ledfreak3d Posted November 21, 2016 Posted November 21, 2016 Hi guys I am having some issues with booting from emmc created a sdcard with th latest armbian version for the orange pi pc plus can boot it without problems updated and upgraded everything. then ran nand-sata-install all seems to be going ok but after that it wont boot from emmc without sd card inserted I am pretty sure I am missing something obvious lol any help with be greatly appreciated
Pieter Posted November 21, 2016 Posted November 21, 2016 This might help: https://forum.armbian.com/index.php/topic/2046-vanilla-kernel-on-opi-pc-install-to-emmc/#entry15685
ledfreak3d Posted November 21, 2016 Author Posted November 21, 2016 Thanks Pieter mutch apprciated. Will give that a try when i am back from work
martinayotte Posted November 21, 2016 Posted November 21, 2016 Yes, indeed, my previous post could help. Check also the root partition in /boot/boot.cmd and also in /etc/fstab files located in the eMMC.
ledfreak3d Posted November 21, 2016 Author Posted November 21, 2016 humz ok that did not work for me but it seems there is also a new kernel and the file located in usr/lib/linux-u-boot-orangepipcplus_5.23_armhf is 5.23 instead of 5.20 dd if=/usr/lib/linux-u-boot-orangepipcplus_5.23_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8 the copy was succesfull but still no boot from emmc maybe eter to do it before anything is updated
martinayotte Posted November 21, 2016 Posted November 21, 2016 Did you verify the rootfs in /boot/boot.cmd and /etc/fstab ? If those are perfect, then, you will need to hook some USB-TTL Serial on Debug port and provide us the boot log output.
ledfreak3d Posted November 22, 2016 Author Posted November 22, 2016 Going todo that when i am at work. Else i will hook up the ttl adaptor and check the debug info
ledfreak3d Posted November 22, 2016 Author Posted November 22, 2016 fstab file shows /dev/mmcblk0p1 / ext 4 boot.cmd shows root=/dev/mmcblk0p1 nand-sata-install show a lot of read only file system errors humz that sounds bad
ledfreak3d Posted November 22, 2016 Author Posted November 22, 2016 tried to format emmc storage manual no problems there these are the steps I am doing now writing new image to card latest armbian 5.20 that's on the oramge pi site booting from card all ok no issues seen. doing no updates at all going straight into root terminal and typing nand-sata-install
tkaiser Posted November 22, 2016 Posted November 22, 2016 dd if=/usr/lib/linux-u-boot-orangepipcplus_5.23_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8 Since you're using legacy image this is not supposed to work at all (eMMC being mmcblk2 is something that happens with mainline kernel but not legacy). Please get a serial console since we have a few rather strange reports regarding eMMC on the Plus: https://github.com/igorpecovnik/lib/pull/540 No progress being made so far (since if we ask for logs and don't get logs then...)
ledfreak3d Posted November 22, 2016 Author Posted November 22, 2016 what image should I use then ? I can do a serial debug if you want but will it show any emmc errors ?
Christos Posted November 22, 2016 Posted November 22, 2016 FYI, I build image with -> https://github.com/igorpecovnik/lib for my PCPlus. Thus having Armbian 5.24, legacy jesse 3.4.113 with desktop and it works flawlessly, nand-sata-install takes quite some time but finishes successfully dont know if you're willing to build from source though..
tkaiser Posted November 22, 2016 Posted November 22, 2016 what image should I use then ? I can do a serial debug if you want but will it show any emmc errors ? Ok, we get 'it does not work!' reports, we can not reproduce the issue since it doesn't happen on our devices and we don't get logs from users even if we ask them. How to proceed? Why don't you provide just a boot log from serial console for any of the 'it does not work!' cases? I've not the slightest idea how this log will look like and that's the reason we need those logs! If I would know the contents I wouldn't need it.
ledfreak3d Posted November 22, 2016 Author Posted November 22, 2016 the log file with sd card inserted U-Boot SPL 2016.09-armbian (Sep 15 2016 - 07:38:36)DRAM: 1024 MiBTrying to boot from MMC1 U-Boot 2016.09-armbian (Sep 15 2016 - 07:38:36 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680)Model: Xunlong Orange Pi PC PlusI2C: readyDRAM: 1 GiBMMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1*** Warning - bad CRC, using default environment In: serialOut: serialErr: serialNet: phy interface0eth0: ethernet@1c30000Hit any key to stop autoboot: 2 1 0switch to partitions #0, OKmmc0 is current deviceScanning mmc 0:1...Found U-Boot script /boot/boot.scr2789 bytes read in 157 ms (16.6 KiB/s)## Executing script at 43100000gpio: pin PL10 (gpio 298) value is 1gpio: pin PG11 (gpio 203) value is 159 bytes read in 118 ms (0 Bytes/s)** File not found /boot/.next **** Unrecognized filesystem type **** File not found .next **37596 bytes read in 436 ms (84 KiB/s)3114592 bytes read in 321 ms (9.3 MiB/s)5025168 bytes read in 468 ms (10.2 MiB/s)## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3114528 Bytes = 3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OKUsing machid 0x1029 from environment Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 1024MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2004620! ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
ledfreak3d Posted November 23, 2016 Author Posted November 23, 2016 anybody the problem is that for some reason the script is unable to copy data correctly to the emmc can anybody point out to me how to repartition the emmc and point to the correct rootfs and bootfs after that the script should run fine
Igor Posted November 23, 2016 Posted November 23, 2016 I fixed some related problems yesterday, try image from beta download to check if it's working for you.
