argulp argulp Posted October 10, 2023 Posted October 10, 2023 Hello I have two Rockpi A (without wireless) since I have upgraded to latest kernel: 6.1.50-current-rockchip64 One of the two USB3 port is not working, the top one (from usb-devices and lsusb I don't see any special difference) it seems USB2 port are ok same issue on two rockpi cards, I have try many usb devices (storage, network etc...) without success I am alone with this issue ? armbianmonitor send to http://ix.io/4IE9 Rgds
kolsi Posted October 16, 2023 Posted October 16, 2023 (edited) Same problem here - Rock 4B+. The upper USB3 port is not working. It does not respect OTG-host switch at all. Using device overlay to switch to port to host/peripheral mode does not work either. Edited October 16, 2023 by kolsi
Nitrax Posted October 22, 2023 Posted October 22, 2023 Tested out a few kernels and 5.15.93 seems to be one of the later that's still working. No USB 3 ports work with my USB stick whith recent kernels (it's not just the OTG port that is broken).
Pietro Mezzaroba Posted October 23, 2023 Posted October 23, 2023 Hi, sorry, it's absurd that this thread isn't being taken into consideration, we're talking about thousands of rock devices no longer having USB 3.0 working....give us importance thanks @admin@Werner@Igor root@DietPi:~# uname -a Linux DietPi 6.1.53-current-rockchip64 #1 SMP PREEMPT Wed Sep 13 07:43:05 UTC 2023 aarch64 GNU/Linux Pietro
SteeMan Posted October 23, 2023 Posted October 23, 2023 37 minutes ago, Pietro Mezzaroba said: root@DietPi:~# uname -a Linux DietPi 6.1.53-current-rockchip64 #1 SMP PREEMPT Wed Sep 13 07:43:05 UTC 2023 aarch64 GNU/Linux You aren't even using Armbian. Why are you complaining in an Armbian forum? Go get support for your dietpi from dietpi. Also remember that Armbian is based on the work of volunteers donating their time (you certainly haven't paid anything to support or further Armbian). So it doesn't make any difference if there are 10 users of a board or many more, generally there is no revenue coming to Armbian to support any boards (as generally the board manufacturers don't want to contribute anything in order to actually provide support, and hope that the Armbian volunteers will provide long term support for their boards for free). Unless you are paying for support you have no right to expect something for free from Armbian. But again since you aren't even using Armbian, you are even farther removed from the right to expect support from Armbian.
Pietro Mezzaroba Posted October 23, 2023 Posted October 23, 2023 ok sorry, we didn't understand each other, dietpi is based on armbian, I thought it was clear, I installed armbian on my board so maybe I will be taken into consideration, obviously by not paying I don't expect anything but I just want it to be taken into consideration I also remember that it hasn't worked for almost two months dietpi@192.168.1.35's password: ____ _ ____ __ _ _ | _ \ ___ ___| | _| _ \ _ __ ___ / /_ | || | | |_) / _ \ / __| |/ / |_) | '__/ _ \ | '_ \| || |_ | _ < (_) | (__| <| __/| | | (_) | | (_) |__ _| |_| \_\___/ \___|_|\_\_| |_| \___/ \___/ |_| Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64 System load: 2% Up time: 3 min Memory usage: 4% of 3.77G IP: 192.168.1.35 CPU temp: 40°C Usage of /: 6% of 29G Last login: Mon Oct 23 13:28:30 2023 from 192.168.1.12 dietpi@rockpro64:~$ dmesg -l 0,1,2,3 [ 2.461314] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 2.554637] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with 0-001b [ 2.706293] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with vcc3v3-sys [ 2.931269] phy phy-ff7c0000.phy.6: phy poweron failed --> -110 [ 2.931404] dwc3 fe800000.usb: error -ETIMEDOUT: failed to initialize core [ 2.967139] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with 0-001b [ 4.127677] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [ 6.092866] (sd-execut[344]: /usr/lib/systemd/system-generators/netplan failed with exit status 1. [ 11.237351] Bluetooth: hci0: command 0x0c03 tx timeout [ 19.429381] Bluetooth: hci0: BCM: Reset failed (-110) dietpi@rockpro64:~$ uname -a Linux rockpro64 6.1.50-current-rockchip64 #3 SMP PREEMPT Wed Aug 30 14:11:13 UTC 2023 aarch64 GNU/Linux dietpi@rockpro64:~$ the problem at hand is this : dwc3 fe800000.usb: error -ETIMEDOUT: failed to initialize core here you can find more information about the tests https://dietpi.com/forum/t/rk3399-hdmi-output-and-usb-3-0-not-working-with-linux-6-1/17776/43 Thx for your time
