  • After updating 5.67, the return value of PING is too large. I suspect that there is a problem with the NIC driver. Please check the driver.
On 10/9/2018 at 8:41 PM, talraash said:
Nexbox a95x(soc amlogic s905 ram 1 storage 8)
All image with kernel 3.14 work with generic gxbb_p200.dtb(old u-boot). Don't have now this box, so don't have opportunity check mainline.  It have some exotic wi-fi module without open sources drivers, so no wi-fi.
Sunvell T95X(soc amlogic s905x ram 2 storage 8).
All image with kernel 3.14 and mainline. With stock firmware don't need manipulate with .dtb files(3.14 kernel), for mainline need generic p212 dtb. Wi-fi  sci9082c, didn't test.
  Hide contents
It don't have open sources drivers...
On 10/22/2018 at 1:39 PM, talraash said:
  Hide contents
really? you quote message with "armbian 5.37 based on 3.14.29" And ask quesions... upd it's not my post but it's clear write that you can use out of box image with kernel 3.14... Is it hard?)
On 10/25/2018 at 2:08 PM, jeanrhum said:
Since I upgrade frequently, I think there is not too much difference. Armbian tools and firmware are updated as other packages. Of course there should be some specific modifications of Balbes after each update he made.
If 5.41 has mali, it is useless for me since I use my box as a server.
Hello, I have beelink GT1 but not ultimate CPU Amlogic S912, GPU Mali-T820MP3 with 2GB and 32GB of RAM I have been trying unsuccessfully with Armbian_5.41.1_S9xxx_Debian_stretch_3.14.29_icewm_20180406 for having the same kernel so I try now with Armbian_5.37_S9xxx_Debian_stretch_3.14.29_icewm_20171226 but I do not recognize WIFI (Ateros chip CQA9377), which dtb can work? I'm still trying with vegas_s96.dtb Thanks in advance.
With 3.14 kernel, I use the dtb of android img that is stored on emmc. So this is the Beelink dtb. In fact it is automatically used when you don't put a dtb file at the root of the sd card. I'll try to install it again, since a recent upgrade broke my system (no ethernet anymore). New images (4.xx) of Balbes does not really work on my box (no ethernet and no usb even if it boots).
I am trying to install Armbian 5.67 on my MXQ PRO 4K but I always have a black screen after the first reboot. I tried the p200 and p201 dtb's but that didn't work either.
Funny thing is I'm able to boot LibreElec and such with the p201 dtb but not Armbian. All i wanted to do really was compile some add-ons for aarch64.
You must use the 281 dtb.
I tested it with my android tv box, found the 5.37 version (3.14.29) best and very stable.
I tested version 5.44 has a midi sequencer with this kennel, but there are many problems.
So I need to use the midi sequencer with 5.37 version,  I noob linux. Can you describe the process of compiling kernels?
Thank you
Thank you
It is described a few pages back.
Hello, I have been testing with several dtb's, I will try without them as you indicate that it assumes by default. Anyway both ubuntu and debian in kernel 3.14.29 linux-headers do not appear and I can not install wifi drivers, if you upgrade to some higher version is blocked, I only run now with ethernet. I will keep trying but I can not get the linux-headers in any way (i'm so too bad with linux). Thank you
I didn't test if wif was working (I think it wasn't), because I only used ethernet.
Did you copy the 281 dtb to the root of BOOT and rename it to dtb.img?
Alternatively, where do I find the kernel headers for 3.14.29? I need to compile the dvb drivers and the only packages with 3.14.29 are:
luca@aml:~$ apt-cache search 3.14.29
linux-dtb-aml-s9xxx - Linux DTB, version 3.14.29
linux-image-aml-s9xxx - Linux kernel, version 3.14.29
No linux headers.
13 minutes ago, olivluca said:
I see those debs are version 5.41, the image I'm using has 5.44. I suppose that's OK (the kernel is the same version).
Actually it doesn't seem to be OK.
Before trying the lengthy compilation of the dvb modules needed, I just tried with the hello module and:
luca@aml:~/hello$ sudo insmod hello.ko
[sudo] password for luca:
Segmentation fault
relevant lines from dmesg
[  127.554547] EBB: Hello world from the BBB LKM!
