blondu Posted November 26, 2022 Posted November 26, 2022 How can I get a driver for USB Geniatech MyGica Stick T230A please? I tried to compile drivers but I don't have the following error: Preparing to compile for kernel version 5.10.110 File not found: /lib/modules/5.10.110-station-m4/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4. make[1]: *** [Makefile:376: alliesconfig] Error 2 make[1]: Leaving directory '/home/ady/media_build/v4l' make: *** [Makefile:26: alliesconfig] Error 2 It installs linux-headers-generic (5.15.0.53.53) so I don't know what to do. Thanks. 0 Quote
balbes150 Posted November 26, 2022 Author Posted November 26, 2022 1 час назад, blondu сказал: For USB-C a CABLETIME 4k/60hz cable This does not work on version 5.10.110. I don't plan to spend a lot of time debugging this mode on an old BSP 5.10 kernel. 0 Quote
balbes150 Posted November 26, 2022 Author Posted November 26, 2022 1 час назад, blondu сказал: USB Geniatech MyGica Stick T230A USB-DVB ? 1 час назад, blondu сказал: It installs linux-headers-generic (5.15.0.53.53) These headers will obviously not work with the 5.10.110 kernel. Use the old 5.10.66 kernel and its headers (station-m3-5.10.66) 0 Quote
balbes150 Posted November 28, 2022 Author Posted November 28, 2022 Ver 20221128-EFI kernel 5.10.110 - version that uses running via EFI\Grub on M3 (rk3588). 0 Quote
balbes150 Posted November 28, 2022 Author Posted November 28, 2022 26.11.2022 в 16:37, blondu сказал: It installs linux-headers-generic (5.15.0.53.53) so I don't know what to do. DEB package with kernel headers for 5.10.110 https://disk.yandex.ru/d/hdWgrVC5gN3qJg 0 Quote
balbes150 Posted December 25, 2022 Author Posted December 25, 2022 Version 20221224 is EDK2-EFI. EDK2-EFI\grub is used to run. Burn the image simultaneously to two media - an SD card and a USB flash drive.After recording, connect the SD card and USB flash drive at the same time. If you have a UART console, you can control the startup process. 0 Quote
balbes150 Posted January 3, 2023 Author Posted January 3, 2023 Version 20230103-edge with kernel 6.2. LAN works and you can control the system via SSH. and version 20230103-EDK2-edge. kernel 6.2. the order of launching the EDK2 version is the same - you need to write the image to two media (SD card and USB flash drive) and use them simultaneously. 0 Quote
Merblud Posted January 4, 2023 Posted January 4, 2023 What happens if a sata-enabled kernel is loaded at the time when the nvme ssd was connected. Or vice versa. Can the ssd be damaged (physically)? 0 Quote
balbes150 Posted January 13, 2023 Author Posted January 13, 2023 The latest versions using EDK2 can now be downloaded from the link. https://users.armbian.com/balbes150/edk2/ 0 Quote
w1nner4fun Posted January 16, 2023 Posted January 16, 2023 (edited) Hi gents, Can anyone share some knowledge on how to dual boot StationOS and Armbian? I've just installed a SATA 2242 ssd and would like to install Armbian on it. I've checked out the stationOS website and it says it's done via "OS Assistant" app which should be in the stationOS firmware. Problem is that there is no such OS Assistant app in the latest stationOS firmware which is installed on my M3 box. The M3 support is on holidays for the Chinese new year and there is no information on their wiki either. Also, if someone has this OS Assistant apk, can you share it please? Thanks. Edited January 16, 2023 by w1nner4fun 0 Quote
balbes150 Posted February 9, 2023 Author Posted February 9, 2023 Version 20230208 kernel 5.10.110. The kernel configuration has changed, driver support has been added to install additional packages with HW 3D support (ARM blobs and panfork). When testing different variants on Station M3, the results were obtained. steps to run HW with the latest images When using DE with x11 (KDE5 XFCE + mesa-panfork) - glmark2 shows about 1100 parrots. sudo add-apt-repository ppa:liujianfeng1994/panfork-mesa sudo apt dist-upgrade reboot When using gnome3+ARM bob, glmark2-es2-wayland showed about 4,400 parrots. download https://github.com/numbqq/mali-debs/blob/master/jammy/arm64/Edge2/wayland/linux-gpu-mali-wayland_1.0-g610-20220510_arm64.deb and install it into the system with the command : sudo dpkg -i --force-overwrite linux-gpu-mali-wayland_1.0-g610-20220510_arm64.deb reboot First of all, I was interested in running KDE5 + wayland, but checking both options (ARM blobs or panfork) did not give results, the GUI does not run in wayland mode, although when using the main kernel + panfrost on rk33xx rk356x, KDE5+wayland works well. surprisingly, even the weakest system (station m1 rk3328 with 1 GB of RAM) was able to work acceptably even with 1920 x 1080 desktop settings (plays full-screen video). Running panfork on gnome 3 + wayland didn't work, I think I made some mistakes, but gnome 3 doesn't interest me, so I didn't waste time on it. Add info steps to run HW with the latest images. 0 Quote
