yanzixiang Posted April 24, 2022 Posted April 24, 2022 (edited) https://www.armbian.com/uefi-arm64/ said it suppport PHYTIUM D2000, so i want to ask, if it support PHYTIUM FT2000/4 ? Edited April 24, 2022 by yanzixiang add a picture
Werner Posted April 24, 2022 Posted April 24, 2022 I cannot find the term "supported" on this page rather than in a hint that says Quote * Specifications differ from hardware revision, model and software support level UEFI in both x86 and arm64 is WIP.
Igor Posted April 24, 2022 Posted April 24, 2022 Images were tested on PHYTIUM D2000 but if they work on newer / other versions, Armbian can only say "probably". If there will be problems, you have to deal with manufacturer to fix or pay someone to fix possible bugs for you. Then send a patch (or upstream) and our images will work (better). We provide and maintain build framework, sources are available.
