greg396 Posted August 15, 2022 Posted August 15, 2022 Dear Forum, I am using a Helios64 with armbian Debian 10 (Buster) Linux-Kernel 5.15.52 and OMV 5.6.26-1. If I want to have further Updates from OMV I need to upgrade to Debian 11, because OMV6 isn't compatible to Buster. Any recomendations how I should upgrade? The H64-System is on a SDD. Should I try a cli system upgrade or installing everything new with a bullseye image, if this is available (Where?)? Best wishes, Greg 0 Quote
Werner Posted August 15, 2022 Posted August 15, 2022 Hi 1 hour ago, greg396 said: if this is available (Where?)? No pre-built image available since it is unmaintained. You can use the build framework to build your own image with Bullseye userspace. 1 hour ago, greg396 said: try a cli system upgrade Userspace upgrades are neither tested nor supported. You can try but you are on your own if something breaks. Create proper backups first. Good luck. 0 Quote
n3o Posted August 22, 2022 Posted August 22, 2022 (edited) @Werner "You can try but you are on your own if something breaks" do You mean side software or side hardware? If openmediavault, armbian and all other packages are opensource the only limit can be represented from the driver that interface with kernel ...is right? (Note: I don't know Linux very well, I have only theoretical notion on operating system) Edited August 22, 2022 by n3o 0 Quote
Werner Posted August 22, 2022 Posted August 22, 2022 Software. Things like inability to boot are possible or package conflicts. 0 Quote
n3o Posted August 22, 2022 Posted August 22, 2022 so best way is make a backup of image on other microsd with Linux-Kernel 5.15.52 and OMV 5.6.26-1 and update both Linux and OMV... if there are problems then switch to other microSD 0 Quote
Daniel Helios64 Posted September 8, 2022 Posted September 8, 2022 Have upgrade Helios64 from OMV5 to OMV6 2 weeks ago. System runs normal. Only issue; fans became quite noisy since upgrade, guess maxrpm fancontrol is not working without hdd temp sensors. Some info on config; root@helios64:~# uname -a Linux helios64 5.15.52-rockchip64 #22.05.4 Upgrade procedure; - Linux updates apt-get update && apt-get upgrade && apt-get dist-upgrade && apt-get --purge autoremove - OMV update omv-update follow questions reboot, hope for the best ;-) 0 Quote
Daniel Helios64 Posted September 8, 2022 Posted September 8, 2022 The Helios64 documentation was a little unclear; with these commands I found a (temp) solution for the RPM; Get hardware addresses (find fan 6 and 7): ls -l /sys/class/hwmon/ Read pwm setting (255 is max, possibly your hwmon-address is different) cat /sys/class/hwmon/hwmon5/pwm1 cat /sys/class/hwmon/hwmon6/pwm1 Manual change rpm for Helios64 fans (value 60 is safe and quiet); echo 70 > /sys/class/hwmon/hwmon5/pwm1 echo 70 > /sys/class/hwmon/hwmon6/pwm1 0 Quote
greg396 Posted September 9, 2022 Author Posted September 9, 2022 Thank you for your input! It would be really nice to collect some experience concerning the upgrade in this thread! 0 Quote
greg396 Posted September 11, 2022 Author Posted September 11, 2022 Is there any way to lower the fans permanently also after a reboot maybe in /etc/fancontrol? 0 Quote
allen--smithee Posted September 12, 2022 Posted September 12, 2022 Hi, maybe you want to modify some lines, /usr/sbin/fancontrol Divulgacher Ligne 44 > MAX= my value is MAX=80 because when it comes to restart or shutdown I want to hear it /etc/fancontrol Divulgacher # Helios64 PWM Fan Control Configuration # /etc/fancontrol # /usr/sbin/fancontrol # /var/run/fancontrol.pid # Command # ls -l /sys/class/hwmon | grep fan # cat /sys/class/hwmon/hwmon4/pwm1 && cat /sys/class/hwmon/hwmon5/pwm1 # systemctl stop fancontrol.service # systemctl start fancontrol.service # echo 255 > /sys/class/hwmon/hwmon4/pwm1 && echo 255 > /sys/class/hwmon/hwmon5/pwm1 # hdparm -H /dev/sdd | grep celsius # hddtemp /dev/sd[a-e] INTERVAL=10 # Temp source : /dev/thermal-cpu FCTEMPS=/dev/fan-p6/pwm1=/dev/thermal-cpu/temp1_input /dev/fan-p7/pwm1=/dev/thermal-cpu/temp1_input # temp1_critique = 85° < big downclock 1.8Ghz => 1.62Ghz/400Mhz # P6 => Fan Right (2SATA+CPU) | P7 => Fan Left (3SATA) #Temp Limit >> PWM => MINPWM MINTEMP=/dev/fan-p6/pwm1=50 /dev/fan-p7/pwm1=50 #Temp Limit >> PWM => MAXPWM MAXTEMP=/dev/fan-p6/pwm1=60 /dev/fan-p7/pwm1=60 #Fan Type "C" 350-3600RPM #PWM < 20 => 0RPM | PWM = 25 => 350 RPM | PWM = 255 => 3600RPM #Fan Start PWM = 25 MINSTART=/dev/fan-p6/pwm1=30 /dev/fan-p7/pwm1=25 #Fan Stop PWM = 15 MINSTOP=/dev/fan-p6/pwm1=35 /dev/fan-p7/pwm1=15 #PWM Minimal < MINSTOP (SSD P7 = 0 / HDD P7 = 35) MINPWM=/dev/fan-p6/pwm1=35 /dev/fan-p7/pwm1=0 #PWM Maximal (75°< PWM for Tcpu100% <80°) #T = 20° PWM = 0 (Fanless with Gelid PAD) | T = 25° PWM = ?? | T = 30° PWM = ?? MAXPWM=/dev/fan-p6/pwm1=60 /dev/fan-p7/pwm1=60 my fancontrol setup with special setting with high quality thermal paste (With Gelid Solutions GP-Ultimate my unit is without thermal bottleneck Fanless) and use only SSDs. MAXPWM is the key to silence but you have to find the max hwmonX/pwm1 value for CPU100%/Thermal PAD/Heatshink solution = temp1_input ≤ 80°C , otherwise you risk reaching the value of temp1_crit under heavy load. Ex: With the original thermal PAD my old MAXPWM=120 0 Quote
