Skip to content
View in the app
Armbian Community Forums
Odroid M1S Image Planned ?
Featured Replies
6 hours ago, Werner said:
Did you check already merged PRs which were adding new boards? Like https://github.com/armbian/build/pull/8754/files
Should give some clues.
Thank you for your reply!
No, I did not check THIS SPECIFIC PR. But of course the other ones, for example those @Igor already pointed to.
And because of the fact, that I already checked several PR and still being not sure how to do it correctly, I hoped for a more general explanation than just another link to another PR...
I wished for some explanations about good practice and how/why things are done the way they are done.
"Path xyz is the place for your .csc files. Path abc for your .dts files because of blablabla..." That would just have been nice to get a better overview.
Beside all the respect and appreciation that I have for you and your colleagues at Armbian, please understand that it is sometimes somewhat exhausting when guys like me try their very best to contribute and then often get calmed by link-drops...
Anyway, I'll check out your referred PR and see if that helps.
Edited by Jojo
We're aware that our documentation isn't great (also about adding new hw: https://docs.armbian.com/Process_Contribute/#adding-a-new-board) but it is hard to find time for such tasks when we're crowded with other stuff already.
Quote
To me it seems that this requires not "normal" .config files, but ".csc" files.
The file extension defines a boards support status. https://docs.armbian.com/User-Guide_Board-Support-Rules/
Anyone can add .csc boards.
For dts files we have dedicated folders to avoid having a patch necessary for them:
https://github.com/armbian/build/tree/main/patch/kernel/archive/rockchip64-6.12/dt
https://github.com/armbian/build/tree/main/patch/kernel/archive/rockchip64-6.18/dt
Understood, all good.
That is a good example for something that is not that clear.
I tried to find a ready-to-use dts file for the M1S in the mainline repo, but it is not one single dts file, but a composition of several files where one file refers to the next one and so on (here). I was confused and so I asked ChatGPT how to merge the mainline dts into Armbian. This was how my patches were created.
After compilation there was indeed one single all-in-one dts file for my board but not before...
EDIT: I just tried another build with just taking the top-level dts file from the mainline repo and placing it in the location you mentioned. Worked like a charm, despite my confusion... 😅
From my point of view it seemed better to have the patches in place to be sure to always pull the most recent DT from the mainline kernel (that of course would require a defined place to put those patches).
But what you say sounds as if it would be preferable to have dts files instead of patches. Is that correct and why?
Edited by Jojo
Yes. In the past everything was added as patch. The problem was (and still is for other reasons) that some patches modifying a dt build on top of each other or stuff breaks. Now the dt can be edited directly and using git blame it is documented who edited what for whatever reason.
Of course sometimes there is an almost perfect dt upstream that needs minor adjustments. Those can be perfectly fine done with a patch.
Also both patches and our dt files only stay for as long as there is no proper equivalent upstream. Once everything is in mainline they are no longer needed.
Okay, thanks for the explanation!
So, I got Armbian compiled and running by just adding the .dts file and the .csc file. The .csc file is a copy of the ODROID M1 .config file, but with some modifications: I threw out the SPI-related stuff, because the M1S does not have a SPI flash to boot from and it gave me arrors during compilation.
I tested basic functionality with a Ubuntu Noble Cinnamon desktop image as well as a headless server image.
Is this enough to create a pull request? How is the Download page created? Is that made by the Armbian team or do I need to add it there as well (how?) ?
Greetings
Tested another Armbian, this time Noble with Gnome desktop.
Although I personally do not like that UI, It performs relatively good. As @Werner predicted, glmark2-es2-wayland finished with a score of 277.
WebGL Aquarium demo works significantly better. While 500 fishes still result in very low FPS, 100 fishes is mostly fluent.
What I observed on all systems I have tested on the M1S, armbian-config takes extremely long to load/open. Sometimes around 5 minutes or so. It would be interesting to know, if this is expected to be normal...
Now that I have tested four different images (Bookworm server, Noble Server, Noble Cinnamon and Noble Gnome), all with "current" kernel (6.12), I feel okay to do the PR.
As said, I did not do that much but only adding the .csc file and the .dts file. This gave me the feeling on the other hand, that your build framework is working really great and makes it "relatively easy" to contribute and test own things, as seen as one knows how the things play together. So apart from all my "complains", your build framework is great!👍
If there are still other M1S users around: Hi!
Hi! I am around...
Thank you for all the work you have been doing on the M1S.
Unfortunately I haven't had the opportunity to test recently, but I expect to.