ledfreak3d Posted November 23, 2016 Author Posted November 23, 2016 is there a new image for that or just run the new script ? in my case it seems there is something going wrong with setting the partitions because if I flash the server version instead of destop it works fine but it changes the size of the bootfs partition
Igor Posted November 23, 2016 Posted November 23, 2016 Background info Location: http://image.armbian.com/betaimages Image: Armbian_5.24.161122_Orangepipc_Ubuntu_xenial_3.4.113_desktop.7z I made some changes, I made tests but it bugs still can be around. Please try.
ledfreak3d Posted November 23, 2016 Author Posted November 23, 2016 thanks Igor you are the best will test and report back to you
ledfreak3d Posted November 23, 2016 Author Posted November 23, 2016 Hey Igor with the new image the nand-sata-install results in there are no targets error message
Igor Posted November 23, 2016 Posted November 23, 2016 True, you need a different config. Run this as root and reboot, than it should work. ln -fs /boot/bin/orangepipcplus.bin /boot/script.bin
ledfreak3d Posted November 23, 2016 Author Posted November 23, 2016 almost Last login: Wed Nov 23 18:44:19 2016 from 192.168.1.1root@orangepipc:~# sudo ln -fs /boot/bin/orangepipcplus.bin /boot/script.binln: failed to create symbolic link ' /boot/script.bin': No such file or directoryroot@orangepipc:~# ok just copied the file manualy as a work around that seem to have done the trick script now runs nope hopefully it will complete without errors btw this image seems to work a lot beter then the old one but still have random disconnects on wifi and lan when connected with putty realy anying when you are running the script and it gets disconnected
Igor Posted November 24, 2016 Posted November 24, 2016 Beta images still have some troubles, that's why they are beta ... try with disabling power management: iwconfig wlan0 power off Wifi should be more responsive after that.
ledfreak3d Posted November 24, 2016 Author Posted November 24, 2016 Awesome thanks Igor you are the man did find a other issues that's not related to the image but was probably causing most of my problems the beefy 2.5 amp 5 volt adaptor I was using was not realy up to the job because voltage was dropping to 4.5 volt under load. so that probably Caused the disconnects and network hickups and random lockups
tkaiser Posted November 24, 2016 Posted November 24, 2016 the beefy 2.5 amp 5 volt adaptor I was using was not realy up to the job because voltage was dropping to 4.5 volt under load. so that probably Caused the disconnects and network hickups and random lockups As always. And with OPi Zero it will get even worse since the Micro USB port there will encourage users to use the crappiest phone 'Chargers' somewhere lying around just to blame Armbian for their PSU troubles.
tkaiser Posted November 24, 2016 Posted November 24, 2016 try with disabling power management: iwconfig wlan0 power offWifi should be more responsive after that. Until the next reboot. That's why h3consumption exists.
Igor Posted November 24, 2016 Posted November 24, 2016 Until the next reboot. That's why h3consumption exists. Sure. I would propose that we switch those defaults to off since power management is causing serious troubles on some wireless chips. Sometimes it's necessary to disable it to be functional at first place. Some people would think that wifi doesn't work at all because it needs seconds to respond, when PM is enabled ... Who needs / want's to save some power he will presumably seek for such how-to and found this way. What do you think?
ledfreak3d Posted November 24, 2016 Author Posted November 24, 2016 As always. And with OPi Zero it will get even worse since the Micro USB port there will encourage users to use the crappiest phone 'Chargers' somewhere lying around just to blame Armbian for their PSU troubles. yep and the funny thing is that I already knew this to start off with so they say assumption is the mother of all fuckups I would say measure before you start don't assume any power adaptor rated for 2 amps is capable of doing so lol
tkaiser Posted November 24, 2016 Posted November 24, 2016 What do you think? I agree though I think we should switch away from the hack-ish way we currently deal with this issue: https://github.com/igorpecovnik/lib/issues/558
ledfreak3d Posted November 24, 2016 Author Posted November 24, 2016 ok all works great now everthing is stable nand-sata-install script runs fine but still no boot from emmc boot.cmd seems fine but fstab file doet not have any location In it dos anybody have an example of that file UUID=ed0bb37c-e98d-47fd-96d7-25ffc9ef3a7a / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1tmpfs /tmp tmpfs defaults,nosuid 0 0/var/swap none swap sw 0 0 root@orangepipc:~# lsblkNAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTmmcblk1boot0 179:32 0 4M 1 diskmmcblk1boot1 179:48 0 4M 1 diskmmcblk0 179:0 0 14.9G 0 disk└─mmcblk0p1 179:1 0 14.8G 0 part /mmcblk1 179:16 0 7.3G 0 disk└─mmcblk1p1 179:17 0 7.2G 0 part boot.cmd file # default valuessetenv load_addr "0x44000000"setenv rootdev "/dev/mmcblk1p1"setenv verbosity "1"setenv console "both"setenv disp_mem_reserves "off"setenv disp_mode "1920x1080p60"setenv rootfstype "ext4" # Print boot sourceitest.b *0x28 == 0x00 && echo "Booting from SD"itest.b *0x28 == 0x02 && echo "Booting from eMMC or secondary SD" if load mmc 0 ${load_addr} /boot/armbianEnv.txt || load mmc 0 ${load_addr} armb$
