EUA Posted April 17, 2017 Posted April 17, 2017 12 hours ago, hojnikb said: Actual sd card slot is still limited to SD25, so you won't see anything like 90MB/s. Not that it matter, because responsiveness is determined by random performance, not sequential. Thank you for explanation. It sounds like a HW limitation, or does it due FW?
hojnikb Posted April 17, 2017 Posted April 17, 2017 1 hour ago, EUA said: Thank you for explanation. It sounds like a HW limitation, or does it due FW? Its a board limitation, so it cant be patch in software.
Igor Posted April 18, 2017 Posted April 18, 2017 9 hours ago, NEON said: On connected HDMI monitor with standby, backlight still on... Any solution? (Last nightly build) IIRC DPMS is / used to be buggy so it's disabled in config ... it goes off and it never came back. Try and play with settings to see if it's working now.
zador.blood.stained Posted April 18, 2017 Posted April 18, 2017 PC2 uses simplefb video output here, so controlling HDMI output is not possible.
NEON Posted April 18, 2017 Posted April 18, 2017 9 hours ago, Igor said: IIRC DPMS is / used to be buggy so it's disabled in config ... it goes off and it never came back. Try and play with settings to see if it's working now. I already tested on this config, is didn't work...
Igor Posted April 18, 2017 Posted April 18, 2017 3 minutes ago, NEON said: I already tested on this config, is didn't work... I failed to see / register that we are talking about PC2 with development mainline kernel and it's temporally simplefb video driver. Bottom up: this function doesn't work with this kernel yet. This is the only kernel ATM.
Menion Posted April 21, 2017 Posted April 21, 2017 Hi One question: is the power button supported by acpi events (via acpid) on WIP Sunxi mainline kernel 4.10.x? Actually I see that when I press the button I get 2 interrupts on CPU0 from this source: 32: 5 0 0 0 sunxi_pio_edge 3 Edge sw4 But a sudo acpi_listen does not report any event Bye
zador.blood.stained Posted April 22, 2017 Posted April 22, 2017 13 hours ago, Menion said: One question: is the power button supported by acpi events (via acpid) on WIP Sunxi mainline kernel 4.10.x? At least on H3 device this button is configured as an input device that sends "shutdown" key press, but I don't remember if it is implemented in the branch we are currently using on PC2.
Menion Posted April 22, 2017 Posted April 22, 2017 Well, H3 boards work (or at least Orange pi pc 1 for sure). Does this require some DTS bindings, or it is something that shall be implemented in kernel?
Menion Posted April 26, 2017 Posted April 26, 2017 Hello Igor. I have noticed that the kernel package of the testing Ubuntu builds, miss the v4l kernel modules. As far as I remember, these modules are part of linux-image-extra package, that is platform specific. Unfortunately the build of the linuxtv kernel repo, fails. Do you know if these package is available somehow? I would like to test the realiability of the USB port with DVB cards, that have some problems with mainline kernels on A20 Bye
Menion Posted April 26, 2017 Posted April 26, 2017 (edited) Small update I build a custom kernel from Igor git repo, with the multimedia drivers. After having installed the packages I could initialize the USB DVB-T (an AS Media). I could also tune the channels, but after a short playback of a DVB-T channel via TVHeadend, the kernel panics and after the reboot, it is not possible to enumerate the key without an hardware power cycle, this is what I get: Spoiler [ 1.955730] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 2.104266] usb 2-1: unable to read config index 0 descriptor/start: -61 [ 2.104273] usb 2-1: can't read