balbes150 Posted December 16, 2018 Author Posted December 16, 2018 42 minutes ago, BuiHuy said: anyone help me install this on x96mini ? Learn how to use search, this issue has been discussed many times.
BuiHuy Posted December 16, 2018 Posted December 16, 2018 2 hours ago, balbes150 said: Learn how to use search, this issue has been discussed many times. hi is me again i have search in THIS topic and finished setup pass information it showing "Reboot the system as soon as possible" im reboot and it showing again , i did is 10 TIME before im come here for help , im using the lastest ver with dtb meson-gxm-khadas-vim2 thanks ! does sdcard size matter cause i have 2 one is 2gb and 4gb i tried 2 of them !
KY69 Posted December 16, 2018 Posted December 16, 2018 18 hours ago, Mike Hammer said: Please, can you link the armbian img that you use? I can't find 5.41.1 Ubuntu Xenial 3.14.29. https://yadi.sk/d/pHxaRAs-tZiei/5.41/mali-6/5.41.1_KODI-17.6 1
Reddwarf Posted December 17, 2018 Posted December 17, 2018 20 hours ago, BuiHuy said: hi is me again i have search in THIS topic and finished setup pass information it showing "Reboot the system as soon as possible" im reboot and it showing again , i did is 10 TIME before im come here for help , im using the lastest ver with dtb meson-gxm-khadas-vim2 thanks ! does sdcard size matter cause i have 2 one is 2gb and 4gb i tried 2 of them ! I think 4gig is just a little too small, I would use at least 8 gig.
bog lee Posted December 17, 2018 Posted December 17, 2018 Is the rtl8723bs combo wlan/bluethoot chip supported in the latest release (Armbian_5.67_Aml-s9xxx_Ubuntu_bionic_default_4.19.6_desktop_20181207)? As for me only the wlan component is working on my Mnini M8S. It looks like the bluetooth hardware isn't recognised at all. I'm thinking my problem could be related either to the chip's driver or my problem with dtb.img during installation. I've tried to install an alternative driver from https://github.com/lwfinger/rtl8723bs_bt, but it didn't make any difference. As for the dtb.img; I couldn't use my android's dtb as it caused the installer to fail straight after the reboot. dtb is OK as md5sum is exactly the same as the one provided at the 150balbes' git repo. The only way to successfully install the image was possible after hardcoding path to the dtb.img in uEnv.ini, also I had to use /boot/dtb/generic meson-gxbb-p200.dtb as my board is p200. Any other way of picking up dtb such as directly from android or placing any dtb.img in /boot failed (btw. is this expected behaviour or a bug?). Looking through this thread, I noticed that ppl managed to get it going for earlier releases by compiling kernel, but I'm hopping this isn't needed any longer. Anyone has an idea/tips how to go about troubleshooting this problem? ~$ ls -l /lib/firmware/rtlwifi/rtl8723b* -rw-rw-r-- 1 root root 31762 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723befw_36.bin -rw-rw-r-- 1 root root 30746 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723befw.bin -rw-rw-r-- 1 root root 20886 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bs_ap_wowlan.bin -rw-rw-r-- 1 root root 9120 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bs_bt.bin -rw-rw-r-- 1 root root 32108 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bs_nic.bin -rw-rw-r-- 1 root root 26398 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bs_wowlan.bin -rw-rw-r-- 1 root root 20886 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bu_ap_wowlan.bin -rw-rw-r-- 1 root root 32108 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bu_nic.bin -rw-rw-r-- 1 root root 26398 Dec 6 15:17 /lib/firmware/rtlwifi/rtl8723bu_wowlan.bin ~$ ls -l /lib/firmware/rtlbt/rtl8723b* -rw-rw-r-- 1 root root 68 Dec 6 15:17 /lib/firmware/rtlbt/rtl8723b_config -rw-rw-r-- 1 root root 59 Dec 6 15:17 /lib/firmware/rtlbt/rtl8723b_config_2Ant_S0 -rw-rw-r-- 1 root root 46236 Dec 6 15:17 /lib/firmware/rtlbt/rtl8723b_fw -rw-rw-r-- 1 root root 75 Dec 6 15:17 /lib/firmware/rtlbt/rtl8723b_VQ0_config -rw-rw-r-- 1 root root 46236 Dec 6 15:17 /lib/firmware/rtlbt/rtl8723b_VQ0_fw dmesg |grep -i rtl8723 [ 11.866677] RTL8723BS: module init start [ 11.866684] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40 [ 11.866686] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40 [ 11.901275] RTL8723BS: rtw_ndev_init(wlan0) [ 11.903075] RTL8723BS: module init ret =0 [ 41.537342] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin [ 44.909176] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [ 53.105718] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [ 61.697665] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [ 70.641023] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [ 86.997712] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [ 96.489400] RTL8723BS: rtw_set_802_11_connect(wlan0) fw_state = 0x00000008 [ 97.048558] RTL8723BS: start auth [ 97.068551] RTL8723BS: auth success, start assoc [ 97.088588] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !! [ 97.088601] RTL8723BS: assoc success [ 98.385865] RTL8723BS: send eapol packet [ 98.397271] RTL8723BS: send eapol packet [ 98.397598] RTL8723BS: set pairwise key camid:4, addr:d0:65:ca:8d:b4:92, kid: 0, type:AES [ 98.398611] RTL8723BS: set group key camid:5, addr:d0:65:ca:8d:b4:92, kid:1, type:AES dmesg |grep -i bluetooth [ 144.696817] Bluetooth: Core ver 2.22 [ 144.696822] Bluetooth: Starting self testing [ 144.712600] Bluetooth: ECDH test passed in 15399 usecs [ 144.715301] Bluetooth: SMP test passed in 2588 usecs [ 144.715310] Bluetooth: Finished self testing [ 144.715388] Bluetooth: HCI device and connection manager initialized [ 144.715399] Bluetooth: HCI socket layer initialized [ 144.715404] Bluetooth: L2CAP socket layer initialized [ 144.715423] Bluetooth: SCO socket layer initialized ~$ lsmod Module Size Used by bluetooth 544768 0 ecdh_generic 24576 1 bluetooth zstd 16384 4 zram 24576 5 zsmalloc 24576 1 zram nls_ascii 16384 1 r8723bs 581632 0 cfg80211 348160 1 r8723bs rfkill 28672 4 bluetooth,cfg80211 meson_rng 16384 0 rng_core 16384 1 meson_rng meson_ir 16384 0 rc_core 49152 2 meson_ir meson_gxbb_wdt 16384 0 pwm_meson 16384 1 ao_cec 16384 0 scpi_hwmon 16384 0 sch_fq_codel 20480 6 ip_tables 28672 0 x_tables 36864 1 ip_tables ipv6 487424 28 crc_ccitt 16384 1 ipv6 ~$ hcitool dev Devices:
balbes150 Posted December 20, 2018 Author Posted December 20, 2018 On 12/17/2018 at 11:14 AM, bog lee said: Is the rtl8723bs combo wlan/bluethoot chip supported in the latest release (Armbian_5.67_Aml-s9xxx_Ubuntu_bionic_default_4.19.6_desktop_20181207)? On 12/17/2018 at 11:14 AM, bog lee said: I'm thinking my problem could be related either to the chip's driver or my problem with dtb.img during installation. I've tried to install an alternative driver from https://github.com/lwfinger/rtl8723bs_bt, but it didn't make any difference. As for the dtb.img; I couldn't use my android's dtb as it caused the installer to fail straight after the reboot. dtb is OK as md5sum is exactly the same as the one provided at the 150balbes' git repo. The only way to successfully install the image was possible after hardcoding path to the dtb.img in uEnv.ini, also I had to use /boot/dtb/generic meson-gxbb-p200.dtb as my board is p200. Any other way of picking up dtb such as directly from android or placing any dtb.img in /boot failed (btw. is this expected behaviour or a bug?). 2 hours ago, Greenhatguy said: I've recently got Armbian running from the SD card using these methods, but my device (MXQ PRO, S905X) does not boot into Android when the SD card is not present. It waits at the Amlogic logo and does nothing. I've tried booting into recovery mode (toothpick method, bootable SD card) but nothing works. Any ideas? On such a meager description of what image you use and what steps did - only psychics will be able to understand what could be the problem.
