m][sko Posted January 19, 2023 Posted January 19, 2023 https://www.microsoft.com/en-us/d/windows-dev-kit-2023/94k0p67w7581 UEFI can be way how to boot it maybe 0 Quote
Igor Posted January 19, 2023 Posted January 19, 2023 On 1/19/2023 at 1:32 PM, m][sko said: UEFI can be way how to boot it maybe Expand With extensive hacking, in theory, perhaps, in reality? No. Same situation is with Lenovo X13s featuring the same SoC. You can boot Linaro hacked Debian with kernel 6.1.y / 6.2.y leaning on device tree. 0 Quote
m][sko Posted January 20, 2023 Author Posted January 20, 2023 @balbes150 Can you explain how UEFI is working on arm? Is it passing some dts or how the linux kernel know what drivers should it start ? 0 Quote
balbes150 Posted January 21, 2023 Posted January 21, 2023 On 1/20/2023 at 1:36 PM, m][sko said: Can you explain how UEFI is working on arm? Is it passing some dts or how the linux kernel know what drivers should it start ? Expand Running u-boot-EFI uses DTBS, which are described in grub.cfg. There is an EDK2-EFI variant, it uses two variants - DTB or ACPI. 0 Quote
m][sko Posted January 21, 2023 Author Posted January 21, 2023 Surface pro X is same hw as windows dev box 2023 https://github.com/linux-surface/surface-pro-x 0 Quote
hexdump Posted January 22, 2023 Posted January 22, 2023 i think the arm version of the surface pro 9 is close to the devkit - surface pro x is an older design using a snapdragon 8cx gen2 (i think) and not the gen3 the devkit is using and which is a very different soc 0 Quote
m][sko Posted February 18, 2023 Author Posted February 18, 2023 https://github.com/merckhung/linux_on_arm64_laptop https://github.com/merckhung/linux_ms_dev_kit/commit/195ccc926158b49c33edbccde99685a497032c3b 0 Quote
m][sko Posted March 4, 2023 Author Posted March 4, 2023 (edited) I was able to boot with this branch https://github.com/jhovold/linux/tree/wip/sc8280xp-v6.2-rc8 and with microsoft dev kit patches on top of that https://github.com/shawnguo2/linux/commits/devkit-dt-6.2-rc5 and this kernel command line clk_ignore_unused efi=novamap earlycon=efifb console=efifb build in ethernet don't work as not all usb-c ports are active so you will need to connect usb-c ethernet to usb-c ports on the side for speed Cpufreq-info show 3GHz but device is running as on lowest freq(800MHz) as that is my experience with running benchmarks Edited March 4, 2023 by m][sko 0 Quote
Igor Posted March 4, 2023 Posted March 4, 2023 My 2c https://github.com/armbian/build/pull/4904 0 Quote
m][sko Posted March 11, 2023 Author Posted March 11, 2023 When I add more stuff to device tree it started to run on full speed It is 2.5x faster then rock 5 0 Quote
m][sko Posted March 11, 2023 Author Posted March 11, 2023 (edited) But still 1.display port switched off after booting 2.build in ethernet isn't working and usb2 ports isn't working Edited March 11, 2023 by m][sko 0 Quote
m][sko Posted March 16, 2023 Author Posted March 16, 2023 when windows dev boot from acpi https://github.com/shawnguo2/linux/commits/wdk2023-acpi-6.2 display is working over efifb build in ethernet is working build in wifi use ath11k and armbian firmware is missing all of this https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/log/ath11k/WCN6855/hw2.0/ all usb ports working cpufreq don't 1 Quote
jglathe Posted August 28, 2023 Posted August 28, 2023 I got the wdk2023 pretty solidly up and running here . There's also an Ubuntu 23.04 USB bootable image available. Could also be done with armbian, I modified the bookworm image and booted with my patched kernel. 0 Quote
