Benedito Portela Posted Wednesday at 12:55 AM Posted Wednesday at 12:55 AM @lowscore I'did uploading for you! https://drive.google.com/file/d/1kgyjLl0JXTwFfWfplOKuQY3vLv_KtYlr/view?usp=sharing 2 Quote
Victor Picinin Posted Thursday at 11:08 PM Posted Thursday at 11:08 PM Hi! I dont know if anyone else mentioned this here but here is my issue: My RK3229 boots into armbian fine but after like 60sec the screen turns black and both blue LED stays on. Is there a fix for this? 0 Quote
Mateus Lima Posted 20 hours ago Posted 20 hours ago I'm trying to boot multitool, but my device is booting directly into android. I've flashed my sdcard using dd and balena, both works fine apparently, the box recognizes the sdcard (it shows on android file manager), but every time I reboot it, it only boots android... Does anyone have any clue of what should I do? 0 Quote
RaptorSDS Posted 20 hours ago Posted 20 hours ago vor 19 Minuten schrieb Mateus Lima: 'm trying to boot multitool, Do you try also toothpick (there is a recovery button behind headphone port) methode and SD-Card ? or USB boot , there are some box with lock bootloader 0 Quote
jeffbzrr Posted 19 hours ago Posted 19 hours ago First of all, I would like to thank you for continuing to maintain this project. I use an RK3228 MXQ running raspotify (another great project) playing music. However, I can't equalize the sound? Is there a way to use a sound equalizer? I tried for ALSA and lost a few days in several things but nothing worked. 0 Quote
Mateus Lima Posted 19 hours ago Posted 19 hours ago 46 minutes ago, RaptorSDS said: Do you try also toothpick (there is a recovery button behind headphone port) methode and SD-Card ? What is this method about? Hold the button while it is booting with the sdcard inserted? I also tried to boot using a usb drive flashed with multitool flashed, but it still boots into android. As for the bootloader, I'm booting it into bootloader mode, and it gets recognised, but "fastboot oem unlock" just prints three dots "..." and doesn't do nothing. In the guide there's a bootloader file I think, but it's not available anymore. 0 Quote
Mateus Lima Posted 18 hours ago Posted 18 hours ago 1 hour ago, Mateus Lima said: my device That's my device, I don't if showing it's board will be helpful. 0 Quote
fabiobassa Posted 18 hours ago Posted 18 hours ago (edited) @Mateus Lima I am not very sure this Is a rockchip board.. i see h3q ...may be an allwinner h3 ?????? Can you check removing the heatsink ? Or check with USB ttl adapter ? Edited 18 hours ago by fabiobassa 0 Quote
Mateus Lima Posted 17 hours ago Posted 17 hours ago 1 hour ago, fabiobassa said: allwinner h3 Well, it seems that I have a very strange device, as I can boot armbian for devices using Allwinner H3, even tho the SoC shows It self as a RK322BA. I don't know what's happening with my device, and unfortunately, there's no much information about it, just some users trying random armbian builds from devices with the same soc, which works, but features like wi-fi doesn't, probably something that can be fixed making a dtb for this device, which I don't know how to unfortunately. 0 Quote
fabiobassa Posted 16 hours ago Posted 16 hours ago @Mateus Lima It Is not the first neither will be the last time that china manufacturers fake soc printing. Have a look on allwinner forum 0 Quote
Victor Picinin Posted 3 hours ago Posted 3 hours ago Quote My RK3229 boots into armbian fine but after like 60sec the screen turns black and both blue LED stays on. Is there a fix for this? This was a watchdog and trust os issue. For anyone having this issue, i fixed by building a new multitool from OP github: https://github.com/paolosabatino/multitool/tree/master Changing the RK322x TRUST_OS to: rk322x_tee_1.0.1-72-gf230aa2.bin And them building a new armbian build replacing the armbian TRUST_OS with this same one. "rk322x_tee_1.0.1-72-gf230aa2.bin" if anyone needs the builded files "multitool and armbian" feel free to email me at vitorpicinin@gmail.com 1 Quote
fabiobassa Posted 2 hours ago Posted 2 hours ago @Victor Picinin Hello Victor thank you for your work. Also @jock and @ilmich managed to obtain free source trust and not the proprietary One but i rembember there were issues ( DMC scaling on DDR3 ??? ) Sure jock or ilmich can answer better 0 Quote
jock Posted 1 hour ago Author Posted 1 hour ago Hello @Victor Picinin yes the problem is exactly a watchdog in the proprietary trust os. Some people have issues after 60 seconds, others after 30 seconds and others after 30 minutes. Being the proprietary Trust OS closed source, we can't know what is happening. I suspect it is a sort of automatic "suspend" feature of some sort, but can't be sure because digging into practically is diffucult. What is sure is that if we use OPTEE Trust OS compiled from open sources (OPTEE is the base for the proprietary Trust OS too), there are no issues of sort, but we lose some features like DDR3 memory scaling and "virtual power off" (a suspend mode that can awaken the board via IR-control; there is a driver and a device tree overlay for that to work in armbian) 0 Quote
Victor Picinin Posted 1 hour ago Posted 1 hour ago @jock do you have this OPTEE already builded for sharing? The one in your multitool git did not work for me, also it shows the last change was 2 years ago hahahha. 0 Quote
jock Posted 1 hour ago Author Posted 1 hour ago 6 minutes ago, Victor Picinin said: The one in your multitool git did not work for me, also it shows the last change was 2 years ago hahahha. Multitool uses the proprietary miniloader blob for booting and it does not work with opensource OPTEE unfortunately. I guess the issue is related with this patch that allows mainline opensource u-boot to support proprietary Trust OS, but that's just an ineducated guess. 0 Quote