BuiHuy Posted December 22, 2018 Posted December 22, 2018 thanks balbes for make my device alive but i have a little issue , i installed lastest ubuntu version kerner 3.14.29 it booted , but look like screen is zoom in , i see only my desktop without taskbar i try to change resolution to 720p it boot to login screen after that nothing show up ! please help me THANK YOU FOR GREAD WORK ! which version recommended on my x96mini and DEB file THANK
BuiHuy Posted December 22, 2018 Posted December 22, 2018 Wifi working well open application a bit slow ( my sdcard class 4 8gb ) chrome work but extreme slow look like 12fps when play video (cpu not full load) for who dont know im using dtb 281 .
balbes150 Posted December 22, 2018 Author Posted December 22, 2018 3 hours ago, BuiHuy said: which version recommended on my x96mini and DEB file THANK I am using on X96mini (2\16) version 5.67 with DTB from khadas-vim. All the details are in the relevant subject. 1
talraash Posted December 22, 2018 Posted December 22, 2018 @BuiHuy disable gpu acceleration in chrome settings. an 480p in browser max(in some case 720p) 1
BuiHuy Posted December 22, 2018 Posted December 22, 2018 2 hours ago, talraash said: @BuiHuy disable gpu acceleration in chrome settings. an 480p in browser max(in some case 720p) thanks but unfortunate i got 1080p ! It is possible to overclock this cpu cause in the box it show 2Ghz of cpu clock speed , but in ubuntu is 1,2Ghz and Go full load when i scrolling but not smooth
mocsadek68 Posted December 24, 2018 Posted December 24, 2018 Hello everybody. I have got an Mecool M8S Pro + (S905X 2Gb 16Gb) machine. I try to install Armbian_5.37_S9xxx_Debian_stretch_3.14.29_xfce_20171226.img, but after the install, the system doesn't operate. The next picture can be seen: https://drive.google.com/file/d/1PPU8q5kft2Io_8StWjMVFIwLYSn9rAbz/view?usp=sharing Thank you for help!
talraash Posted December 24, 2018 Posted December 24, 2018 On 12/22/2018 at 6:12 PM, BuiHuy said: thanks but unfortunate i got 1080p ! It is possible to overclock this cpu cause in the box it show 2Ghz of cpu clock speed , but in ubuntu is 1,2Ghz and Go full load when i scrolling but not smooth You soc maximum 1.2GHz by amlogic blob...
Mike Hammer Posted December 28, 2018 Posted December 28, 2018 On 12/15/2018 at 6:46 PM, guidol said: please check this url: https://yadi.sk/d/pHxaRAs-tZiei/5.41/no-mali Thank you very much.
Mike Hammer Posted December 28, 2018 Posted December 28, 2018 On 12/16/2018 at 12:36 PM, KY69 said: https://yadi.sk/d/pHxaRAs-tZiei/5.41/mali-6/5.41.1_KODI-17.6 Thanks a lot.
petatester Posted January 8, 2019 Posted January 8, 2019 On WeTek Hub (1GB RAM) I'm getting the following error on any image from yadi.sk: Quote E:footer is wrong E:signature verification failed Instalation aborted I tried with 2 sd cards. I properly set the uEnv.ini and then run the aml_autoscript.zip in updates section :S
zillaf Posted January 9, 2019 Posted January 9, 2019 On 12/24/2018 at 1:49 PM, mocsadek68 said: Hello everybody. I have got an Mecool M8S Pro + (S905X 2Gb 16Gb) machine. I try to install Armbian_5.37_S9xxx_Debian_stretch_3.14.29_xfce_20171226.img, but after the install, the system doesn't operate. The next picture can be seen: https://drive.google.com/file/d/1PPU8q5kft2Io_8StWjMVFIwLYSn9rAbz/view?usp=sharing Thank you for help! I have the same Box and did try many .dtb files and images. The only one i got to work was the 3.14 Kernel Images with the lepotato2g dtb. Try Armbian_5.44_S9xxx_Debian_stretch_3.14.29_xfce_20180601. The newer Version from 20180729 has a different dtb file for the lepotato which didn't work for me. (Or take the new image but the dtb file from the old one) As mentioned, did try 4.9 and 4.19 Images but no luck to get it working with different dtb files... Maybe someone can give me a tip :) I have decompiled some dtb files back to dts (and the original android) to have a look at the differences, but with the newer kernels the "format" inside did change completly... Anyone having this Box, and got it to work, please get in touch with me :) (maybe with all the dtb file testing i did make a mistake^^) Thanks
balbes150 Posted January 9, 2019 Author Posted January 9, 2019 23 hours ago, petatester said: On WeTek Hub (1GB RAM) I'm getting the following error on any image from yadi.sk: Maybe Wetek Hub needs to use the same multi-boot approach that works for Week Play 2. You need to add a special file " boot.ini", I remember sending it to the user Wetek Play2.