balbes150 Posted February 16, 2023 Author Posted February 16, 2023 Version 20230216. Added support for automatic fan control. 0 Quote
balbes150 Posted February 19, 2023 Author Posted February 19, 2023 New version 20230219 with direct support for launching from USB. You don't need to copy anything manually anymore. When installing a new bootloader on eMMC, you get the opportunity to directly start the system from USB without using any additional devices. At the same time, you get the opportunity to start from USB when using SD\eMMC\NVMe, i.e. if you have these media with your system, when you connect USB to the system, when you turn on the power, the system starts from the beginning with USB. This is convenient for quick startup of other systems, without the need to change something or disconnect other media (SD\NVMe). For example, you can install the main Ubuntu system on NVMe and at any time quickly launch another version from USB - Debian, etc. 0 Quote
w1nner4fun Posted February 24, 2023 Posted February 24, 2023 Hi, I tried two of the images today, the 20230219 Armbian_23.02.0-trunk_Station-m3_jammy_legacy_5.10.110_kde-plasma_desktop.img and 20230217 Armbian_23.02.0-trunk_Station-m3_jammy_legacy_5.10.110_kde-plasma_desktop.img But both of these images just stop/freeze after creating the user account, at "entering the desktop environment". I just have the mouse coursor frozen in the middle of the screen on black background. FYI, I'm using a USB wireless Logitech mouse. I have waited like 10 minutes to see if will go through and then unplugged power and booted again. Still the same after reboot. It just stops after mouse coursor appears on the black screen. The older images (the ones that had full speed fan) didn't show this issue. Can you please advise? Thanks in advance. 0 Quote
w1nner4fun Posted February 24, 2023 Posted February 24, 2023 Just tried GNOME Armbian_23.02.0-trunk_Station-m3_jammy_legacy_5.10.110_gnome_desktop.img and it doesn't have this problem. I can access desktop without issues. I'd like to try the kde too, please help. 0 Quote
balbes150 Posted February 24, 2023 Author Posted February 24, 2023 16 минут назад, w1nner4fun сказал: I'd like to try the kde too, please help There are several solutions. The simplest one is after the first login (after the initial setup, when the screen is black with the mouse cursor), wait 10-15 minutes (this is the time to reset the automatic login), turn off the power and turn it on again so that the LIGHTDM screen appears, select the x11 option (do not use wayland until the ARM-BLOB package is installed). Or switch to the console (Ctrl+Alt+F2), and install the ARM-BLOB or Panfork package and reboot the system. 0 Quote
w1nner4fun Posted February 24, 2023 Posted February 24, 2023 I've just tried waiting longer than 15 minutes but the lightdm screen didn't appear. Just the frozen mouse cursor on black background. Also tried switching to console (Ctrl+Alt+F2 right after boot) after setup was done, but nothing happened. It would just go again to the mouse cursor on black background. Also tried this key combination when the mouse coursor is on screen but no luck, as I didn't know when to input the Ctrl+Alt+F2 combination. Anyway, I've had the idea of using putty on my desktop PC and succeeded to access the M3's console. There I've typed sudo systemctl enable lightdm and rebooted. This worked. Thanks, I can now try the KDE! 0 Quote
balbes150 Posted February 25, 2023 Author Posted February 25, 2023 14 часов назад, w1nner4fun сказал: I've just tried waiting longer than 15 minutes but the lightdm screen didn't appear. Just the frozen mouse cursor on black background. Nothing should appear on the screen at the first start, you are waiting only for the auto-login to be turned off automatically during this time and at the next reboot you will get a working login screen to choose which version to use (x11 or wayland). 14 часов назад, w1nner4fun сказал: Also tried switching to console (Ctrl+Alt+F2 right after boot) after setup was done, but nothing happened. It would just go again to the mouse cursor on black background. Also tried this key combination when the mouse coursor is on screen but no luck, as I didn't know when to input the Ctrl+Alt+F2 combination. You need to switch to the console no earlier than 10-15 minutes, only after all automatic processes are completed. 0 Quote
Darkdonut Posted February 25, 2023 Posted February 25, 2023 Hi! Thank you for your very nice work and usable images, the only 2 problems left for me are : 1. When i enable the nvme dtb in extlinux.conf i loose the fan, it don't spin when system is on BUT it goes full speed a fraction of second when powering off the system. (fan is ok with the default dtb) 2. in the instructions for enabling 3D acceleration (the panfork way) ,my system (nvme dtb) don't have access to DMC peripheral (/sys/class/devfreq/dmc/governor) for setting the governor the performance, hence mid-low glmark2 score. PS: my system is copied to nvme and booted from sdcard, and the board is one of the very first batch sold by firefly roc-rk3588s-pc (v0.1) 0 Quote