[  127.554567] Unable to handle kernel paging request at virtual address 557723e008
[  127.556478] pgd = ffffffc0615b2000
[  127.560013] [557723e008] *pgd=00000000615e2003, *pmd=0000000000000000
[  127.566573] Internal error: Oops: 96000006 [#1] PREEMPT SMP
[  127.572262] Modules linked in: hello(O) zram joydev aml_nftl_dev(P)
[  127.578647] CPU: 0 PID: 4784 Comm: insmod Tainted: P           O 3.14.29-aml-s9xxx-ge672901-dirty #32
[  127.587959] task: ffffffc0615c4000 ti: ffffffc062a08000 task.ti: ffffffc062a08000
[  127.595555] PC is at module_put+0x48/0xe0
[  127.599691] LR is at load_module+0x16f0/0x1ee0
[  127.604259] pc : [<ffffffc001113bf0>] lr : [<ffffffc001117368>] pstate: 60000145
[  127.611762] sp : ffffffc062a0bd00
[  127.615212] x29: ffffffc062a0bd00 x28: 0000000000000001
[  127.620645] x27: ffffffc061586dc8 x26: ffffffc002081a60
[  127.626079] x25: ffffffc061586d80 x24: ffffffbffc02d0d0
[  127.631513] x23: ffffffc062a08000 x22: ffffffc001117368
[  127.636946] x21: ffffffc062a08000 x20: ffffffbffc02d0d0
[  127.642380] x19: ffffffc002081a98 x18: 0000000000000002
[  127.647814] x17: 0000000000000007 x16: 0000000000000001
[  127.653248] x15: 0000000000000000 x14: ffffffc082160287
[  127.658681] x13: ffffffc002160296 x12: 000000000000003c
[  127.664115] x11: ffffffc062a0ba40 x10: ffffffc062a0ba40
[  127.669549] x9 : 0000000000087633 x8 : 6874206d6f726620
[  127.674982] x7 : 646c726f77206f6c x6 : ffffffc0021602bb
[  127.680416] x5 : 0000000000000000 x4 : 0000000000000000
[  127.685850] x3 : 0000000000000000 x2 : 000000007723e000
[  127.691283] x1 : 0000000000000000 x0 : 0000005500000008
[  127.696718]
               PC: 0xffffffc001113b70:
[  127.701979] 3b70  b90052a0 35fffc40 f94002a0 360ffc00 94286560 17ffffde 52800033 2a1303e0
[  127.710259] 3b90  a9425bf5 a94153f3 a8c37bfd d65f03c0 52800013 17ffffd7 a9bd7bfd 910003fd
[  127.718539] 3bb0  a90153f3 a9025bf5 aa0003f4 aa1e03f6 aa1e03e0 d503201f b40002b4 910003e0
[  127.726818] 3bd0  9272c415 b94052a0 11000400 b90052a0 d5033abf f9410a80 d538d082 91002000
[  127.735098] 3bf0  f8626801 91000421 f8226801 d503201f b94052a0 51000400 b90052a0 35000080
[  127.743378] 3c10  f94002a0 36080040 9428653a a94153f3 a9425bf5 a8c37bfd d65f03c0 d503201f
[  127.751659] 3c30  b94052a0 11000400 b90052a0 b00081c0 91266000 f9403413 b4000113 f9400263
[  127.759939] 3c50  f9400660 aa1603e2 aa1403e1 d63f0060 f8410e63 b5ffff63 b94052a0 51000400
[  127.768219]
               LR: 0xffffffc0011172e8:
[  127.773480] 72e8  97fda8b4 2a0003f4 7100001f 5400068b 54000160 90005140 9123e004 910a8084
[  127.781760] 7308  2a1403e3 aa1503e2 aa0403e1 f00065c0 91326000 942835b2 942843d1 b900031f
[  127.790040] 7328  91298340 aa1803e2 d2800001 91006000 97feb25a f9400ae0 b9401400 36700040
[  127.798320] 7348  97feba6e 9129835a 52800014 9100e353 aa1303e0 94285ef7 aa1803e0 97fff211
[  127.806600] 7368  aa1803e0 940f2965 b9417703 f940b702 f9409b01 f940c300 f900b302 b9017303
[  127.814880] 7388  f900bf00 aa1803e0 97fff8bc f9009b1f b901431f aa1303e0 b9014b1f b901531f
[  127.823160] 73a8  94285f18 d2800003 52800002 52800061 91034340 97ff22ed 17fffb26 52800040
[  127.831440] 73c8  b9000300 97ff9be3 aa1803e0 97fff1f5 aa1803e2 d2800041 aa1603e0 97feb22f
[  127.839721]
               SP: 0xffffffc062a0bc80:
[  127.844981] bc80  fc02d0d0 ffffffbf 62a08000 ffffffc0 01117368 ffffffc0 62a08000 ffffffc0
