balbes150 Posted August 18, 2022 Posted August 18, 2022 The first version of Armbian images for Station M3 rk3588s (rk3588s-roc-pc) is available. the launch is very simple - download, unpack, burn to an SD card, connect to the device and turn on the power. The system starts automatically. At the first launch, perform the initial setup in the same way as all Armbian-enabled devices. https://disk.yandex.ru/d/-zSW21XKN0pfIA 0 Quote
balbes150 Posted August 19, 2022 Author Posted August 19, 2022 ver 20220819 fix HDMI sound and analog sound 0 Quote
Werner Posted August 19, 2022 Posted August 19, 2022 Create a forum tag ( station-m3) for it and move to unsupported rockchip? What do you think? 0 Quote
balbes150 Posted August 20, 2022 Author Posted August 20, 2022 On 8/19/2022 at 2:46 PM, Werner said: Create a forum tag ( station-m3) for it and move to unsupported rockchip? What do you think? Expand tag rk3588s 0 Quote
Werner Posted August 20, 2022 Posted August 20, 2022 On 8/20/2022 at 8:56 AM, balbes150 said: rk3588s Expand done 0 Quote
blondu Posted August 25, 2022 Posted August 25, 2022 (edited) Hello, yesterday I received the rk3588s-roc-pc 😃 and I installed the distribution after changing the cooler and feeding at 3.3v (luckily it came with the old version, with a radiator). It works fine, thanks. A problem would be with the Apple Magic Wireless Trackpad, which does not emulate the right button or click. I also installed Synaptic and gnome to try. How can it be solved with the touchpad? A good day! Edited August 25, 2022 by blondu 0 Quote
balbes150 Posted August 25, 2022 Author Posted August 25, 2022 On 8/25/2022 at 8:05 AM, blondu said: problem would be with the Apple Magic Wireless Trackpad Expand I don't have this equipment and I have no idea what it requires. 0 Quote
blondu Posted August 25, 2022 Posted August 25, 2022 (edited) The usb c output also works as video port 2 I did not try simultaneously! I think it's the same problem with any touchpad. I measured the temperature in idle mode, it remains at 41 celsius and when playing YouTube 4k at 51 celsius. The Power on off button works. Edited August 25, 2022 by blondu 0 Quote
blondu Posted August 25, 2022 Posted August 25, 2022 I installed internally and ubuntu still behaves the same way with the touchpad and displays the same kernel version: 5.10.66 I guess it's from the kernel. Thanks 0 Quote
blondu Posted August 25, 2022 Posted August 25, 2022 (edited) Wifi also works with RTL8821CU Edited August 25, 2022 by blondu 0 Quote
blondu Posted August 25, 2022 Posted August 25, 2022 Can the operating system be installed internally on the mmc? 0 Quote
balbes150 Posted August 26, 2022 Author Posted August 26, 2022 On 8/25/2022 at 7:36 PM, blondu said: Can the operating system be installed internally on the mmc? Expand If eMMC is visible, the process is possible, but pay attention, I have not checked this mode and the consequences are not known. 0 Quote
blondu Posted August 26, 2022 Posted August 26, 2022 (edited) I installed internally, fast boot, runs much faster. Let's see if I still have a loader for loading another OS system... Comparable to odroid n2 at the moment. Edited August 26, 2022 by blondu 0 Quote
blondu Posted August 27, 2022 Posted August 27, 2022 I installed the OS M3 system on the mmc, the modified android, but I quickly returned to Armbian. I didn't solve it with the touchpad, I work with the mouse. The price seems to remain around $310, but there is an extra case and remote control. The sale seems to start after September 1. 0 Quote
balbes150 Posted August 28, 2022 Author Posted August 28, 2022 Several tests of full-screen video playback on Station M3 (rk3588s) using the latest Armbian images. https://bbs.stationpc.com/forum.php?mod=redirect&goto=findpost&ptid=323&pid=1141&fromuid=636914 0 Quote