balbes150 Posted February 28, 2023 Author Posted February 28, 2023 25.02.2023 в 15:45, Darkdonut сказал: . When i enable the nvme dtb in extlinux.conf i loose the fan, it don't spin when system is on BUT it goes full speed a fraction of second when powering off the system. (fan is ok with the default dtb) I checked the fan operation with NVMe. Yes, there is a problem (I observe a different situation - the fan is constantly running at high speed.) - the control does not work, the reason is the change of parameters (when the NVMe is physically connected, the control parameter changes). The control parameter is hard-coded in a binary file that is represented by Firefly. I have requested Firefly sources or a new binary version for NVMe. 25.02.2023 в 15:45, Darkdonut сказал: 2. in the instructions for enabling 3D acceleration (the panfork way) ,my system (nvme dtb) don't have access to DMC peripheral (/sys/class/devfreq/dmc/governor) for setting the governor the performance, hence mid-low glmark2 score. All these "points" are marketing nonsense that you should not pay attention to. I recommend using ARM-blob, you can take deb packages from Firefly or connect their repository and install them over the network (see their Ubuntu image for details). 0 Quote
balbes150 Posted March 2, 2023 Author Posted March 2, 2023 25.02.2023 в 15:45, Darkdonut сказал: 1. When i enable the nvme dtb in extlinux.conf i loose the fan, it don't spin when system is on BUT it goes full speed a fraction of second when powering off the system. (fan is ok with the default dtb) To operate the automatic fan control when using NVMe, replace the /usr/bn/firefly-fan-control file with the new version at the link. https://disk.yandex.ru/d/2ltDBcIso0z9hg 0 Quote
netter Posted March 2, 2023 Posted March 2, 2023 How we can operate automatic fan control?? I've changed dtb to nvme version and the new file firefly_fan_control and has the same problem: fan is full of RPM all time. I've checked the dtb of official ubuntu in StationOS page, and nvme is ok an fan too, changing the content of dtb file, but in armbian i cannot to do it. Note: best regards all members, and thanks for your work. I'm new in forum. 0 Quote
balbes150 Posted March 3, 2023 Author Posted March 3, 2023 12 часов назад, netter сказал: I've changed dtb to nvme version and the new file firefly_fan_control and has the same problem: fan is full of RPM all time. What image are you using ? This only works in the latest versions >= 20230216 0 Quote
Darkdonut Posted March 4, 2023 Posted March 4, 2023 (edited) Hi thank you for being so quick , tested your new files, the fan spins but with an erratic behavior , it seems to start normally, the speed goes down at first but when i run glmark , it goes down until it stops completely while the load should(?) be generating more heat , tested with the latest image == 20230303 Edited March 4, 2023 by Darkdonut 0 Quote
netter Posted March 6, 2023 Posted March 6, 2023 Yes, is the latest version. The problem was the execution permission. Granted execution permission to root, was able to execute the fan control. The new problem is the same of Darkdonut: the fan not stops completely when device is running. When M3 run the official Ubuntu version of Firefly, the fan stops completely and only run when the SOC is hot. Thanks. 0 Quote
balbes150 Posted March 6, 2023 Author Posted March 6, 2023 If you have any questions about the automatic operation of the fan, contact the manufacturer. He provided only closed binary files, respectively, what and how it works is not available to me. p.s. On my model rk3588s-roc-pc, the fan does not stop completely with any versions and systems, including with all official versions of Ubuntu. 0 Quote
netter Posted March 6, 2023 Posted March 6, 2023 ok. I will investigate. Thanks for your work. 0 Quote
w1nner4fun Posted March 9, 2023 Posted March 9, 2023 On 3/6/2023 at 2:53 PM, balbes150 said: On my model rk3588s-roc-pc, the fan does not stop completely with any versions and systems, including with all official versions of Ubuntu. I've also tried firefly's official systems, both Ubuntu and Debian. I can confirm that the fan doesn't stop completely on neither of them. It slows down enough to keep noise low, just like it does with latest armbian image (thanks for that balbes150's) 0 Quote
balbes150 Posted March 22, 2023 Author Posted March 22, 2023 Version 20230322-edge with kernel 6.2 (pancsf-midstream). HDMI USB LAN works and you can enable HW acceleration for 3d. For details on how to enable acceleration, see this topic. 0 Quote
