2 hours ago, m][sko said:
UEFI can be way how to boot it maybe
With extensive hacking, in theory, perhaps, in reality? No.
Same situation is with Lenovo X13s featuring the same SoC. You can boot Linaro hacked Debian with kernel 6.1.y / 6.2.y leaning on device tree.
19 часов назад, m][sko сказал:
Can you explain how UEFI is working on arm?
Is it passing some dts or how the linux kernel know what drivers should it start ?
Running u-boot-EFI uses DTBS, which are described in grub.cfg. There is an EDK2-EFI variant, it uses two variants - DTB or ACPI.
i think the arm version of the surface pro 9 is close to the devkit - surface pro x is an older design using a snapdragon 8cx gen2 (i think) and not the gen3 the devkit is using and which is a very different soc
I was able to boot
with this branch
https://github.com/jhovold/linux/tree/wip/sc8280xp-v6.2-rc8
and with microsoft dev kit patches on top of that
https://github.com/shawnguo2/linux/commits/devkit-dt-6.2-rc5
and this kernel command line
 clk_ignore_unused efi=novamap earlycon=efifb console=efifb
build in ethernet don't work as not all usb-c ports are active
so you will need to connect usb-c ethernet  to usb-c ports on the side
for speed
Cpufreq-info show 3GHz but device is running as on lowest freq(800MHz) as that is my experience with running benchmarks
Edited by m][sko
But still
1.display port switched off after booting
2.build in ethernet isn't working and usb2 ports  isn't working
Edited by m][sko
I got the wdk2023 pretty solidly up and running here . There's also an Ubuntu 23.04 USB bootable image available. Could also be done with armbian, I modified the bookworm image and booted with my patched kernel.