blondu Posted August 28, 2022 Posted August 28, 2022 I discovered the problem with the Apple trackpad, it is not activated when compiling: # CONFIG_HID_MAGICMOUSE is not set and must be activated as a module: CONFIG_HID_fMAGICMOUSE=m, can it be recompiled for activation or activate only the respective module? Thanks, I couldn't find the source code... 0 Quote
balbes150 Posted August 28, 2022 Author Posted August 28, 2022 On 8/28/2022 at 9:23 AM, blondu said: CONFIG_HID_fMAGICMOUSE=m, Expand Try this version 20220828, it has this option enabled as a module. 0 Quote
balbes150 Posted August 28, 2022 Author Posted August 28, 2022 On 8/28/2022 at 2:02 PM, blondu said: And some errors. Expand These "errors" report that you have nothing connected to MPI\CSI\LVDS 0 Quote
blondu Posted August 28, 2022 Posted August 28, 2022 In the m2 slot, it recognizes the sata ssd, at the moment I will not test it. 0 Quote
balbes150 Posted August 28, 2022 Author Posted August 28, 2022 On 8/28/2022 at 2:44 PM, blondu said: In the m2 slot, it recognizes the sata ssd, at the moment I will not test it. Expand I plan to add another DTB in which NVMe mode will be enabled and for those who need NVMe, it will be enough just to edit extlinux.conf and specify DTB for NVMe. 0 Quote
blondu Posted August 28, 2022 Posted August 28, 2022 I converted to dts and attachedroc-rk3588s-pc.dtb.dts 0 Quote
balbes150 Posted August 28, 2022 Author Posted August 28, 2022 On 8/28/2022 at 3:34 PM, blondu said: I converted to dts and attached Expand I already have everything I need to create all dtbs 0 Quote
blondu Posted August 28, 2022 Posted August 28, 2022 (edited) In what mode does the ssd work, sata mode or PCIe Gen2 with a bus? with chromium webgl how to set hardware? thanks Edited August 28, 2022 by blondu 0 Quote
balbes150 Posted August 29, 2022 Author Posted August 29, 2022 On 8/28/2022 at 4:50 PM, blondu said: n what mode does the ssd work, sata mode or PCIe Gen2 with a bus? Expand By default, SATA mode is enabled, to switch to NVMe, you need to change DTB (switch SATA mode to NVMe). On 8/28/2022 at 4:50 PM, blondu said: with chromium webgl how to set hardware? Expand Add the necessary to the source code (libraries, ffmpeg, browser, etc.) and build a new version 0 Quote
blondu Posted August 31, 2022 Posted August 31, 2022 I installed a Transcend TS240GMTS420S sata that reads and writes with approximately 500Mb/s. It boots from it and works very well, I don't know what I will do with the 64Gb eMMM, maybe another system... Thanks for the system. 0 Quote
balbes150 Posted August 31, 2022 Author Posted August 31, 2022 On 8/31/2022 at 10:23 AM, blondu said: I don't know what I will do with the 64Gb eMMM Expand I have long suggested to Firefly to make eMMC a removable module, or at least reduce its size and produce a model with 8 GB of eMMC. If you place the u-boot in SPI, eMMC will not be needed at all and you can significantly reduce the price. Perhaps if more users write to them about this, they will listen and release an additional version without eMMC. On 8/31/2022 at 10:23 AM, blondu said: sata that reads and writes with approximately 500Mb/s. Expand In the coming days I am waiting for the delivery of NVMe 2242 models, I think their speed will be significantly higher than SATA. By the way, it would be good to collect the results and links to SATA\NVMe models that have been tested in work on M2\m3\p2 and post this information on the official Fyrefly forum and here.. 0 Quote
blondu Posted September 1, 2022 Posted September 1, 2022 (edited) 1.I looked for data on access speeds for the three types of boards and the best documented is the store where the access speed for each m2 ssd is specified: Station M2, Station P2 and Station M3, the RK3588S chip is smaller than the RK3588, the pci bus is reduced as bandwidth so I'm curious how it behaves with NVMe 2242. 2.I have a Wi-Fi 6E 2x2 MT7921K M.2 module renamed AMD RZ608 from GMKtec NucBox 5 does it work in M.2? Edited September 1, 2022 by blondu 0 Quote
