During spring cleaning I found Nokia 128Mb SD card and I could not resist to make the standard test ... which took around one hour to finish :D
I expect worse.
  Reveal hidden contents
I think i still have 32MB MMC card lying around somewhere :P
As far as i recall, it was very slow even at the time:)
Expand
I needed small sized cards for nfs boot. I ordered 10pcs of them on Aliexpress and received exactly same ones (Nokia 128MB) probably ripped off old phones :-).
1 could not initialize but rest of them passed badblock test (I received refund for bad piece without any problem).
Than I ordered cheaper ones, 10 pcs again. I got new cards with orange/white colour.
1 could not innitialize => rubbish
2 did not pass test in external but passed test in internal reader => ??rubbish
2 did not pass neither in external or internal reader => rubbish
So keep this card :-) it still has value.
  On 4/10/2017 at 8:59 AM, technik007_cz said:
badblock test
Expand
Better use F3 or H2testw instead: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card
Badblocks semantics are pretty useless on flash media implementing FTL (flash translation layer) since there's no real mapping between physical flash cells and logical blocks. F3 or H2testw do a better job here and sellers usually accept their logs/screenshots to get a refund/replacement. BTW: both tools reports writing and reading speeds which is also interesting since some flash media do 60MB/s fine... but just for a couple of minutes and then slow down. Another good reason to get a refund/replacement!
And here is a related but rather lenghty discussion regarding SD card 'problems' (that are on some platforms often caused by the other standard SBC problem: underpowering, especially Raspberries a few years ago suffered from SD card corruption related to undervoltage): http://tech.scargill.net/a-question-of-lifespan/
@tkaiser
I tested 10pcs of 128MB sized and there is result.
I needed insert card in and just only press enter in opened terminal screen (with command ready like badblocks -wsv /dev/mmcblk0), replace card and press again until no more cards left.
Badblocks found 5 cards with errors and i decided just for case test good ones with f3.
I must mount card, change directory, write test data, unmount, unplug it, plug it again. (I tried test on cards marked bad by badblocks and sometimes it did not find error without replugging it !!!)
and make same procedure .. mount card, change directory and run reading test of  previously data.
And result of f3 test on "badblocks" cards marked ok? F3 did not find any error.
Sorry F3 is not user friendly and I am definitely staying with "badblocks -wsv" which is easier to operate for me.
Expand
Well, you're free to do whatever you want, even fooling yourself :)
For anyone else who stumbles accross this: badblocks is absolutely useless when it's about flash media you bought recently (SD cards, SSDs, USB thumb drives and so on). If you bought really cheap old crap cards somewhere it might blame them correctly as bad but it it's not possible to check for the real problems we face with SD cards today: Checking fraud/counterfeit cards: http://www.happybison.com/reviews/how-to-check-and-spot-fake-micro-sd-card-8/
This is only possible by writing random data patterns to the card and then read all of them back. Takes some time but it's strongly recommended to test immediately with every flash based media you buy. H2testw is easy to use on Windows, F3 is easy to use within Armbian (we automated that for you so in case you forgot to check your card directly after purchase just let 'armbianmonitor -c $HOME' run)
Again: badblocks works fine with spinning rust but is absolutely useless to check flash based media: http://git.net/ml/zfs-discuss/2014-10/msg00312.html
The underlying technology has to be considered and then certain tools/strategies that worked fine for decades are of no use any more. Same for example with 'RAID 1' many people seem to love. Useful with HDDs, not that much with SD cards and an attempt to fool yourself when done with 2 SSD of same type.