n3o Posted September 13, 2022 Posted September 13, 2022 (edited) @greg396 can You post the plugins and extra that You have installed? Edited September 13, 2022 by n3o 0 Quote
greg396 Posted September 15, 2022 Author Posted September 15, 2022 I just use the Usb-backup plugin. I tried the upgrade but had some errors which I couldn't solve ending up in installing the latest bullseye image from here https://armbian.hosthatch.com/archive/helios64/archive/ first to SD then to eMMC and then the system to a SSD while booting from eMMC - which works now really good again with having actual OMV6. The only trouble is that I won't get the fan quiet Thank you allen--smithee for your modification which doesn't work for me, sorry! I can only manual set it quiet with Daniel Helios64 commands echo 70 > /sys/class/hwmon/hwmon5/pwm1 echo 70 > /sys/class/hwmon/hwmon6/pwm1 0 Quote
allen--smithee Posted September 15, 2022 Posted September 15, 2022 I'm curious what is the result of this command systemctl status fancontrol.service and what does the next command say systemctl start fancontrol.service if the configuration file /etc/fancontrol contains it a syntax error or wrong variable fancontrol will not run. also check ls -l /sys/class/hwmon | grep fan ls -l /etc/udev/rules.d/ cat /etc/udev/rules.d/90-helios64-hwmon.rules ls -l /dev/thermal-cpu/ Have you read old threads on the subject? 0 Quote
greg396 Posted September 16, 2022 Author Posted September 16, 2022 Dear allen--smithee, thank you for taking you time! Yes, indeed the service won't start automatic after a reboot status fancontrol.service shows these errors: Error: file /dev/fan-p5/pwm1 doesn't exist Error: file /dev/thermal-cpu/temp1_input doesn't exist Error: file /dev/thermal-cpu/temp1_input doesn't exist I could fix it with sudo ln -s /sys/devices/virtual/thermal/thermal_zone0/hwmon0 /dev/thermal-cpu and then starting the service manual but after a reboot it's gone I don't understand how I can apply it permantent fancontrol.service ● fancontrol.service - fan speed regulator Loaded: loaded (/lib/systemd/system/fancontrol.service; enabled; vendor preset: enabled) Drop-In: /etc/systemd/system/fancontrol.service.d └─pid.conf Active: failed (Result: exit-code) since Fri 2022-09-16 17:53:17 UTC; 4s ago Docs: man:fancontrol(8) man:pwmconfig(8) Process: 3011 ExecStartPre=/usr/sbin/fancontrol --check (code=exited, status=0/SUCCESS) Process: 3144 ExecStart=/usr/sbin/fancontrol (code=exited, status=1/FAILURE) Main PID: 3144 (code=exited, status=1/FAILURE) CPU: 1.362s Sep 16 17:53:17 helios64 fancontrol[3144]: AVERAGE=1 Sep 16 17:53:17 helios64 fancontrol[3144]: Error: file /dev/fan-p5/pwm1 doesn't exist Sep 16 17:53:17 helios64 fancontrol[3144]: Error: file /dev/thermal-cpu/temp1_input doesn't exist Sep 16 17:53:17 helios64 fancontrol[3144]: Error: file /dev/thermal-cpu/temp1_input doesn't exist Sep 16 17:53:17 helios64 fancontrol[3144]: At least one referenced file is missing. Either some req> Sep 16 17:53:17 helios64 fancontrol[3144]: modules haven't been loaded, or your configuration file > Sep 16 17:53:17 helios64 fancontrol[3144]: In the latter case, you should run pwmconfig again. Sep 16 17:53:17 helios64 systemd[1]: fancontrol.service: Main process exited, code=exited, status=1> Sep 16 17:53:17 helios64 systemd[1]: fancontrol.service: Failed with result 'exit-code'. Sep 16 17:53:17 helios64 systemd[1]: fancontrol.service: Consumed 1.362s CPU time. lines 1-22/22 (END) s -l /sys/class/hwmon | grep fan lrwxrwxrwx 1 root root 0 Sep 16 17:55 hwmon4 -> ../../devices/platform/p7-fan/hwmon/hwmon4 lrwxrwxrwx 1 root root 0 Sep 16 17:51 hwmon5 -> ../../devices/platform/p6-fan/hwmon/hwmon5 ls -l /etc/udev/rules.d/ total 56 -rw-r--r-- 1 root root 70 Nov 19 2020 10-wifi-disable-powermanagement.rules -rw-r--r-- 1 root root 45 Feb 3 2021 50-mali.rules -rw-r--r-- 1 root root 138 Feb 3 2021 50-rk3399-vpu.rules -rw-r--r-- 1 root root 3132 Feb 3 2021 50-usb-realtek-net.rules -rw-r--r-- 1 root root 20275 Aug 31 20:17 61-openmediavault-dev-disk-by-id.rules -rw-r--r-- 1 root root 79 Feb 3 2021 70-keep-usb-lan-as-eth1.rules -rw-r--r-- 1 root root 866 Feb 3 2021 90-helios64-hwmon.rules -rw-r--r-- 1 root root 424 Feb 3 2021 90-helios64-ups.rules -rw-r--r-- 1 root root 1348 Jan 20 2022 99-openmediavault-md-raid.rules -rw-r--r-- 1 root root 1647 Jan 20 2022 99-openmediavault-nonrot.rules cat /etc/udev/rules.d/90-helios64-hwmon.rules # Helios64 persistent hwmon ACTION=="remove", GOTO="helios64_hwmon_end" # KERNELS=="p6-fan", SUBSYSTEMS=="platform", ENV{_HELIOS64_FAN_}="p6", ENV{_IS_HELIOS64_FAN_}="1", ENV{IS_HELIOS64_HWMON}="1" KERNELS=="p7-fan", SUBSYSTEMS=="platform", ENV{_HELIOS64_FAN_}="p7", ENV{_IS_HELIOS64_FAN_}="1", ENV{IS_HELIOS64_HWMON}="1" KERNELS=="2-004c", SUBSYSTEMS=="i2c", DRIVERS=="lm75", ENV{IS_HELIOS64_HWMON}="1" SUBSYSTEM!="hwmon", GOTO="helios64_hwmon_end" ENV{HWMON_PATH}="/sys%p" # ATTR{name}=="cpu", ENV{IS_HELIOS64_HWMON}="1", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu" # ENV{IS_HELIOS64_HWMON}=="1", ATTR{name}=="lm75", ENV{HELIOS64_SYMLINK}="/dev/thermal-board" ENV{_IS_HELIOS64_FAN_}=="1", ENV{HELIOS64_SYMLINK}="/dev/fan-$env{_HELIOS64_FAN_}" # ENV{IS_HELIOS64_HWMON}=="1", RUN+="/bin/ln -sf $env{HWMON_PATH} $env{HELIOS64_SYMLINK}" LABEL="helios64_hwmon_end" ls -l /dev/thermal-cpu/ ls: cannot access '/dev/thermal-cpu/': No such file or directory /usr/sbin/pwmconfig: There are no fan-capable sensor modules installed 0 Quote
