Posted (edited)
vor 38 Minuten schrieb jock:
The only thing I may think about is a flag somewhere on the filesystem that is checked by the script and avoids the real bootloader upgrade.
When a script is possible than uENV.txt should be the best point , also in thinging of rk322x-config where a question for user can be implement
my thought was more that we support Multitool with 2 small xz files extractet  and from 24.xx image and 21.01.01 image ( maybe later get update in newer  multitool version) , and when he has problem he can use a new item point where the bootloader get write like the script above
#!/bin/bash
set -e
# Path
UENV_FILE="/boot/uENV.txt"
# read variable out of uENV
UPGRADEBOOT=$(grep -Po '(?<=Upgradeboot=)\d' "$UENV_FILE" || true)
#or this maybe better
UPGRADEBOOT=$(grep -Po '(?<=Upgradeboot=)\d' "$UENV_FILE" || echo "1")
# Proof, Upgradeboot=0
if [ "$UPGRADEBOOT" -eq 0 ]; then
    echo "Upgradeboot is deactive, Installation abort." >&2
    exit 1
fi
preinstall script
Edited by RaptorSDS
Hello all,
I tried making the procedure and it all worked until I erased the flash memory and tried booting up Armbian, I have an MXQ Pro 4k tvbox with a board that uses NAND so I did the procedures that it's recommended for it. However it was stuck in boot and trying to restore the backup I made did not restore it, so I tried following the steps to upgrade the bootloader as it solves not being able to boot images; but when I put the usb-to-usb io the computer and the board, it is not recognized, both red and blue lights turn on but not completely, in contrast when the board is turned on a bright blue light glows, but there instead the dim blue and red light appears. Am I doing something wrong? Am I maybe not in maskroom mode? And finally, I can use the multitool even though the board is stuck on boot, can I do the same procedures of rkflashtool in the local shell or something?
Thank you all in advance and sorry for any inconveniences.
14 hours ago, jock said:
I can reinstate the opensource optee as Trust OS, which seems to be more compatible, but we lose DDR clock scaling - that increases a lot the general performances - and virtual poweroff from the closed source rockchip Trust OS. Which one to choose?
I see that OPTEE is still in developing.
Is it possible to implement option to choose which bootloader to use during the compilation of the armbian image?
It looks to me way too complex from the maintenance point of view: users may create unwanted mixtures installing things from the multitool over already installed systems (for example 24.02 bootloader on an older armbian release); and also when armbian advances I have to keep the multitool binaries updated as well. It is already very tiring keeping the thing aligned against mainline kernel on every release I don't want to add another burden.
One thing that solves all the boot problems is to reintroduce the OPTEE trust os: it surely does not unwanted things in the background, but then we lose some useful features.
Otherwise I would keep the "manual" procedure for the time being for the problematic boards, until I get the hands on one of them and can study the issue with detail, or some bright idea pops out.
Nope, because this is a very specific problem of tvboxes; regular single board computer users and maintainers don't have to mess with such unknown variables.
That is the main reason why tv boxes, along the funny and always changing hardware they carry, are not and will never be officially supported by armbian, but just by community members.
Recently I started to get system freezes when torrenting. I use the ubuntu server version and it worked fine for years, but now the system freezes when I download torrents greater whan 1 GB. I have tried qbittorent and rtorrent with the same result. I know that is the torrent because the system runs for hours untill I add a torrent and afeter a few minutes it became inacessible by ssh. I use a mounted external sd card as download folder, but the system itself is intalled in the internal memory. Can this be as hardware issue?
The problems you're facing are consistent with failing storage. Whether that's the SD or the onboard MMC remains to be seen.
Of course, it might not be, either, but this would be where I start the diagnostic: try swap that SD.
Posted (edited)
You are so right.
What a surprise when I removed the heatsink!
 Probably that's why this board has trouble during booting process.
Edited by svdmk
I have successfully booted the  Armbian_community_24.5.0-trunk.93_Rk322x-box_bookworm_current_6.6.18_minimal.img on my new MXQ PRO 4k rk3229, first I use the MultiTool to flash the armbian to internal storage (if it doesn't find the internal storage reboot the device in the menu), then download the LibreELEC-RK322X.arm-11.0-nightly-20240218-d7324fb-rk322x.img and flashed to an sd card, I booted on this sdcard and use the SSH to copy the rk322x-box.dtb to the internal storage, then it boots just fine, here is the .dtb file I use rk322x-box.dtb
@Sigma7 Here are the Libreelec and Armbian that I have used, you don't actually need to download the libreelec if you have access to a linux machine, because you can just download the .dtb file above and put them into the armbian image flashed to the sd card (replace the file /boot/dtb-6.6.18-current-rockchip/rk322x-box.dtb with the rk322x-box.dtb from the libreelec image), I think it should work on other armbian images (I suggest you to try the latest stable Armbian build) note that I use the images without desktop environment because I mainly use for servers, if you want grab a xfce desktop image and should work as well.
