ArmBoy1988 Posted May 18 Share Posted May 18 (edited) A new variation of Orange Pi 5 is now available. I think it's available on AliExpress, but I've seen the item on Amazon.com as well...reasonable price: https://www.amazon.com/Orange-Pi-Rockchip-Frequency-Development/dp/B0C5BZLPZN It comes now with the RK3588 instead of the RK3588s of the 5 and 5B. It's similar in capabilities of the Rock 5B but I believe has a few more bells and whistles. It has two 2.5GB ethernet ports. Separate connectors than GPIO for RTC and fan. Full size HDMI input as well as 2 full size HDMI outputs. Can have m.2 for 2230 WiFi/BT on top side as well as m.2 2280 on bottom of board. I think it can only go up to 16GB memory. Not sure if Armbian will make all of these work...yet. But this makes perfect sense...I just bouth my Orange Pi 5 about a month ago PS: A new tag is required for this new variation...I guess. PPS: Other thing to note is that Amazon link is for a 16GB version and includes a power supply. However, this particular listing ships from China. For Orange Pi 5 and 5B there were listings that were fulfilled by Amazon. I would think that Orange Pi will/may have those in the near future, that ship from the US...hopefully, but likely a little more expensive. PPPS: If you go to that Amazon link, there is also a version with 4GB and no power supply for $99.99 at the time this was posted. Edited May 18 by ArmBoy1988 0 Quote Link to comment Share on other sites More sharing options...
Turbine Posted May 19 Share Posted May 19 I wasn't too upset with the wifi version. However those two 2.5gbps ethernet ports have me regretting the 5. You sure do need that good powersupply with this model. I have to run my external data SSD drive off of an externally powered USB hub too, as it draws too much power. 0 Quote Link to comment Share on other sites More sharing options...
ArmBoy1988 Posted May 19 Author Share Posted May 19 I was thinking that if the Orange Pi 5 I purchased didn't live up to what I was looking for, I'd buy the Rock 5B or something like that. In any case, I got the 16GB memory, m.2 for an SSD and I wasn't going to need WiFi or I could just get a WiFi dongle, if needed. A big difference, for me, is the PCIe throughput, I think that the throughput for the m.2 on the 5 will probably be sufficient. 0 Quote Link to comment Share on other sites More sharing options...
Avatar Ng Posted May 27 Share Posted May 27 Just got mine, let me test out opi5/5b image today and get back to you guys. 1 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted May 27 Share Posted May 27 Looks like they improved packaging, a lot 0 Quote Link to comment Share on other sites More sharing options...
royk Posted May 27 Share Posted May 27 Yup packaging looks good indeed, ordered one too so I could use the "old" one for LinuxCNC (great machine for it). Would've been better if it had a 12v dc input, atm I'm using a 5v 4a usb c adapter, it seems like this is giving me sporadic issues. Hopefully this isn't the case with the OPi5+. Otherwise power direct on the pins worked fine. I hesitated to buy the NanoPC-T6 which has a nice case (20,-) and 12v input, but it doesn't have MTD and no choice to buy without emmc. @Avatar Ng Did you buy a case/heatsink with it? 0 Quote Link to comment Share on other sites More sharing options...
Avatar Ng Posted Sunday at 03:41 PM Share Posted Sunday at 03:41 PM @royk yeah man, NanoPC-T6 seems like a better deal, I NEED A CASE XD ... end up I add on NVME, Wi-Fi6+BT5, casing (design my own), ... etc the cost goes up a lot 😂 Quick update, tried Armbian image "Armbian_22.11.4_Orangepi5_jammy_legacy_5.10.110_gnome_desktop.img" no luck; probably other image is like Radxa 5b image is a closer sibling?? and no debug message due to not found my tty debug cable yet 😅. 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted Sunday at 11:18 PM Share Posted Sunday at 11:18 PM @Avatar Ng Can you try this image https://github.com/efectn/armbian-images/releases/download/20230528-1940/Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop.img.xz 1 Quote Link to comment Share on other sites More sharing options...
haajee Posted Monday at 07:19 PM Share Posted Monday at 07:19 PM Hmm, got my Orange Pi 5 now running as home server and runs great. But this plus version does look great to have also. Like the 2.5Gbps ethernet ports... Perfect platform to build your own router. 0 Quote Link to comment Share on other sites More sharing options...
