flot010 Posted September 10, 2022 Posted September 10, 2022 I can't seem to get apt-get update to work, this is a fresh install anyone know the fix? mango@nezha:~$ sudo apt-get update Hit:3 http://ports.ubuntu.com jammy InRelease Hit:4 http://ports.ubuntu.com jammy-security InRelease Hit:5 http://ppa.launchpadcontent.net/oibaf/graphics-drivers/ubuntu jammy InRelease Hit:6 http://ports.ubuntu.com jammy-updates InRelease Hit:7 http://ports.ubuntu.com jammy-backports InRelease Hit:1 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Hit:2 https://cli.github.com/packages stable InRelease Err:2 https://cli.github.com/packages stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 Reading package lists... Done N: Skipping acquire of configured file 'main/binary-riscv64/Packages' as repository 'http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease' doesn't support architecture 'riscv64' W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://cli.github.com/packages stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 W: Failed to fetch http://cli.github.com/packages/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 W: Some index files failed to download. They have been ignored, or old ones used instead. 0 Quote
Werner Posted September 10, 2022 Posted September 10, 2022 Hi, Talk to the owner of the repo to provide the necessary key. No idea who is that though, certainly not us. Never saw those addresses. Therefore most likely not an official Armbian image but some 3rd party work. 0 Quote
MaxT Posted September 10, 2022 Posted September 10, 2022 Have the very same issue with image just taken from Armbian downloads (RockPi 4B, current, jammy) 0 Quote
Werner Posted September 10, 2022 Posted September 10, 2022 Can you verify that the file /usr/share/keyrings/githubcli.gpg is there? 0 Quote
Solution Igor Posted September 10, 2022 Solution Posted September 10, 2022 6 hours ago, flot010 said: I can't seem to get apt-get update to work, this is a fresh install anyone know the fix? No Linux is having full control over its component made by thousands of people. This particular problem was caused by this https://github.com/cli/cli/issues/6175 where you can find instructions how to fix a problem you have. I already fixed the key, so future releases will have this fixed https://github.com/armbian/build/pull/4163 1 Quote
MaxT Posted September 10, 2022 Posted September 10, 2022 Igor, thank you for your efforts and keeping an eye on things! 0 Quote
flot010 Posted September 10, 2022 Author Posted September 10, 2022 Thank you for fixing it Igor! 1 Quote
dev001 Posted September 22, 2022 Posted September 22, 2022 I'm using Odroid-C2 and using Armbian 22.08 Jammy XFCE build (Armbian_22.08.1_Odroidc2_jammy_current_5.10.139_xfce_desktop.img) from https://www.armbian.com/odroid-c2/. When updating the repository before an upgrade, I get a signature verification issue. $ sudo apt-get update Hit:4 http://deb.volian.org/volian scar InRelease Hit:6 http://ports.ubuntu.com jammy InRelease Get:1 https://cli.github.com/packages stable InRelease [3,917 B] Hit:7 http://ppa.launchpadcontent.net/saiarcot895/chromium-beta/ubuntu jammy InRelease Hit:8 http://ports.ubuntu.com jammy-security InRelease Hit:2 http://armbian.chi.auroradev.org/apt jammy InRelease Hit:3 https://box64.debian.ryanfortner.dev/debian ./ InRelease Hit:9 http://ports.ubuntu.com jammy-updates InRelease Hit:10 http://ppa.launchpadcontent.net/mozillateam/ppa/ubuntu jammy InRelease Hit:5 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Hit:11 http://ports.ubuntu.com jammy-backports InRelease Hit:12 http://ppa.launchpadcontent.net/oibaf/graphics-drivers/ubuntu jammy InRelease Err:1 https://cli.github.com/packages stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://cli.github.com/packages stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 W: Failed to fetch http://cli.github.com/packages/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 W: Some index files failed to download. They have been ignored, or old ones used instead. 0 Quote
NicoD Posted September 22, 2022 Posted September 22, 2022 I noticed the same on a fresh image on the Station P1. So the fix from above was : sudo apt-key del C99B11DEB97541F0 && sudo rm /etc/apt/sources.list.d/githubcli.list But sudo rm /etc/apt/sources.list.d/githubcli.list I think this should be sufficient since it ain't doing the apt-key thing. There was a small mistake in the original source. github-cli.list vs githubcli.list 0 Quote