SteeMan Posted October 23, 2023 Posted October 23, 2023 Just because someone (dietpi) forks Armbian, doesn't give credit to armbian, and doesn't contribute back to Armbian, doesn't mean that Armbian can then support their end users. We have no idea what dietpi has done to their code after forking off of armbian, so we again can't help you. Complain to those that can/should be providing you support. We can't. Of course you always have the option to install a genuine Armbian build. That doesn't mean that this will get magically fixed, but at least we will not completely ignore your request. 1
SteeMan Posted October 23, 2023 Posted October 23, 2023 29 minutes ago, Pietro Mezzaroba said: dietpi@192.168.1.35's password: ____ _ ____ __ _ _ | _ \ ___ ___| | _| _ \ _ __ ___ / /_ | || | | |_) / _ \ / __| |/ / |_) | '__/ _ \ | '_ \| || |_ | _ < (_) | (__| <| __/| | | (_) | | (_) |__ _| |_| \_\___/ \___|_|\_\_| |_| \___/ \___/ |_| Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64 System load: 2% Up time: 3 min Memory usage: 4% of 3.77G IP: 192.168.1.35 CPU temp: 40°C Usage of /: 6% of 29G Last login: Mon Oct 23 13:28:30 2023 from 192.168.1.12 dietpi@rockpro64:~$ dmesg -l 0,1,2,3 I agree that this branding is confusing for end users. 1
argulp argulp Posted November 3, 2023 Author Posted November 3, 2023 Hello, so we agree... latest kernel is affecting USB port Someone from Armbian works on the issue, or maybe I need to contact Radxa or Linus Torvals ? I don't complain, and your work is fabulous but I need to fix this issue soon Thank you
Luca Di Natale Posted November 20, 2023 Posted November 20, 2023 Hello, same problem for me. I have 3 RockPI 4B+ and 1 RockPI 4A and after a kernel update to the latest version the upper USB3 port is not working anymore. I tryed ather other distributions (DietPI, ArchlinuxARM) on one of my board and the problem is replicated. It appears to be a kernel problem!!!!!
Igor Posted November 20, 2023 Posted November 20, 2023 On 11/3/2023 at 2:51 PM, argulp argulp said: but I need to fix this issue soon "The worst-case scenario is that you give the maintainers an opportunity to reconsider if continuing to work on the open source project is worth it." https://minimaxir.com/2023/11/open-source-dead-github/
Igor Posted November 21, 2023 Posted November 21, 2023 Welcome to Armbian community support. 17 hours ago, Luca Di Natale said: It appears to be a kernel problem! Probably you are right. You don't expect from a few Armbian maintainers to fix problems for all other (competitive wanna be) distributions? At least Dietpi is directly competing with Armbian OS and without a shame making up they are better Debian and Armbian ... Average Joe can't see their sales BS which is contributing nothing to stability or overall experience - which is the value people seeks. Their usual support response on real problems: "Oh, this is kernel problem. Armbian/* developers must(!) fix that". Really? We can't fix this for our users, but we must for theirs. Sick. All replies after initial post are pretty much useless pressure making. Its against forum rules and you don't talk to open source developers this way. They are totally overloaded without this and can only turn you down? See? You feel nice about copy cats that lies "we are not responsible, they are", bad about us. This is how open source piracy works. Fixing problems is expensive. Very expensive. They, including people that sold you hardware, are equally responsible or not responsible. This year we invested lets say 10.000 hours into R&D, bug fixing, they invested 10m for fixing banal common problem. Armbian core interest is maintaining build framework https://github.com/armbian/build Download it, try it and try to use it to fix the problem you have with this hardware. When you do, make a contribution to code we ship, or directly to kernel.org You don't know how to code, but you would like our help? Check https://forum.armbian.com/staffapplications/ and start contributing daily to open source project. One full time general purpose person can have significant impact on resolving problems. In span of 5 years, months can be saved, perhaps a year. Just for sorting out labeling colors, which are still not in best order, https://github.com/armbian/build/pull/5916 I spent more then a day. I am sure this is a task anyone could do. There are tons of non hardcore development related tasks that developers are dealing with in order that this project operates and that we have fun. No fun? If there is not fun ... there is source. Dig in and fix a problem. In open source, this is your problem anyway. Currently we are struggle with those issues: https://www.armbian.com/participate/ This one was not even recorded yet as we don't have people and hiring is still not possible. Closing this topic down. Armbian provides best effort support. Nothing more to add here. If / when solution is found, its continued here https://github.com/armbian/build/pulls