allen--smithee Posted September 17, 2022 Posted September 17, 2022 p5-fan and /dev/thermal-cpu doesn't exist, try with these changes copy paste /etc/udev/rules.d/90-helios64-hwmon.rules Spoiler # Helios64 persistent hwmon ACTION=="remove", GOTO="helios64_hwmon_end" # KERNELS=="p6-fan", SUBSYSTEMS=="platform", ENV{_HELIOS64_FAN_}="p6", ENV{_IS_HELIOS64_FAN_}="1", ENV{IS_HELIOS64_HWMON}="1" KERNELS=="p7-fan", SUBSYSTEMS=="platform", ENV{_HELIOS64_FAN_}="p7", ENV{_IS_HELIOS64_FAN_}="1", ENV{IS_HELIOS64_HWMON}="1" KERNELS=="2-004c", SUBSYSTEMS=="i2c", DRIVERS=="lm75", ENV{IS_HELIOS64_HWMON}="1" KERNELS=="thermal_zone0", SUBSYSTEMS=="thermal", ENV{IS_HELIOS64_HWMON}="1" SUBSYSTEM!="hwmon|thermal", GOTO="helios64_hwmon_end" ENV{HWMON_PATH}="/sys%p" # ATTR{type}=="soc-thermal", ENV{HWMON_PATH}="/sys%p/temp", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu/temp1_input", RUN+="/usr/bin/mkdir /dev/thermal-cpu/" ATTR{name}=="cpu", ENV{IS_HELIOS64_HWMON}="1", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu" # ENV{IS_HELIOS64_HWMON}=="1", ATTR{name}=="lm75", ENV{HELIOS64_SYMLINK}="/dev/thermal-board" ENV{_IS_HELIOS64_FAN_}=="1", ENV{HELIOS64_SYMLINK}="/dev/fan-$env{_HELIOS64_FAN_}" # ENV{IS_HELIOS64_HWMON}=="1", RUN+="/bin/ln -sf $env{HWMON_PATH} $env{HELIOS64_SYMLINK}" LABEL="helios64_hwmon_end" copy paste /etc/fancontrol Spoiler # Helios64 PWM Fan Control Configuration # /etc/fancontrol INTERVAL=10 # Temp source : /dev/thermal-cpu FCTEMPS=/dev/fan-p6/pwm1=/dev/thermal-cpu/temp1_input /dev/fan-p7/pwm1=/dev/thermal-cpu/temp1_input MINTEMP=/dev/fan-p6/pwm1=45 /dev/fan-p7/pwm1=45 MAXTEMP=/dev/fan-p6/pwm1=80 /dev/fan-p7/pwm1=80 MINSTART=/dev/fan-p6/pwm1=25 /dev/fan-p7/pwm1=25 MINSTOP=/dev/fan-p6/pwm1=15 /dev/fan-p7/pwm1=15 MINPWM=/dev/fan-p6/pwm1=0 /dev/fan-p7/pwm1=0 MAXPWM=/dev/fan-p6/pwm1=120 /dev/fan-p7/pwm1=120 shutdown 0 Start ls -l /dev/thermal-cpu/ systemctl status fancontrol.service 0 Quote
greg396 Posted September 17, 2022 Author Posted September 17, 2022 Thank you. You just need to exchange this fix here https://github.com/useful64/build/commit/b9f17bdffa24cc3309dc20de487aaa19bb5c481d -> ATTR{name}=="cpu|cpu_thermal", ENV{IS_HELIOS64_HWMON}="1", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu" is missing above et voila ls -l /dev/thermal-cpu/ total 0 device -> ../../thermal_zone0 subsystem -> ../../../../../class/hwmon temp1_crit temp1_input uevent so the working /etc/udev/rules.d/90-helios64-hwmon.rules looks like # Helios64 persistent hwmon ACTION=="remove", GOTO="helios64_hwmon_end" # KERNELS=="p6-fan", SUBSYSTEMS=="platform", ENV{_HELIOS64_FAN_}="p6", ENV{_IS_HELIOS64_FAN_}="1", EN> KERNELS=="p7-fan", SUBSYSTEMS=="platform", ENV{_HELIOS64_FAN_}="p7", ENV{_IS_HELIOS64_FAN_}="1", EN> KERNELS=="2-004c", SUBSYSTEMS=="i2c", DRIVERS=="lm75", ENV{IS_HELIOS64_HWMON}="1" KERNELS=="thermal_zone0", SUBSYSTEMS=="thermal", ENV{IS_HELIOS64_HWMON}="1" SUBSYSTEM!="hwmon|thermal", GOTO="helios64_hwmon_end" ENV{HWMON_PATH}="/sys%p" # ATTR{type}=="soc-thermal", ENV{HWMON_PATH}="/sys%p/temp", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu/t> ATTR{name}=="cpu", ENV{IS_HELIOS64_HWMON}="1", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu" ATTR{name}=="cpu|cpu_thermal", ENV{IS_HELIOS64_HWMON}="1", ENV{HELIOS64_SYMLINK}="/dev/thermal-cpu" # ENV{IS_HELIOS64_HWMON}=="1", ATTR{name}=="lm75", ENV{HELIOS64_SYMLINK}="/dev/thermal-board" ENV{_IS_HELIOS64_FAN_}=="1", ENV{HELIOS64_SYMLINK}="/dev/fan-$env{_HELIOS64_FAN_}" # ENV{IS_HELIOS64_HWMON}=="1", RUN+="/bin/ln -sf $env{HWMON_PATH} $env{HELIOS64_SYMLINK}" LABEL="helios64_hwmon_end" 0 Quote
allen--smithee Posted September 17, 2022 Posted September 17, 2022 fancontrol no longer returns an error , your startup and shutdown are no longer noisy now ? 0 Quote
greg396 Posted September 17, 2022 Author Posted September 17, 2022 No error anymore, working expected. After restart the fan spins get quiet after a short time :) 1 Quote
