Armbian crashing when trying to compile code?
Go to solution Solved by Igor,
I am using my Orange Pi as a Pi-Hole and also to run a discord bot of mine
I am having the issue with this repo where I can install packages with `pnpm install` will run and work fine, but when i move to use `pnpm compile` which uses Parcel to compile the codebase from TS and etc to workable JS, I run it and it starts that command and then the Putty terminal I use to remote into my OrangePi (which is on my LAN) from my Windows 11 machine gets a "remote connection terminated" which generally just happens when the remote restarts.
Any idea why this may be happening?
$ armbianmonitor -U
     1
     2  ### Activated 1 lzo-rle zram swap devices with 1867MB each.
     3  ### Activated Armbian ramlog partition with zstd compression
     4
     5  Tue Aug 29 12:00:32 AM EDT 2023 | Orange Pi 5 | 23.02.2 | arm64 | aarch64 | 5.10.110-rockchip-rk3588
     6
     7  ### dmesg:
     8
     9  [    4.374503] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
    10  [    4.374528] Linux version 5.10.110-rockchip-rk3588 (root@5280a832a398) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #23.02.2 SMP Fri Feb 17 23:59:20 UTC 2023
    11  [    4.385273] Machine model: Orange Pi 5
    12  [    4.385430] efi: UEFI not found.
    13  [    4.389176] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
    14  [    4.389195] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
    15  [    4.389268] Reserved memory: created CMA memory pool at 0x00000000ef800000, size 8 MiB
    16  [    4.389273] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
    17  [    4.472949] Zone ranges:
    18  [    4.472956]   DMA      [mem 0x0000000000200000-0x00000000efffffff]
    19  [    4.472967]   DMA32    empty
    20  [    4.472973]   Normal   empty
    21  [    4.472979] Movable zone start for each node
    22  [    4.472982] Early memory node ranges
    23  [    4.472987]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
    24  [    4.472996] Initmem setup node 0 [mem 0x0000000000200000-0x00000000efffffff]
    25  [    4.473002] On node 0 totalpages: 982528
    26  [    4.473007]   DMA zone: 15352 pages used for memmap
    27  [    4.473011]   DMA zone: 0 pages reserved
    28  [    4.473016]   DMA zone: 982528 pages, LIFO batch:63
    29  [    4.493640] psci: probing for conduit method from DT.
    30  [    4.493651] psci: PSCIv1.1 detected in firmware.
    31  [    4.493655] psci: Using standard PSCI v0.2 function IDs
    32  [    4.493661] psci: MIGRATE_INFO_TYPE not supported.
    33  [    4.493668] psci: SMC Calling Convention v1.2
    34  [    4.494079] percpu: Embedded 32 pages/cpu s93416 r8192 d29464 u131072
    35  [    4.494125] pcpu-alloc: s93416 r8192 d29464 u131072 alloc=32*4096
    36  [    4.494132] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
    37  [    4.494280] Detected VIPT I-cache on CPU0
    38  [    4.494323] CPU features: detected: GIC system register CPU interface
    39  [    4.494329] CPU features: detected: Virtualization Host Extensions
    40  [    4.494339] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    41  [    4.494351] alternatives: patching kernel code
    42  [    4.494695] Built 1 zonelists, mobility grouping on.  Total pages: 967176
    43  [    4.494705] Kernel command line: root=UUID=db80a2ac-ec37-4fda-91db-92604becfcce rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=d3d72b81-812f-0647-b27b-46c4eb10cfe8 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    44  [    4.495543] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    45  [    4.495745] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    46  [    4.495752] mem auto-init: stack:off, heap alloc:off, heap free:off
    47  [    4.541208] Memory: 3794988K/3930112K available (16576K kernel code, 3432K rwdata, 6320K rodata, 6912K init, 625K bss, 126932K reserved, 8192K cma-reserved)
    48  [    4.541351] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    49  [    4.541387] ftrace: allocating 63645 entries in 249 pages
    50  [    4.641615] ftrace: allocated 249 pages with 6 groups
    51  [    4.641909] rcu: Hierarchical RCU implementation.
    52  [    4.641915] rcu:     RCU event tracing is enabled.
    53  [    4.641920]  Rude variant of Tasks RCU enabled.
    54  [    4.641924]  Tracing variant of Tasks RCU enabled.
    55  [    4.641930] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
    56  [    4.647237] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    57  [    4.650014] GICv3: GIC: Using split EOI/Deactivate mode
    58  [    4.650020] GICv3: 480 SPIs implemented
    59  [    4.650024] GICv3: 0 Extended SPIs implemented
    60  [    4.650056] GICv3: Distributor has no Range Selector support
    61  [    4.650066] GICv3: 16 PPIs implemented
    62  [    4.650111] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
    63  [    4.650235] ITS [mem 0xfe640000-0xfe65ffff]
    64  [    4.650287] ITS@0x00000000fe640000: allocated 8192 Devices @2a00000 (indirect, esz 8, psz 64K, shr 0)
    65  [    4.650313] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @2a10000 (flat, esz 2, psz 64K, shr 0)
    66  [    4.650323] ITS: using cache flushing for cmd queue
    67  [    4.650362] ITS [mem 0xfe660000-0xfe67ffff]
    68  [    4.650407] ITS@0x00000000fe660000: allocated 8192 Devices @2a30000 (indirect, esz 8, psz 64K, shr 0)
    69  [    4.650432] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @2a40000 (flat, esz 2, psz 64K, shr 0)
    70  [    4.650441] ITS: using cache flushing for cmd queue
    71  [    4.650664] GICv3: using LPI property table @0x0000000002a50000
    72  [    4.650784] GIC: using cache flushing for LPI property table
    73  [    4.650794] GICv3: CPU0: using allocated LPI pending table @0x0000000002a60000
    74  [    4.650972] random: get_random_bytes called from start_kernel+0x3e4/0x5d8 with crng_init=0
    75  [    4.780142] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    76  [    4.780152] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    77  [    4.780162] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    78  [    4.781460] Console: colour dummy device 80x25
    79  [    4.781499] printk: console [tty1] enabled
    80  [    4.781525] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
    81  [    4.781535] pid_max: default: 32768 minimum: 301
    82  [    4.781639] LSM: Security Framework initializing
    83  [    4.781701] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    84  [    4.781715] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    85  [    4.783708] rcu: Hierarchical SRCU implementation.
    86  [    4.784583] Platform MSI: msi-controller@fe640000 domain created
    87  [    4.784604] Platform MSI: msi-controller@fe660000 domain created
    88  [    4.784974] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
    89  [    4.784997] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
    90  [    4.785190] EFI services will not be available.
    91  [    4.785541] smp: Bringing up secondary CPUs ...
    92  [    4.786149] Detected VIPT I-cache on CPU1
    93  [    4.786183] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
    94  [    4.786200] GICv3: CPU1: using allocated LPI pending table @0x0000000002a70000
    95  [    4.786245] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
    96  [    4.786969] Detected VIPT I-cache on CPU2
    97  [    4.786997] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
    98  [    4.787013] GICv3: CPU2: using allocated LPI pending table @0x0000000002a80000
    99  [    4.787052] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
   100  [    4.787703] Detected VIPT I-cache on CPU3
   101  [    4.787727] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
   102  [    4.787743] GICv3: CPU3: using allocated LPI pending table @0x0000000002a90000
   103  [    4.787781] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
   104  [    4.788412] CPU features: detected: Spectre-v4
   105  [    4.788415] CPU features: detected: Spectre-BHB
   106  [    4.788417] Detected PIPT I-cache on CPU4
   107  [    4.788430] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
   108  [    4.788440] GICv3: CPU4: using allocated LPI pending table @0x0000000002aa0000
   109  [    4.788463] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
   110  [    4.789054] Detected PIPT I-cache on CPU5
   111  [    4.789069] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
   112  [    4.789078] GICv3: CPU5: using allocated LPI pending table @0x0000000002ab0000
   113  [    4.789103] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
   114  [    4.789710] Detected PIPT I-cache on CPU6
   115  [    4.789724] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
   116  [    4.789734] GICv3: CPU6: using allocated LPI pending table @0x0000000002ac0000
   117  [    4.789758] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
   118  [    4.790371] Detected PIPT I-cache on CPU7
   119  [    4.790385] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
   120  [    4.790394] GICv3: CPU7: using allocated LPI pending table @0x0000000002ad0000
   121  [    4.790419] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
   122  [    4.790491] smp: Brought up 1 node, 8 CPUs
   123  [    4.790508] SMP: Total of 8 processors activated.
   124  [    4.790514] CPU features: detected: Privileged Access Never
   125  [    4.790518] CPU features: detected: User Access Override
   126  [    4.790523] CPU features: detected: 32-bit EL0 Support
   127  [    4.790527] CPU features: detected: Common not Private translations
   128  [    4.790531] CPU features: detected: RAS Extension Support
   129  [    4.790535] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
   130  [    4.790540] CPU features: detected: CRC32 instructions
   131  [    4.790543] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
   132  [    4.790550] CPU features: detected: RCpc load-acquire (LDAPR)
   133  [    4.790629] CPU: All CPU(s) started at EL2
   134  [    4.792543] devtmpfs: initialized
   135  [    4.806387] Registered cp15_barrier emulation handler
   136  [    4.806395] Registered setend emulation handler
   137  [    4.806399] KASLR disabled due to lack of seed
   138  [    4.806477] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
   139  [    4.806484] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
   140  [    4.806684] pinctrl core: initialized pinctrl subsystem
   141  [    4.806790] regulator-dummy: no parameters, enabled
   142  [    4.806921] DMI not present or invalid.
