence of the userdata directory ($fp_actual).\n\nPlease ensure all previous external drives are connected and functional, before trying again.\n\nUnable to continue, exiting."
		kill -INT $$ # kill all current scripts, excluding shell
	# Prompt user to create a backup before system changes. Exit existing scripts if failed.
	G_PROMPT_BACKUP(){
		[[ $G_PROMPT_BACKUP_DISABLED == 1 ]] && return 0
		G_WHIP_YESNO 'Would you like to create (or update) a "DietPi-Backup" of the system, before proceeding?\n\n"DietPi-Backup" creates a system restore point, which can be recovered if unexpected issues occur.\n\nFor more information on "DietPi-Backup", please use the link below:\n - https://dietpi.com/docs/dietpi_tools/#dietpi-backup-backuprestore' || return 0
		/boot/dietpi/dietpi-backup 1
		local exit_code=$?
		G_DIETPI-NOTIFY -1 $exit_code 'DietPi-Backup'
		(( $exit_code )) || return 0
		# Kill current scripts, excluding shell
		G_WHIP_MSG '[FAILED] DietPi-Backup was unable to complete sucessfully.\n\nTo avoid issues, the current program will now be terminated.\n\nLog file: /var/log/dietpi-backup.log'
		kill -INT $$
		return 1
	# If file/folder exists, backup to *.bak_DDMMYYY
	G_BACKUP_FP(){
		local ainput_string=("$@")
		local fp_db_log='/var/tmp/dietpi/logs/G_BACKUP_FP.db'
		local print_fp_db_info=0
		local i
		for i in "${ainput_string[@]}"
		do
			[[ -e $i ]] || continue
			local fp_backup_target="$i.bak_$(date +%d%m%y)"
			local index=0
			while [[ -e ${fp_backup_target}_$index ]]
			do
				((index++))
			done
			local notify_code=1
			if cp -a "$i" "${fp_backup_target}_$index"; then
				notify_code=0
				print_fp_db_info=1
				echo "${fp_backup_target}_$index # $G_PROGRAM_NAME" >> $fp_db_log
			fi
			G_DIETPI-NOTIFY $notify_code "$i: backup to ${fp_backup_target}_$index"
		done
		(( $print_fp_db_info )) && G_DIETPI-NOTIFY 2 "For a full list of backup items, please see $fp_db_log"
	# Apply and update to different branch
	G_DEV_BRANCH(){
		G_CHECK_ROOT_USER 1
		G_CONFIG_INJECT 'DEV_GITBRANCH=' "DEV_GITBRANCH=$1" /boot/dietpi.txt
		/boot/dietpi/dietpi-update -1
	# Inject setting into config file: First tries to replace old setting, else commented setting and otherwise adds to end of file.
	# Usage:
	# - $1 Setting pattern to find existing setting with grep extended regular expression support
	# - $2 Target setting + value, to inject into config file: After bash string expansion (e.g. variables), everything else will be taken literally, thus no further escaping is required.
	# - $3 Path to config file
	# - $4 (optional) Line pattern after which the setting will be added instead of end of file with grep extended regular expression support
	# - GCI_PASSWORD=1 G_CONFIG_INJECT, password entry, do not print raw output to screen.
	# - GCI_PRESERVE=1 G_CONFIG_INJECT preserves current setting, if present.
	# - GCI_BACKUP=1 G_CONFIG_INJECT creates a backup before editing the file, if backup does not yet exist, to: $3.bak
	# - GCI_NEWLINE=1 G_CONFIG_INJECT explicitly expands newlines \n within $2, which by default are taken literally
	#	NB: Be careful with this, since pattern matching is only done per line which can lead to doubled lines when applying G_CONFIG_INJECT a second time.