configurations, error -61 [ 2.231746] usb 2-1: new high-speed USB device number 3 using ehci-platform [ 2.380261] usb 2-1: unable to read config index 0 descriptor/start: -61 [ 2.380269] usb 2-1: can't read configurations, error -61 [ 2.380490] random: fast init done [ 2.507696] usb 2-1: new high-speed USB device number 4 using ehci-platform [ 2.536375] usb 2-1: unable to read config index 0 descriptor/start: -61 [ 2.536379] usb 2-1: can't read configurations, error -61 [ 2.663694] usb 2-1: new high-speed USB device number 5 using ehci-platform [ 2.692376] usb 2-1: unable to read config index 0 descriptor/start: -61 [ 2.692379] usb 2-1: can't read configurations, error -61 [ 2.699694] usb usb2-port1: unable to enumerate USB device [ 2.894246] random: crng init done [ 3.079749] usb 5-1: new full-speed USB device number 2 using ohci-platform [ 3.290733] usb 5-1: not running at top speed; connect to a high speed hub [ 3.296726] usb 5-1: unable to read config index 0 descriptor/start: -61 [ 3.296731] usb 5-1: can't read configurations, error -61 [ 3.483696] usb 5-1: new full-speed USB device number 3 using ohci-platform [ 3.694721] usb 5-1: not running at top speed; connect to a high speed hub [ 3.700722] usb 5-1: unable to read config index 0 descriptor/start: -61 [ 3.700725] usb 5-1: can't read configurations, error -61 [ 3.891711] usb 5-1: new full-speed USB device number 4 using ohci-platform [ 3.924721] usb 5-1: not running at top speed; connect to a high speed hub [ 3.930723] usb 5-1: unable to read config index 0 descriptor/start: -61 [ 3.930726] usb 5-1: can't read configurations, error -61 [ 3.959961] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 4.115717] usb 5-1: new full-speed USB device number 5 using ohci-platform [ 4.148730] usb 5-1: not running at top speed; connect to a high speed hub [ 4.154727] usb 5-1: unable to read config index 0 descriptor/start: -61 [ 4.154731] usb 5-1: can't read configurations, error -61 [ 4.159703] usb usb5-port1: unable to enumerate USB device I have a 3A power supply and the DVB-T key is the only thing connected to USB (well actually, nothing is connected to the board). Without the kernel panic, it is the same problem I experience with the BananaPi, using this key. Does anyone know if there is some well known USB limitation with AllWinner in mainline? This key works ok with a Raspberry PI, even if some RPi specific tweaks are required at kernel cmdline Edited April 29, 2017 by zador.blood.stained Added spoiler tags
Menion Posted April 26, 2017 Posted April 26, 2017 (edited) I managed to get the kernel fault log: Spoiler [ 828.919647] INFO: rcu_sched self-detected stall on CPU [ 828.925694] 0-...: (1 GPs behind) idle=5a7/140000000000002/0 softirq=8118/8119 fqs=2179 [ 828.934283] (t=5250 jiffies g=4414 c=4413 q=163) [ 828.939572] Task dump for CPU 0: [ 828.939672] kworker/0:3 R running task 0 499 2 0x00000002 [ 828.940171] Workqueue: events dbs_work_handler [ 828.940312] Call trace: [ 828.940585] [<ffff000008087a20>] dump_backtrace+0x0/0x220 [ 828.940830] [<ffff000008087c54>] show_stack+0x14/0x20 [ 828.941035] [<ffff0000080d0c84>] sched_show_task+0x10c/0x170 [ 828.941219] [<ffff0000080d3470>] dump_cpu_task+0x40/0x50 [ 828.941425] [<ffff000008156264>] rcu_dump_cpu_stacks+0x98/0xe0 [ 828.941659] [<ffff000008100108>] rcu_check_callbacks+0x678/0x858 [ 828.941892] [<ffff000008102c74>] update_process_times+0x2c/0x58 [ 828.942108] [<ffff00000811205c>] tick_sched_handle.isra.7+0x24/0x70 [ 828.942294] [<ffff0000081120ec>] tick_sched_timer+0x44/0x90 [ 828.942530] [<ffff0000081037a8>] __hrtimer_run_queues+0xf0/0x178 [ 828.942758] [<ffff000008103ae8>] hrtimer_interrupt+0xa0/0x220 [ 828.942993] [<ffff00000869ee20>] arch_timer_handler_phys+0x30/0x40 [ 828.943225] [<ffff0000080f61b8>] handle_percpu_devid_irq+0x78/0x130 [ 828.943410] [<ffff0000080f0eac>] generic_handle_irq+0x24/0x38 [ 828.943586] [<ffff0000080f152c>] __handle_domain_irq+0x5c/0xb8 [ 828.943759] [<ffff000008080d24>] gic_handle_irq+0x54/0xa8 [ 828.943902] Exception stack(0xffff80003ef7fcf0 to 0xffff80003ef7fe20) [ 828.944072] fce0: ffff80003ef7fd20 0001000000000000 [ 828.944275] fd00: ffff80003ef7fe50 ffff00000869bf28 0000000060000145 ffff000008002010 [ 828.944460] fd20: ffff80003dafec98 0000000000000001 0000000000000000 0000000000000000 [ 828.944654] fd40: ffff80003c183020 000000007f0442a0 ffff000008cefa00 0000000002008d80 [ 828.944848] fd60: dead000000000200 dead000000000100 000000007f0449c0 a1f337920e2aedb8 [ 828.945040] fd80: 68b600c080ce36d2 f6544622d5dac600 defc40e002c0d0df 0000000000000001 [ 828.945222] fda0: 0000000000000001 000000000000001c 0000000000000001 ffff80003dafeb90 [ 828.945412] fdc0: ffff80003dafeca0 ffff000008b82af8 ffff000008b82af8 0000000000000000 [ 828.945600] fde0: ffff80003dafec80 0000000000000038 0000000000000000 ffff80003bdd4b00 [ 828.945795] fe00: ffff000008b15180 ffff80003ef7fe50 ffff00000869bef4 ffff80003ef7fe50 [ 828.945971] [<ffff000008081ff4>] el1_irq+0xb4/0x140 [ 828.946226] [<ffff000008637244>] usb_led_activity+0x7c/0x88 [ 828.946480] [<ffff0000085e8010>] __usb_hcd_giveback_urb+0x60/0x150 [ 828.946702] [<ffff0000085e8198>] usb_giveback_urb_bh+0x98/0xe8 [ 828.946916] [<ffff0000080ad854>] tasklet_action+0x74/0x120 [ 828.947117] [<ffff0000080ada64>] __do_softirq+0x10c/0x218 [ 828.947312] [<ffff0000080ade70>] irq_exit+0xc8/0x118 [ 828.947497] [<ffff0000080f1530>] __handle_domain_irq+0x60/0xb8 [ 828.947663] [<ffff000008080d24>] gic_handle_irq+0x54/0xa8 [ 828.947796] Exception stack(0xffff80003d057a60 to 0xffff80003d057b90) [ 828.947995] 7a60: ffff80003d806100 ffff80003d806100 0000000000000000 000000000a037a00 [ 828.948181] 7a80: 0000000000000000 0000000000000012 ffff000008b6d440 0000000000000003 [ 828.948365] 7aa0: 00000000280de800 0000000000000001 00000000112a8800 00000000bcd3d800 [ 828.948540] 7ac0: 0000000000000021 0000000000000005 0000000000000001 0000000000000001 [ 828.948719] 7ae0: 0000000000000001 000000000000001c 0000000000000001 ffff80003d806100 [ 828.948914] 7b00: ffff80003d806900 00000000016e3600 00000000405f7e00 ffff80003ef804e0 [ 828.949108] 7b20: ffff80003c7956c0 ffff80003c795500 ffff80003c7956e0 ffff80003d883d20 [ 828.949302] 7b40: 0000000000000000 ffff80003d057b90 ffff00000851dcb8 ffff80003d057b90 [ 828.949497] 7b60: ffff00000851dbdc 0000000060000145 ffff80003d057ba0 ffff00000851c00c [ 828.949640] 7b80: ffffffffffffffff ffff80003d806900 [ 828.949807] [<ffff000008081ff4>] el1_irq+0xb4/0x140 [ 828.950045] [<ffff00000851dbdc>] clk_change_rate+0x1bc/0x238 [ 828.950258] [<ffff00000851dcb8>] clk_core_set_rate_nolock+0x60/0xc8 [ 828.950457] [<ffff00000851dd48>] clk_set_rate+0x28/0x58 [ 828.950650] [<ffff00000858e38c>] _generic_set_opp+0x9c/0x190 [ 828.950834] [<ffff00000858f2b8>] dev_pm_opp_set_rate+0x120/0x298 [ 828.951044] [<ffff000008674458>] set_target+0x30/0x38 [ 828.951310] [<ffff00000866e48c>] __cpufreq_driver_target+0x244/0x528 [ 828.951503] [<ffff000008672a24>] od_dbs_update+0x104/0x1a0 [ 828.951704] [<ffff00000867365c>] dbs_work_handler+0x3c/0x78 [ 828.951906] [<ffff0000080bf9b0>] process_one_work+0x1d8/0x388 [ 828.952087] [<ffff0000080bfba8>] worker_thread+0x48/0x4a0 [ 828.952304] [<ffff0000080c5a28>] kthread+0xf0/0x120 [ 828.952487] [<ffff0000080826c0>] ret_from_fork+0x10/0x50 [ 856.032718] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [kworker/0:3:499] [ 856.041028] Modules linked in: as102_fe dvb_as102 dvb_core sun8i_codec_analog