[  127.853261] bca0  fc02d0d0 ffffffbf 61586d80 ffffffc0 02081a60 ffffffc0 61586dc8 ffffffc0
[  127.861541] bcc0  00000001 00000000 62a0bd00 ffffffc0 01117368 ffffffc0 62a0bd00 ffffffc0
[  127.869821] bce0  01113bf0 ffffffc0 60000145 00000000 62a08000 ffffffc0 fc02d120 ffffffbf
[  127.878101] bd00  62a0bd30 ffffffc0 01117368 ffffffc0 02081a98 ffffffc0 00000000 00000000
[  127.886381] bd20  fc02d0e8 ffffffbf 02081a78 ffffffc0 62a0be40 ffffffc0 01117d28 ffffffc0
[  127.894661] bd40  00000000 00000000 00000003 00000000 6d5cb328 00000055 7efda8f4 0000007f
[  127.902941] bd60  40000000 00000000 00000015 00000000 00000117 00000000 00000111 00000000
[  127.911224]
               X6: 0xffffffc00216023b:
[  127.916483] 0238  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  127.924762] 0258  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  127.933042] 0278  00000000 00000000 00000001 00000000 30303020 32303330 34303330 5d304032
[  127.941323] 0298  39323020 37322038 3131392e 40343232 58205d30 30203a36 66666678 63666666
[  127.949603] 02b8  31323030 33323036 310a3a62 33373131 5d3e3836 74737020 3a657461 30303620
[  127.957882] 02d8  34313030 2d0a0a35 37366567 31303932 7269642d 23207974 6f0a3233 616e7275
[  127.966163] 02f8  6f63206c 70757272 20646574 7520726f 656c636e 796c6e61 75687320 6f642074
[  127.974442] 0318  202c6e77 616e6572 676e696d 646e6120 70657220 6963616c 0a2e676e 756f7267
[  127.982722] 0338  61622070 20646573 65726966 6c6c6177 2e676e69 4f4d4b0a 492d2044 20324e44
[  127.991004]
               X10: 0xffffffc062a0b9c0:
[  127.996350] b9c0  61586dc8 ffffffc0 00000001 00000000 62a0ba40 ffffffc0 62a0ba40 ffffffc0
[  128.004630] b9e0  62a0ba10 ffffffc0 ffffffd0 00000000 62a0ba40 ffffffc0 62a0ba40 ffffffc0
[  128.012910] ba00  62a0ba10 ffffffc0 ffffffd0 00000000 0000007f 00000000 00087633 00000000
[  128.021190] ba20  00000000 00000000 00000002 00000000 01dcfced ffffffc0 01dcfcf6 ffffffc0
[  128.029470] ba40  62a0ba60 ffffffc0 010ecd80 ffffffc0 02160288 ffffffc0 021794b0 ffffffc0
[  128.037750] ba60  62a0ba90 ffffffc0 010ecf70 ffffffc0 00000000 00000000 00000000 00000000
[  128.046030] ba80  00000022 00000000 014ed544 ffffffc0 62a0bb00 ffffffc0 010ededc ffffffc0
[  128.054310] baa0  021794b0 ffffffc0 000001c0 00000000 62a0bae0 ffffffc0 010edcc0 ffffffc0
[  128.062591]
               X11: 0xffffffc062a0b9c0:
[  128.067938] b9c0  61586dc8 ffffffc0 00000001 00000000 62a0ba40 ffffffc0 62a0ba40 ffffffc0
[  128.076218] b9e0  62a0ba10 ffffffc0 ffffffd0 00000000 62a0ba40 ffffffc0 62a0ba40 ffffffc0
[  128.084497] ba00  62a0ba10 ffffffc0 ffffffd0 00000000 0000007f 00000000 00087633 00000000
[  128.092777] ba20  00000000 00000000 00000002 00000000 01dcfced ffffffc0 01dcfcf6 ffffffc0
[  128.101058] ba40  62a0ba60 ffffffc0 010ecd80 ffffffc0 02160288 ffffffc0 021794b0 ffffffc0
[  128.109338] ba60  62a0ba90 ffffffc0 010ecf70 ffffffc0 00000000 00000000 00000000 00000000
[  128.117618] ba80  00000022 00000000 014ed544 ffffffc0 62a0bb00 ffffffc0 010ededc ffffffc0
[  128.125898] baa0  021794b0 ffffffc0 000001c0 00000000 62a0bae0 ffffffc0 010edcc0 ffffffc0
[  128.134179]
               X13: 0xffffffc002160216:
[  128.139525] 0214  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.147805] 0234  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.156085] 0254  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.164365] 0274  00000000 00000000 00000000 00000001 00000000 30303020 32303330 36333430