   143  [    4.807042] NET: Registered protocol family 16
   144  [    4.808177] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
   145  [    4.808284] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   146  [    4.808305] audit: initializing netlink subsys (disabled)
   147  [    4.808386] audit: type=2000 audit(0.026:1): state=initialized audit_enabled=0 res=1
   148  [    4.808920] thermal_sys: Registered thermal governor 'fair_share'
   149  [    4.808922] thermal_sys: Registered thermal governor 'step_wise'
   150  [    4.808924] thermal_sys: Registered thermal governor 'user_space'
   151  [    4.808927] thermal_sys: Registered thermal governor 'power_allocator'
   152  [    4.809069] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
   153  [    4.809102] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
   154  [    4.809133] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
   155  [    4.809163] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
   156  [    4.809194] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
   157  [    4.809226] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
   158  [    4.809245] cpuidle: using governor menu
   159  [    4.809252] Registered FIQ tty driver
   160  [    4.809458] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   161  [    4.809577] ASID allocator initialised with 65536 entries
   162  [    4.810920] ramoops: dmesg-0 0x20000@0x0000000000110000
   163  [    4.810934] ramoops: console 0x80000@0x0000000000130000
   164  [    4.810944] ramoops: pmsg    0x50000@0x00000000001b0000
   165  [    4.810990] printk: console [ramoops-1] enabled
   166  [    4.810993] pstore: Registered ramoops as persistent store backend
   167  [    4.810995] ramoops: using 0xf0000@0x110000, ecc: 0
   168  [    4.860784] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
   169  [    4.861045] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
   170  [    4.861255] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
   171  [    4.861502] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
   172  [    4.861753] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
   173  [    4.861804] rockchip-pinctrl pinctrl: probed pinctrl
   174  [    4.869549] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   175  [    4.869553] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   176  [    4.869556] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   177  [    4.869559] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   178  [    4.930092] raid6: neonx8   gen()  5656 MB/s
   179  [    4.986846] raid6: neonx8   xor()  4355 MB/s
   180  [    5.043603] raid6: neonx4   gen()  5662 MB/s
   181  [    5.100359] raid6: neonx4   xor()  4601 MB/s
   182  [    5.157114] raid6: neonx2   gen()  5322 MB/s
   183  [    5.213871] raid6: neonx2   xor()  4167 MB/s
   184  [    5.270626] raid6: neonx1   gen()  4506 MB/s
   185  [    5.327383] raid6: neonx1   xor()  3236 MB/s
   186  [    5.384143] raid6: int64x8  gen()  1389 MB/s
   187  [    5.440897] raid6: int64x8  xor()   923 MB/s
   188  [    5.497658] raid6: int64x4  gen()  1817 MB/s
   189  [    5.554402] raid6: int64x4  xor()  1007 MB/s
   190  [    5.611167] raid6: int64x2  gen()  2509 MB/s
   191  [    5.667919] raid6: int64x2  xor()  1369 MB/s
   192  [    5.724670] raid6: int64x1  gen()  2066 MB/s
   193  [    5.781426] raid6: int64x1  xor()  1014 MB/s
   194  [    5.781428] raid6: using algorithm neonx4 gen() 5662 MB/s
   195  [    5.781430] raid6: .... xor() 4601 MB/s, rmw enabled
   196  [    5.781432] raid6: using neon recovery algorithm
   197  [    5.781999] fiq_debugger fiq_debugger.0: IRQ fiq not found
   198  [    5.782005] fiq_debugger fiq_debugger.0: IRQ wakeup not found
   199  [    5.782009] fiq_debugger_probe: could not install nmi irq handler
   200  [    5.782088] printk: console [ttyFIQ0] enabled
   201  [    5.782186] Registered fiq debugger ttyFIQ0
   202  [    5.782373] vcc12v_dcin: 12000 mV, enabled
   203  [    5.782447] reg-fixed-voltage vcc12v-dcin: vcc12v_dcin supplying 12000000uV
   204  [    5.782495] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
   205  [    5.782499] vcc5v0_sys: supplied by vcc12v_dcin
   206  [    5.782505] vcc12v_dcin: could not add device link regulator.2: -ENOENT
   207  [    5.782520] vcc5v0_sys: 5000 mV, enabled
   208  [    5.782581] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
   209  [    5.782625] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree
   210  [    5.782629] vcc5v0_usbdcin: supplied by vcc12v_dcin
   211  [    5.782632] vcc12v_dcin: could not add device link regulator.3: -ENOENT
   212  [    5.782645] vcc5v0_usbdcin: 5000 mV, enabled
   213  [    5.782707] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV
   214  [    5.782750] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree
   215  [    5.782753] vcc5v0_usb: supplied by vcc5v0_usbdcin
   216  [    5.782756] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT
   217  [    5.782770] vcc5v0_usb: 5000 mV, enabled
   218  [    5.782825] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV
   219  [    5.782921] vbus5v0_typec: 5000 mV, disabled
   220  [    5.782968] reg-fixed-voltage vbus5v0-typec: Looking up vin-supply from device tree
   221  [    5.782972] vbus5v0_typec: supplied by vcc5v0_usb
   222  [    5.783002] reg-fixed-voltage vbus5v0-typec: vbus5v0_typec supplying 5000000uV
   223  [    5.783055] reg-fixed-voltage vcc3v3-pcie2x1l2: Looking up vin-supply from device tree
   224  [    5.783059] vcc3v3_pcie2x1l2: supplied by vcc5v0_sys
   225  [    5.783062] vcc5v0_sys: could not add device link regulator.6: -ENOENT
   226  [    5.841057] vcc3v3_pcie2x1l2: 1800 mV, enabled
   227  [    5.841125] reg-fixed-voltage vcc3v3-pcie2x1l2: vcc3v3_pcie2x1l2 supplying 1800000uV
   228  [    5.841176] reg-fixed-voltage vcc-1v1-nldo-s3: Looking up vin-supply from device tree
   229  [    5.841180] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
   230  [    5.841183] vcc5v0_sys: could not add device link regulator.7: -ENOENT
   231  [    5.841197] vcc_1v1_nldo_s3: 1100 mV, enabled
   232  [    5.841250] reg-fixed-voltage vcc-1v1-nldo-s3: vcc_1v1_nldo_s3 supplying 1100000uV
   233  [    5.841511] iommu: Default domain type: Translated
   234  [    5.841577] rk_iommu fdab9000.iommu: version = 2
   235  [    5.841887] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply from device tree
   236  [    5.841905] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vdpu-supply property in node /power-management@fd8d8000/power-controller failed
   237  [    5.841957] rk_iommu fdb50800.iommu: version = 2
   238  [    5.842170] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply from device tree
   239  [    5.842186] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga30-supply property in node /power-management@fd8d8000/power-controller failed
   240  [    5.842211] rk_iommu fdb60f00.iommu: version = 2
   241  [    5.842368] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply from device tree
   242  [    5.842384] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rga31-supply property in node /power-management@fd8d8000/power-controller failed
   243  [    5.842412] rk_iommu fdb70f00.iommu: version = 2
   244  [    5.842589] rk_iommu fdb90480.iommu: version = 2
   245  [    5.842782] rk_iommu fdba0800.iommu: version = 2
   246  [    5.842979] rk_iommu fdba4800.iommu: version = 2
   247  [    5.843175] rk_iommu fdba8800.iommu: version = 2
   248  [    5.843370] rk_iommu fdbac800.iommu: version = 2
   249  [    5.843565] rk_iommu fdbb0800.iommu: version = 2
   250  [    5.843710] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply from device tree
   251  [    5.843726] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc0-supply property in node /power-management@fd8d8000/power-controller failed
   252  [    5.843770] rk_iommu fdbdf000.iommu: version = 2
   253  [    5.843871] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply from device tree
   254  [    5.843887] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vcodec-supply property in node /power-management@fd8d8000/power-controller failed
   255  [    5.843994] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply from device tree
   256  [    5.844010] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up venc1-supply property in node /power-management@fd8d8000/power-controller failed
   257  [    5.844059] rk_iommu fdbef000.iommu: version = 2
   258  [    5.844280] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply from device tree
   259  [    5.844296] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec0-supply property in node /power-management@fd8d8000/power-controller failed
   260  [    5.844351] rk_iommu fdc38700.iommu: version = 2
   261  [    5.844588] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply from device tree
   262  [    5.844604] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up rkvdec1-supply property in node /power-management@fd8d8000/power-controller failed
   263  [    5.844657] rk_iommu fdc48700.iommu: version = 2
   264  [    5.844823] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply from device tree
   265  [    5.844838] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up vi-supply property in node /power-management@fd8d8000/power-controller failed
   266  [    5.844887] rk_iommu fdcb7f00.iommu: version = 2
   267  [    5.845073] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply from device tree
   268  [    5.845089] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up isp1-supply property in node /power-management@fd8d8000/power-controller failed
   269  [    5.845132] rk_iommu fdcc7f00.iommu: version = 2
   270  [    5.845327] rk_iommu fdce0800.iommu: version = 2
   271  [    5.845441] rk_iommu fdd97e00.iommu: version = 2
   272  [    5.845742] SCSI subsystem initialized
   273  [    5.845755] libata version 3.00 loaded.
   274  [    5.845828] usbcore: registered new interface driver usbfs
   275  [    5.845842] usbcore: registered new interface driver hub
   276  [    5.845855] usbcore: registered new device driver usb
   277  [    5.845891] mc: Linux media interface: v0.10
   278  [    5.845901] videodev: Linux video capture interface: v2.00
   279  [    5.845928] pps_core: LinuxPPS API ver. 1 registered
   280  [    5.845930] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   281  [    5.845935] PTP clock support registered
   282  [    5.846183] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
   283  [    5.846214] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
   284  [    5.847138] Advanced Linux Sound Architecture Driver Initialized.
   285  [    5.847384] Bluetooth: Core ver 2.22
   286  [    5.847396] NET: Registered protocol family 31
   287  [    5.847399] Bluetooth: HCI device and connection manager initialized
   288  [    5.847403] Bluetooth: HCI socket layer initialized
   289  [    5.847406] Bluetooth: L2CAP socket layer initialized
   290  [    5.847413] Bluetooth: SCO socket layer initialized
   291  [    5.847424] NetLabel: Initializing
   292  [    5.847426] NetLabel:  domain hash size = 128
   293  [    5.847428] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   294  [    5.847452] NetLabel:  unlabeled traffic allowed by default
   295  [    5.848753] rockchip-cpuinfo cpuinfo: SoC            : 35881000
   296  [    5.848757] rockchip-cpuinfo cpuinfo: Serial         : 2b99ff24bfe6e67d
   297  [    5.849139] clocksource: Switched to clocksource arch_sys_counter
   298  [    6.233722] VFS: Disk quotas dquot_6.6.0
   299  [    6.233749] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   300  [    6.238930] NET: Registered protocol family 2
   301  [    6.239006] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
   302  [    6.240102] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
   303  [    6.240159] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
   304  [    6.240324] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
   305  [    6.240702] TCP: Hash tables configured (established 32768 bind 32768)
   306  [    6.240788] MPTCP token hash table entries: 4096 (order: 5, 196608 bytes, linear)
   307  [    6.240840] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
   308  [    6.240917] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
   309  [    6.241043] NET: Registered protocol family 1
   310  [    6.241365] RPC: Registered named UNIX socket transport module.
   311  [    6.241367] RPC: Registered udp transport module.
   312  [    6.241369] RPC: Registered tcp transport module.
   313  [    6.241370] RPC: Registered tcp NFSv4.1 backchannel transport module.
   314  [    6.241790] PCI: CLS 0 bytes, default 64
   315  [    6.242071] Trying to unpack rootfs image as initramfs...
   316  [    6.619012] Freeing initrd memory: 15184K
   317  [    6.619924] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
   318  [    6.620401] kvm [1]: IPA Size Limit: 40 bits
   319  [    6.620412] kvm [1]: GICv3: no GICV resource entry
   320  [    6.620414] kvm [1]: disabling GICv2 emulation
   321  [    6.620416] kvm [1]: GIC system register CPU interface enabled
   322  [    6.620555] kvm [1]: vgic interrupt IRQ9
   323  [    6.620722] kvm [1]: VHE mode initialized successfully
   324  [    6.623385] Initialise system trusted keyrings
   325  [    6.623479] workingset: timestamp_bits=46 max_order=20 bucket_order=0
   326  [    6.626328] NFS: Registering the id_resolver key type
   327  [    6.626337] Key type id_resolver registered
   328  [    6.626339] Key type id_legacy registered
   329  [    6.626373] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   330  [    6.626375] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
   331  [    6.626386] ntfs: driver 2.1.32 [Flags: R/W].