petatester Posted January 9, 2019 Posted January 9, 2019 1 hour ago, balbes150 said: Maybe Wetek Hub needs to use the same multi-boot approach that works for Week Play 2. You need to add a special file " boot.ini", I remember sending it to the user Wetek Play2. Interesting, i tried using multiboot from LibElec & company but when Wetek shows the "Press power button to boot from sdcard" and you press it, nothing happens, loads Android as usual. Maybe the Android version is too up to date and needs a downgrade?
balbes150 Posted January 10, 2019 Author Posted January 10, 2019 15 hours ago, petatester said: Interesting, i tried using multiboot from LibElec & company but when Wetek shows the "Press power button to boot from sdcard" and you press it, nothing happens, loads Android as usual. Maybe the Android version is too up to date and needs a downgrade?  Try to ask the user about the start. Please note that the LE option, which is specifically designed for Wetek, does not have a universal multi-boot and will not work correctly with Armbian. https://forum.libreelec.tv/thread/12330-test-libreelec-images-with-kodi-18-for-s9xxx/?postID=106454#post106454
petatester Posted January 10, 2019 Posted January 10, 2019 6 minutes ago, balbes150 said: Try to ask the user about the start. Please note that the LE option, which is specifically designed for Wetek, does not have a universal multi-boot and will not work correctly with Armbian. https://forum.libreelec.tv/thread/12330-test-libreelec-images-with-kodi-18-for-s9xxx/?postID=106454#post106454 Ty for the link!
gnthibault Posted January 16, 2019 Posted January 16, 2019 On 6/7/2017 at 8:40 AM, balbes150 said: 1. After the first command, you need to wait 1-2 minutes and check the network connections Manager the advent of Wi-Fi. If your desired network appears, you need to open the file /etc/modules and add on a new line the name of the module wifi_dummy. After that, reboot the system, if you did everything correctly, you should automatically see the wifi network at startup. 2. If the first module (wifi_dummy) network did not work. You need to run the second command "sudo modprobe dhd" . Notice all the letters exactly as written. Capitalization is important in LINUX. dhd is not equal DHD. Other actions with the dhd module are the same as in the first point. The wifi_dummy trick does not work anymore with recent version of armbian (I am using 5.71) what is the new trick @balbes150 thank you in advance for your help
flm Posted January 17, 2019 Posted January 17, 2019 Hello. Is it possible to get wifi running on x96 box (it has 8189etv chip)?
David Markey Posted January 19, 2019 Posted January 19, 2019 I have bricked my s905x box, I installed onto the in built memory and now it kernel oops. It was working for a long time. How can I force to boot off SD card again?
balbes150 Posted January 19, 2019 Author Posted January 19, 2019 1 hour ago, David Markey said: I have bricked my s905x box, I installed onto the in built memory and now it kernel oops. It was working for a long time. How can I force to boot off SD card again? Write in detail what you did, what settings you used, what image was used, what is happening now.
David Markey Posted January 19, 2019 Posted January 19, 2019 It's a while since I set this box up.. it just decided not to boot recently.. I believe i used some script supplied by armbian or yourself to install onto the internal storage. I think it was 5.34 I've tried to solder the serial headers but I cannot I started to make a mess. Here is the boot sequence: I c
balbes150 Posted January 20, 2019 Author Posted January 20, 2019 Not mounted root. Perhaps any problem with eMMC or wrong DTB.
David Markey Posted January 20, 2019 Posted January 20, 2019 Yeah this was working for months with whatever DTB so must be eMMC problem. Is this box for the garbage?
balbes150 Posted January 20, 2019 Author Posted January 20, 2019 5 minutes ago, David Markey said: Yeah this was working for months with whatever DTB so must be eMMC problem. Is this box for the garbage? Start the system from external media and try to check the file system in the eMMC. You may need to reinstall.