[  128.172645] 0294  5d304035 39323020 38322034 3433312e 40393731 58205d30 203a3331 66667830
[  128.180925] 02b4  66666666 32303063 32303631 0a3a3631 33373131 5d3e3836 74737020 3a657461
[  128.189205] 02d4  30303620 34313030 2d0a0a35 37366567 31303932 7269642d 23207974 6f0a3233
[  128.197485] 02f4  616e7275 6f63206c 70757272 20646574 7520726f 656c636e 796c6e61 75687320
[  128.205765] 0314  6f642074 202c6e77 616e6572 676e696d 646e6120 70657220 6963616c 0a2e676e
[  128.214046]
               X14: 0xffffffc082160207:
[  128.219393] 0204  ******** ******** ******** ******** ******** ******** ******** ********
[  128.227673] 0224  ******** ******** ******** ******** ******** ******** ******** ********
[  128.235953] 0244  ******** ******** ******** ******** ******** ******** ******** ********
[  128.244232] 0264  ******** ******** ******** ******** ******** ******** ******** ********
[  128.252513] 0284  ******** ******** ******** ******** ******** ******** ******** ********
[  128.260793] 02a4  ******** ******** ******** ******** ******** ******** ******** ********
[  128.269073] 02c4  ******** ******** ******** ******** ******** ******** ******** ********
[  128.277353] 02e4  ******** ******** ******** ******** ******** ******** ******** ********
[  128.285633] 0304  ******** ******** ******** ******** ******** ******** ******** ********
[  128.293915]
               X19: 0xffffffc002081a18:
[  128.299260] 1a18  02081a18 ffffffc0 02081a18 ffffffc0 00000000 00000000 00000000 00000000
[  128.307540] 1a38  00000004 00000000 01111260 ffffffc0 0208f1c8 ffffffc0 00000000 00000000
[  128.315820] 1a58  00000008 00000000 fc000000 ffffffbf fc02d0d8 ffffffbf fc014980 ffffffbf
[  128.324099] 1a78  00000000 00100010 02081a80 ffffffc0 02081a80 ffffffc0 02087e68 ffffffc0
[  128.332380] 1a98  00000000 00000000 02081aa0 ffffffc0 02081aa0 ffffffc0 615c4000 ffffffc0
[  128.340661] 1ab8  00000000 00000000 01e73798 ffffffc0 00000124 00000000 01114390 ffffffc0
[  128.348940] 1ad8  00000000 00000000 01114310 ffffffc0 01112948 ffffffc0 01113ee8 ffffffc0
[  128.357220] 1af8  01dd2d70 ffffffc0 00000080 00000000 00000000 00000000 011140b0 ffffffc0
[  128.365501]
               X21: 0xffffffc062a07f80:
[  128.370847] 7f80  00000000 00000000 8f356000 0000007f 8f3575a0 0000007f 8f3b77a0 0000007f
[  128.379127] 7fa0  00000002 00000000 00000000 00000000 8f35b000 0000007f d3d1e530 0000007f
[  128.387408] 7fc0  8f238f24 0000007f d3d1e530 0000007f 8f2a6aec 0000007f 60000000 00000000
[  128.395687] 7fe0  00000000 00000000 0000005e 00000000 ad77e8d8 35a00244 9a7153fe 829df003
[  128.403967] 8000  00000002 00000000 ffffffff ffffffff 615c4000 ffffffc0 02078bf0 ffffffc0
[  128.412247] 8020  010ad3c8 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[  128.420528] 8040  00000000 00000000 00000000 00000000 00000003 00000000 57ac6e9d 00000000
[  128.428808] 8060  76f0fe92 456d6c56 ab369d3a 814ddcee 9b2cd2d7 3a7da748 e53133de 459269cb
[  128.437089]
               X22: 0xffffffc0011172e8:
[  128.442435] 72e8  97fda8b4 2a0003f4 7100001f 5400068b 54000160 90005140 9123e004 910a8084
[  128.450715] 7308  2a1403e3 aa1503e2 aa0403e1 f00065c0 91326000 942835b2 942843d1 b900031f
