y52 Posted March 19, 2018 Posted March 19, 2018 On 18/03/2018 at 12:58 PM, Tazz said: GlobalScaleTechnologies .dtb is for their own provided kernel. As you are using Armbian, use what is provided by Armbian. The Armbian's dtb raises kernel panic on my board setenv fdt_name_a boot/dtb/marvell/armada-3720-community.dtb [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Debian GNU/Linux 9 espressobin ttyMV0 espressobin login: [ 108.552976] Unable to handle kernel paging request at virtual address 555555555555cd [ 108.560575] pgd = ffffffc07780e000 [ 108.564546] [555555555555cd] *pgd=000000007697c003, *pud=000000007697c003, *pmd=0000000000000000 [ 108.573474] Internal error: Oops: 96000004 [#1] PREEMPT SMP [ 108.579140] Modules linked in: bridge stp llc xt_nat iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 ip6t_rt nf_defrag_ipv4 xt_tcpudp nf_conntrack_ipv6 nf_defrag_ipv6 xt_conntrack nf_conntrack ip6table_filter iptable_filter ip6_tables ip_tables x_tables [ 108.602572] CPU: 1 PID: 7 Comm: rcu_preempt Not tainted 4.4.112-mvebu64 #8 [ 108.609767] Hardware name: Marvell Armada 3720 Community Board (DT) [ 108.615981] task: ffffffc07807c500 ti: ffffffc0780b8000 task.ti: ffffffc0780b8000 [ 108.623909] PC is at mv_udc_irq+0x730/0xc00 [ 108.628135] LR is at mv_udc_irq+0x728/0xc00 .... [ 115.737495] Process kworker/1:3 (pid: 554, stack limit = 0xffffffc0777c4020) [ 115.744526] Stack: (0xffffffc0777c7cd0 to 0xffffffc0777c8000) ... [ 115.961471] Call trace: [ 115.964001] [<ffffffc000095f9c>] check_and_switch_context+0x2c/0x450 [ 115.970582] [<ffffffc0009e44cc>] __schedule+0x17c/0x5d8 [ 115.975633] [<ffffffc0009e496c>] schedule+0x44/0xb8 [ 115.981036] [<ffffffc0000cd5dc>] worker_thread+0x1ac/0x4d0 [ 115.986626] [<ffffffc0000d3250>] kthread+0xf8/0x110 [ 115.991669] [<ffffffc000085dd0>] ret_from_fork+0x10/0x40 [ 115.997251] Code: a90363f7 a90153f3 2a0103f7 a9046bf9 (b9413382) The board is stable at 1000/800 u-boot with the GlobalScaleTechnologies's dtb setenv fdt_name_a boot/dtb/marvell/armada-3720-community-v5.dtb
Tazz Posted March 19, 2018 Posted March 19, 2018 yes, 4.4.112-mvebu64 is the BSP/global scale kernel. Armbian provided 4.4.112 kernel should be updated with latest dtb. I only use latest/mainline Armbian kernel. BSP kernels are a dead end in my opinion. For crypto: the armv8 crypto extension support is very good. safexcel aka EIP support in the bsp (4.4) suck. We should wait mainline support (with added algo too). But the best perf with EIP will be obtained by in kernel users (ipsec, block encypt, future TLS app sockets). Cryptodev is not the panacea for userspace. It will mainly offload main CPUs for other tasks.
y52 Posted March 19, 2018 Posted March 19, 2018 19 minutes ago, Tazz said: Armbian provided 4.4.112 kernel should be updated with latest dtb. The " boot/dtb/marvell/armada-3720-community.dtb" came with the Armbian distribution. root@espressobin:~# uname -a Linux espressobin 4.4.112-mvebu64 It is discrepant if the dtb doesn't correspond to the Armbian's build and might be a source of instability.
Tazz Posted March 20, 2018 Posted March 20, 2018 Things evolve and fix are made, even in the dts/dtb.
y52 Posted March 20, 2018 Posted March 20, 2018 2 hours ago, Tazz said: Things evolve and fix are made, even in the dts/dtb. Where could they be retrieved from? 22 hours ago, Tazz said: EIP will be obtained by in kernel users (ipsec, block encypt I also wait for the crypto support for the router's ipsec feature.