sun4i_codec snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer [ 856.041949] CPU: 0 PID: 499 Comm: kworker/0:3 Not tainted 4.10.0-sun50iw2 #1 [ 856.042036] Hardware name: Xunlong Orange Pi PC 2 (DT) [ 856.042358] Workqueue: events dbs_work_handler [ 856.042548] task: ffff80003bdd4b00 task.stack: ffff80003d054000 [ 856.042809] PC is at __usb_hcd_giveback_urb+0x7c/0x150 [ 856.043015] LR is at __usb_hcd_giveback_urb+0x78/0x150 [ 856.043152] pc : [<ffff0000085e802c>] lr : [<ffff0000085e8028>] pstate: 80000145 [ 856.043228] sp : ffff80003ef7fea0 [ 856.043320] x29: ffff80003ef7fea0 x28: ffff000008b15180 [ 856.043548] x27: ffff80003bdd4b00 x26: 0000000000000000 [ 856.043758] x25: 0000000000000038 x24: 0000000000000030 [ 856.043967] x23: ffff000008ae5000 x22: 0000000000000000 [ 856.044170] x21: ffff80003c629000 x20: 0000000000000140 [ 856.044374] x19: ffff80003c183b00 x18: 0000000000000001 [ 856.044569] x17: 000000000000001c x16: 0000000000000001 [ 856.044762] x15: 0000000000000001 x14: 0000000000000205 [ 856.044965] x13: ffff000008ba7a00 x12: 0000000000000001 [ 856.045159] x11: 0000000000000001 x10: 000000007f044960 [ 856.045367] x9 : dead000000000100 x8 : dead000000000200 [ 856.045570] x7 : 0000000002008d80 x6 : ffff000008cef9a0 [ 856.045771] x5 : 000000007f044840 x4 : 0000000000000040 [ 856.045970] x3 : ffff000008cef880 x2 : 00000000000060e4 [ 856.046164] x1 : 00000000000001c0 x0 : 0000000000000000 menion@orangepipc2:~$ Edited April 29, 2017 by zador.blood.stained Added spoiler tags
pec Posted May 1, 2017 Posted May 1, 2017 @Menion IIRC I had the same issue. Try setting CPU governor to "performance".
Menion Posted May 3, 2017 Posted May 3, 2017 On 1/5/2017 at 8:28 PM, pec said: @Menion IIRC I had the same issue. Try setting CPU governor to "performance". Apparently it has something to do with the specific DVB-T driver. I have tested a Terratec based on em28xx plus xc3028 tuner. Even if this key require much more current, it works perfectly with OPiPc2
VyacheslavS Posted May 7, 2017 Posted May 7, 2017 Today I updated immediately noticed that did not work for several teams: Spoiler :~$ cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 1: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 2: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 3: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. ~$ cat /sys/class/thermal/thermal_zone0/temp cat: /sys/class/thermal/thermal_zone0/temp: No such file or directory svm@orangepipc2:~$ $ uname -a Linux orangepipc2 4.11.0-sun50iw2 #3 SMP Sun May 7 03:57:56 CEST 2017 aarch64 aarch64 aarch64 GNU/Linux svm@orangepipc2:~$ My log - http://sprunge.us/fFCg What you need to do that would work?
zador.blood.stained Posted May 7, 2017 Posted May 7, 2017 2 minutes ago, VyacheslavS said: What you need to do that would work? Wait (1 week or more) until migration to 4.11 is completed or use a previous nightly image with kernel 4.10 1
VyacheslavS Posted May 7, 2017 Posted May 7, 2017 How to roll back to the previous kernel? Or need the whole system to put from zero?
zador.blood.stained Posted May 7, 2017 Posted May 7, 2017 1 hour ago, VyacheslavS said: How to roll back to the previous kernel? Not possible unless you have a backup. Beta/nightly repository usually has only the latest kernel versions so installing older kernel versions is not possible unless you or anybody else have required .deb files.
VyacheslavS Posted May 8, 2017 Posted May 8, 2017 Today came the update. The temperature value earned. Information about the processor not working yet. ~$ uname -a Linux orangepipc2 4.11.0-sun50iw2 #5 SMP Mon May 8 03:30:32 CEST 2017 aarch64 aarch64 aarch64 GNU/Linux The CPU is now hotter. No load was +45C, now +52C.