freed00m Posted September 18, 2022 Posted September 18, 2022 20 hours ago, allen--smithee said: shutdown are no longer noisy I think shutdowns will always be noisy, because the script ends and there is a TRAP signal that turns it to 100% . But not sure if MAXPWN affects the AFCPWM values in that script. Just look at the `/usr/sbin/fancontrol` ``` function restorefans() { local status=$1 fcvcount pwmo echo 'Aborting, restoring fans...' let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do pwmo=${AFCPWM[$fcvcount]} pwmdisable $pwmo let fcvcount=$fcvcount+1 done echo 'Verify fans have returned to full speed' rm -f "$PIDFILE" exit $status } trap 'restorefans 0' SIGQUIT SIGTERM trap 'restorefans 1' SIGHUP SIGINT ``` 0 Quote
allen--smithee Posted September 18, 2022 Posted September 18, 2022 /usr/sbin/fancontrol line 44 >> Max= precisely defines the nominal speed when fancontrol is inactive, which means, at the ignition of the device before the launching of the processes (including fancontrol) and at the extintion of the device when the processes are interrupted (including fancontrol) and it can last several minutes when you have installed OMV and some containers. But yes indeed you hear the fans roar for a second at the start and the end before the unit shuts down completely. I leave MAX=80 because from memory during my previous tests, the fans make an audible noise, which allowed me to verify that my unit restarted or turned off when I sent a command from my phone. A memory because it's been a while... /usr/sbin/fancontrol Spoiler #!/bin/bash # # Simple script implementing a temperature dependent fan speed control # Supported Linux kernel versions: 2.6.5 and later # # Version 0.71 # # Usage: fancontrol [CONFIGFILE] # # Dependencies: # bash, grep, sed, cut, sleep, readlink, lm_sensors :) # # Please send any questions, comments or success stories to # marius.reiner@hdev.de # Thanks! # # For configuration instructions and warnings please see fancontrol.txt, which # can be found in the doc/ directory or at the website mentioned above. # # # Copyright 2003 Marius Reiner <marius.reiner@hdev.de> # Copyright (C) 2007-2014 Jean Delvare <jdelvare@suse.de> # # This program is free software; you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation; either version 2 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License # along with this program; if not, write to the Free Software # Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, # MA 02110-1301 USA. # # PIDFILE="/var/run/fancontrol.pid" #DEBUG=1 MAX=80 function LoadConfig { local fcvcount fcv echo "Loading configuration from $1 ..." if [ ! -r "$1" ] then echo "Error: Can't read configuration file" >&2 exit 1 fi # grep configuration from file INTERVAL=$(grep -E '^INTERVAL=.*$' $1 | sed -e 's/INTERVAL=//g') DEVPATH=$(grep -E '^DEVPATH=.*$' $1 | sed -e 's/DEVPATH= *//g') DEVNAME=$(grep -E '^DEVNAME=.*$' $1 | sed -e 's/DEVNAME= *//g') FCTEMPS=$(grep -E '^FCTEMPS=.*$' $1 | sed -e 's/FCTEMPS=//g') MINTEMP=$(grep -E '^MINTEMP=.*$' $1 | sed -e 's/MINTEMP=//g') MAXTEMP=$(grep -E '^MAXTEMP=.*$' $1 | sed -e 's/MAXTEMP=//g') MINSTART=$(grep -E '^MINSTART=.*$' $1 | sed -e 's/MINSTART=//g') MINSTOP=$(grep -E '^MINSTOP=.*$' $1 | sed -e 's/MINSTOP=//g') # optional settings: FCFANS=$(grep -E '^FCFANS=.*$' $1 | sed -e 's/FCFANS=//g') MINPWM=$(grep -E '^MINPWM=.*$' $1 | sed -e 's/MINPWM=//g') MAXPWM=$(grep -E '^MAXPWM=.*$' $1 | sed -e 's/MAXPWM=//g') # Check whether all mandatory settings are set if [[ -z ${INTERVAL} || -z ${FCTEMPS} || -z ${MINTEMP} || -z ${MAXTEMP} || -z ${MINSTART} || -z ${MINSTOP} ]] then echo "Some mandatory settings missing, please check your config file!" >&2 exit 1 fi if [ "$INTERVAL" -le 0 ] then echo "Error in configuration file:" >&2 echo "INTERVAL must be at least 1" >&2 exit 1 fi # write settings to arrays for easier use and print them echo echo "Common settings:" echo " INTERVAL=$INTERVAL" let fcvcount=0 for fcv in $FCTEMPS do if ! echo $fcv | grep -E -q '=' then echo "Error in configuration file:" >&2 echo "FCTEMPS value is improperly formatted" >&2 exit 1 fi AFCPWM[$fcvcount]=$(echo $fcv |cut -d'=' -f1) AFCTEMP[$fcvcount]=$(echo $fcv |cut -d'=' -f2) AFCFAN[$fcvcount]=$(echo $FCFANS |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) AFCMINTEMP[$fcvcount]=$(echo $MINTEMP |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) AFCMAXTEMP[$fcvcount]=$(echo $MAXTEMP |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) AFCMINSTART[$fcvcount]=$(echo $MINSTART |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) AFCMINSTOP[$fcvcount]=$(echo $MINSTOP |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) AFCMINPWM[$fcvcount]=$(echo $MINPWM |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) [ -z "${AFCMINPWM[$fcvcount]}" ] && AFCMINPWM[$fcvcount]=0 AFCMAXPWM[$fcvcount]=$(echo $MAXPWM |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) [ -z "${AFCMAXPWM[$fcvcount]}" ] && AFCMAXPWM[$fcvcount]=255 # verify the validity of the settings if [ "${AFCMINTEMP[$fcvcount]}" -ge "${AFCMAXTEMP[$fcvcount]}" ] then echo "Error in configuration file (${AFCPWM[$fcvcount]}):" >&2 echo "MINTEMP must be less than MAXTEMP" >&2 exit 1 fi if [ "${AFCMAXPWM[$fcvcount]}" -gt 255 ] then echo "Error in configuration file (${AFCPWM[$fcvcount]}):" >&2 echo "MAXPWM must be at most 255" >&2 exit 1 fi if [ "${AFCMINSTOP[$fcvcount]}" -ge "${AFCMAXPWM[$fcvcount]}" ] then echo "Error in configuration file (${AFCPWM[$fcvcount]}):" >&2 echo "MINSTOP must be less than MAXPWM" >&2 exit 1 fi if [ "${AFCMINSTOP[$fcvcount]}" -lt "${AFCMINPWM[$fcvcount]}" ] then echo "Error in configuration file (${AFCPWM[$fcvcount]}):" >&2 echo "MINSTOP must be greater than or equal to MINPWM" >&2 exit 1 fi if [ "${AFCMINPWM[$fcvcount]}" -lt 0 ] then echo "Error in configuration file (${AFCPWM[$fcvcount]}):" >&2 echo "MINPWM must be at least 0" >&2 exit 1 fi echo echo "Settings for ${AFCPWM[$fcvcount]}:" echo " Depends on ${AFCTEMP[$fcvcount]}" echo " Controls ${AFCFAN[$fcvcount]}" echo " MINTEMP=${AFCMINTEMP[$fcvcount]}" echo " MAXTEMP=${AFCMAXTEMP[$fcvcount]}" echo " MINSTART=${AFCMINSTART[$fcvcount]}" echo " MINSTOP=${AFCMINSTOP[$fcvcount]}" echo " MINPWM=${AFCMINPWM[$fcvcount]}" echo " MAXPWM=${AFCMAXPWM[$fcvcount]}" let fcvcount=fcvcount+1 done echo } function DevicePath() { if [ -h "$1/device" ] then readlink -f "$1/device" | sed -e 's/^\/sys\///' fi } function DeviceName() { if [ -r "$1/name" ] then cat "$1/name" | sed -e 's/[[:space:]=]/_/g' elif [ -r "$1/device/name" ] then cat "$1/device/name" | sed -e 's/[[:space:]=]/_/g' fi } function ValidateDevices() { local OLD_DEVPATH="$1" OLD_DEVNAME="$2" outdated=0 local entry device name path for entry in $OLD_DEVPATH do device=$(echo "$entry" | sed -e 's/=[^=]*$//') path=$(echo "$entry" | sed -e 's/^[^=]*=//') if [ "$(DevicePath "$device")" != "$path" ] then echo "Device path of $device has changed" >&2 outdated=1 fi done for entry in $OLD_DEVNAME do device=$(echo "$entry" | sed -e 's/=[^=]*$//') name=$(echo "$entry" | sed -e 's/^[^=]*=//') if [ "$(DeviceName "$device")" != "$name" ] then echo "Device name of $device has changed" >&2 outdated=1 fi done return $outdated } function FixupDeviceFiles { local DEVICE="$1" local fcvcount pwmo tsen fan let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do pwmo=${AFCPWM[$fcvcount]} AFCPWM[$fcvcount]=${pwmo//$DEVICE\/device/$DEVICE} if [ "${AFCPWM[$fcvcount]}" != "$pwmo" ] then echo "Adjusing $pwmo -> ${AFCPWM[$fcvcount]}" fi let fcvcount=$fcvcount+1 done let fcvcount=0 while (( $fcvcount < ${#AFCTEMP[@]} )) # go through all temp inputs do tsen=${AFCTEMP[$fcvcount]} AFCTEMP[$fcvcount]=${tsen//$DEVICE\/device/$DEVICE} if [ "${AFCTEMP[$fcvcount]}" != "$tsen" ] then echo "Adjusing $tsen -> ${AFCTEMP[$fcvcount]}" fi let fcvcount=$fcvcount+1 done let fcvcount=0 while (( $fcvcount < ${#AFCFAN[@]} )) # go through all fan inputs do fan=${AFCFAN[$fcvcount]} AFCFAN[$fcvcount]=${fan//$DEVICE\/device/$DEVICE} if [ "${AFCFAN[$fcvcount]}" != "$fan" ] then echo "Adjusing $fan -> ${AFCFAN[$fcvcount]}" fi let fcvcount=$fcvcount+1 done } # Some drivers moved their attributes from hard device to class device function FixupFiles { local DEVPATH="$1" local entry device for entry in $DEVPATH do device=$(echo "$entry" | sed -e 's/=[^=]*$//') if [ -e "$device/name" ] then FixupDeviceFiles "$device" fi done } # Check that all referenced sysfs files exist function CheckFiles { local outdated=0 fcvcount pwmo tsen fan let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do pwmo=${AFCPWM[$fcvcount]} if [ ! -w $pwmo ] then echo "Error: file $pwmo doesn't exist" >&2 outdated=1 fi let fcvcount=$fcvcount+1 done let fcvcount=0 while (( $fcvcount < ${#AFCTEMP[@]} )) # go through all temp inputs do tsen=${AFCTEMP[$fcvcount]} if [ ! -r $tsen ] then echo "Error: file $tsen doesn't exist" >&2 outdated=1 fi let fcvcount=$fcvcount+1 done let fcvcount=0 while (( $fcvcount < ${#AFCFAN[@]} )) # go through all fan inputs do # A given PWM output can control several fans for fan in $(echo ${AFCFAN[$fcvcount]} | sed -e 's/+/ /') do if [ ! -r $fan ] then echo "Error: file $fan doesn't exist" >&2 outdated=1 fi done let fcvcount=$fcvcount+1 done if [ $outdated -eq 1 ] then echo >&2 echo "At least one referenced file is missing. Either some required kernel" >&2 echo "modules haven't been loaded, or your configuration file is outdated." >&2 echo "In the latter case, you should run pwmconfig again." >&2 fi return $outdated } if [ "$1" == "--check" ] then if [ -f "$2" ] then LoadConfig $2 else LoadConfig /etc/fancontrol fi exit 0 fi if [ -f "$1" ] then LoadConfig $1 else LoadConfig /etc/fancontrol fi # Detect path to sensors if echo "${AFCPWM[0]}" | grep -E -q '^/' then DIR=/ elif echo "${AFCPWM[0]}" | grep -E -q '^hwmon[0-9]' then DIR=/sys/class/hwmon elif echo "${AFCPWM[0]}" | grep -E -q '^[1-9]*[0-9]-[0-9abcdef]{4}' then DIR=/sys/bus/i2c/devices else echo "$0: Invalid path to sensors" >&2 exit 1 fi if [ ! -d $DIR ] then echo $0: 'No sensors found! (did you load the necessary modules?)' >&2 exit 1 fi cd $DIR # Check for configuration change if [ "$DIR" != "/" ] && [ -z "$DEVPATH" -o -z "$DEVNAME" ] then echo "Configuration is too old, please run pwmconfig again" >&2 exit 1 fi if [ "$DIR" = "/" -a -n "$DEVPATH" ] then echo "Unneeded DEVPATH with absolute device paths" >&2 exit 1 fi if ! ValidateDevices "$DEVPATH" "$DEVNAME" then echo "Configuration appears to be outdated, please run pwmconfig again" >&2 exit 1 fi if [ "$DIR" = "/sys/class/hwmon" ] then FixupFiles "$DEVPATH" fi CheckFiles || exit 1 if [ -f "$PIDFILE" ] then echo "File $PIDFILE exists, is fancontrol already running?" >&2 exit 1 fi echo $$ > "$PIDFILE" # associative arrays to hold pwmN device name as key, and as value the # pwmN_enable and pwmN values as they were before fancontrol was started declare -A PWM_ENABLE_ORIG_STATE declare -A PWM_ORIG_STATE # $1 = pwm file name function pwmdisable() { local ENABLE=${1}_enable # No enable file? Just set to max if [ ! -f $ENABLE ] then echo $MAX > $1 return 0 fi # Try to restore pwmN and pwmN_enable value to the same state as before # fancontrol start. Restoring the pwmN value is tried first, before the # pwmN_enable mode switch. # Some chips seem to need this to properly restore fan operation, # when activating automatic (2) mode. if [ ${PWM_ENABLE_ORIG_STATE[${1}]} ] then #restore the pwmN value if [ "$DEBUG" != "" ] then echo "Restoring ${1} original value of ${PWM_ORIG_STATE[${1}]}" fi echo ${PWM_ORIG_STATE[${1}]} > ${1} 2> /dev/null # restore the pwmN_enable value, if it is not 1. # 1 is already set through fancontrol and setting it again might just # reset the pwmN value. if [ ${PWM_ENABLE_ORIG_STATE[${1}]} != 1 ] then if [ "$DEBUG" != "" ] then echo "Restoring $ENABLE original value of ${PWM_ENABLE_ORIG_STATE[${1}]}" fi echo ${PWM_ENABLE_ORIG_STATE[${1}]} > $ENABLE 2> /dev/null # check if setting pwmN_enable value was successful. Checking the # pwmN value makes no sense, as it might already have been altered # by the chip. if [ "$(cat $ENABLE)" = ${PWM_ENABLE_ORIG_STATE[${1}]} ] then return 0 fi # if pwmN_enable is manual (1), check if restoring the pwmN value worked elif [ "$(cat ${1})" = ${PWM_ORIG_STATE[${1}]} ] then return 0 fi fi # Try pwmN_enable=0 echo 0 > $ENABLE 2> /dev/null if [ "$(cat $ENABLE)" -eq 0 ] then # Success return 0 fi # It didn't work, try pwmN_enable=1 pwmN=255 echo 1 > $ENABLE 2> /dev/null echo $MAX > $1 if [ "$(cat $ENABLE)" -eq 1 -a "$(cat $1)" -ge 190 ] then # Success return 0 fi # Nothing worked echo "$ENABLE stuck to" "$(cat $ENABLE)" >&2 return 1 } # $1 = pwm file name function pwmenable() { local ENABLE=${1}_enable if [ -f $ENABLE ] then # save the original pwmN_control state, e.g. 1 for manual or 2 for auto, # and the value from pwmN local PWM_CONTROL_ORIG=$(cat $ENABLE) local PWM_ORIG=$(cat ${1}) if [ "$DEBUG" != "" ] then echo "Saving $ENABLE original value as $PWM_CONTROL_ORIG" echo "Saving ${1} original value as $PWM_ORIG" fi #check for degenerate case where these values might be empty if [ $PWM_CONTROL_ORIG ] && [ $PWM_ORIG ] then PWM_ENABLE_ORIG_STATE[${1}]=$PWM_CONTROL_ORIG PWM_ORIG_STATE[${1}]=$PWM_ORIG fi # enable manual control by fancontrol echo 1 > $ENABLE 2> /dev/null if [ $? -ne 0 ] then return 1 fi fi echo $MAX > $1 } function restorefans() { local status=$1 fcvcount pwmo echo 'Aborting, restoring fans...' let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do pwmo=${AFCPWM[$fcvcount]} pwmdisable $pwmo let fcvcount=$fcvcount+1 done echo 'Verify fans have returned to full speed' rm -f "$PIDFILE" exit $status } trap 'restorefans 0' SIGQUIT SIGTERM trap 'restorefans 1' SIGHUP SIGINT # main function function UpdateFanSpeeds { local fcvcount local pwmo tsens fan mint maxt minsa minso minpwm maxpwm local tval pwmpval fanval min_fanval one_fan one_fanval local -i pwmval let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do #hopefully shorter vars will improve readability: pwmo=${AFCPWM[$fcvcount]} tsens=${AFCTEMP[$fcvcount]} fan=${AFCFAN[$fcvcount]} let mint="${AFCMINTEMP[$fcvcount]}*1000" let maxt="${AFCMAXTEMP[$fcvcount]}*1000" minsa=${AFCMINSTART[$fcvcount]} minso=${AFCMINSTOP[$fcvcount]} minpwm=${AFCMINPWM[$fcvcount]} maxpwm=${AFCMAXPWM[$fcvcount]} read tval < ${tsens} if [ $? -ne 0 ] then echo "Error reading temperature from $DIR/$tsens" restorefans 1 fi read pwmpval < ${pwmo} if [ $? -ne 0 ] then echo "Error reading PWM value from $DIR/$pwmo" restorefans 1 fi # If fanspeed-sensor output shall be used, do it if [[ -n ${fan} ]] then min_fanval=100000 fanval= # A given PWM output can control several fans for one_fan in $(echo $fan | sed -e 's/+/ /') do read one_fanval < ${one_fan} if [ $? -ne 0 ] then echo "Error reading Fan value from $DIR/$one_fan" >&2 restorefans 1 fi # Remember the minimum, it only matters if it is 0 if [ $one_fanval -lt $min_fanval ] then min_fanval=$one_fanval fi if [ -z "$fanval" ] then fanval=$one_fanval else fanval="$fanval/$one_fanval" fi done else min_fanval=1 # set it to a non zero value, so the rest of the script still works fi # debug info if [ "$DEBUG" != "" ] then echo "pwmo=$pwmo" echo "tsens=$tsens" echo "fan=$fan" echo "mint=$mint" echo "maxt=$maxt" echo "minsa=$minsa" echo "minso=$minso" echo "minpwm=$minpwm" echo "maxpwm=$maxpwm" echo "tval=$tval" echo "pwmpval=$pwmpval" echo "fanval=$fanval" echo "min_fanval=$min_fanval" fi