   332  [    6.646479] NET: Registered protocol family 38
   333  [    6.646484] xor: measuring software checksum speed
   334  [    6.648011]    8regs           :  6460 MB/sec
   335  [    6.649155]    32regs          :  8662 MB/sec
   336  [    6.650111]    arm64_neon      : 10316 MB/sec
   337  [    6.650114] xor: using function: arm64_neon (10316 MB/sec)
   338  [    6.650118] Key type asymmetric registered
   339  [    6.650120] Asymmetric key parser 'x509' registered
   340  [    6.650135] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
   341  [    6.650249] io scheduler mq-deadline registered
   342  [    6.650254] io scheduler kyber registered
   343  [    6.651470] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree
   344  [    6.651478] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
   345  [    6.651522] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree
   346  [    6.651528] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
   347  [    6.652760] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree
   348  [    6.652768] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed
   349  [    6.653826] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree
   350  [    6.653833] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed
   351  [    6.655249] phy phy-fee00000.phy.3: Looking up phy-supply from device tree
   352  [    6.655255] phy phy-fee00000.phy.3: Looking up phy-supply property in node /phy@fee00000 failed
   353  [    6.655383] phy phy-fee20000.phy.4: Looking up phy-supply from device tree
   354  [    6.655388] phy phy-fee20000.phy.4: Looking up phy-supply property in node /phy@fee20000 failed
   355  [    6.655784] phy phy-feda0000.phy.5: Looking up phy-supply from device tree
   356  [    6.655790] phy phy-feda0000.phy.5: Looking up phy-supply property in node /phy@feda0000 failed
   357  [    6.655926] phy phy-fedb0000.phy.6: Looking up phy-supply from device tree
   358  [    6.655931] phy phy-fedb0000.phy.6: Looking up phy-supply property in node /phy@fedb0000 failed
   359  [    6.656245] phy phy-fed60000.hdmiphy.7: Looking up phy-supply from device tree
   360  [    6.656251] phy phy-fed60000.hdmiphy.7: Looking up phy-supply property in node /hdmiphy@fed60000 failed
   361  [    6.656943] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
   362  [    6.657665] phy phy-fed80000.phy.8: Looking up phy-supply from device tree
   363  [    6.657672] phy phy-fed80000.phy.8: Looking up phy-supply property in node /phy@fed80000/dp-port failed
   364  [    6.657705] phy phy-fed80000.phy.9: Looking up phy-supply from device tree
   365  [    6.657710] phy phy-fed80000.phy.9: Looking up phy-supply property in node /phy@fed80000/u3-port failed
   366  [    6.658912] rk-pcie fe190000.pcie: invalid prsnt-gpios property in node
   367  [    6.658917] rk-pcie fe190000.pcie: Looking up vpcie3v3-supply from device tree
   368  [    6.659084] pwm-backlight backlight: Looking up power-supply from device tree
   369  [    6.659090] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
   370  [    6.659094] pwm-backlight backlight: supply power not found, using dummy regulator
   371  [    6.659211] rk-pcie fe190000.pcie: missing legacy IRQ resource
   372  [    6.659220] rk-pcie fe190000.pcie: IRQ msi not found
   373  [    6.659222] rk-pcie fe190000.pcie: use outband MSI support
   374  [    6.659225] rk-pcie fe190000.pcie: Missing *config* reg space
   375  [    6.659232] rk-pcie fe190000.pcie: host bridge /pcie@fe190000 ranges:
   376  [    6.659244] rk-pcie fe190000.pcie:      err 0x00f4000000..0x00f40fffff -> 0x00f4000000
   377  [    6.659250] rk-pcie fe190000.pcie:       IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
   378  [    6.659259] rk-pcie fe190000.pcie:      MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000
   379  [    6.659266] pwm-backlight backlight_1: Looking up power-supply from device tree
   380  [    6.659268] rk-pcie fe190000.pcie:      MEM 0x0a00000000..0x0a3fffffff -> 0x0a00000000
   381  [    6.659274] pwm-backlight backlight_1: Looking up power-supply property in node /backlight_1 failed
   382  [    6.659278] pwm-backlight backlight_1: supply power not found, using dummy regulator
   383  [    6.659290] rk-pcie fe190000.pcie: Missing *config* reg space
   384  [    6.659311] rk-pcie fe190000.pcie: invalid resource
   385  [    6.659507] iep: Module initialized.
   386  [    6.659537] mpp_service mpp-srv: bb1f05b87 author: Yandong Lin 2022-10-21 video: rockchip: mpp: add calc hw real times per task
   387  [    6.659539] mpp_service mpp-srv: probe start
   388  [    6.661147] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
   389  [    6.661359] mpp_vdpu2 fdb50400.vdpu: probe device
   390  [    6.661461] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
   391  [    6.661466] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
   392  [    6.661589] mpp_vdpu2 fdb50400.vdpu: probing finish
   393  [    6.661767] mpp_vepu2 jpege-ccu: probing start
   394  [    6.661770] mpp_vepu2 jpege-ccu: probing finish
   395  [    6.661853] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1
   396  [    6.661946] mpp_vepu2 fdb50000.vepu: probing start
   397  [    6.662034] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0
   398  [    6.662038] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0
   399  [    6.662158] mpp_vepu2 fdb50000.vepu: probing finish
   400  [    6.662263] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
   401  [    6.662409] mpp_vepu2 fdba0000.jpege-core: probing start
   402  [    6.662519] mpp_vepu2 fdba0000.jpege-core: attach ccu success
   403  [    6.662623] mpp_vepu2 fdba0000.jpege-core: probing finish
   404  [    6.662723] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
   405  [    6.662866] mpp_vepu2 fdba4000.jpege-core: probing start
   406  [    6.662960] mpp_vepu2 fdba4000.jpege-core: attach ccu success
   407  [    6.663104] mpp_vepu2 fdba4000.jpege-core: probing finish
   408  [    6.663192] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
   409  [    6.663339] mpp_vepu2 fdba8000.jpege-core: probing start
   410  [    6.663433] mpp_vepu2 fdba8000.jpege-core: attach ccu success
   411  [    6.663554] mpp_vepu2 fdba8000.jpege-core: probing finish
   412  [    6.663645] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
   413  [    6.663790] mpp_vepu2 fdbac000.jpege-core: probing start
   414  [    6.663882] mpp_vepu2 fdbac000.jpege-core: attach ccu success
   415  [    6.664004] mpp_vepu2 fdbac000.jpege-core: probing finish
   416  [    6.664243] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
   417  [    6.664383] mpp-iep2 fdbb0000.iep: probe device
   418  [    6.664498] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
   419  [    6.664608] mpp-iep2 fdbb0000.iep: probing finish
   420  [    6.664790] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
   421  [    6.664999] mpp_jpgdec fdb90000.jpegd: probe device
   422  [    6.665234] mpp_jpgdec fdb90000.jpegd: probing finish
   423  [    6.665559] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
   424  [    6.665613] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
   425  [    6.665698] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
   426  [    6.665966] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
   427  [    6.666081] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
   428  [    6.666084] rkvdec2_init:1008: No niu aclk reset resource define
   429  [    6.666087] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
   430  [    6.666089] rkvdec2_init:1011: No niu hclk reset resource define
   431  [    6.666103] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply from device tree
   432  [    6.666108] mpp_rkvdec2 fdc38100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc38000 failed
   433  [    6.666115] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled
   434  [    6.666162] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
   435  [    6.666165] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
   436  [    6.666308] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
   437  [    6.666310] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
   438  [    6.666313] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
   439  [    6.666315] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
   440  [    6.666319] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
   441  [    6.666346] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
   442  [    6.666417] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
   443  [    6.666648] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
   444  [    6.666756] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
   445  [    6.666759] rkvdec2_init:1008: No niu aclk reset resource define
   446  [    6.666762] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
   447  [    6.666764] rkvdec2_init:1011: No niu hclk reset resource define
   448  [    6.666778] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply from device tree
   449  [    6.666783] mpp_rkvdec2 fdc48100.rkvdec-core: Looking up vdec-supply property in node /rkvdec-core@fdc48000 failed
   450  [    6.666788] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled
   451  [    6.666825] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
   452  [    6.666840] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
   453  [    6.667006] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
   454  [    6.667008] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
   455  [    6.667011] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
   456  [    6.667013] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
   457  [    6.667017] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
   458  [    6.667046] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
   459  [    6.667199] mpp_rkvenc2 rkvenc-ccu: probing start
   460  [    6.667202] mpp_rkvenc2 rkvenc-ccu: probing finish
   461  [    6.667305] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
   462  [    6.667486] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
   463  [    6.667501] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
   464  [    6.667641] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
   465  [    6.667766] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
   466  [    6.667833] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
   467  [    6.668065] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
   468  [    6.668079] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
   469  [    6.668238] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
   470  [    6.668370] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
   471  [    6.668576] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply from device tree
   472  [    6.668596] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up av1-supply property in node /power-management@fd8d8000/power-controller failed
   473  [    6.668861] mpp_av1dec: Adding child /av1d@fdc70000
   474  [    6.668936] mpp_av1dec: register device av1d-master
   475  [    6.668961] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
   476  [    6.668978] av1_iommu_probe_device,737, consumer : av1d-master, supplier : fdca0000.iommu
   477  [    6.669008] mpp_av1dec av1d-master: Adding to iommu group 18
   478  [    6.669255] mpp_av1dec av1d-master: probing start
   479  [    6.669489] mpp_av1dec av1d-master: probing finish
   480  [    6.669527] mpp_service mpp-srv: probe success
   481  [    6.677442] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
   482  [    6.677448] dma-pl330 fea10000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
   483  [    6.678387] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
   484  [    6.678391] dma-pl330 fea30000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
   485  [    6.679299] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
   486  [    6.679304] dma-pl330 fed10000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
   487  [    6.679642] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
   488  [    6.679699] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
   489  [    6.679752] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
   490  [    6.679802] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
   491  [    6.679852] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
   492  [    6.680267] rockchip-system-monitor rockchip-system-monitor: system monitor probe
   493  [    6.681002] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
   494  [    6.681476] febc0000.serial: ttyS9 at MMIO 0xfebc0000 (irq = 100, base_baud = 1500000) is a 16550A
   495  [    6.682505] random: fast init done
   496  [    6.682557] random: crng init done
   497  [    6.683427] rockchip-vop2 fdd90000.vop: Adding to iommu group 17
   498  [    6.689494] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
   499  [    6.689502] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
   500  [    6.689520] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
   501  [    6.689527] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
   502  [    6.689536] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -2
   503  [    6.689761] [drm] failed to init overlay plane Cluster0-win1
   504  [    6.689791] [drm] failed to init overlay plane Cluster1-win1
   505  [    6.689819] [drm] failed to init overlay plane Cluster2-win1
   506  [    6.689848] [drm] failed to init overlay plane Cluster3-win1
   507  [    6.700303] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc011169a80)
   508  [    6.701173] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
   509  [    6.701369] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffffffc011171900)
   510  [    6.701433] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffffffc011173f38)
   511  [    6.702032] rockchip-drm display-subsystem: failed to parse loader memory
   512  [    6.702100] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
   513  [    6.702155] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
   514  [    6.702178] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
   515  [    6.702639] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
   516  [    6.708570] brd: module loaded