vlad_cool Posted October 5, 2022 Posted October 5, 2022 Maybe replacing url in /etc/spt/sources.list to `http://old-releases.ubuntu.com/ubuntu` can help? It worked for me, but I had a bit different error. 0 Quote
armisstrong69 Posted October 6, 2022 Posted October 6, 2022 https://github.com/cli/cli/issues/6175 I say the solution mentioned here was to: apt-key del C99B11DEB97541F0 && sudo rm /etc/apt/sources.list.d/github-cli.list So I am assuming I should replace C99B11DEB97541F0 with the key code I got in my error? Looks asking because concerned this might break my system... 0 Quote
armisstrong69 Posted October 10, 2022 Posted October 10, 2022 I see this is the beginners section so mind as a beginner I had difficulty following the solution to the problem presented here Igor posted the "solution" which is I quote Quote "No Linux is having full control over its component made by thousands of people. This particular problem was caused by this https://github.com/cli/cli/issues/6175 where you can find instructions how to fix a problem you have. I already fixed the key, so future releases will have this fixed https://github.com/armbian/build/pull/4163 So I went to the first link he posted for the "instructions" and saw the first post stating a sort of diagnostic for the error, and a large amount of following comments from the community, one of these comments was from a user called "rmw" where he says, Quote "We are working on an update for Codespaces. (Update: #6175 (comment)) If you are seeing issues in Actions workflows, please share more details in this issue. Manually, you are able to reset your system with sudo apt-key del C99B11DEB97541F0 && sudo rm /etc/apt/sources.list.d/github-cli.list" 0 Quote
armisstrong69 Posted October 10, 2022 Posted October 10, 2022 Sorry to double post but it was not letting my type anything after that last quote I made.. So I did "sudo apt-key del C99B11DEB97541F0 && sudo rm /etc/apt/sources.list.d/github-cli.list" and then tried again "sudo apt-get update" and heres my output excluding a lot GET links. Get:21 http://deb.debian.org/debian sid/contrib armhf Packages T-2022-10-10-1406.43-F-2022-10-08-1410.42.pdiff [335 B] Fetched 1817 kB in 10s (185 kB/s) Reading package lists... Done W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://cli.github.com/packages stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA7571xxxx W: Failed to fetch http://cli.github.com/packages/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA7571xxxx W: Some index files failed to download. They have been ignored, or old ones used instead. Put xxxx for the last Pubkey numbers for security (idk I am a beginner). I also tried to tinker changing the pubkey using different sources before, idk if this may have caused a problem. This future release that fixes this Igor mentions hasn't been released yet? (I saw latest release is still from August) Please help, Thanks 0 Quote
Andro Posted October 18, 2022 Posted October 18, 2022 Fresh install of Armbian 22 XFCE as at today and exact same issue. This does not appear to be fixed? W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://cli.github.com/packages stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 W: Failed to fetch http://cli.github.com/packages/dists/stable/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23F3D4EA75716059 0 Quote
armisstrong69 Posted October 18, 2022 Posted October 18, 2022 (edited) Atleast tell me if you are seething because you dont like my wording in the title or something like that... I am about to give up on this distro due to lack of support. Edited October 18, 2022 by armisstrong69 0 Quote
Igor Posted October 18, 2022 Posted October 18, 2022 5 hours ago, Andro said: This does not appear to be fixed? Problem was fixed in sources, but images still have this purely cosmetic problem. Operation of full images rebuilt is very expensive as it takes several days. You do expect images are tested, even that is almost exclusively our private cost. 5 hours ago, armisstrong69 said: due to lack of support. There is nothing more to support. Problem was solved. If you are not satisfied with a solution and you want more then your contracts provides, I am gladly willing to help you on commercial terms. 0 Quote