	# NB:
	# - Within double quotes "", as usual, escape literally meant double quotes and dollar signs $ with leading backslash \.
	# - Within single quotes '', as usual, escape literally meant single quotes via: '\'' # End leading string; Add escaped single quote; Start trailing string
	# - Additionally in case of extended regular expression support ($1 and $4), the following characters need to be escaped via backslash \, if wanted literally:
	# Example:
	# - G_CONFIG_INJECT 'prefer-family[[:blank:]=]' 'prefer-family = IPv4' /etc/wgetrc
	G_CONFIG_INJECT(){
		[[ $G_PROGRAM_NAME ]] || local G_PROGRAM_NAME='G_CONFIG_INJECT'
		local pattern=${1//\//\\\/}
		local setting_raw=$2
		local setting=${2//\\/\\\\}; setting=${setting//./\\.}; setting=${setting//+/\\+}; setting=${setting//\*/\\\*}; setting=${setting//\?/\\\?}; setting=${setting//[/\\[}
		setting=${setting//\(/\\\(}; setting=${setting//\{/\\\{}; setting=${setting//^/\\^}; setting=${setting//&/\\&}; setting=${setting//$/\\$}; setting=${setting//|/\\|}; setting=${setting//\//\\\/}
		[[ $GCI_NEWLINE == 1 ]] && setting=${setting//\\\\n/\\n}
		local file=$3
		local after=${4//\//\\\/}
		local error
		# Colouring output
		local yellow reset
		[[ -t 0 || -t 1 ]] && yellow='\e[33m' reset='\e[0m'
		# Replace password string by asterisks in output string
		if [[ $GCI_PASSWORD == 1 ]]; then
			local password=$(sed -E "s/^.*${pattern}[[:blank:]]*//" <<< "$setting_raw")
			setting_raw="$(sed -E "s/(^.*${pattern}[[:blank:]]*).*$/\1/" <<< "$setting_raw")${password//?/*}"
			unset -v password
		fi
		syntax_error(){
			[[ $after ]] && after="after line \$4\n	$after (raw escaped input)\n"
			[[ $error ]] && error="\n\"grep\" or \"sed\" reported the following error:\n	$error\n"
			G_WHIP_MSG "[FAILED] Syntax error
$error
Couldn't add setting \$2
	$setting (escaped input)
into file \$3
	$file
$after
NB:
 - Within double quotes \"\", as usual, escape literally meant double quotes and dollar signs \$ via:
 	\\\" respectively \\\$
 	'\'' # <End leading string>; <Add escaped single quote>; <Start trailing string>
 - Additionally in case of extended regular expression support (\$1 and \$4), the following characters need to be escaped via backslash \, if wanted literally:
 - Do not escape forward slashes /, which will be done internally for all arguments!"
			unset -v syntax_error
		if [[ ! -w $file ]]; then
			G_WHIP_MSG "[FAILED] File does not exist or cannot be written to by current user
\nPlease verify the existence of the file \$3
	$file
\nRetry with proper permissions or apply the setting manually:
	$setting_raw"
		elif error=$(grep -Eq "^[[:blank:]]*$pattern" "$file" 2>&1); then
			# As an error within the condition leads to result "false", it can be caught only in next "elif"/"else" statement.
			if [[ $GCI_PRESERVE == 1 ]]; then
				G_DIETPI-NOTIFY 0 "Current setting in $yellow$file$reset will be preserved: $yellow$([[ $GCI_PASSWORD == 1 ]] && echo "${setting_raw//\\/\\\\}" || grep -Em1 "^[[:blank:]]*$pattern" "$file" | sed 's|\\|\\\\|g')$reset"
			elif error=$(grep -Eq "^[[:blank:]]*$setting([[:space:]]|$)" "$file" 2>&1); then
				G_DIETPI-NOTIFY 0 "Desired setting in $yellow$file$reset was already set: $yellow$([[ $GCI_PASSWORD == 1 ]] && echo "${setting_raw//\\/\\\\}" || grep -Em1 "^[[:blank:]]*$pattern" "$file" | sed 's|\\|\\\\|g')$reset"
			elif error=$( (( $(grep -Ec "^[[:blank:]]*$pattern" "$file" 2>&1) > 1 )) 2>&1); then
				[[ $error ]] && { syntax_error; return 1; }
				G_WHIP_MSG "[FAILED] Setting was found multiple times
\nThe pattern \$1
	$(sed -E "c\\$pattern" <<< '')
was found multiple times in file \$3
	$file
\n____________
$(grep -En "^[[:blank:]]*$pattern" "$file")
____________
\nEither the pattern \$1 needs to be more specific or the desired setting can appear multiple times by design and it cannot be predicted which instance to edit.