   517  [    6.711783] loop: module loaded
   518  [    6.711985] zram: Added device: zram0
   519  [    6.712131] lkdtm: No crash points registered, enable through debugfs
   520  [    6.714334] rockchip-spi feb20000.spi: no high_speed pinctrl state
   521  [    6.715793] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
   522  [    6.716087] rk806 spi2.0: ON: 0x60 OFF:0x2
   523  [    6.717806] rk806-regulator rk806-regulator.6.auto: Looking up vcc1-supply from device tree
   524  [    6.717815] vdd_gpu_s0: supplied by vcc5v0_sys
   525  [    6.717821] vcc5v0_sys: could not add device link regulator.8: -ENOENT
   526  [    6.718562] vdd_gpu_s0: 550 <--> 950 mV at 750 mV, enabled
   527  [    6.718952] rk806-regulator rk806-regulator.6.auto: Looking up vcc2-supply from device tree
   528  [    6.718956] vdd_cpu_lit_s0: supplied by vcc5v0_sys
   529  [    6.718961] vcc5v0_sys: could not add device link regulator.9: -ENOENT
   530  [    6.719202] vdd_cpu_lit_s0: 550 <--> 950 mV at 750 mV, enabled
   531  [    6.719661] rk806-regulator rk806-regulator.6.auto: Looking up vcc3-supply from device tree
   532  [    6.719666] vdd_log_s0: supplied by vcc5v0_sys
   533  [    6.719670] vcc5v0_sys: could not add device link regulator.10: -ENOENT
   534  [    6.719895] vdd_log_s0: 675 <--> 750 mV at 750 mV, enabled
   535  [    6.720339] rk806-regulator rk806-regulator.6.auto: Looking up vcc4-supply from device tree
   536  [    6.720344] vdd_vdenc_s0: supplied by vcc5v0_sys
   537  [    6.720349] vcc5v0_sys: could not add device link regulator.11: -ENOENT
   538  [    6.720566] vdd_vdenc_s0: 550 <--> 950 mV at 750 mV, enabled
   539  [    6.721081] rk806-regulator rk806-regulator.6.auto: Looking up vcc5-supply from device tree
   540  [    6.721086] vdd_ddr_s0: supplied by vcc5v0_sys
   541  [    6.721090] vcc5v0_sys: could not add device link regulator.12: -ENOENT
   542  [    6.721307] vdd_ddr_s0: 675 <--> 900 mV at 850 mV, enabled
   543  [    6.721499] rk806-regulator rk806-regulator.6.auto: Looking up vcc6-supply from device tree
   544  [    6.721504] vdd2_ddr_s3: supplied by vcc5v0_sys
   545  [    6.721508] vcc5v0_sys: could not add device link regulator.13: -ENOENT
   546  [    6.721782] vdd2_ddr_s3: at 500 mV, enabled
   547  [    6.722119] rk806-regulator rk806-regulator.6.auto: Looking up vcc7-supply from device tree
   548  [    6.722125] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
   549  [    6.722129] vcc5v0_sys: could not add device link regulator.14: -ENOENT
   550  [    6.722345] vdd_2v0_pldo_s3: 2000 mV, enabled
   551  [    6.722692] rk806-regulator rk806-regulator.6.auto: Looking up vcc8-supply from device tree
   552  [    6.722697] vcc_3v3_s3: supplied by vcc5v0_sys
   553  [    6.722702] vcc5v0_sys: could not add device link regulator.15: -ENOENT
   554  [    6.722918] vcc_3v3_s3: 3300 mV, enabled
   555  [    6.723238] rk806-regulator rk806-regulator.6.auto: Looking up vcc9-supply from device tree
   556  [    6.723243] vddq_ddr_s0: supplied by vcc5v0_sys
   557  [    6.723247] vcc5v0_sys: could not add device link regulator.16: -ENOENT
   558  [    6.723535] vddq_ddr_s0: at 500 mV, enabled
   559  [    6.723873] rk806-regulator rk806-regulator.6.auto: Looking up vcc10-supply from device tree
   560  [    6.723878] vcc_1v8_s3: supplied by vcc5v0_sys
   561  [    6.723882] vcc5v0_sys: could not add device link regulator.17: -ENOENT
   562  [    6.724104] vcc_1v8_s3: 1800 mV, enabled
   563  [    6.724442] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree
   564  [    6.724519] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
   565  [    6.724524] vcc_1v1_nldo_s3: could not add device link regulator.18: -ENOENT
   566  [    6.724744] vdd_0v75_s3: 750 mV, enabled
   567  [    6.725156] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree
   568  [    6.725162] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
   569  [    6.725166] vcc_1v1_nldo_s3: could not add device link regulator.19: -ENOENT
   570  [    6.725382] vdd_ddr_pll_s0: 850 mV, enabled
   571  [    6.725650] avdd_0v75_s0: Bringing 750000uV into 837500-837500uV
   572  [    6.725776] avdd_0v75_s0: ramp_delay not set
   573  [    6.725842] rk806-regulator rk806-regulator.6.auto: Looking up vcc13-supply from device tree
   574  [    6.725848] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
   575  [    6.725853] vcc_1v1_nldo_s3: could not add device link regulator.20: -ENOENT
   576  [    6.726068] avdd_0v75_s0: 837 mV, enabled
   577  [    6.726401] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree
   578  [    6.726407] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
   579  [    6.726412] vcc_1v1_nldo_s3: could not add device link regulator.21: -ENOENT
   580  [    6.726627] vdd_0v85_s0: 850 mV, enabled
   581  [    6.726947] rk806-regulator rk806-regulator.6.auto: Looking up vcc14-supply from device tree
   582  [    6.726953] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3
   583  [    6.726957] vcc_1v1_nldo_s3: could not add device link regulator.22: -ENOENT
   584  [    6.727179] vdd_0v75_s0: 750 mV, enabled
   585  [    6.727564] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree
   586  [    6.727599] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
   587  [    6.727603] vdd_2v0_pldo_s3: could not add device link regulator.23: -ENOENT
   588  [    6.727887] avcc_1v8_s0: 1800 mV, enabled
   589  [    6.728281] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree
   590  [    6.728288] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
   591  [    6.728292] vdd_2v0_pldo_s3: could not add device link regulator.24: -ENOENT
   592  [    6.728587] vcc_1v8_s0: 1800 mV, enabled
   593  [    6.728920] rk806-regulator rk806-regulator.6.auto: Looking up vcc11-supply from device tree
   594  [    6.728926] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
   595  [    6.728931] vdd_2v0_pldo_s3: could not add device link regulator.25: -ENOENT
   596  [    6.729227] avdd_1v2_s0: 1200 mV, enabled
   597  [    6.729556] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree
   598  [    6.729561] vcc_3v3_s0: supplied by vcc5v0_sys
   599  [    6.729566] vcc5v0_sys: could not add device link regulator.26: -ENOENT
   600  [    6.729780] vcc_3v3_s0: 3300 mV, enabled
   601  [    6.730103] rk806-regulator rk806-regulator.6.auto: Looking up vcc12-supply from device tree
   602  [    6.730108] vccio_sd_s0: supplied by vcc5v0_sys
   603  [    6.730113] vcc5v0_sys: could not add device link regulator.27: -ENOENT
   604  [    6.730335] vccio_sd_s0: 1800 <--> 3300 mV at 3300 mV, enabled
   605  [    6.730663] rk806-regulator rk806-regulator.6.auto: Looking up vcca-supply from device tree
   606  [    6.730668] pldo6_s3: supplied by vcc5v0_sys
   607  [    6.730672] vcc5v0_sys: could not add device link regulator.28: -ENOENT
   608  [    6.730877] pldo6_s3: 1800 mV, enabled
   609  [    6.731200] rk806 spi2.0: no sleep-setting state
   610  [    6.731204] rk806 spi2.0: no reset-setting pinctrl state
   611  [    6.731206] rk806 spi2.0: no dvs-setting pinctrl state
   612  [    6.733235] rockchip-spi feb20000.spi: register misc device rkspi-dev2
   613  [    6.735103] spi-nor spi5.0: XM25QU128C (16384 Kbytes) read_data x4
   614  [    6.735119] 1 fixed-partitions partitions found on MTD device sfc_nor
   615  [    6.735121] Creating 1 MTD partitions on "sfc_nor":
   616  [    6.735125] 0x000000000000-0x000001000000 : "loader"
   617  [    6.736929] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
   618  [    6.737058] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply from device tree
   619  [    6.737070] rk_gmac-dwmac fe1c0000.ethernet: Looking up phy-supply property in node /ethernet@fe1c0000 failed
   620  [    6.737084] rk_gmac-dwmac fe1c0000.ethernet: no regulator found
   621  [    6.737088] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
   622  [    6.737093] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42).
   623  [    6.737096] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay.
   624  [    6.737100] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff
   625  [    6.737112] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
   626  [    6.737117] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
   627  [    6.737121] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
   628  [    6.737136] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
   629  [    6.737354] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID
   630  [    6.737518] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
   631  [    6.737523] rk_gmac-dwmac fe1c0000.ethernet:         DWMAC4/5
   632  [    6.737527] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
   633  [    6.737530] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
   634  [    6.737533] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
   635  [    6.737536] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
   636  [    6.737568] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
   637  [    6.737572] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   638  [    6.737575] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
   639  [    6.737578] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
   640  [    6.737582] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
   641  [    6.866926] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   642  [    6.877908] usbcore: registered new interface driver rndis_wlan
   643  [    6.877927] usbcore: registered new interface driver asix
   644  [    6.877941] usbcore: registered new interface driver cdc_ether
   645  [    6.877955] usbcore: registered new interface driver rndis_host
   646  [    6.877976] usbcore: registered new interface driver cdc_ncm
   647  [    6.886392] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   648  [    6.886412] ehci-pci: EHCI PCI platform driver
   649  [    6.886473] ehci-platform: EHCI generic platform driver
   650  [    6.888942] ehci-platform fc800000.usb: EHCI Host Controller
   651  [    6.888970] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
   652  [    6.889103] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000
   653  [    6.892479] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   654  [    6.899175] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
   655  [    6.899454] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
   656  [    6.899465] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   657  [    6.899472] usb usb1: Product: EHCI Host Controller
   658  [    6.899480] usb usb1: Manufacturer: Linux 5.10.110-rockchip-rk3588 ehci_hcd
   659  [    6.899487] usb usb1: SerialNumber: fc800000.usb
   660  [    6.899961] hub 1-0:1.0: USB hub found
   661  [    6.900007] hub 1-0:1.0: 1 port detected
   662  [    6.902510] ehci-platform fc880000.usb: EHCI Host Controller
   663  [    6.902534] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2
   664  [    6.902646] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000
   665  [    6.915830] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
   666  [    6.916076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
   667  [    6.916086] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   668  [    6.916093] usb usb2: Product: EHCI Host Controller
   669  [    6.916101] usb usb2: Manufacturer: Linux 5.10.110-rockchip-rk3588 ehci_hcd
   670  [    6.916108] usb usb2: SerialNumber: fc880000.usb
   671  [    6.916560] hub 2-0:1.0: USB hub found
   672  [    6.916604] hub 2-0:1.0: 1 port detected
   673  [    6.917578] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   674  [    6.917598] ohci-platform: OHCI generic platform driver
   675  [    6.917964] ohci-platform fc840000.usb: Generic Platform OHCI controller
   676  [    6.917985] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3
   677  [    6.918084] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000
   678  [    6.919143] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   679  [    6.945810] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   680  [    6.972475] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   681  [    6.976725] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
   682  [    6.976735] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   683  [    6.976743] usb usb3: Product: Generic Platform OHCI controller
   684  [    6.976750] usb usb3: Manufacturer: Linux 5.10.110-rockchip-rk3588 ohci_hcd
   685  [    6.976757] usb usb3: SerialNumber: fc840000.usb
   686  [    6.977205] hub 3-0:1.0: USB hub found
   687  [    6.977252] hub 3-0:1.0: 1 port detected
   688  [    6.977952] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
   689  [    6.977972] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4
   690  [    6.978077] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000
   691  [    6.999143] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   692  [    7.025810] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   693  [    7.036724] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
   694  [    7.036734] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   695  [    7.036742] usb usb4: Product: Generic Platform OHCI controller
   696  [    7.036749] usb usb4: Manufacturer: Linux 5.10.110-rockchip-rk3588 ohci_hcd
   697  [    7.036756] usb usb4: SerialNumber: fc8c0000.usb
   698  [    7.037223] hub 4-0:1.0: USB hub found
   699  [    7.037267] hub 4-0:1.0: 1 port detected
   700  [    7.038669] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
   701  [    7.038691] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5
   702  [    7.038824] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
   703  [    7.038870] xhci-hcd xhci-hcd.7.auto: irq 119, io mem 0xfcd00000
   704  [    7.039262] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
   705  [    7.039272] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   706  [    7.039280] usb usb5: Product: xHCI Host Controller
   707  [    7.039287] usb usb5: Manufacturer: Linux 5.10.110-rockchip-rk3588 xhci-hcd
   708  [    7.039294] usb usb5: SerialNumber: xhci-hcd.7.auto
   709  [    7.039749] hub 5-0:1.0: USB hub found
   710  [    7.039795] hub 5-0:1.0: 1 port detected
   711  [    7.040177] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