As for the low performance, I really had the feeling that the M1S is slow on graphics, but decent (for its class) on regular CPU work. I had tested with linuxfactory's bookwork image and that was the feeling I got from then.
I don't think the long wait time for armbian-config to open is normal. My first bet would be something related to network access, either there is not a working internet access or some configuration is wrong.  My second bet, some sort of reading error on the microSD card. The M1S isn't that sloooow. :P
I would suggest you check dmesg for a clue after running armbian-config.
Best regards,
Sérgio
Hey, I am really happy there is someone else with M1S - just got it today in the mail and after first boot received notification that ubuntu 20.04 server is no longer supported (shocker!).
It would be nice to be able to run later kernel (you've mentioned 6.12) on the machine.
I was not able to follow your steps to get it working, unfortunately.
I don't care for desktop performance at all.
Would it be possible to get the image of ubuntu noble server? Or is there some place with idiot-proof step-by-step guide for noobs?
Thanks in advance!
Thanks in advance!
Currently Noble Server is not planned.
I have the impression, that generally speaking Debian is the way to go for server stuff while Ubuntu is more targeting Desktop systems (at least Armbian). Of course there might be cases where both are provided.
All my small servers here at home run Debian-based systems. Never had any issues or disadvantages compared to Ubuntu...
If you read through this thread, you'll see what is needed to build it on your own:
- clone the Armbian repo
- get the correct dts file and place it in the correct folder
- get the correct csc file and place it in the correct folder
- run the compile script and choose M1S from the list
The files and where to place them can be found in the corresponding PR on github.
If you don't get it running on your own just wait/hope a little bit for the board to be officially (community-)supported by Armbian.
Or I share the pre-compiled image with you (on your own risk).
Greetings
Edited by Jojo
Debian would be even better, it just was not in your list. I'll then go and try to replicate your how-to, let's see if I can succeed :)
@Jojo Would you be so kind and lend me a hand here?
What I did:
  • clone the repo locally
  • manually changed the files in your PR (csc, dts and modified the .config)
  • run ./compile.sh
The problem is - it does not offer the M1S board in the list of targets.
I must be missing a step or two. Would you mind checking my steps and advise, please?
Never mind - all I needed to do is to click the middle option in the compile menu (Show CSC/WIP/EOS/TVB) :)
Edited by SanchoSK
I just wanted to thank @Jojo for the hints and guidance - it works, my Armbian was directly installed onto my eMMC and booted right away, all seems to be working fine, I can move forward with my project. Really appreciated!
Good to hear that it worked for you 👍.
The PR on Github seems to be on a good way, so "official" support might be there soon... :)
On 10/24/2025 at 9:18 AM, Jojo said:
initially I had the M1S connected to the Aux input of my AV receiver. There seems to be a problem with display detection (EDID, available modes) and so the M1S does not know which display mode to set.
In the meantime I got HDMI also working through my AVR. I just changed the cable and that did the trick...
One thing to mention: the system seems to be allergic to hot-plugging the HDMI cable. So if I connect/reconnect the cable during runtime, the HDMI output will be gone. It requires a reboot WITH CABLE CONNECTED.
Not a big issue from my pov, but important to know...
Hello, another Odroid M1S owner and user here. I tried the Ubuntu image because I was curious about video acceleration in particular. So I installed Kodi and played a few videos. There is no acceleration. This means that this image is not usable as a player. However, it will probably be usable as an SMB/NFS server (I'll try using it that way for a while).
A few comments:
- Gnome is relatively slower, but not unusably slow (I personally don't mind, because I don't intend to use the M1S as a desktop)
- Gnome sometimes has problems rendering windows, there are strange stripes, only in certain parts of the windows, and at times it is so annoying that it becomes unusable
- Personally, I would love it if someone experienced could take a working GPU driver and put it into this image. That would solve everything, and we could all use the M1S to our full satisfaction (however, it's probably not that easy, because otherwise the guys at Odroid would have already done it).
- I will add relevant links to a functional accelerated solution that makes the M1S a fully functional driver, but based on the very old and not very usable 5.10 kernel
- https://forum.odroid.com/viewtopic.php?f=217&t=47621 here is a functional Odroid based image solution for media player.
- By the way, I managed to upgrade the image mentioned here to Ubuntu 24.04, using the Kodi build for Odroid M2 ( https://forum.odroid.com/ viewtopic.php?f=235&t=49005 ), but I had to stay on kernel 5.10, and even this version works relatively well as a functional player with accelerated videos (the old kernel is a prerequisite)
I hope that I have contributed at least a little to making this Armbian image gradually become the standard for M1S, because this computer deserves it.