Avatar Ng Posted Wednesday at 01:50 AM Share Posted Wednesday at 01:50 AM (edited) @Efe Çetin Seems like the OPI5 image ("Armbian_23.02.2_Orangepi5_jammy_legacy_5.10.110.img") works better (at least it boots and got into console display) than the one you provide me, I tried both "Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop.img" and the one from Radxa Rock 5b ("Armbian_23.02.2_Rock-5b_jammy_legacy_5.10.110.img"), these don't even boot with display. Seems the official branch added support for this new board. https://github.com/orangepi-xunlong/orangepi-build/tree/next Let me supplement all those debug logs in the following days, apologize for the TTY debug cable, I have to get a new one. Following were stack trace from TTY, using image "Armbian_23.08.0-trunk_Orangepi5-plus_jammy_legacy_5.10.160_gnome_desktop.img". Quote Note: I've flash my SPI Flash by the way, for PCIE NVMe boot using OrangePi official Ubuntu image. [ 430.778765] rk806-pinctrl rk806-pinctrl.7.auto: not freeing pin 1 (gpio_pwrctrl2) as part of deactivating group gpio_pwrctrl2 - it is already used for some other setting [ 431.082338] reboot: Power down \0\0\0DDR Version V1.08 20220617 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB Manufacturer ID:0x6 CH0 RX Vref:32.7%, TX Vref:22.8%,21.8% CH1 RX Vref:31.7%, TX Vref:22.8%,22.8% CH2 RX Vref:31.7%, TX Vref:22.8%,22.8% CH3 RX Vref:30.7%, TX Vref:22.8%,22.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (May 25 2023 - 10:42:30) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(806278dba1...) + OK ## Checking uboot 0x00200000 ... sha256(6e73bf447d...) + OK ## Checking fdt 0x00311dd0 ... sha256(d2dda3ef7c...) + OK ## Checking atf-2 0x000f0000 ... sha256(c00c7fd75b...) + OK ## Checking atf-3 0xff100000 ... sha256(71c3a5841b...) + OK ## Checking atf-4 0xff001000 ... sha256(2301cf73be...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 727.55 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang NOTICE: BL31: Built : 11:23:47, Aug 15 2022 INFO: spec: 0x1 INFO: ext 32k is valid INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: system boots from cpu-hwid-0 INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (May 28 2023 - 19:44:43 +0000) Model: RK3588 Orange Pi 5 Plus PreSerial: 2, raw, 0xfeb50000 DRAM: 15.7 GiB Sysmem: init Relocation Offset: eda65000 Relocation fdt: eb9f9a98 - eb9fecc8 CR: M/C/I Using default environment mmc@fe2c0000: 0, mmc@fe2e0000: 1 Bootdev(atags): mmc 0 MMC0: Legacy, 52Mhz PartType: EFI DM: v2 boot mode: None Model: RK3588 Orange Pi 5 Plus CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 switch to partitions #0, OK mmc0 is current device mmc@fe2c0000: 0 (SD) mmc@fe2e0000: 1 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr reading /boot.scr 3476 bytes read in 10 ms (338.9 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0 reading /armbianEnv.txt 168 bytes read in 2 ms (82 KiB/s) reading /uInitrd 15256327 bytes read in 1225 ms (11.9 MiB/s) reading /Image 34638336 bytes read in 2775 ms (11.9 MiB/s) ** Unable to read file /dtb/rockchip/rk3588s-orangepi-5-plus.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Default at 0xeb9f9a98 ** Unable to read file /dtb/rockchip/overlay/rockchip-rk3588-fixup.scr ** Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15256263 Bytes = 14.