   712  [    7.040194] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6
   713  [    7.040209] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
   714  [    7.040303] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
   715  [    7.040474] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
   716  [    7.040484] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   717  [    7.040492] usb usb6: Product: xHCI Host Controller
   718  [    7.040499] usb usb6: Manufacturer: Linux 5.10.110-rockchip-rk3588 xhci-hcd
   719  [    7.040506] usb usb6: SerialNumber: xhci-hcd.7.auto
   720  [    7.040976] hub 6-0:1.0: USB hub found
   721  [    7.041020] hub 6-0:1.0: 1 port detected
   722  [    7.041541] usbcore: registered new interface driver cdc_acm
   723  [    7.041548] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
   724  [    7.041764] usbcore: registered new interface driver uas
   725  [    7.041908] usbcore: registered new interface driver usb-storage
   726  [    7.043230] usbcore: registered new interface driver usbtouchscreen
   727  [    7.044964] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.5.auto/input/input0
   728  [    7.045548] i2c /dev entries driver
   729  [    7.050096] rk860-regulator 0-0042: Looking up vin-supply from device tree
   730  [    7.050112] vdd_cpu_big0_s0: supplied by vcc5v0_sys
   731  [    7.050126] vcc5v0_sys: could not add device link regulator.29: -ENOENT
   732  [    7.052476] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   733  [    7.054362] vdd_cpu_big0_s0: 550 <--> 1050 mV at 800 mV, enabled
   734  [    7.059393] rk860-regulator 0-0043: Looking up vin-supply from device tree
   735  [    7.059407] vdd_cpu_big1_s0: supplied by vcc5v0_sys
   736  [    7.059418] vcc5v0_sys: could not add device link regulator.30: -ENOENT
   737  [    7.063632] vdd_cpu_big1_s0: 550 <--> 1050 mV at 800 mV, enabled
   738  [    7.066551] Goodix-TS 2-0014: Looking up AVDD28-supply from device tree
   739  [    7.066559] Goodix-TS 2-0014: Looking up AVDD28-supply property in node /i2c@feaa0000/touchscreen@14 failed
   740  [    7.066570] Goodix-TS 2-0014: supply AVDD28 not found, using dummy regulator
   741  [    7.066623] Goodix-TS 2-0014: Looking up VDDIO-supply from device tree
   742  [    7.066629] Goodix-TS 2-0014: Looking up VDDIO-supply property in node /i2c@feaa0000/touchscreen@14 failed
   743  [    7.066637] Goodix-TS 2-0014: supply VDDIO not found, using dummy regulator
   744  [    7.079143] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   745  [    7.105809] rk-pcie fe190000.pcie: PCIe Linking... LTSSM is 0x3
   746  [    7.159293] Goodix-TS 2-0014: i2c test failed attempt 1: -6
   747  [    7.185952] Goodix-TS 2-0014: i2c test failed attempt 2: -6
   748  [    7.212475] Goodix-TS 2-0014: I2C communication failure: -6
   749  [    7.215619] rk860-regulator 2-0042: Looking up vin-supply from device tree
   750  [    7.215624] vdd_npu_s0: supplied by vcc5v0_sys
   751  [    7.215630] vcc5v0_sys: could not add device link regulator.31: -ENOENT
   752  [    7.219689] vdd_npu_s0: 550 <--> 950 mV at 800 mV, enabled
   753  [    7.222518] typec_fusb302 6-0022: Looking up vbus-supply from device tree
   754  [    7.250436] rtc-hym8563 6-0051: rtc information is valid
   755  [    7.256048] rtc-hym8563 6-0051: registered as rtc0
   756  [    7.257087] rtc-hym8563 6-0051: setting system clock to 2023-08-29T04:00:24 UTC (1693281624)
   757  [    7.261349] Goodix-TS 7-0014: Looking up AVDD28-supply from device tree
   758  [    7.261367] Goodix-TS 7-0014: Looking up AVDD28-supply property in node /i2c@fec90000/touchscreen@14 failed
   759  [    7.261393] Goodix-TS 7-0014: supply AVDD28 not found, using dummy regulator
   760  [    7.261513] Goodix-TS 7-0014: Looking up VDDIO-supply from device tree
   761  [    7.261529] Goodix-TS 7-0014: Looking up VDDIO-supply property in node /i2c@fec90000/touchscreen@14 failed
   762  [    7.261552] Goodix-TS 7-0014: supply VDDIO not found, using dummy regulator
   763  [    7.352664] Goodix-TS 7-0014: i2c test failed attempt 1: -6
   764  [    7.379326] Goodix-TS 7-0014: i2c test failed attempt 2: -6
   765  [    7.405837] Goodix-TS 7-0014: I2C communication failure: -6
   766  [    7.407934] rkcifhw fdce0000.rkcif: Adding to iommu group 16
   767  [    7.408485] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF
   768  [    7.410880] rkisp_hw fdcb0000.rkisp: Adding to iommu group 14
   769  [    7.411239] rkisp_hw fdcb0000.rkisp: is_thunderboot: 0
   770  [    7.411249] rkisp_hw fdcb0000.rkisp: max input:0x0@0fps
   771  [    7.411258] rkisp_hw fdcb0000.rkisp: Missing rockchip,grf property
   772  [    7.411474] rkisp_hw fdcb0000.rkisp: no find phandle sram
   773  [    7.411730] rkisp_hw fdcc0000.rkisp: Adding to iommu group 15
   774  [    7.412211] rkisp_hw fdcc0000.rkisp: is_thunderboot: 0
   775  [    7.412222] rkisp_hw fdcc0000.rkisp: max input:0x0@0fps
   776  [    7.412229] rkisp_hw fdcc0000.rkisp: Missing rockchip,grf property
   777  [    7.412449] rkisp_hw fdcc0000.rkisp: no find phandle sram
   778  [    7.414630] usbcore: registered new interface driver uvcvideo
   779  [    7.414636] USB Video Class driver (1.1.1)
   780  [    7.417467] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
   781  [    7.418696] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
   782  [    7.419691] cpu cpu0: Looking up cpu-supply from device tree
   783  [    7.420178] cpu cpu0: bin=0
   784  [    7.420351] cpu cpu0: leakage=12
   785  [    7.420372] cpu cpu0: Looking up cpu-supply from device tree
   786  [    7.421803] cpu cpu0: pvtm=1461
   787  [    7.421890] cpu cpu0: pvtm-volt-sel=3
   788  [    7.421921] cpu cpu0: Looking up cpu-supply from device tree
   789  [    7.422044] cpu cpu0: Looking up mem-supply from device tree
   790  [    7.422204] cpu cpu4: Looking up cpu-supply from device tree
   791  [    7.423900] cpu cpu4: bin=0
   792  [    7.424070] cpu cpu4: leakage=10
   793  [    7.424089] cpu cpu4: Looking up cpu-supply from device tree
   794  [    7.430596] cpu cpu4: pvtm=1696
   795  [    7.434564] cpu cpu4: pvtm-volt-sel=4
   796  [    7.434593] cpu cpu4: Looking up cpu-supply from device tree
   797  [    7.435091] cpu cpu4: Looking up mem-supply from device tree
   798  [    7.435628] cpu cpu6: Looking up cpu-supply from device tree
   799  [    7.437296] cpu cpu6: bin=0
   800  [    7.437466] cpu cpu6: leakage=10
   801  [    7.437483] cpu cpu6: Looking up cpu-supply from device tree
   802  [    7.443952] cpu cpu6: pvtm=1685
   803  [    7.447896] cpu cpu6: pvtm-volt-sel=4
   804  [    7.447924] cpu cpu6: Looking up cpu-supply from device tree
   805  [    7.448420] cpu cpu6: Looking up mem-supply from device tree
   806  [    7.449539] cpu cpu0: avs=0
   807  [    7.450468] cpu cpu4: avs=0
   808  [    7.451387] cpu cpu6: avs=0
   809  [    7.451545] cpu cpu0: EM: OPP:816000 is inefficient
   810  [    7.451548] cpu cpu0: EM: OPP:600000 is inefficient
   811  [    7.451633] cpu cpu0: EM: created perf domain
   812  [    7.451668] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
   813  [    7.452236] cpu cpu4: EM: OPP:2304000 is inefficient
   814  [    7.452241] cpu cpu4: EM: OPP:816000 is inefficient
   815  [    7.452243] cpu cpu4: EM: OPP:600000 is inefficient
   816  [    7.452379] cpu cpu4: EM: created perf domain
   817  [    7.452410] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
   818  [    7.460795] cpu cpu6: EM: OPP:2304000 is inefficient
   819  [    7.460799] cpu cpu6: EM: OPP:816000 is inefficient
   820  [    7.460802] cpu cpu6: EM: OPP:600000 is inefficient
   821  [    7.460955] cpu cpu6: EM: created perf domain
   822  [    7.461357] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
   823  [    7.477705] sdhci: Secure Digital Host Controller Interface driver
   824  [    7.477710] sdhci: Copyright(c) Pierre Ossman
   825  [    7.477715] Synopsys Designware Multimedia Card Interface Driver
   826  [    7.478642] sdhci-pltfm: SDHCI platform and OF driver helper
   827  [    7.481923] ledtrig-cpu: registered to indicate activity on CPUs
   828  [    7.481971] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
   829  [    7.482044] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd
   830  [    7.483469] cryptodev: driver 1.12 loaded.
   831  [    7.483532] hid: raw HID events driver (C) Jiri Kosina
   832  [    7.483945] usbcore: registered new interface driver usbhid
   833  [    7.483952] usbhid: USB HID core driver
   834  [    7.484511] ashmem: initialized
   835  [    7.488715] rockchip-saradc fec10000.saradc: Looking up vref-supply from device tree
   836  [    7.490207] optee: probing for conduit method.
   837  [    7.490214] optee: api uid mismatch
   838  [    7.490227] optee: probe of firmware:optee failed with error -22
   839  [    7.491233] usbcore: registered new interface driver snd-usb-audio
   840  [    7.497966] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply from device tree
   841  [    7.498007] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up audio-supply property in node /power-management@fd8d8000/power-controller failed
   842  [    7.501751] debugfs: File 'Capture' in directory 'dapm' already present!
   843  [    7.503678] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card0/input1
   844  [    7.506454] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card1/input2
   845  [    7.508366] input: headset-keys as /devices/platform/es8388-sound/input/input3
   846  [    7.520738] ES8323 6-0010: ASoC: error at soc_component_write_no_lock on ES8323.6-0010: -5
   847  [    7.575545] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card2/input4
   848  [    7.576573] Initializing XFRM netlink socket
   849  [    7.576585] NET: Registered protocol family 17
   850  [    7.576878] [BT_RFKILL]: Enter rfkill_rk_init
   851  [    7.576881] [WLAN_RFKILL]: Enter rfkill_wlan_init
   852  [    7.577252] Key type dns_resolver registered
   853  [    7.578498] registered taskstats version 1
   854  [    7.578505] Loading compiled-in X.509 certificates
   855  [    7.579388] Btrfs loaded, crc32c=crc32c-generic
   856  [    7.579500] pstore: Using crash dump compression: deflate
   857  [    7.579735] rga3_core0 fdb60000.rga: Adding to iommu group 2
   858  [    7.579922] rga: rga3_core0_irq, irq = 34, match scheduler
   859  [    7.580189] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831.
   860  [    7.580208] rga: rga3_core0 probe successfully
   861  [    7.580481] rga3_core1 fdb70000.rga: Adding to iommu group 3
   862  [    7.580670] rga: rga3_core1_irq, irq = 35, match scheduler
   863  [    7.581060] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831.
   864  [    7.581078] rga: rga3_core1 probe successfully
   865  [    7.581393] rga: rga2_irq, irq = 36, match scheduler
   866  [    7.581711] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
   867  [    7.581720] rga: rga2 probe successfully
   868  [    7.581908] rga2_mmu: IOMMU binding successfully, default mapping core[0x1]
   869  [    7.582195] rga: Module initialized. v1.2.20
   870
   871  [    7.582202] ********************************************************************
   872  [    7.582205] **     NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE           **
   873  [    7.582208] **        **
   874  [    7.582210] **  WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
   875  [    7.582212] **        **
   876  [    7.582214] ** This means that this kernel is built to expose clk operations  **
   877  [    7.582217] ** such as parent or rate setting, enabling, disabling, etc.      **
   878  [    7.582219] ** to userspace, which may compromise security on your system.    **
   879  [    7.582221] **        **
   880  [    7.582223] ** If you see this message and you are not debugging the          **
   881  [    7.582225] ** kernel, report this immediately to your vendor!                **
   882  [    7.582228] **        **
   883  [    7.582230] **     NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE           **
   884  [    7.582232] ********************************************************************
   885  [    7.628382] reg-fixed-voltage combophy-avdd0v85: Looking up vin-supply from device tree
   886  [    7.628460] combophy_avdd0v85: supplied by vdd_0v85_s0
   887  [    7.628469] vdd_0v85_s0: could not add device link regulator.32: -ENOENT
   888  [    7.628530] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply from device tree
   889  [    7.628563] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed
   890  [    7.628742] mali fb000000.gpu: Kernel DDK version g13p0-01eac0
   891  [    7.628761] mali fb000000.gpu: Looking up mali-supply from device tree
   892  [    7.634108] combophy_avdd0v85: 850 mV, enabled
   893  [    7.634312] reg-fixed-voltage combophy-avdd0v85: combophy_avdd0v85 supplying 850000uV
   894  [    7.634435] mali fb000000.gpu: Looking up mem-supply from device tree
   895  [    7.634548] reg-fixed-voltage combophy-avdd1v8: Looking up vin-supply from device tree
   896  [    7.634552] mali fb000000.gpu: Looking up mali-supply from device tree
   897  [    7.634610] combophy_avdd1v8: supplied by avcc_1v8_s0
   898  [    7.634619] avcc_1v8_s0: could not add device link regulator.33: -ENOENT
   899  [    7.637879] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST
   900  [    7.637885] vdd_gpu_s0: Failed to create debugfs directory
   901  [    7.637894] mali fb000000.gpu: Looking up mem-supply from device tree
   902  [    7.637982] combophy_avdd1v8: 1800 mV, enabled
   903  [    7.638066] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST
   904  [    7.638071] vdd_gpu_s0: Failed to create debugfs directory
   905  [    7.638198] mali fb000000.gpu: Looking up mali-supply from device tree
   906  [    7.638218] vdd_gpu_s0: could not add device link fb000000.gpu: -EEXIST
   907  [    7.638223] vdd_gpu_s0: Failed to create debugfs directory
   908  [    7.638517] reg-fixed-voltage combophy-avdd1v8: combophy_avdd1v8 supplying 1800000uV
   909  [    7.638726] mali fb000000.gpu: leakage=18
   910  [    7.638798] mali fb000000.gpu: Looking up mali-supply from device tree
   911  [    7.644409] vcc_3v3_sd_s0: 3300 mV, disabled
   912  [    7.644494] debugfs: Directory 'fb000000.gpu-mali' with parent 'vdd_gpu_s0' already present!