Tazz Posted March 20, 2018 Posted March 20, 2018 BSP version is 4.4.52 armada-17.10.3 which is not very "secure" to use on a networked platform. So Armbian developers updated the BSP with patches. Great piece of boring work. Big thanks to them. https://github.com/armbian/build/tree/development/patch/kernel/mvebu64-default Something broke and is disabled so work when using the BSP dtb. Try with the latest Armbian version in the repo 4.4.121-mvebu64 or build the 4.4.122-mvebu64. The problem is perhaps fixed.
y52 Posted March 20, 2018 Posted March 20, 2018 I shall not be able building the 4.4.122-mvebu64 now, while the prebuilt image is a 4.4.112-mvebu64 only. It is worth updating it, so that it could be tested by a wider audience (like me). If I manage setting up a production board with the docker's service, I shall probably setup a build infrastructure within it.
Tazz Posted March 21, 2018 Posted March 21, 2018 apt-get update/upgrade or dpkg -i and you should be able to intal 4.4.121 no ?
y52 Posted March 21, 2018 Posted March 21, 2018 2 hours ago, Tazz said: apt-get update/upgrade or dpkg -i and you should be able to intal 4.4.121 no ? Nope. It doesn't change anything at all : root@espressobin:~# uname -a Linux espressobin 4.4.112-mvebu64 #8 SMP PREEMPT Wed Jan 24 22:53:43 CET 2018 aarch64 GNU/Linux
tom_i Posted March 25, 2018 Posted March 25, 2018 Hi all, so I've bought this SATA miniPCI card for to have 2 or more HDD (SSD) together, like some NAS or so. Booting with SSD works just when I connect SSD to SATA connector on my EspressoBin. If I connect it to miniPCI card, it doesn't boot from u-boot. So if I connect SSD to SATA connector on EspressoBin, it boots, but problem is when I connect HDD to the miniPCI slot. Booting is ok till Armbian decided that /dev/sda1 is HDD and /dev/sdb1 is SSD which is wrong. Is there any hack for u-boot to change booting option from that miniPCI card? My actual ENV from u-boot: Marvell>> printenv baudrate=115200 boot=interface scsi boot_interface=scsi bootargs=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/sda1 rw rootwait bootcmd=scsi scan; scsi dev 0; ext4load scsi 0:1 $kernel_addr $image_name;ext4load scsi 0:1 $initrd_addr $initrd_image; ext4load scsi 0:1 $fdt_addr $fdt_name_a;ext4load scsi 0:1 $fdt_addr $fdt_name_b;setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 eth1addr=00:51:82:11:22:01 eth2addr=00:51:82:11:22:02 eth3addr=00:51:82:11:22:03 ethact=neta@30000 ethaddr=F0:AD:XX:XX:XX:XX ethprime=eth0 fdt_addr=0x4f00000 fdt_high=0xffffffffffffffff fdt_name=boot/dtb/marvell/armada-3720-community.dtb fdt_name_a=boot/dtb/marvell/armada-3720-community.dtb fdt_name_b=boot/dtb/marvell/armada-3720-espressobin.dtb fdtcontroladdr=7f7182d8 gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr $image_name; tftpboot $fdt_addr $fdt_name; run get_ramfs get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramfs_addr 0x8000000; tftpboot $ramfs_addr $ramfs_name; else setenv ramfs_addr -;fi hostname=marvell image_name=boot/Image initrd_addr=0x1100000 initrd_image=boot/uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x5000000 loadaddr=0x5000000 netdev=eth0 netmask=255.255.255.0 ramfs_addr=0x8000000 ramfs_name=- root=root=/dev/sda1 rw rootdev=/dev/sda1 rootfstype=ext4 rootpath=/srv/nfs/ serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath $extra_params stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 verbosity=1 Environment size: 1772/65532 bytes
Igor Posted March 25, 2018 Posted March 25, 2018 47 minutes ago, tom_i said: Booting is ok till Armbian decided that /dev/sda1 is HDD and /dev/sdb1 is SSD which is wrong. It doesn't appear that you are using armbian boot environment. How-to is written on the download page: https://www.armbian.com/espressobin/ but in this case, it might not help. If those SATA ports on addon are not recognized from u-boot, you can't boot from it anyway and you need to boot from some other media: SD, eMMC, USB, SATA on Espressobin.