armisstrong69 Posted October 18, 2022 Posted October 18, 2022 (edited) 17 hours ago, Igor said: There is nothing more to support. Problem was solved. If you are not satisfied with a solution and you want more then your contracts provides, I am gladly willing to help you on commercial terms. Dear masterful and gracious Igor, please enlighten us Beginners and help us understand this solution we are misunderstanding! Please have pity on us sinful and dumb beginners! I laid out my confusion regarding the solution in detail in a previous thread but it was just merged with this one! Edited October 18, 2022 by armisstrong69 0 Quote
Igor Posted October 19, 2022 Posted October 19, 2022 7 hours ago, armisstrong69 said: Please have pity on us sinful and dumb beginners! Do you understand what "best effort support" means? And why software is released under such terms? Don't you think we would not rather tell you - "dear users. Thank you for downloading our investment. If you have any problems with your computer, come, we will be happy to solve it " - if that would be possible? Check support terms once again and try to understand who pays that? When you are taking your car to the car repair shop. Do you expect they will pay for the parts and service or is that on you to cover? Its not about you. This community has limited answering capacity and if you don't behave, you are only lowering your chances of getting attention. Look around - you are not the only one asking for something. 0 Quote
armisstrong69 Posted October 19, 2022 Posted October 19, 2022 15 hours ago, Igor said: Its not about you. tfw 0 Quote
armisstrong69 Posted October 20, 2022 Posted October 20, 2022 10 hours ago, Igor said: Patience For an update? I am about to change distro, I REALLY AM GOING IT DO IT!!! 😬 0 Quote
Igor Posted October 20, 2022 Posted October 20, 2022 25 minutes ago, armisstrong69 said: For an update? Patience for getting human response on whatever your problem is. 25 minutes ago, armisstrong69 said: I am about to change distro Before you are going to switch some problems with another, please read this FAQ. 0 Quote
armisstrong69 Posted October 21, 2022 Posted October 21, 2022 On 10/18/2022 at 1:56 AM, Igor said: I am gladly willing to help you on commercial terms. Ok man name your price, I already waited a while on this thread. I need my apt update man, how much u want. I aint got much but Ill see what I can do. 0 Quote
Werner Posted October 22, 2022 Posted October 22, 2022 More information about personalized/professional support is available here: https://github.com/armbian/build#support 0 Quote
armisstrong69 Posted October 22, 2022 Posted October 22, 2022 8 hours ago, Werner said: More information about personalized/professional support is available here: https://github.com/armbian/build#support Noob question sir, will this erase the data I have on my current Armbian install? Wondering if this is a reinstall before I attempt. Thanks. Igor your git there looks good man. Did Igor found Armbian?! 0 Quote
Werner Posted October 22, 2022 Posted October 22, 2022 Personalized support will not erase your data unless specifically asked for. Yes, Igor is the founder of the Armbian project. Feel free to watch the video from the BalCCon2K17 on which he also talks a bit about the early days of Armbian: https://www.armbian.com/authors/ 0 Quote
armisstrong69 Posted October 24, 2022 Posted October 24, 2022 On 10/22/2022 at 10:48 AM, Werner said: Personalized support Ok after ./compile.sh there was a pubkey error while it was trying to update (how ironic), and now im at a GUI menu that has 2 options... U-boot and Kernel Packages and Full OS Image for flashing... Ok... Please bear with me as I am a beginner in this beginner thread, and I dont know which of those two options I should select to fix my apt update pubkey error. I appreciate you for trying to help, and Igor for developing all this stuff. 0 Quote
armisstrong69 Posted October 29, 2022 Posted October 29, 2022 The support doesnt seem very personalized imo. 0 Quote
armisstrong69 Posted October 31, 2022 Posted October 31, 2022 (edited) Is this fixed in the new version? There is no Debian edition? Edited October 31, 2022 by armisstrong69 0 Quote