Please retry with more specific parameter \$1 or apply the setting manually:
	$setting_raw"
			else
				[[ $GCI_BACKUP == 1 && ! -f $file.bak ]] && cp -a "$file" "$file.bak" && G_DIETPI-NOTIFY 2 "Config file backup created: $yellow$file.bak$reset"
				error=$(sed -Ei "0,/^[[:blank:]]*$pattern.*$/s//$setting/" "$file" 2>&1) || { syntax_error; return 1; }
				G_DIETPI-NOTIFY 0 "Setting in $yellow$file$reset adjusted: $yellow${setting_raw//\\/\\\\}$reset"
			fi
		elif error=$(grep -Eq "^[[:blank:]#;]*$pattern" "$file" 2>&1); then
			error=$(sed -Ei "0,/^[[:blank:]#;]*$pattern.*$/s//$setting/" "$file" 2>&1) || { syntax_error; return 1; }
			G_DIETPI-NOTIFY 0 "Comment in $yellow$file$reset converted to setting: $yellow${setting_raw//\\/\\\\}$reset"
		else
			if [[ $after ]]; then
				if error=$(grep -Eq "^[[:blank:]]*$after" "$file" 2>&1); then
					error=$(sed -Ei "0,/^[[:blank:]]*$after.*$/s//&\n$setting/" "$file" 2>&1) || { syntax_error; return 1; }
					G_DIETPI-NOTIFY 0 "Added setting $yellow${setting_raw//\\/\\\\}$reset to $yellow$file$reset after line $yellow$(grep -Em1 "^[[:blank:]]*$after" "$file" | sed 's|\\|\\\\|g')$reset"
				else
					G_WHIP_MSG "[FAILED] Setting could not be added after desired line
\nThe pattern \$4
	$(sed -E "c\\$after" <<< '')
could not be found in file \$3
	$file
\nPlease retry with valid parameter \$4 or apply the setting manually:
	$setting_raw"
				fi
			else
				# The following sed does not work on empty files:
				[[ ! -s $file ]] && echo '# Added by DietPi:' >> "$file"
				error=$(sed -Ei "\$a\\$setting" "$file" 2>&1) || { syntax_error; return 1; }
				G_DIETPI-NOTIFY 0 "Added setting $yellow${setting_raw//\\/\\\\}$reset to end of file $yellow$file$reset"
			fi
		fi
	: # Return exit code 0, by triggering null as last command to output
So it's not a piece of cake ! 🤯
Edited by TRS-80
put long output inside spoiler
Merged three posts. You may want to use spoiler ( grafik.png) for longer posts to reduce overall topic length.
Yeah, I went ahead and put it into a spoiler (to fold away) but something that big (especially that likely exists publicly in some forge) I would have probably linked to, personally.
Well, I give you credit for at least doing some investigation.  :)
Other than noticing the great length of that script, I will admit to not investing any time whatsoever studying it any further.  :)
However, my immediate thought is:  Do you really want to rely on something so complex to continue to be maintained by a third party?  Or to fork and maintain yourself?  Especially given that bash scripting is admittedly not your cup of tea?
Prior to seeing this script, I was already a bit skeptical about how far DietPi strays away from standard Debian ways of doing things.  But that was based on very brief experience playing around with it only once some time ago.
If we take a step back to the fundamental problem that is trying to be solved here, that seems to me essentially to be backup.  And backup is good!  However perhaps there is some other better way to go about that?
For backups I occasionally create a direct sector-by-sector image using Win32DiskImager. Usually when I've made a fair few user-land alterations, which reminds me that I am due to take another back-up soon.
I need something like TimeShift or Systemback (other examples). I tested these two apps that I've always used on Linux distros, but they didn't work on Armbian. I'd like incremental snapshots of file system to be restored at a later date to undo all changes to the system.
You're probably going to need to be a little more hands on with the tool you choose.
I like borg and borgmatic.
Hey guys, I searched for "snap" in the Software application and "Back In Time" appeared with a graphical interface 🤣 I'm so glad Armbian read my mind. 🤭
Now I'm trying to configure: I don't know which system folder I should choose for backup (in the future I want to restore only the system) and where to save the snapshots.