if (( $tval <= $mint )) then pwmval=$minpwm # below min temp, use defined min pwm elif (( $tval >= $maxt )) then pwmval=$maxpwm # over max temp, use defined max pwm else # calculate the new value from temperature and settings pwmval="(${tval}-${mint})*(${maxpwm}-${minso})/(${maxt}-${mint})+${minso}" if [ $pwmpval -eq 0 -o $min_fanval -eq 0 ] then # if fan was stopped start it using a safe value echo $minsa > $pwmo # Sleep while still handling signals sleep 1 & wait fi fi echo $pwmval > $pwmo # write new value to pwm output if [ $? -ne 0 ] then echo "Error writing PWM value to $DIR/$pwmo" >&2 restorefans 1 fi if [ "$DEBUG" != "" ] then echo "new pwmval=$pwmval" fi let fcvcount=$fcvcount+1 done } echo 'Enabling PWM on fans...' let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do pwmo=${AFCPWM[$fcvcount]} pwmenable $pwmo if [ $? -ne 0 ] then echo "Error enabling PWM on $DIR/$pwmo" >&2 restorefans 1 fi let fcvcount=$fcvcount+1 done echo 'Starting automatic fan control...' # main loop calling the main function at specified intervals while true do UpdateFanSpeeds # Sleep while still handling signals sleep $INTERVAL & wait done 12 hours ago, freed00m said: I think shutdowns will always be noisy, because the script ends and there is a TRAP signal that turns it to 100% . Line 394 >> declare -A PWM_ENABLE_ORIG_STATE Line 395 >> declare -A PWM_ORIG_STATE Spoiler # associative arrays to hold pwmN device name as key, and as value the # pwmN_enable and pwmN values as they were before fancontrol was started declare -A PWM_ENABLE_ORIG_STATE declare -A PWM_ORIG_STATE # $1 = pwm file name function pwmdisable() { local ENABLE=${1}_enable # No enable file? Just set to max if [ ! -f $ENABLE ] then echo $MAX > $1 return 0 fi # Try to restore pwmN and pwmN_enable value to the same state as before # fancontrol start. Restoring the pwmN value is tried first, before the # pwmN_enable mode switch. # Some chips seem to need this to properly restore fan operation, # when activating automatic (2) mode. if [ ${PWM_ENABLE_ORIG_STATE[${1}]} ] then #restore the pwmN value if [ "$DEBUG" != "" ] then echo "Restoring ${1} original value of ${PWM_ORIG_STATE[${1}]}" fi echo ${PWM_ORIG_STATE[${1}]} > ${1} 2> /dev/null # restore the pwmN_enable value, if it is not 1. # 1 is already set through fancontrol and setting it again might just # reset the pwmN value. if [ ${PWM_ENABLE_ORIG_STATE[${1}]} != 1 ] then if [ "$DEBUG" != "" ] then echo "Restoring $ENABLE original value of ${PWM_ENABLE_ORIG_STATE[${1}]}" fi echo ${PWM_ENABLE_ORIG_STATE[${1}]} > $ENABLE 2> /dev/null # check if setting pwmN_enable value was successful. Checking the # pwmN value makes no sense, as it might already have been altered # by the chip. if [ "$(cat $ENABLE)" = ${PWM_ENABLE_ORIG_STATE[${1}]} ] then return 0 fi # if pwmN_enable is manual (1), check if restoring the pwmN value worked elif [ "$(cat ${1})" = ${PWM_ORIG_STATE[${1}]} ] then return 0 fi fi # Try pwmN_enable=0 echo 0 > $ENABLE 2> /dev/null if [ "$(cat $ENABLE)" -eq 0 ] then # Success return 0 fi # It didn't work, try pwmN_enable=1 pwmN=255 echo 1 > $ENABLE 2> /dev/null echo $MAX > $1 if [ "$(cat $ENABLE)" -eq 1 -a "$(cat $1)" -ge 190 ] then # Success return 0 fi # Nothing worked echo "$ENABLE stuck to" "$(cat $ENABLE)" >&2 return 1 } # $1 = pwm file name function pwmenable() { local ENABLE=${1}_enable if [ -f $ENABLE ] then # save the original pwmN_control state, e.g. 1 for manual or 2 for auto, # and the value from pwmN local PWM_CONTROL_ORIG=$(cat $ENABLE) local PWM_ORIG=$(cat ${1}) if [ "$DEBUG" != "" ] then echo "Saving $ENABLE original value as $PWM_CONTROL_ORIG" echo "Saving ${1} original value as $PWM_ORIG" fi #check for degenerate case where these values might be empty if [ $PWM_CONTROL_ORIG ] && [ $PWM_ORIG ] then PWM_ENABLE_ORIG_STATE[${1}]=$PWM_CONTROL_ORIG PWM_ORIG_STATE[${1}]=$PWM_ORIG fi # enable manual control by fancontrol echo 1 > $ENABLE 2> /dev/null if [ $? -ne 0 ] then return 1 fi fi echo $MAX > $1 } >> /usr/sbin/pwmconfig 12 hours ago, freed00m said: But not sure if MAXPWN affects the AFCPWM values in that script. line 46 >> function LoadConfig line 108 Line 521 >> function UpdateFanSpeeds Line 609 Spoiler function LoadConfig ... AFCMAXPWM[$fcvcount]=$(echo $MAXPWM |sed -e 's/ /\n/g' |grep -E "${AFCPWM[$fcvcount]}" |cut -d'=' -f2) [ -z "${AFCMAXPWM[$fcvcount]}" ] && AFCMAXPWM[$fcvcount]=255 ... # main function function UpdateFanSpeeds { local fcvcount local pwmo tsens fan mint maxt minsa minso minpwm maxpwm local tval pwmpval fanval min_fanval one_fan one_fanval local -i pwmval let fcvcount=0 while (( $fcvcount < ${#AFCPWM[@]} )) # go through all pwm outputs do #hopefully shorter vars will improve readability: pwmo=${AFCPWM[$fcvcount]} tsens=${AFCTEMP[$fcvcount]} fan=${AFCFAN[$fcvcount]} let mint="${AFCMINTEMP[$fcvcount]}*1000" let maxt="${AFCMAXTEMP[$fcvcount]}*1000" minsa=${AFCMINSTART[$fcvcount]} minso=${AFCMINSTOP[$fcvcount]} minpwm=${AFCMINPWM[$fcvcount]} maxpwm=${AFCMAXPWM[$fcvcount]} read