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... Device 0: unknown device Device 2: Could not get clock for spi@fe2b0000: -2 unknown device Device 1: Could not get clock for spi@fe2b0000: -2 unknown device Device 0: unknown device starting USB... Bus usb@fc800000: "Synchronous Abort" handler, esr 0x96000004 * Reason: Exception from a Data abort, from current exception level * PC = 00000000002809c0 * LR = 00000000002809c0 * SP = 00000000eb9f8b50 * ESR_EL2 = 0000000096000004 * Reloc Off = 00000000eda65000 x0 : ffffffffffffffff x1 : 00000000edd3a9f1 x2 : 00000000fffffffc x3 : 0000000000000000 x4 : 00000000edd432ed x5 : 000000000000006e x6 : 00000000edd2e12e x7 : 0000000000000000 x8 : 0000000000000044 x9 : 0000000000000008 x10: 00000000ffffffd0 x11: 00000000ebc6d288 x12: 0000000000000000 x13: 0000000000000004 x14: 000000000000000c x15: 0000000000000002 x16: 00000000edca9f74 x17: 0000000000000005 x18: 00000000eb9ffce0 x19: 0000000000000000 x20: 00000000ebc88f80 x21: 00000000ebc64140 x22: 00000000ebc89110 x23: 00000000edd4cfec x24: 00000000edd77d40 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 00000000ebc88930 x29: 00000000eb9f8d30 Call trace: PC: [< 002809c0 >] LR: [< 002809c0 >] Stack: [< 002809c0 >] [< 00233494 >] [< 0027cb00 >] [< 00212d3c >] [< 00212ddc >] [< 0022ad20 >] [< 00218124 >] [< 002182d8 >] [< 002179ec >] [< 0022a2d0 >] [< 0022ad20 >] [< 00218124 >] [< 002182d8 >] [< 002179ec >] [< 0022a2d0 >] [< 0022ad20 >] [< 00218124 >] [< 002182d8 >] [< 00217a28 >] [< 00217fdc >] [< 00217db8 >] [< 002182d8 >] [< 002179ec >] [< 0022a2d0 >] [< 0022ad20 >] [< 00218124 >] [< 002182d8 >] [< 002179ec >] [< 0022a240 >] [< 00218978 >] [< 00216818 >] [< 00219018 >] [< 0028cc68 >] [< 00219254 >] [< 00201e18 >] Copy info from "Call trace..." to a file(eg. dump.txt), and run command in your U-Boot project: ./scripts/stacktrace.sh dump.txt Resetting CPU ... ### ERROR ### Please RESET the board ### Edited Wednesday at 05:03 PM by Avatar Ng 0 Quote Link to comment Share on other sites More sharing options...
Avatar Ng Posted Wednesday at 05:27 PM Share Posted Wednesday at 05:27 PM (edited) Here's another, tried an older image "Armbian_22.11.4_Orangepi5_jammy_legacy_5.10.110_gnome_desktop.img", at least there's a display, and then after the Armbian logo loading screen, gets into the following infinite loop (please find full log at attachment) ... [ 217.042512] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3 [ 217.145850] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3 [ 217.249275] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3 [ 217.352617] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3 [ 217.455849] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3 [ 217.559164] rk3x-i2c fec80000.i2c: timeout, ipd: 0x80, state: 3 ... Image "Armbian_23.02.2_Orangepi5_jammy_legacy_5.10.110.img" is more silent, it stops at "Starting kernel ...", let me know if you need that log too, I forgot to capture it, it also has a display on my HDMI monitor. Hope that helps. ReceivedTofile-COM7-6_1_2023_1-21-02_AM.DAT Edited Wednesday at 05:30 PM by Avatar Ng 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted Wednesday at 05:57 PM Share Posted Wednesday at 05:57 PM @Avatar Ng looks like it's my bad. can you try to replace `rk3588s-orangepi-5-plus.dtb` with `rk3588-orangepi-5-plus.dtb` in armbianEnv.txt 0 Quote Link to comment Share on other sites More sharing options...
