fredrum Posted March 9, 2023 Posted March 9, 2023 (edited) I have been looking into this as well over the last two weeks or so to try to get a claerer picture. But don't have that yet. I'm no kernel guy just a hobbyist programmer but I have used drm prime in a software I've modified for Raspberry, Chaiki for Raspberry I'm currently trying to port that over to OPi5. There's various places that can give you some hints but I'm going to assume that you guys are all aware of those already so not going to post. But did you see this one? I just spotted it but haven't had time to try yet https://github.com/rockchip-linux/mpp/pull/122/commits I didn't have luck running the current default 'mpi_dec_test' but there might be some drm prime hints in that PR? Edited March 9, 2023 by fredrum 0 Quote
Poincare Posted March 11, 2023 Posted March 11, 2023 (edited) Is this broken now? At step one, github returns a 404 page does not exist error. Well, I have just used the regular XFCE image since the GitHub link does not appear to work from stage 1. However, after installing that and exactly following this guide, at step 6 there is no Kodi to select in the lower right hand side of the screen. Then, is there some way to execute Kodi without having to sign in as a user and then run Kodi? Edited March 12, 2023 by Poincare 0 Quote
vandyman Posted March 12, 2023 Posted March 12, 2023 I followed the guide in post #1. And it installs Kodi 19.4. I can I upgrade to version 20.0? 0 Quote
royk Posted March 13, 2023 Posted March 13, 2023 @vandyman For hw acceleration you'll need to compile it with ffmpeg configured to use rkmpp. @amazingfate At the repo of JeffyCN I saw some commits related to NV12_10, NV15 and NV16, could this be the missing link for hdr video? https://github.com/JeffyCN/xorg-xserver/commit/aa8e4176d3a4c6ee258f333e9dac8ce6ef827d4c https://github.com/JeffyCN/xorg-xserver/commit/2a9c55ef3300e696d16ff6c868332fdcfa1b5740 0 Quote
amazingfate Posted March 13, 2023 Posted March 13, 2023 @roykthat is not the drm format of hdr. 1 Quote
amazingfate Posted March 17, 2023 Posted March 17, 2023 @royk @luizkun take a look at this: https://github.com/xbmc/xbmc/pull/16103 1 Quote
luizkun Posted March 17, 2023 Posted March 17, 2023 Hi @amazingfate , Can you share us how to build kodi from xbmc source with lib ffmpeg from jeffyCN ? i read your guide from post in radax forum , but it's still little confused how to combine all of them into one build environment . I think Kodi 21 fixed this issue , so i will try to build and start debug from this version instead of kodi 19.4 . 0 Quote
royk Posted March 17, 2023 Posted March 17, 2023 (edited) @luizkun You could find the build options in the source that amazingfate has uploaded on his repository, just build ffmpeg with rkmpp and libdrm enabled, then build kodi with gles and at least gbm. But just use a newer version doesn't work, already tried. @amazingfate Tnx I will have a look if I could find something in there. But I'm 100% sure that HDR did work at the beginning, so there has been a change somewhere, still not sure if it's mpp, libdrm or something else. I was thinking something in ffmpeg, since you'd found a working solution and after that JeffyCN made some commits which makes no sense to me like: #ifndef DRM_FORMAT_NV15 // fourcc_code('N', 'V', '1', '5') #define DRM_FORMAT_NV15 fourcc_code('N', 'A', '1', '2') #endif Removed these lines but this had the same result. Something else I was thinking is that at the beginning gbm used the original driver? and now panfork. But I'm unable to make the original driver to work in gbm. Edited March 17, 2023 by royk 1 Quote
amazingfate Posted March 20, 2023 Posted March 20, 2023 @roykNV15 and NA12 are the drm format for 10bit videos. HDR support are in the hdmi kernel driver:https://github.com/armbian/linux-rockchip/blob/rockchip-5.10/drivers/gpu/drm/rockchip/dw_hdmi-rockchip.c#L1748 I don't have a HDR monitor so I can't test. 0 Quote