   913  [    7.651185] reg-fixed-voltage vcc-3v3-sd-s0: Looking up vin-supply from device tree
   914  [    7.651239] vcc_3v3_sd_s0: supplied by vcc_3v3_s3
   915  [    7.652776] mali fb000000.gpu: pvtm=900
   916  [    7.659454] reg-fixed-voltage vcc-3v3-sd-s0: vcc_3v3_sd_s0 supplying 3300000uV
   917  [    7.659938] mali fb000000.gpu: pvtm-volt-sel=4
   918  [    7.660181] rockchip-dmc dmc: Looking up center-supply from device tree
   919  [    7.660919] mali fb000000.gpu: avs=0
   920  [    7.661309] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 136; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
   921  [    7.668968] rockchip-dmc dmc: Looking up mem-supply from device tree
   922  [    7.677208] mali fb000000.gpu: GPU hardware issue table may need updating:
   923                 r0p0 status 5 is unknown; treating as r0p0 status 0
   924  [    7.677216] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
   925  [    7.677309] mali fb000000.gpu: No priority control manager is configured
   926  [    7.677317] mali fb000000.gpu: No memory group manager is configured
   927  [    7.677344] mali fb000000.gpu: Protected memory allocator not available
   928  [    7.677729] rockchip-dmc dmc: Looking up center-supply from device tree
   929  [    7.677761] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
   930  [    7.678888] mali fb000000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model'
   931  [    7.678898] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
   932  [    7.679210] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
   933  [    7.679469] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
   934  [    7.679720] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ''
   935  [    7.682541] vdd_ddr_s0: could not add device link dmc: -EEXIST
   936  [    7.682549] vdd_ddr_s0: Failed to create debugfs directory
   937  [    7.683275] rockchip-dmc dmc: Looking up mem-supply from device tree
   938  [    7.683531] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model
   939  [    7.683540] vdd_log_s0: could not add device link dmc: -EEXIST
   940  [    7.683545] vdd_log_s0: Failed to create debugfs directory
   941  [    7.683705] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
   942  [    7.684331] rockchip-dmc dmc: leakage=41
   943  [    7.684359] rockchip-dmc dmc: leakage-volt-sel=1
   944  [    7.684981] rockchip-dmc dmc: avs=0
   945  [    7.684994] rockchip-dmc dmc: current ATF version 0x100
   946  [    7.685164] rockchip-dmc dmc: normal_rate = 1560000000
   947  [    7.685171] rockchip-dmc dmc: reboot_rate = 2112000000
   948  [    7.685178] rockchip-dmc dmc: suspend_rate = 528000000
   949  [    7.685184] rockchip-dmc dmc: video_4k_rate = 1560000000
   950  [    7.685190] rockchip-dmc dmc: video_4k_10b_rate = 1560000000
   951  [    7.685196] rockchip-dmc dmc: video_svep_rate = 1560000000
   952  [    7.685202] rockchip-dmc dmc: boost_rate = 2112000000
   953  [    7.685208] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000
   954  [    7.685213] rockchip-dmc dmc: performance_rate = 2112000000
   955  [    7.685220] rockchip-dmc dmc: hdmirx_rate = 2112000000
   956  [    7.685230] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
   957  [    7.685238] rockchip-dmc dmc: failed to get vop pn to msch rl
   958  [    7.685443] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
   959  [    7.686271] rockchip-dmc dmc: could not find power_model node
   960  [    7.686441] mali fb000000.gpu: Probed as mali0
   961  [    7.688545] input: adc-keys as /devices/platform/adc-keys/input/input5
   962  [    7.690342] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply from device tree
   963  [    7.690369] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdmmc-supply property in node /power-management@fd8d8000/power-controller failed
   964  [    7.690402] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply from device tree
   965  [    7.690422] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up sdio-supply property in node /power-management@fd8d8000/power-controller failed
   966  [    7.690448] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply from device tree
   967  [    7.690468] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up pcie-supply property in node /power-management@fd8d8000/power-controller failed
   968  [    7.690505] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply from device tree
   969  [    7.690524] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu-supply property in node /power-management@fd8d8000/power-controller failed
   970  [    7.690942] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
   971  [    7.690970] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
   972  [    7.690982] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
   973  [    7.691025] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 89,32 bit host data width,256 deep fifo
   974  [    7.691135] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree
   975  [    7.691376] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree
   976  [    7.692753] RKNPU fdab0000.npu: Adding to iommu group 0
   977  [    7.692933] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
   978  [    7.693031] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree
   979  [    7.693885] RKNPU fdab0000.npu: Looking up mem-supply from device tree
   980  [    7.694522] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdab0000-0xfdabffff]
   981  [    7.694539] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdac0000-0xfdacffff]
   982  [    7.694554] RKNPU fdab0000.npu: can't request region for resource [mem 0xfdad0000-0xfdadffff]
   983  [    7.695185] [drm] Initialized rknpu 0.8.2 20220829 for fdab0000.npu on minor 1
   984  [    7.695608] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply from device tree
   985  [    7.695647] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up nputop-supply property in node /power-management@fd8d8000/power-controller failed
   986  [    7.695727] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply from device tree
   987  [    7.695748] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu1-supply property in node /power-management@fd8d8000/power-controller failed
   988  [    7.695825] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply from device tree
   989  [    7.695845] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up npu2-supply property in node /power-management@fd8d8000/power-controller failed
   990  [    7.695962] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree
   991  [    7.695979] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST
   992  [    7.695981] vdd_npu_s0: Failed to create debugfs directory
   993  [    7.696673] RKNPU fdab0000.npu: Looking up mem-supply from device tree
   994  [    7.696731] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST
   995  [    7.696734] vdd_npu_s0: Failed to create debugfs directory
   996  [    7.697472] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree
   997  [    7.697487] vdd_npu_s0: could not add device link fdab0000.npu: -EEXIST
   998  [    7.697489] vdd_npu_s0: Failed to create debugfs directory
   999  [    7.699406] RKNPU fdab0000.npu: leakage=9
  1000  [    7.699431] RKNPU fdab0000.npu: Looking up rknpu-supply from device tree
  1001  [    7.699448] debugfs: Directory 'fdab0000.npu-rknpu' with parent 'vdd_npu_s0' already present!
  1002  [    7.708603] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  1003  [    7.709306] RKNPU fdab0000.npu: pvtm=905
  1004  [    7.715914] RKNPU fdab0000.npu: pvtm-volt-sel=4
  1005  [    7.716926] RKNPU fdab0000.npu: avs=0
  1006  [    7.717143] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
  1007  [    7.727069] RKNPU fdab0000.npu: failed to find power_model node
  1008  [    7.727086] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
  1009  [    7.727094] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
  1010  [    7.728803] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1011  [    7.742757] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1012  [    7.743960] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1013  [    7.743973] cfg80211: failed to load regulatory.db
  1014  [    7.744598] rockchip-pm rockchip-suspend: not set pwm-regulator-config
  1015  [    7.745462] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 409; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '23:42:35', on 'Feb 17 2023'.
  1016  [    7.745752] Mali:
  1017  [    7.745755] Mali device driver loaded
  1018  [    7.745762] ALSA device list:
  1019  [    7.745768]   #0: rockchip-dp0
  1020  [    7.745772]   #1: rockchip-hdmi0
  1021  [    7.745775]   #2: rockchip-es8388
  1022  [    7.748288] vccio_sd_s0: ramp_delay not set
  1023  [    7.751997] Freeing unused kernel memory: 6912K
  1024  [    7.770615] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
  1025  [    7.782944] Run /init as init process
  1026  [    7.782952]   with arguments:
  1027  [    7.782957]     /init
  1028  [    7.782961]   with environment:
  1029  [    7.782965]     HOME=/
  1030  [    7.782969]     TERM=linux
  1031  [    7.782974]     splash=verbose
  1032  [    7.782978]     ubootpart=d3d72b81-812f-0647-b27b-46c4eb10cfe8
  1033  [    7.782983]     cgroup_enable=memory
  1034  [    7.782987]     cgroup_memory=1
  1035  [    7.804961] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 135
  1036  [    7.804987] mmc1: new ultra high speed SDR104 SDXC card at address 5048
  1037  [    7.805863] mmcblk1: mmc1:5048 SD64G 58.0 GiB
  1038  [    7.812611]  mmcblk1: p1 p2
  1039  [    9.549367] rk-pcie fe190000.pcie: PCIe Link Fail
  1040  [    9.549384] rk-pcie fe190000.pcie: failed to initialize host
  1041  [    9.988710] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: (null)
  1042  [   10.541821] NET: Registered protocol family 10
  1043  [   10.544451] Segment Routing with IPv6
  1044  [   10.583600] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  1045  [   10.586488] systemd[1]: Detected architecture arm64.
  1046  [   10.596435] systemd[1]: Hostname set to <orangepi5>.
  1047  [   10.672672] vendor storage:20190527 ret = -1
  1048  [   11.476973] systemd[1]: Queued start job for default target Graphical Interface.
  1049  [   11.480434] systemd[1]: Created slice Slice /system/modprobe.
  1050  [   11.481744] systemd[1]: Created slice Slice /system/serial-getty.
  1051  [   11.483036] systemd[1]: Created slice Slice /system/systemd-fsck.
  1052  [   11.483860] systemd[1]: Created slice User and Session Slice.
  1053  [   11.484184] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1054  [   11.484957] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  1055  [   11.485349] systemd[1]: Reached target Slice Units.
  1056  [   11.485484] systemd[1]: Reached target Swaps.
  1057  [   11.485575] systemd[1]: Reached target System Time Set.
  1058  [   11.485792] systemd[1]: Reached target Local Verity Protected Volumes.
  1059  [   11.496024] systemd[1]: Listening on RPCbind Server Activation Socket.
  1060  [   11.496494] systemd[1]: Listening on Syslog Socket.
  1061  [   11.496884] systemd[1]: Listening on fsck to fsckd communication Socket.
  1062  [   11.497149] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1063  [   11.497864] systemd[1]: Listening on Journal Audit Socket.
  1064  [   11.498225] systemd[1]: Listening on Journal Socket (/dev/log).
  1065  [   11.498693] systemd[1]: Listening on Journal Socket.
  1066  [   11.500725] systemd[1]: Listening on udev Control Socket.
  1067  [   11.501005] systemd[1]: Listening on udev Kernel Socket.
  1068  [   11.501072] systemd[1]: Reached target Socket Units.
  1069  [   11.502882] systemd[1]: Mounting Huge Pages File System...
  1070  [   11.504620] systemd[1]: Mounting POSIX Message Queue File System...
  1071  [   11.506395] systemd[1]: Mounting Kernel Debug File System...