tval < ${tsens} if [ $? -ne 0 ] then echo "Error reading temperature from $DIR/$tsens" restorefans 1 fi read pwmpval < ${pwmo} if [ $? -ne 0 ] then echo "Error reading PWM value from $DIR/$pwmo" restorefans 1 fi # If fanspeed-sensor output shall be used, do it if [[ -n ${fan} ]] ... fi # debug info if [ "$DEBUG" != "" ] then echo "pwmo=$pwmo" echo "tsens=$tsens" echo "fan=$fan" echo "mint=$mint" echo "maxt=$maxt" echo "minsa=$minsa" echo "minso=$minso" echo "minpwm=$minpwm" echo "maxpwm=$maxpwm" echo "tval=$tval" echo "pwmpval=$pwmpval" echo "fanval=$fanval" echo "min_fanval=$min_fanval" fi if (( $tval <= $mint )) then pwmval=$minpwm # below min temp, use defined min pwm elif (( $tval >= $maxt )) then pwmval=$maxpwm # over max temp, use defined max pwm else # calculate the new value from temperature and settings pwmval="(${tval}-${mint})*(${maxpwm}-${minso})/(${maxt}-${mint})+${minso}" if [ $pwmpval -eq 0 -o $min_fanval -eq 0 ] then # if fan was stopped start it using a safe value echo $minsa > $pwmo # Sleep while still handling signals sleep 1 & wait fi fi ... done } 1 Quote
eClapton Posted October 3, 2022 Posted October 3, 2022 (edited) Hello @allen--smithee Im surprised by your uptime. I have manually freezed updates to my Helios64 at 21.05.1, because last time I tried the update, the / partition was mounted ro, and had to downgrade. Is it safe to upgrade to 21.08.2? My systems reboots frequently: Edited October 3, 2022 by eClapton typo 0 Quote
allen--smithee Posted October 4, 2022 Posted October 4, 2022 I share my personal experience, this one works with me. I use Helios64 on SD Card 32Gb, with this version https://imola.armbian.com/archive/helios64/archive/Armbian_21.08.2_Helios64_buster_current_5.10.63.img.xz installing omv with this script. https://github.com/OpenMediaVault-Plugin-Developers/installScript I modified or added a few lines in files but I can't tell you exactly which one and how because I forgot since. I use 3 SSD disks individually managed by OMV + Containers. no raid, just EXT format Nothing special, but it is sufficient for my family use. With 45 cents per kilowatt, Helios64 + SSD will cost me a maximum of 40 Euros this year. (Energie cost 2.5x since september) 0 Quote
n3o Posted October 12, 2022 Posted October 12, 2022 (edited) if I follow your steps here isn't necessary made a build such here https://docs.armbian.com/Developer-Guide_Build-Options/ ? if however I want compile a build , I should just only execute the following command ./compile.sh BOARD=helios64 BRANCH=current KERNEL_ONLY=no RELEASE=buster ? the main scope that I'm interested, as well as the updates of omv and plugin, is the support of ZFS filesystem even with previous build, build 2.1.5 ( https://github.com/openzfs/zfs/releases ), I can't install it on my system and I get the following error modprobe: FATAL: Module zfs not found in directory /lib/modules/5.15.52-rockchip64 How can I solve ? @Daniel Helios64 and @greg396 do You get some issue with omv 6 and linux kernel 5.15.52 ? p.s.: if we want continue to support helios64 hardware, what it's needed? the source code of driver of the various peripherals and what other? if there is an issue with omv 6, it should be related only between linux kernel and omv 6, why helios hardware should be involved? p.s. 2: somebody has tried kernel 5.19.15? Edited October 12, 2022 by n3o 0 Quote
bunducafe Posted December 14, 2022 Posted December 14, 2022 My Helios64 has some hick-ups now end then and it takes a few attempts to get it booted properly. No big big issue, but annoying nontheless. I am wondering who is playing with the community builds? Until now I could not dig deep enough to compile my own build so far but I do suppose that some might do that here and possibly share the output. Or push me in the right direction where I could look and / or indeed build something from the scratch... The hardware setup of the helios64 is untouched therefore I do think that I don't need a kernel >5.15. but within the community builds we are already at 6.0.x and I have that slight concern that this will work well together with OMV for example... or is this a concern that I should not have at all Or do you guys have a preference for a specific / stable linux kernel for the helios64? That's also something I would consider to freeze the kernel completely if one of the builds work as expected without hick-ups. 0 Quote
Atticka Posted February 23, 2023 Posted February 23, 2023 Quick add to the thread, I did the 10->11 and then OMV5->6 upgrade recently and everything went as planned and has been working well since (over a week in now). 0 Quote
bunducafe Posted March 26, 2023 Posted March 26, 2023 Short shout out: running stable on the latest 5.19.x kernel. But with cpu frequency throttled to 400 - 1600 ondemand governor. Means that it runs slightly below maximum power. Does anyone know if there is a workaround to correct this issue and use it with full cpu power and not creating any kernel panic? 0 Quote
