November 9, 20233 yr My Orange Pi 5 appears to be completely dead. No lights turn on when the power is connected and the SD card is freshly imaged as well. This started happening when I connected a USB-C multi-port dongle with a connected PD power supply to it. Is it possible to revive this?
November 9, 20233 yr 9 hours ago, Ravi Terala said: USB-C multi-port dongle with a connected PD power supply It doesn't have pd, only 5V. I hope your powered hub didn't send anything higher. Try a 5V PSU instead.
November 9, 20233 yr Author I wasn't using PD, was using the plain old 5V 4A power supply I was using earlier. The board was already powered up with the 5V-4A power supply when I connected the USB-C multi-port dongle. Is there a way to diagnose what went wrong? Is the board totally dead?
November 11, 20233 yr @Ravi Terala Read the manual, there you can see how to use the UART, mind the baudrate capability of the adapter.
November 11, 20233 yr On 11/9/2023 at 6:04 PM, Ravi Terala said: Is there a way to diagnose what went wrong?
November 12, 20233 yr Make sure you have the adapter set to 3.3V and you only need 3 pins. The ground goes to the ground, but then you need transmit (Tx) to receive (Rx) and receive (Rx) to transmit (Tx). I use minicom in a Linux terminal with baud rate set to 1500000 and the adapter will be located on /dev/ttyUSB0. To adjust those settings in minicom, "sudo minicom -s" and save as dfl. You can also give your user permission to use minicom without sudo. "sudo usermod -a -G $USER dialout" then log out and log back in.
November 27, 20232 yr Author @Jaybyrd, @Werner I tried the maskrom process and nothing is detected. I tested all the pins using a multimeter and no voltage is detected on any of the pins. Is this board now completely dead? Any way to revive this?
November 27, 20232 yr Author I guess the board might have been fried. No power shows up on any where.
