Pieter Posted September 16, 2016 Share Posted September 16, 2016 Hi, I'm trying to install Armbian 5.20 vanilla kernel to eMMC on my Opi PC+. After nand-sata-install finishes I shutdown the Opi PC+ and power it back on. At least, I enable the power, I don't see anything happening in minicom on my pc. Only when powering it with a microsd in the slot (with armbian) will the uboot show in minicom on my pc. Doing a nand-sata-install with 5.14 legacy worked. What am I doing wrong (especially seeing nothing after a reboot with my ttl-to-usb connected is a bit strange for this noob)? Link to comment Share on other sites More sharing options...
martinayotte Posted September 16, 2016 Share Posted September 16, 2016 It seems that there is a bug with improper path while trying to copy the u-boot-sunxi-with-spl.bin into the eMMC. The workaround for now is booting from your sdcard and writing the u-boot manually : dd if=/usr/lib/linux-u-boot-dev-orangepipcplus_5.20_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8 Then reboot without sdcard, it should work. 1 Link to comment Share on other sites More sharing options...
StaLeWaR Posted September 17, 2016 Share Posted September 17, 2016 by the way, I wanted to know - what load faster with emmc or sdcard? there is a difference? Link to comment Share on other sites More sharing options...
Igor Posted September 17, 2016 Share Posted September 17, 2016 by the way, I wanted to know - what load faster with emmc or sdcard? there is a difference? eMMC is faster in all cases. Check background with some tests: http://forum.armbian.com/index.php/topic/954-sd-card-performance/ 1 Link to comment Share on other sites More sharing options...
StaLeWaR Posted September 17, 2016 Share Posted September 17, 2016 @Igor Thank you for your link. Probably the best option eMMC Link to comment Share on other sites More sharing options...
Pieter Posted September 17, 2016 Author Share Posted September 17, 2016 @martinayotte, That worked! Thanks :-) Link to comment Share on other sites More sharing options...