royk Posted March 20, 2023 Posted March 20, 2023 @amazingfate Yes I've seen it's in the kernel. Still haven't found the solution yet. Something that struck me is that the block sizes of NV15 are different than NV12_10 when I look at { .format = DRM_FORMAT_NV12_10, .depth = 0, .num_planes = 2, + .char_per_block = { 5, 10, 0 }, .block_w = { 4, 4, 0 }, .block_h = { 4, 4, 0 }, + .hsub = 2, .vsub = 2, .is_yuv = true}, { .format = DRM_FORMAT_NV15, .depth = 0, .num_planes = 2, .char_per_block = { 5, 5, 0 }, .block_w = { 4, 2, 0 }, .block_h = { 1, 1, 0 }, .hsub = 2, .vsub = 2, .is_yuv = true }, Trying some things with the libraries, next step will be adding NV12_10 back in the kernel. 0 Quote
vandyman Posted March 24, 2023 Posted March 24, 2023 The newest Ubuntu image for Op5 has Kodi built in and installed. Maybe some of the Ubuntu technics can be add to Armbian. 0 Quote
royk Posted March 24, 2023 Posted March 24, 2023 (edited) @vandyman And does that one play HDR videos? @amazingfate and @luizkun I haven't found the exact problem yet, but luckily found a backup. With this backup it does play HDR videos again, but with the HDR Vision the colors don't match. After compiling a new version of mpp the same problem occured as before. So the problem should be in mpp or the combi of the new version with ..... The file I've uploaded is the working one for HDR10, is from date 2022-11-16 librockchip_mpp.so.0 Edited March 24, 2023 by royk 0 Quote
vandyman Posted March 24, 2023 Posted March 24, 2023 (edited) @royk I tried to run the Ubuntu kodi, but I get the green screen. My guess is that Wayland needs to be enabled. Oh! By the way. I am referring to the official Op5 Ubuntu build on the Opi website. Edited March 24, 2023 by vandyman 0 Quote
royk Posted March 24, 2023 Posted March 24, 2023 (edited) @vandyman Ok tnx, to be able to watch hdr at the moment it's only possible from gbm with gles rendering, I'm almost certain it doesn't work. I think that ffmpeg needs some adjustments due to changes in mpp. @amazingfate Found something, in ./mpp/codec/dec/h265/h265d_refs.c there is a line "s->h265dctx->pix_fmt |= MPP_FRAME_HDR;" when I change that to "s->h265dctx->pix_fmt |= MPP_FMT_YUV420SP_10BIT:" it plays HDR again. I assume a proper way to fix this is to add "MPP_FRAME_HDR" to ffmpeg? Edited March 25, 2023 by royk 0 Quote
luizkun Posted March 25, 2023 Posted March 25, 2023 Thanks @royk, i think amazingfate will trigger build his packages for latest change , i will update packages and double check again 0 Quote
luizkun Posted March 25, 2023 Posted March 25, 2023 Beside that , i'd like to share my ATV image for Opi5 too, hope you will like it https://drive.google.com/file/d/1pg9MJIAmDCPsiLw6fj-brLAD-wZCBmjz/view?fbclid=IwAR2ehaw9Q_-XtCEY7so3u_zp_WGcc1Ly9ZMgUCEWUWx5wxK9QXIQTfSKFko This is image for SD card , can burn it via balenaetcher or image burning tool 2 Quote
royk Posted March 27, 2023 Posted March 27, 2023 @amazingfate HDR problem is solved by https://github.com/JeffyCN/FFmpeg/commit/2e578b9ce6f46c4e2ab7f5bc3e066a7be1d586bc 3 Quote
amazingfate Posted March 27, 2023 Posted March 27, 2023 @roykWell done! I've just uploaded a new version of ffmpeg to my ppa. 5 Quote
PajPaj Posted March 27, 2023 Posted March 27, 2023 Thank you @royk and @amazingfate I've just tried to play some HDR 10bit videos and now they play fine. Also if I play 4k videos from chromium they are playing fine without cpu usage I've installed VLC and tried to play some HDR 10bit videos and they can also be played. However, it seems they are being played through CPU, as I can see one core at 100% all the time. Does anyone know how to make VLC (or any other standalone player) to play the videos using the gpu? Thanks 0 Quote
Werner Posted March 28, 2023 Posted March 28, 2023 6 hours ago, PajPaj said: Does anyone know how to make VLC (or any other standalone player) to play the videos using the gpu? My best guess is that Chromium received some patches already to make use of hw acceleration while VLC does not know yet how to do that. 0 Quote