umiddelb Posted March 25, 2018 Posted March 25, 2018 1 hour ago, tom_i said: Booting is ok till Armbian decided that /dev/sda1 is HDD and /dev/sdb1 is SSD which is wrong. You can hardwire the partition to boot the userland from by its UUID, e.g. root=UUID=cc255a80-136b-4c36-9bba-2dd32fa5d750 instead of root=/dev/sda1 You need to modify bootargs environment variable either by modifying it directly or by facilitating the Armbian way of booting and editing /boot/armbianEnv.txt # sudo blkid tells you which UUID belongs to which partition.
tom_i Posted March 25, 2018 Posted March 25, 2018 @Igor - I used to use SD card for running EspressoBin, but it was slow, so I decided to buy SSD and use HDD for "home" data. I've used "nand-sata-install" to copy data from SD card to SSD. @umiddelb - "/boot/armbianEnv.txt" had that UUID saved, with it no boot if the normal HDD is connected. And then I've tried to setup "root=UUID=0f9d4af6-12cd-3e33-b234-3385f706f468", "saveenv" but that parameter isn't saved There is still "root=root=/dev/sda1"
tom_i Posted March 25, 2018 Posted March 25, 2018 Loading, please wait... starting version 238 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.31.1 [/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1 /dev/sda1: recovering journal /dev/sda1: clean, 31481/61054976 files, 208644350/244190390 blocks done. [ 8.717541] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... mount: No such file or directory mount: invalid option -- done. mount: No such file or directory run-init: opening console: No such file or directory Target filesystem doesn't have requested /sbin/init. run-init: opening console: No such file or directory run-init: opening console: No such file or directory run-init: opening console: No such file or directory run-init: opening console: No such file or directory run-init: opening console: No such file or directory No init found. Try passing init= bootarg. (initramfs)
umiddelb Posted March 25, 2018 Posted March 25, 2018 You need to modify `rootdev´, not `root´. `set_bootargs´ is never called. (The u-boot environment isn't in a good shape)
tom_i Posted March 26, 2018 Posted March 26, 2018 6 hours ago, umiddelb said: You need to modify `rootdev´, not `root´. `set_bootargs´ is never called. (The u-boot environment isn't in a good shape) Oh.. ok thank you, I'll try it today... Anyway you meant my u-boot isn't in a good shape? Should I remove some stuff from there?
umiddelb Posted March 26, 2018 Posted March 26, 2018 It's the stored u-boot environment. You might consider to load the Armbian defaults for the espressobin.
tom_i Posted March 26, 2018 Posted March 26, 2018 Setup "rootdev" for using UUID doesn't help. But I think, that u-boot is ok. It boots to armbian, but after Armbian checks disks it changes names. So HDD is /dev/sda1 and SSD is /dev/sdb1.
martinayotte Posted March 26, 2018 Posted March 26, 2018 9 minutes ago, tom_i said: It boots to armbian, but after Armbian checks disks it changes names Did you also check UUID in /etc/fstab ?
tom_i Posted March 26, 2018 Posted March 26, 2018 Yes of course, there are right UUIDs for SSD / and for HDD which is currently commented. Actual situation when both are connected: (initramfs) blkid /dev/sdb1: UUID="0f9d4af6-98bf-4e76-bf12-3f85f706f468" TYPE="ext4" PARTUUID="669c2e15-01" /dev/sda1: UUID="5d577507-8c81-4be3-ba3d-5776baf857d1" TYPE="ext4" PARTUUID="aa448862-01" From /etc/fstab: root@espressobin:~# cat /etc/fstab # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 /var/swap none swap sw 0 0 #UUID=05f654b5-c16f-49ed-86c1-6474b04e92da /media/mmcboot ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 #/media/mmcboot/boot /boot none bind 0 0 UUID=0f9d4af6-98bf-4e76-bf12-3f85f706f468 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 #UUID=5d577507-8c81-4be3-ba3d-5776baf857d1 /media/multimedia ext4 auto,rw,user 0 1 As you can see, that SSD is configured to mount to "/" but it doesn't :-/ armbianEnv.tct: root@espressobin:~# cat /boot/armbianEnv.txt verbosity=1 emmc_fix=off ... rootdev=UUID=0f9d4af6-98bf-4e76-bf12-3f85f706f468 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
Igor Posted March 26, 2018 Posted March 26, 2018 If your u-boot doesn't load our boot.scr it's irrelevant what's inside armbianEnv.txt since it's not loaded.