[  128.458995] 7328  91298340 aa1803e2 d2800001 91006000 97feb25a f9400ae0 b9401400 36700040
[  128.467275] 7348  97feba6e 9129835a 52800014 9100e353 aa1303e0 94285ef7 aa1803e0 97fff211
[  128.475555] 7368  aa1803e0 940f2965 b9417703 f940b702 f9409b01 f940c300 f900b302 b9017303
[  128.483835] 7388  f900bf00 aa1803e0 97fff8bc f9009b1f b901431f aa1303e0 b9014b1f b901531f
[  128.492115] 73a8  94285f18 d2800003 52800002 52800061 91034340 97ff22ed 17fffb26 52800040
[  128.500395] 73c8  b9000300 97ff9be3 aa1803e0 97fff1f5 aa1803e2 d2800041 aa1603e0 97feb22f
[  128.508676]
               X23: 0xffffffc062a07f80:
[  128.514023] 7f80  00000000 00000000 8f356000 0000007f 8f3575a0 0000007f 8f3b77a0 0000007f
[  128.522302] 7fa0  00000002 00000000 00000000 00000000 8f35b000 0000007f d3d1e530 0000007f
[  128.530583] 7fc0  8f238f24 0000007f d3d1e530 0000007f 8f2a6aec 0000007f 60000000 00000000
[  128.538862] 7fe0  00000000 00000000 0000005e 00000000 ad77e8d8 35a00244 9a7153fe 829df003
[  128.547143] 8000  00000002 00000000 ffffffff ffffffff 615c4000 ffffffc0 02078bf0 ffffffc0
[  128.555422] 8020  010ad3c8 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[  128.563702] 8040  00000000 00000000 00000000 00000000 00000003 00000000 57ac6e9d 00000000
[  128.571982] 8060  76f0fe92 456d6c56 ab369d3a 814ddcee 9b2cd2d7 3a7da748 e53133de 459269cb
[  128.580264]
               X25: 0xffffffc061586d00:
[  128.585610] 6d00  61586f00 ffffffc0 61cf7688 ffffffc0 00000000 00000000 00000000 00000000
[  128.593890] 6d20  00000000 00000000 00020023 66780111 2d346563 73736573 2e6e6f69 006c6d78
[  128.602170] 6d40  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.610450] 6d60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.618730] 6d80  507e7ac0 ffffffc0 00000001 00000000 616b2140 ffffffc0 00000124 00000000
[  128.627010] 6da0  00000024 00000000 fc02d024 ffffffbf 01114170 ffffffc0 00000000 00000000
[  128.635290] 6dc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.643570] 6de0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.651851]
               X26: 0xffffffc0020819e0:
[  128.657198] 19e0  020db670 ffffffc0 02080f80 ffffffc0 0110b730 ffffffc0 0110b690 ffffffc0
[  128.665478] 1a00  00000000 00000000 ffffffff 00000001 00000001 00000000 02081a18 ffffffc0
[  128.673757] 1a20  02081a18 ffffffc0 00000000 00000000 00000000 00000000 00000004 00000000
[  128.682037] 1a40  01111260 ffffffc0 0208f1c8 ffffffc0 00000000 00000000 00000008 00000000
[  128.690317] 1a60  fc000000 ffffffbf fc02d0d8 ffffffbf fc014980 ffffffbf 00000000 00100010
[  128.698598] 1a80  02081a80 ffffffc0 02081a80 ffffffc0 02087e68 ffffffc0 00000000 00000000
[  128.706878] 1aa0  02081aa0 ffffffc0 02081aa0 ffffffc0 615c4000 ffffffc0 00000000 00000000
[  128.715157] 1ac0  01e73798 ffffffc0 00000124 00000000 01114390 ffffffc0 00000000 00000000
[  128.723438]
               X27: 0xffffffc061586d48:
[  128.728785] 6d48  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.737065] 6d68  00000000 00000000 00000000 00000000 00000000 00000000 507e7ac0 ffffffc0
[  128.745345] 6d88  00000001 00000000 616b2140 ffffffc0 00000124 00000000 00000024 00000000
[  128.753624] 6da8  fc02d024 ffffffbf 01114170 ffffffc0 00000000 00000000 00000000 00000000
[  128.761905] 6dc8  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.770185] 6de8  00000000 00000000 00000000 00000000 00000000 00000000 2d6e7572 72657375