royk Posted March 30, 2023 Posted March 30, 2023 @PajPaj You could try: https://github.com/philn/glide 0 Quote
amielke Posted March 31, 2023 Posted March 31, 2023 (edited) My pulse audio mapping. It works with 5.1 surround, all channels are correct with the config. I am using this config on an orange pi 5. Zitat sudo nano /usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf [Mapping hdmi-surround] description = Digital Surround 5.1 (HDMI) device-strings = hdmi:%f paths-output = hdmi-output-0 #channel-map = front-left,front-right,rear-left,rear-right,lfe,front-center channel-map = front-left,front-right,lfe,front-center,rear-left,rear-right priority = 8 direction = output Edited April 1, 2023 by amielke 0 Quote
Bee Posted April 1, 2023 Posted April 1, 2023 (edited) @luizkun, Hi could you please share the drive link again, seems like it is dead, I would love to try out this ATV build! Thanks! Edited April 1, 2023 by Rabee Hanzla 0 Quote
TRS-80 Posted April 2, 2023 Posted April 2, 2023 On 3/7/2023 at 5:23 PM, fredrum said: Might be worth pointing out even if maybe many people are aware that there's two completely differernt uses of the term 'DRM'. DRM = Digital Rights Management. Ie support for enforcing copy right protection of media. also DRM = Direct Render Manager. A render and display path in Linux that can show images when not under X11. Good point which probably bears repeating. However, in the first case, I think that 'Digital Restrictions Management' is a more accurate term. You could even say DRM is defective by design. 0 Quote
dkg Posted April 2, 2023 Posted April 2, 2023 On bullseye or archlinux based OS, hdmi cec works. (armbian, official ..) However, it does not work on ubuntu based OS (armbian, official ubuntu). Can this be fixed? 0 Quote
amielke Posted April 2, 2023 Posted April 2, 2023 @dkg Do you have a link to download Archlinux for Orange PI 5 0 Quote
dkg Posted April 2, 2023 Posted April 2, 2023 [mention=206176]dkg[/mention] Do you have a link to download Archlinux for Orange PI 5 rebornOS or https://github.com/7Ji/orangepi5-archlinuxarmSent from my iPhone using Tapatalk 0 Quote
royk Posted April 2, 2023 Posted April 2, 2023 @dkg Can't test it at the moment, but it did work. Don't you have a /dev/cec0 device? How did you test, which version, dtb? 0 Quote
dkg Posted April 2, 2023 Posted April 2, 2023 (edited) [mention=205859]royk[/mention] dkinght@orangepi5:/dev$ ls -al cec0crw-rw---- 1 root video 248, 0 4월 2 21:49 cec0 dkinght@orangepi5:/dev$ cec-client No device type given. Using 'recording device'* failed to open vchiq instance dkinght@orangepi5:/dev$ cec-client -l libCEC version: 6.0.2, compiled on Linux-4.15.0-166-generic ... , features: P8_USB, DRM, P8_detect, randr, RPi, Exynos, AOCECFound devices: NONE dkinght@orangepi5:/dev$ cec-compliance -d0 Driver Info: Driver Name : dwhdmi-rockchip Adapter Name : dw_hdmi_qp Capabilities : 0x0000000e Logical Addresses Transmit Passthrough Driver version : 5.10.110 Available Logical Addresses: 4 Connector Info : None Physical Address : f.f.f.f Logical Address Mask : 0x0000 CEC Version : 2.0 OSD Name : '' Logical Addresses : 0 FAIL: missing logical address(es), use cec-ctl to configure this dkinght@orangepi5:~$ uname -a Linux orangepi5 5.10.110-rockchip-rk3588 #1 SMP Sun Mar 19 16:54:42 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux dkinght@orangepi5:/boot/dtb/rockchip$ ls -al rk3588s-ora*-rwxr-xr-x 1 root root 235351 3월 31 20:59 rk3588s-orangepi-5.dtb-rwxr-xr-x 1 root root 234574 3월 31 20:59 rk3588s-orangepi-5b.dtb this in my armbian Edited April 3, 2023 by dkg 0 Quote
Alex D Posted April 3, 2023 Posted April 3, 2023 (edited) It would be great to have hdmi-cec working on ARMBIAN as well. It works on rebornOS. I can help with any tests/checks as well if you need those. Edited April 3, 2023 by Alex D 0 Quote