  1072  [   11.508462] systemd[1]: Mounting Kernel Trace File System...
  1073  [   11.508871] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  1074  [   11.511844] systemd[1]: Starting Restore / save the current clock...
  1075  [   11.514030] systemd[1]: Starting Set the console keyboard layout...
  1076  [   11.516333] systemd[1]: Starting Create List of Static Device Nodes...
  1077  [   11.518995] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  1078  [   11.521464] systemd[1]: Starting Load Kernel Module configfs...
  1079  [   11.523741] systemd[1]: Starting Load Kernel Module drm...
  1080  [   11.526322] systemd[1]: Starting Load Kernel Module efi_pstore...
  1081  [   11.528286] systemd[1]: Starting Load Kernel Module fuse...
  1082  [   11.530038] systemd[1]: Starting Load Kernel Module pstore_blk...
  1083  [   11.532108] systemd[1]: Starting Load Kernel Module pstore_zone...
  1084  [   11.535401] systemd[1]: Starting Load Kernel Module ramoops...
  1085  [   11.537295] systemd[1]: Started Nameserver information manager.
  1086  [   11.538275] systemd[1]: Reached target Preparation for Network.
  1087  [   11.538528] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  1088  [   11.542229] fuse: init (API version 7.32)
  1089  [   11.544641] systemd[1]: Starting Load Kernel Modules...
  1090  [   11.546272] systemd[1]: Starting Remount Root and Kernel File Systems...
  1091  [   11.547825] systemd[1]: Starting Coldplug All udev Devices...
  1092  [   11.550695] systemd[1]: Mounted Huge Pages File System.
  1093  [   11.551006] systemd[1]: Mounted POSIX Message Queue File System.
  1094  [   11.551210] systemd[1]: Mounted Kernel Debug File System.
  1095  [   11.551387] systemd[1]: Mounted Kernel Trace File System.
  1096  [   11.551874] systemd[1]: Finished Restore / save the current clock.
  1097  [   11.552511] systemd[1]: Finished Create List of Static Device Nodes.
  1098  [   11.552906] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  1099  [   11.553210] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  1100  [   11.553602] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  1101  [   11.553903] systemd[1]: Finished Load Kernel Module configfs.
  1102  [   11.554261] systemd[1]: modprobe@drm.service: Deactivated successfully.
  1103  [   11.554567] systemd[1]: Finished Load Kernel Module drm.
  1104  [   11.554926] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1105  [   11.555192] systemd[1]: Finished Load Kernel Module efi_pstore.
  1106  [   11.555552] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  1107  [   11.555890] systemd[1]: Finished Load Kernel Module fuse.
  1108  [   11.556262] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  1109  [   11.556751] systemd[1]: Finished Load Kernel Module pstore_blk.
  1110  [   11.557174] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  1111  [   11.557523] systemd[1]: Finished Load Kernel Module pstore_zone.
  1112  [   11.557944] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  1113  [   11.558281] systemd[1]: Finished Load Kernel Module ramoops.
  1114  [   11.559385] systemd[1]: Finished Load Kernel Modules.
  1115  [   11.561318] systemd[1]: Mounting FUSE Control File System...
  1116  [   11.562930] systemd[1]: Mounting Kernel Configuration File System...
  1117  [   11.564830] systemd[1]: Starting Apply Kernel Variables...
  1118  [   11.566513] systemd[1]: Mounted FUSE Control File System.
  1119  [   11.566771] systemd[1]: Mounted Kernel Configuration File System.
  1120  [   11.570513] EXT4-fs (mmcblk1p2): re-mounted. Opts: commit=600,errors=remount-ro
  1121  [   11.573648] systemd[1]: Finished Remount Root and Kernel File Systems.
  1122  [   11.573969] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1123  [   11.575597] systemd[1]: Starting Load/Save Random Seed...
  1124  [   11.577102] systemd[1]: Starting Create System Users...
  1125  [   11.603154] systemd[1]: Finished Apply Kernel Variables.
  1126  [   11.603960] systemd[1]: Finished Load/Save Random Seed.
  1127  [   11.604281] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  1128  [   11.608946] systemd[1]: Finished Create System Users.
  1129  [   11.611802] systemd[1]: Starting Create Static Device Nodes in /dev...
  1130  [   11.630996] systemd[1]: Finished Set the console keyboard layout.
  1131  [   11.646373] systemd[1]: Finished Create Static Device Nodes in /dev.
  1132  [   11.646998] systemd[1]: Reached target Preparation for Local File Systems.
  1133  [   11.650043] systemd[1]: Mounting /tmp...
  1134  [   11.653174] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  1135  [   11.658239] systemd[1]: Mounted /tmp.
  1136  [   11.733276] systemd[1]: Started Rule-based Manager for Device Events and Files.
  1137  [   11.816135] systemd[1]: Finished Coldplug All udev Devices.
  1138  [   11.818967] systemd[1]: Created slice Slice /system/systemd-backlight.
  1139  [   11.827590] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  1140  [   11.829821] systemd[1]: Starting Show Plymouth Boot Screen...
  1141  [   11.831746] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight...
  1142  [   11.833737] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight_1...
  1143  [   11.859061] systemd[1]: Found device /dev/ttyFIQ0.
  1144  [   11.877658] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  1145  [   11.878489] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight.
  1146  [   11.879274] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:backlight_1.
  1147  [   11.881054] systemd[1]: Reached target Hardware activated USB gadget.
  1148  [   11.906408] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
  1149  [   11.953393] systemd[1]: Started Show Plymouth Boot Screen.
  1150  [   11.953775] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1151  [   11.954038] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
  1152  [   11.954111] systemd[1]: Reached target Local Encrypted Volumes.
  1153  [   11.956202] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  1154  [   11.958056] systemd[1]: Starting Load Kernel Module efi_pstore...
  1155  [   11.960019] systemd[1]: Starting Load Kernel Module pstore_blk...
  1156  [   11.962007] systemd[1]: Starting Load Kernel Module pstore_zone...
  1157  [   11.963964] systemd[1]: Starting Load Kernel Module ramoops...
  1158  [   11.964152] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  1159  [   11.964852] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  1160  [   11.965196] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  1161  [   11.965668] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1162  [   11.965989] systemd[1]: Finished Load Kernel Module efi_pstore.
  1163  [   11.966347] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  1164  [   11.966618] systemd[1]: Finished Load Kernel Module pstore_blk.
  1165  [   11.966942] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  1166  [   11.967217] systemd[1]: Finished Load Kernel Module pstore_zone.
  1167  [   11.971937] systemd[1]: Found device /dev/disk/by-uuid/66CE-2ED0.
  1168  [   11.972340] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  1169  [   11.972642] systemd[1]: Finished Load Kernel Module ramoops.
  1170  [   11.974291] systemd[1]: Starting File System Check on /dev/disk/by-uuid/66CE-2ED0...
  1171  [   11.974395] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1172  [   11.984855] systemd[1]: Started File System Check Daemon to report status.
  1173  [   12.080898] systemd[1]: Finished File System Check on /dev/disk/by-uuid/66CE-2ED0.
  1174  [   12.083872] systemd[1]: Mounting /boot...
  1175  [   12.088942] FAT-fs (mmcblk1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
  1176  [   12.109091] systemd[1]: Mounted /boot.
  1177  [   12.109538] systemd[1]: Reached target Local File Systems.
  1178  [   12.109737] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
  1179  [   12.112419] systemd[1]: Starting Armbian leds state...
  1180  [   12.115478] systemd[1]: Starting Armbian ZRAM config...
  1181  [   12.118327] systemd[1]: Starting Set console font and keymap...
  1182  [   12.121188] systemd[1]: Starting Raise network interfaces...
  1183  [   12.123752] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
  1184  [   12.123933] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  1185  [   12.124039] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  1186  [   12.131601] systemd[1]: Starting Set Up Additional Binary Formats...
  1187  [   12.131781] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  1188  [   12.131873] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  1189  [   12.134162] systemd[1]: Finished Armbian leds state.
  1190  [   12.135166] systemd[1]: Finished Set console font and keymap.
  1191  [   12.136774] systemd[1]: Received SIGRTMIN+20 from PID 296 (plymouthd).
  1192  [   12.139046] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 518 (systemd-binfmt)
  1193  [   12.140942] systemd[1]: Mounting Arbitrary Executable File Formats File System...
  1194  [   12.147432] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
  1195  [   12.159245] systemd[1]: Mounted Arbitrary Executable File Formats File System.
  1196  [   12.164488] systemd[1]: Finished Set Up Additional Binary Formats.
  1197  [   12.328181] zram0: detected capacity change from 0 to 1958543360
  1198  [   12.386011] Adding 1912636k swap on /dev/zram0.  Priority:5 extents:1 across:1912636k SS
  1199  [   12.401927] zram: Added device: zram1
  1200  [   12.467329] systemd[1]: Finished Raise network interfaces.
  1201  [   12.510277] zram1: detected capacity change from 0 to 52428800
  1202  [   12.561086] systemd[1]: Finished Armbian ZRAM config.
  1203  [   12.569729] systemd[1]: Starting Armbian memory supported logging...
  1204  [   12.630239] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  1205  [   12.905158] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1206  [   12.905454] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
  1207  [   12.911634] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  1208  [   12.916958] systemd[1]: Starting Load Kernel Module efi_pstore...
  1209  [   12.922371] systemd[1]: Starting Load Kernel Module pstore_blk...
  1210  [   12.927238] systemd[1]: Starting Load Kernel Module pstore_zone...
  1211  [   12.931677] systemd[1]: Starting Load Kernel Module ramoops...
  1212  [   12.932060] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  1213  [   12.932290] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  1214  [   12.934413] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  1215  [   12.935245] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  1216  [   12.936317] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1217  [   12.937078] systemd[1]: Finished Load Kernel Module efi_pstore.
  1218  [   12.937988] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  1219  [   12.938704] systemd[1]: Finished Load Kernel Module pstore_blk.
  1220  [   12.939588] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  1221  [   12.940300] systemd[1]: Finished Load Kernel Module pstore_zone.
  1222  [   12.941227] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  1223  [   12.941909] systemd[1]: Finished Load Kernel Module ramoops.
  1224  [   12.942337] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1225  [   13.896705] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1226  [   13.896857] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
  1227  [   13.900705] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  1228  [   13.904072] systemd[1]: Starting Load Kernel Module efi_pstore...
  1229  [   13.907315] systemd[1]: Starting Load Kernel Module pstore_blk...
  1230  [   13.911131] systemd[1]: Starting Load Kernel Module pstore_zone...
  1231  [   13.914973] systemd[1]: Starting Load Kernel Module ramoops...
  1232  [   13.915320] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  1233  [   13.915530] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  1234  [   13.917411] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  1235  [   13.918411] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  1236  [   13.919761] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1237  [   13.920694] systemd[1]: Finished Load Kernel Module efi_pstore.
  1238  [   13.921851] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  1239  [   13.922862] systemd[1]: Finished Load Kernel Module pstore_blk.
  1240  [   13.924233] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  1241  [   13.925175] systemd[1]: Finished Load Kernel Module pstore_zone.
  1242  [   13.926307] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  1243  [   13.927228] systemd[1]: Finished Load Kernel Module ramoops.
  1244  [   13.927733] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1245  [   14.579422] systemd[1]: Finished Armbian memory supported logging.
  1246  [   14.587382] systemd[1]: Starting Journal Service...
  1247  [   14.730145] systemd[1]: Started Journal Service.
  1248  [   14.762810] systemd-journald[719]: Received client request to flush runtime journal.