[  128.778465] 6e08  3030312d 756c2d30 785c6163 69666432 6f666572 32785c78 72636d64 78636864
[  128.786745] 6e28  65642e70 6c756166 6f6d2e74 2e746e75 75716572 73657269 00000000 00000000
[  128.795026]
               X29: 0xffffffc062a0bc80:
[  128.800373] bc80  fc02d0d0 ffffffbf 62a08000 ffffffc0 01117368 ffffffc0 62a08000 ffffffc0
[  128.808652] bca0  fc02d0d0 ffffffbf 61586d80 ffffffc0 02081a60 ffffffc0 61586dc8 ffffffc0
[  128.816932] bcc0  00000001 00000000 62a0bd00 ffffffc0 01117368 ffffffc0 62a0bd00 ffffffc0
[  128.825213] bce0  01113bf0 ffffffc0 60000145 00000000 62a08000 ffffffc0 fc02d120 ffffffbf
[  128.833492] bd00  62a0bd30 ffffffc0 01117368 ffffffc0 02081a98 ffffffc0 00000000 00000000
[  128.841773] bd20  fc02d0e8 ffffffbf 02081a78 ffffffc0 62a0be40 ffffffc0 01117d28 ffffffc0
[  128.850052] bd40  00000000 00000000 00000003 00000000 6d5cb328 00000055 7efda8f4 0000007f
[  128.858332] bd60  40000000 00000000 00000015 00000000 00000117 00000000 00000111 00000000
[  128.868253] Process insmod (pid: 4784, stack limit = 0xffffffc062a08058)
[  128.875067] Stack: (0xffffffc062a0bd00 to 0xffffffc062a0c000)
[  128.880935] bd00: 62a0bd30 ffffffc0 01117368 ffffffc0 02081a98 ffffffc0 00000000 00000000
[  128.889214] bd20: fc02d0e8 ffffffbf 02081a78 ffffffc0 62a0be40 ffffffc0 01117d28 ffffffc0
[  128.897494] bd40: 00000000 00000000 00000003 00000000 6d5cb328 00000055 7efda8f4 0000007f
[  128.905774] bd60: 40000000 00000000 00000015 00000000 00000117 00000000 00000111 00000000
[  128.914053] bd80: 02077000 ffffffc0 62a08000 ffffffc0 62a0be40 ffffffc0 62a0bdf8 ffffffc0
[  128.922334] bda0: 00000072 ffffffc0 00000003 00000064 0000006e ffffffbf 01b3fb60 ffffffc0
[  128.930614] bdc0: 0000003f 00000000 00000124 ffffffc0 01114298 ffffffc0 00000014 ffffffc0
[  128.938894] bde0: 00800002 ffff81b4 00000001 000003e8 000003e8 00000000 000011d8 00000000
[  128.947173] be00: 5c08ef08 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.955453] be20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  128.963734] be40: f450f100 0000007f 0108426c ffffffc0 aa384840 00000055 6d5cb328 00000055
[  128.972014] be60: ffffffff ffffffff 00000003 00000000 0397a000 ffffff80 000011d8 00000000
[  128.980294] be80: 0397ac58 ffffff80 0397ab90 ffffff80 0397a8b8 ffffff80 000002e0 00000000
[  128.988573] bea0: 00000340 00000000 00000000 00000000 00000000 00000000 00000013 00000014
[  128.996854] bec0: 0000000e 00000000 00000008 00000000 00000003 00000000 6d5cb328 00000055
[  129.005133] bee0: 00000000 00000000 00000003 00000000 00000000 00000000 00000000 00000000
[  129.013413] bf00: 00000000 00000000 00000000 00000000 00000111 00000000 7f0682a0 0000007f
[  129.021693] bf20: 00000001 00000000 00000000 00000000 00000001 00000000 0000270f 00000000
[  129.029974] bf40: 00000002 00000000 00000000 00000000 6d5ddf50 00000055 7efda8d0 0000007f
[  129.038254] bf60: 7f061a70 0000007f aa384840 00000055 6d5cb328 00000055 00000000 00000000
[  129.046534] bf80: 00000000 00000000 aa384810 00000055 f450f1c8 0000007f 00000000 00000000
[  129.054813] bfa0: 00000008 00000000 00000000 00000000 00000000 00000000 f450f100 0000007f
[  129.063094] bfc0: 6d5c20fc 00000055 f450f100 0000007f 7efda8f4 0000007f 40000000 00000000
[  129.071373] bfe0: 00000003 00000000 00000111 00000000 e3b034d9 9a8141c8 027bbcc8 834bcf33