Let me know if it worked for you.
@KanexMarcus hello, why did you substitute the armbian device tree with the libreelec one? It is wrong and prevents the armbian device tree overlays to work correctly if you do so.
@KanexMarcus probably your board is a r29 and you need to enable the led-conf7 device tree overlay in /boot/armbianEnv.txt. Unfortunately it is a manual procedure that has to be done manually from the multitool.
Hi everyone.
I have a that box here (rk3229 2/16GB) and tried to install Armbian, but the Multitool crashes after a few seconds.
The blue LED stops flashinng and turns on and HDMI signal drops (screen goes to power saving).
I started backing up my emmc but after 2% or so it happens, the exact time seems a bit random, between 10 seconds and 1 minute maybe. It also happens when I just let it stay on the initial screen.
Tried different power adapters and SD cards, one was a brand new Sandisk 32GB. The Android it came with runs flawlessly for more than one hour now. Only HDMI and a generic keyboard are connected.
Any ideas what I could try? Thank you
vor 15 Minuten schrieb moddien:
please also show picture of boeard maybe board print name , some R29 boards have diffirent pin setting so ist maybe one of this creepy and non standart boards
Posted (edited)
Thanks for the quick reply.
edit: would a serial cable help? i could borrow one from a friend. also added screenshot from the device info android app
Edited by moddien
@moddien Hello! Yes, a serial adapter would indeed provide some debug info that can be useful. I don't remember such "r3229q-221p" board, so perhaps it is a new board.
Be sure to use the latest multitool first. User @svdmk had a similar problem, you can check the latest two pages of this thread for some reference.
At the moment the solution is a bit of a hack and involves switching bootloaders, which is not the easier thing to do.
Two same boards but different cpu.
Rockchip labeled works fine with armbian, multitool and libreelec.
The board with huawei labeled cpu has the previously described problem, multitool and armbian stop working after a minute.
Method of switching bootloaders suggested by @jock  works.
Looks like the CE (China Export NOT the EU CE) have "re branding"  one RK to some HUW chop that was likely in one phone copy running one RK chip and (or more likely tablet).
2020. 1. 9. 오전 5시 31분, jock이 말했습니다:
위의 절차는 간단하고 편안하지만 항상 장치가 SD 카드에서 Armbian 이미지를 시동하는 것을 먼저 테스트하는 것이 좋습니다 .
하드웨어가 매우 다양하기 때문에 여기에 제안된 이미지가 작아질 가능성은 거의 없습니다.
This is the MXQ PRO 4K 5G TV BOX with RK322A CPU, 1GB RAM, and 8GB eMMC. I booted MULTITOOL onto the SD card and burned the latest jammy image and Legacy 4.4 image for RK322X. After REBOOT on MULTITOOL, I got a nice ARMBIAN screen and everything was fine. But when I restart it after shutdown, the screen goes blank. It is still possible to boot with MULTITOOL on SD, and from here you can enter ARMBIAN through the REBOOT menu, but booting with only eMMC fails as the monitor screen goes into sleep mode. What's the problem?
Hello, there can be dozen of problems with those symptoms: the kernel does not boot, the image you used is bad, the board is unsupported and does not boot, HDMI does not work on your board, the eMMC is empty, etc... etc...
You should try a newer image with a mainline kernel (4.4 is unsupported and unmaintained anymore) and possibly provide UART serial logs to debug the problem.
Thank you all for your replies. I was a bit busy in the last days and it took me some time to figure out how to dump the flash to my windows pc (i didnt want to mess with it before I had a backup) - I used this rkdumper 1.09test with driver 4.5, other versions gave me errors.
RK3229Q-221P-V1.3 original android (Google Drive)
Tbh I didnt read the whole thread, i stopped after about 15 pages from the beginning before I posted. Indeed @svdmk 's board looks identical to mine. I will look into the bootloader switch next and report back. also I ordered a ttl adapter which should arrive within a week.
Have a great weekend everyone!
@moddien thanks for the firmware, I will try to inspect as soon as possible.
Usually the first page of the thread and the last 3/4 pages are enough to get up to date with recent developments.
Many useful experiences are scattered through the  thread, but usually the most important things are collected in the first page.
Posted (edited)
Thank you for answer. I've only tested the Legacy 4.4 image briefly, and baked the latest image for rk322x. If I boot with the SD card (MULTITOOL), press the REBOOT menu, and remove the SD card, then I can boot with the latest image burned into eMMC and use all functions. I'm just curious as to why I have to go through procedures like "SD boot" and "Remove SD after REBOOT" to boot. I still don't know how to check LOG through UART.
Edited by 송호상
You're welcome. Normally, after burning the image on eMMC, you should do SHUTDOWN in multitool, remove power, unplug the sdcard and restore power.