Trifon Chervenkov Posted May 8, 2017 Posted May 8, 2017 Hi all, I am trying to use vlan functionality I've noticed that the kernel is compiled without vlan 802.1q support (/boot/config-4.11.0-sun50iw2): # CONFIG_VLAN_8021Q is not set Is it possible to include it in the next releases?
stanislav_labs Posted May 14, 2017 Posted May 14, 2017 Hi ! I try to use last firmware for OP PC 2 - Armbian_5.27.170502_Orangepipc2_Ubuntu_xenial_dev_4.10.0_desktop.img and cant work normally USB cameras - (UVC usb2.0 and MicrcoftVX-1000).. lsusb Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 003: ID 1871:0142 Aveo Technology Corp. Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 002: ID 1a2c:0023 China Resource Semico Co., Ltd v4l2-ctl --list-devices - GET ERROR Failed to open /dev/video0: No such file or directory and then i try to build driver from rep git clone git://linuxtv.org/media_build.git i have some error.. /root/.config/guvcview2/media_build/v4l/vim2m.c: In function 'vim2m_release': /root/.config/guvcview2/media_build/v4l/vim2m.c:959:30: error: 'struct v4l2_fh' has no member named 'm2m_ctx' v4l2_m2m_ctx_release(ctx->fh.m2m_ctx); ^ scripts/Makefile.build:300: recipe for target '/root/.config/guvcview2/media_build/v4l/vim2m.o' failed make[3]: *** [/root/.config/guvcview2/media_build/v4l/vim2m.o] Error 1 Makefile:1492: recipe for target '_module_/root/.config/guvcview2/media_build/v4l' failed make[2]: *** [_module_/root/.config/guvcview2/media_build/v4l] Error 2 make[2]: Leaving directory '/usr/src/linux-headers-4.11.0-sun50iw2' Makefile:51: recipe for target 'default' failed make[1]: *** [default] Error 2 make[1]: Leaving directory '/root/.config/guvcview2/media_build/v4l' Makefile:26: recipe for target 'all' failed make: *** [all] Error 2 Thanks
Menion Posted May 18, 2017 Posted May 18, 2017 You have to clone the armbian repo: https://github.com/armbian/build Then recompile a kernel (use ./compile.sh KERNEL_CONFIGURE=yes KERNEL_ONLY=yes) and enable under drivers/multimedia/platform the v4l webcam support you need The out of tree linuxtv will never compile unless if matched with exactly the kernel version supported. It is a long story, and sadly one of the biggest limitation in Linux, that I believe no one is really willing to solve, such implement a stable framework for out of tree drivers implementation.
Hoefnix Posted May 19, 2017 Posted May 19, 2017 Planning on buying an Orange Pi and would like to buy a H5 based one but warned by the disclaimer I have a simple question... is the current support good enough for semi-production environment or should i stick with the H3 CPU?
Hoefnix Posted May 20, 2017 Posted May 20, 2017 3 hours ago, martinayotte said: That all depends about what you wish to do ... Well stuff like homegrown phyton scripts, things like nzbget, couch potato and homebridge
hojnikb Posted May 21, 2017 Posted May 21, 2017 Looks like cpufreq is still broken (did an update after a while). Just a warning for those updating.
freemaker Posted May 23, 2017 Posted May 23, 2017 Ic2 not working in latest mainline Installed Armbian_5.27.170522_Orangepipc2_Ubuntu_xenial_dev_4.11.1_desktop.img on OrangePi PC2 Found i2c missing Adds overylay in /boot/armbianEnv.txt ->overlays=i2c0 i2c1 i2c2 Modified i2c to enabled in /boot/dtb-4.11.1-sun50iw2/allwinner/sun50i-h5-orangepi-pc2.dtb Still no luck to find any i2c devices
zador.blood.stained Posted May 23, 2017 Posted May 23, 2017 5 hours ago, freemaker said: Ic2 not working in latest mainline Hm. "reg" property of i2c2 in sunxi-h3-h5.dtsi is wrong (copy-paste issue) i2c1: i2c@01c2b000 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C1>; resets = <&ccu RST_BUS_I2C1>; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; }; i2c2: i2c@01c2b400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C2>; resets = <&ccu RST_BUS_I2C2>; pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; }; The issue is present in linux-next too, so it has to be reported upstream.
zador.blood.stained Posted May 23, 2017 Posted May 23, 2017 I2C should work after the next kernel and DT packages update.