[  129.079650] Call trace:
[  129.082247] [<ffffffc001113bf0>] module_put+0x48/0xe0
[  129.087418] [<ffffffc001117364>] load_module+0x16ec/0x1ee0
[  129.093024] [<ffffffc001117d24>] SyS_finit_module+0xb4/0xc8
[  129.098715] Code: d5033abf f9410a80 d538d082 91002000 (f8626801)
[  129.105090] ---[ end trace b0497897d8af2493 ]---
[  129.109678] note: insmod[4784] exited with preempt_count 1
I also tried to take the configuration of the running kernel from /proc/config.gz (which is different from the one contained in the deb) with the same result
Hi there,i have extracted the dtb file of Android, how can I make the dtb file available for the current linux image?
I got a new tv box beelink GT1 mini with s905x2, When can you support this chip?
@balbes150 do you know why such a simple module doesn't work (and messes up the kernel so badly that afterwards lsmod hangs forever)?
A mismatch between the compiler used to compile the kernel and the one installed with armbian perhaps? If so, what compiler should I use to compile the module?
use the system image 5.41 (where the kernel is the same as the packages on the site) and compiler 4.9
   On 9/14/2018 at 9:34 PM, Thang said:
How can I get the kernel headers for the latest 5.59 build?
https://yadi.sk/d/tNM7NdyB3afohU
Someone can repost it please ?
37 minutes ago, jpl250rs said:
yes thanks for your answer i did browse it aleary but i'm not able to find the kernel headers for the 4.18.0-aml-s9xxx (5.59)
Commit 846b7fe on Aug 19, 2018 has a Makefile with version/patch/sublevel of 4.18.0 - does that kernel source tree have the required header files (with a few .c files as bonus :-) ?
The direct link is https://github.com/150balbes/Amlogic_s905-kernel/tree/846b7fef181189f73ada11fd9ecb69691ed05fd3
10 minutes ago, jpl250rs said:
ok thanks , i was looking for a deb file
Now i get to learn how to install it :D
To 'install', just download the zip file and extract the folder into /usr/src
Rename the resulting directory 4.18.0-aml-s9xxx etc  to give you /usr/src/4.18.0-aml-s9xxx
 i'm better looking to this folder
/lib/modules/4.18.0-aml-s9xxx/build
i need it to compile my driver and i see no build folder
it should be arround 10MB only and the whole folder you link me is about 800MB
The 800Mb includes (sic) the header files and the rest of the kernel source. You can use this to compile what ever additional modules (driver) you wish so place it in the location where the driver source is looking for it.
Hi please help ! I try install on my x96mini (s905w) but cant boot into homescreen tried all dtb file from s905x to s905 at lastest version i see new one file call s905w i tried it too but cant pass the ton of word , alway have error like failed cant not start network etc etc filesystem and alot word ! Anyone have done with this please help me out of this show me what dtb you used and ver sdcard or usb , thanks
On 10/20/2018 at 11:40 AM, KY69 said:
Tanix TX3 mini 2GB RAM (S905W)
5.41.1 Ubuntu Xenial 3.14.29 icewm 20180406: everything working, boot from SD, system on HDD
A5X Max 4GB RAM (RK3328)
5.62 Ubuntu Bionic 4.4.143 desktop 20181014: rk3328-evb.dtb, boot from SD, system on HDD, just started testing, wifi and audio not working yet, ethernet okay.
Please, can you link the armbian img that you use?
I can't find 5.41.1 Ubuntu Xenial 3.14.29.
Thanks.