We only provide mainline based kernel, where video acceleration might not work. If you have a need for that, than use those hints:
add DT here:
https://github.com/armbian/linux-rockchip/blob/rk-6.1-rkr5.1/arch/arm64/boot/dts/rockchip/rk3568-odroid-m1.dts
enable vendor kernel
https://github.com/armbian/build/blob/main/config/boards/odroidm1s.csc#L7
build with ENABLE_EXTENSIONS="v4l2loopback-dkms,mesa-vpu" and desktop will work faster, video acceleration will most likely just work OOB.
2 hours ago, Igor said:
Writing how-to takes more time then doing it :(
Are you sure about the math, because if you write a tutorial, even a relatively brief one, covering at least a few points to guide me more than just a few hints, you'll save a lot of work for a lot of people who would otherwise spend hours doing it. 😉
One might think that if this was a perfect world.  The reality is that very few people want to spend the time to find and read tutorials/FAQs/documentation.  They just come to these forums and expect expert hand holding support for free from people who are volunteering their time.  Igor has a lot more important things to be working on to keep Armbian afloat then even responding to posts in these forums.
While I don't personally deal with rockchip sbc's, so I can't help you specifically here, as a moderator of these forums, I end up answering the same questions over and over again simply because people expect free support, not a community of people just trying to help.
In the spirit of open source the easiest way for someone to contribute to help others is to dig in, learn and then contribute back what they have learned either through these forums, through contributing to the Armbian documentation or through actual code.
(I'm mostly writing this, so that Igor doesn't need to take his time to respond, since I want him to be using his time elsewhere)
@SteeManI partially agree with you. So far, that you say, that people like @Igormight have more important things to do, than to answer (apparent) n00b questions in forums and I also agree that it is highly important, that there are more volunteering people who try to contribute.
But on the other hand I think, that the perspective of you and many other "higher" developers (not only at Armbian) shifts with the level of expertise. What I mean by that is, that when people like me want to start to contribute, we have very limited knowledge in many fields. So many things are mysterious and sometimes we don't even know what we should look after or what we should search for when problems occur.
You are right, that many questions arise regularly and sometimes this is annoying and a reference to the documentation is totally appropriate! But I have the feeling, that particularly here at Armbian, the demands for a question to be posted is very high (compared to the knowledge that beginners come with). And it happens VERY often, that it feels like a slap in the face when I have the courage to ask something and I get told "please stfu, here's a link to the source code."
And I can tell you, that it is exactly this behavior, that brought me to the point, where I thought "well, f**k it. I just wait for my problems to be solved by others, if my request for help to help myself is treated like a request to get my b**t whipped for free". I've felt this quite often here. But I am STILL here, because Armbian is important to me - not only as the OS of my choice, but also as a project that is worth to be supported! But you should also know, that the willingness to contribute (as far as a n00b like me can) will go down rapidly, when you get slapped often enough. And to complain, that people don't want to contribute after slapping them is not fair.
After that said, there the main topic:
I was able to build Armbian with vendor kernel and extensions. I did this by adding the corresponding options to the build command. In my case, my build command looked like this:
./compile.sh build BOARD=odroidm1s NO_HOST_RELEASE_CHECK=yes KERNEL_BTF=no BRANCH=vendor RELEASE=noble BUILD_DESKTOP=yes DESKTOP_ENVIRONMENT=gnome KERNEL_CONFIGURE=no BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers internet multimedia desktop_tools editors' ENABLE_EXTENSIONS="v4l2loopback-dkms,mesa-vpu"
First of all, I hope that this was the correct way to do it. Because my other option would have been to modify the board config file. But that didn't feel right...
The problem now is, that the board just does not boot. After waiting some time the board falls back to the system I have installed on eMMC. Using another non-vendor system on SD card works.
I have the feeling that there is something wrong between u-boot and the vendor-image. Maybe the vendor kernel image expects petitboot and does not work with u-boot? Is there a way to proof that (without overriding u-boot with petitboot)?
You see... n00b question AGAIN. But I try to come as far as possible on my own...
Cheers and have a very nice and joyful xmas season!
Edited by Jojo
See here, HW description bulletpoint 17
https://www.hardkernel.com/shop/odroid-m1s-with-4gbyte-ram/
Maybe it is also available on the 40-pins or 14-pins I/O headers, so a simple generic USB serial cable with jumper wires can be connected.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