  1249
  1250  ### armbian-release:
  1251
  1252  # PLEASE DO NOT EDIT THIS FILE
  1253  BOARD=orangepi5
  1254  BOARD_NAME="Orange Pi 5"
  1255  BOARDFAMILY=rockchip-rk3588
  1256  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1257  BUILD_REPOSITORY_COMMIT=1a8daf0
  1258  VERSION=23.02.2
  1259  LINUXFAMILY=rockchip-rk3588
  1260  ARCH=arm64
  1261  IMAGE_TYPE=stable
  1262  BOARD_TYPE=conf
  1263  INITRD_ARCH=arm64
  1264  KERNEL_IMAGE_TYPE=stable
  1265  BRANCH=legacy
  1266
  1267  ### boot environment:
  1268
  1269  verbosity=1
  1270  bootlogo=false
  1271  overlay_prefix=rockchip-rk3588
  1272  fdtfile=rockchip/rk3588s-orangepi-5.dtb
  1273  rootdev=UUID=db80a2ac-ec37-4fda-91db-92604becfcce
  1274  rootfstype=ext4
  1275  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1276
  1277
  1278  ### lsusb:
  1279
  1280  Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1281  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1282  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1283  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1284  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1285  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1286
  1287  ### lscpu:
  1288
  1289  Architecture:                    aarch64
  1290  CPU op-mode(s):                  32-bit, 64-bit
  1291  Byte Order:                      Little Endian
  1292  CPU(s):                          8
  1293  On-line CPU(s) list:             0-7
  1294  Vendor ID:                       ARM
  1295  Model name:                      Cortex-A55
  1296  Model:                           0
  1297  Thread(s) per core:              1
  1298  Core(s) per socket:              4
  1299  Socket(s):                       1
  1300  Stepping:                        r2p0
  1301  CPU max MHz:                     1800.0000
  1302  CPU min MHz:                     408.0000
  1303  BogoMIPS:                        48.00
  1304  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1305  Model name:                      Cortex-A76
  1306  Model:                           0
  1307  Thread(s) per core:              1
  1308  Core(s) per socket:              2
  1309  Socket(s):                       2
  1310  Stepping:                        r4p0
  1311  CPU max MHz:                     2400.0000
  1312  CPU min MHz:                     408.0000
  1313  BogoMIPS:                        48.00
  1314  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1315  L1d cache:                       384 KiB (8 instances)
  1316  L1i cache:                       384 KiB (8 instances)
  1317  L2 cache:                        2.5 MiB (8 instances)
  1318  L3 cache:                        3 MiB (1 instance)
  1319  Vulnerability Itlb multihit:     Not affected
  1320  Vulnerability L1tf:              Not affected
  1321  Vulnerability Mds:               Not affected
  1322  Vulnerability Meltdown:          Not affected
  1323  Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
  1324  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  1325  Vulnerability Spectre v2:        Vulnerable: Unprivileged eBPF enabled
  1326  Vulnerability Srbds:             Not affected
  1327  Vulnerability Tsx async abort:   Not affected
  1328
  1329  ### cpuinfo:
  1330
  1331  processor       : 0
  1332  BogoMIPS        : 48.00
  1333  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1334  CPU implementer : 0x41
  1335  CPU architecture: 8
  1336  CPU variant     : 0x2
  1337  CPU part        : 0xd05
  1338  CPU revision    : 0
  1339
  1340  processor       : 1
  1341  BogoMIPS        : 48.00
  1342  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1343  CPU implementer : 0x41
  1344  CPU architecture: 8
  1345  CPU variant     : 0x2
  1346  CPU part        : 0xd05
  1347  CPU revision    : 0
  1348
  1349  processor       : 2
  1350  BogoMIPS        : 48.00
  1351  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1352  CPU implementer : 0x41
  1353  CPU architecture: 8
  1354  CPU variant     : 0x2
  1355  CPU part        : 0xd05
  1356  CPU revision    : 0
  1357
  1358  processor       : 3
  1359  BogoMIPS        : 48.00
  1360  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1361  CPU implementer : 0x41
  1362  CPU architecture: 8
  1363  CPU variant     : 0x2
  1364  CPU part        : 0xd05
  1365  CPU revision    : 0
  1366
  1367  processor       : 4
  1368  BogoMIPS        : 48.00
  1369  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1370  CPU implementer : 0x41
  1371  CPU architecture: 8
  1372  CPU variant     : 0x4
  1373  CPU part        : 0xd0b
  1374  CPU revision    : 0
  1375
  1376  processor       : 5
  1377  BogoMIPS        : 48.00
  1378  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1379  CPU implementer : 0x41
  1380  CPU architecture: 8
  1381  CPU variant     : 0x4
  1382  CPU part        : 0xd0b
  1383  CPU revision    : 0
  1384
  1385  processor       : 6
  1386  BogoMIPS        : 48.00
  1387  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1388  CPU implementer : 0x41
  1389  CPU architecture: 8
  1390  CPU variant     : 0x4
  1391  CPU part        : 0xd0b
  1392  CPU revision    : 0
  1393
  1394  processor       : 7
  1395  BogoMIPS        : 48.00
  1396  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
  1397  CPU implementer : 0x41
  1398  CPU architecture: 8
  1399  CPU variant     : 0x4
  1400  CPU part        : 0xd0b
  1401  CPU revision    : 0
  1402
  1403  Serial          : 2b99ff24bfe6e67d
  1404
  1405  ### meminfo:
  1406
  1407  MemTotal:        3825276 kB
  1408  MemFree:         3584344 kB
  1409  MemAvailable:    3653248 kB
  1410  Buffers:           12548 kB
  1411  Cached:            67772 kB
  1412  SwapCached:            0 kB
  1413  Active:            21396 kB
  1414  Inactive:          79352 kB
  1415  Active(anon):        604 kB
  1416  Inactive(anon):    30012 kB
  1417  Active(file):      20792 kB
  1418  Inactive(file):    49340 kB
  1419  Unevictable:        2840 kB
  1420  Mlocked:               0 kB
  1421  SwapTotal:       1912636 kB
  1422  SwapFree:        1912636 kB
  1423  Dirty:             18964 kB
  1424  Writeback:             0 kB
  1425  AnonPages:         24452 kB
  1426  Mapped:            17320 kB
  1427  Shmem:              6172 kB
  1428  KReclaimable:      37372 kB
  1429  Slab:              79200 kB
  1430  SReclaimable:      37372 kB
  1431  SUnreclaim:        41828 kB
  1432  KernelStack:        3744 kB
  1433  PageTables:         2776 kB
  1434  NFS_Unstable:          0 kB
  1435  Bounce:                0 kB
  1436  WritebackTmp:          0 kB
  1437  CommitLimit:     3825272 kB
  1438  Committed_AS:      76216 kB
  1439  VmallocTotal:   262930368 kB
  1440  VmallocUsed:       26556 kB
  1441  VmallocChunk:          0 kB
  1442  Percpu:             2976 kB
  1443  CmaTotal:           8192 kB
  1444  CmaAllocated:       3088 kB
  1445  CmaReleased:        5104 kB
  1446  CmaFree:             344 kB
  1447  HugePages_Total:       0
  1448  HugePages_Free:        0
  1449  HugePages_Rsvd:        0
  1450  HugePages_Surp:        0
  1451  Hugepagesize:       2048 kB
  1452  Hugetlb:               0 kB
  1453
  1454  ### virtual memory:
  1455
  1456  vm.admin_reserve_kbytes = 8192
  1457  vm.block_dump = 0
  1458  vm.dirty_background_bytes = 0
  1459  vm.dirty_background_ratio = 10
  1460  vm.dirty_bytes = 0
  1461  vm.dirty_expire_centisecs = 3000
  1462  vm.dirty_ratio = 20
  1463  vm.dirtytime_expire_seconds = 43200
  1464  vm.dirty_writeback_centisecs = 500
  1465  vm.extra_free_kbytes = 0
  1466  vm.hugetlb_shm_group = 0
  1467  vm.laptop_mode = 0
  1468  vm.legacy_va_layout = 0
  1469  vm.lowmem_reserve_ratio = 256   256     32      0
  1470  vm.max_map_count = 65530
  1471  vm.min_free_kbytes = 7800
  1472  vm.mmap_min_addr = 32768
  1473  vm.mmap_rnd_bits = 18
  1474  vm.mmap_rnd_compat_bits = 11
  1475  vm.nr_hugepages = 0
  1476  vm.nr_overcommit_hugepages = 0
  1477  vm.oom_dump_tasks = 1
  1478  vm.oom_kill_allocating_task = 0
  1479  vm.overcommit_kbytes = 0
  1480  vm.overcommit_memory = 0
  1481  vm.overcommit_ratio = 50
  1482  vm.page-cluster = 0
  1483  vm.page_lock_unfairness = 5
  1484  vm.panic_on_oom = 0
  1485  vm.percpu_pagelist_fraction = 0
  1486  vm.stat_interval = 1
  1487  vm.swappiness = 100
  1488  vm.user_reserve_kbytes = 118343
  1489  vm.vfs_cache_pressure = 100
  1490  vm.watermark_boost_factor = 15000
  1491  vm.watermark_scale_factor = 10
  1492
  1493  ### ip addr:
  1494
  1495  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1496      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1497      inet XXX.XXX.0.1/8 scope host lo
  1498         valid_lft forever preferred_lft forever
  1499      inet6 ::1/128 scope host
  1500         valid_lft forever preferred_lft forever
  1501  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1502      link/ether 66:f1:42:b0:93:75 brd ff:ff:ff:ff:ff:ff
  1503
  1504  ### partitions:
  1505
  1506  major minor  #blocks  name
  1507
  1508   254        0    1912640 zram0
  1509    31        0      16384 mtdblock0
  1510   179        0   60768256 mmcblk1
  1511   179        1     262144 mmcblk1p1
  1512   179        2   59867136 mmcblk1p2
  1513   254        1      51200 zram1
  1514
  1515  ### df:
  1516
  1517  tmpfs           374M  6.1M  368M   2% /run
  1518  /dev/mmcblk1p2   57G  6.1G   51G  11% /
  1519  tmpfs           1.9G     0  1.9G   0% /dev/shm
  1520  tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  1521  tmpfs           1.9G     0  1.9G   0% /tmp
  1522  /dev/mmcblk1p1  256M  154M  103M  61% /boot
  1523  /dev/zram1       47M   19M   25M  44% /var/log
  1524
  1525  ### lsblk:
  1526
  1527  NAME        FSTYPE  SIZE MOUNTPOINT UUID
  1528  mtdblock0            16M
  1529  mmcblk1              58G
  • Solution
1 hour ago, Daniel Turcich said:
Any idea why this may be happening?
Expensive research is usually needed to fully understand why this is happening. But as most developers knows that Rockchip legacy kernel is a consumer demo-grade trash, its unlikely this will happen. Repairing deep problems just for this kernel is usually futile. It is not Armbian problem, but Rockchip's which provides this fork and currently the only stable(ish) kernel you can run on those devices. It is worth trying to build image from latest sources. They have been greatly improved, but can't tell if your problem will be gone. I assume you are using stock power supply? Not sufficient power can help in crashing ...
If you need to run some serious things on your device, move to test 6.5.y kernel (CI builds at the bottom of the page). This is the only sane way, but they come without video output. We are running several build runners on few Rock 5 devices and so far it does the job. Here are logs: https://paste.armbian.com/gupidarusa
BTW, Welcome!
I haven't had problems until now, I am using a rather dinky powersupply atm. It looks like they reccomend a 5v 4a but I assume that's not enough, they use USB-C as delivery. Any suggestions on what voltage and amperage I should look for?
I will look into compiling from source using `6.5.#` kernel, I don't use a video out, only need it to act as a DNS and run some backends/ APIs I write.
tl;dr: 5.3 to 5.4 volts and 4 amps. Ideally something industrial-grade.
Ideally you'd get something that outputs slightly above 5 volts in order to compensate for voltage drop.
For example the wall adapter sold by Xulong with their boards actually outputs 5.3 volts (even though the there is 5 volts written on it). Under full load the voltage drops down to around 5 volts across the board (measured at the USB-A connector).
Now imagine powering the board with "only" 5 volts and put a heavy load to it. Will drop well below 5v and this causes malfunction. Also RK SoCs seem to enjoy slight overvoltage :D
Personally I like Mean Well, they are decent brand who tend to deliver the advertised voltage (which is a whole another problem with no-name supplies, not just in SBC world but also PC and others) and last a good long while.  And pretty affordable, usually.
Lately I have even been switching to DIN rail mounted power supplies for my SBCs (and other devices, even monitors, as I had too many power bricks piling up around my desktop/workbench area).