tom_i Posted March 26, 2018 Posted March 26, 2018 Ahaa, so I should use these: setenv initrd_addr 0x1100000 setenv image_name boot/Image setenv load_script 'if test -e mmc 0:1 boot/boot.scr; then echo \"... booting from SD\";setenv boot_interface mmc;else echo \"... booting from USB/SATA\";usb start;setenv boot_interface usb;fi;if test -e \$boot_interface 0:1 boot/boot.scr;then ext4load \$boot_interface 0:1 0x00800000 boot/boot.scr; source; fi' setenv bootcmd 'run get_images; run set_bootargs; run load_script;booti \$kernel_addr \$ramfs_addr \$fdt_addr' But configure it for using SSD. So it should look like this: setenv boot_interface scsi setenv rootdev "/dev/sda1" setenv root root=/dev/sda1 rw setenv initrd_addr 0x1100000 setenv image_name boot/Image setenv load_script 'if test -e mmc 0:1 boot/boot.scr; then echo \"... booting from SD\";setenv boot_interface mmc;else echo \"... booting from USB/SATA\";usb start;setenv boot_interface usb;fi;if test -e \$boot_interface 0:1 boot/boot.scr;then ext4load \$boot_interface 0:1 0x00800000 boot/boot.scr; source; fi' setenv bootcmd 'run get_images; run set_bootargs; run load_script;booti \$kernel_addr \$ramfs_addr \$fdt_addr' And what about this parameters? setenv bootcmd 'scsi scan; scsi dev 0; ext4load scsi 0:1 $kernel_addr $image_name;ext4load scsi 0:1 $initrd_addr $initrd_image; ext4load scsi 0:1 $fdt_addr $fdt_name;setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr' Something should be there too right?
umiddelb Posted March 27, 2018 Posted March 27, 2018 8 hours ago, tom_i said: Setup "rootdev" for using UUID doesn't help. But I think, that u-boot is ok. It boots to armbian, but after Armbian checks disks it changes names. So HDD is /dev/sda1 and SSD is /dev/sdb1. Choosing the root device partition by its UUID only works when you boot via an intermediate initrd.
y52 Posted March 29, 2018 Posted March 29, 2018 Is there a solution powering down the board from the command line? The result of "shutdown -h now" will only unmount the OS, but the hardware will stay under power.
tom_i Posted March 30, 2018 Posted March 30, 2018 I think there is no possiblity like this, because it hasn't ATX power supply Anyway, I'm shutting it down via sudo halt and it unmount drives and turn off HDD, but when I'm listening it carefully HDD make some low noise. So maybe EspressoBin can't turn HDD completely off.
tom_i Posted March 30, 2018 Posted March 30, 2018 My problem with no boot with SSD and HDD I've solved with renaming rootdev root and bootargs root with /dev/sdb1 Of course, I've updated U-Boot from Armbian
y52 Posted March 30, 2018 Posted March 30, 2018 15 hours ago, tom_i said: I think there is no possiblity like this, because it hasn't ATX power supply I run different other arm boards. BananaPI board, for example, executes power down and switches off the LEDs. It is not heating in a powered down state. Espressobin leaves the LED turned on and the CPU continue heating.
Tazz Posted April 1, 2018 Posted April 1, 2018 It seems that because how the led is wired, it could not be controlled by software (not a gpio capable pin). For the rest, surely need more kernel support.
y52 Posted April 3, 2018 Posted April 3, 2018 On 01/04/2018 at 10:04 PM, Tazz said: not a gpio capable pin Does the board schematics wire the LED as gpio capable? At the same time, is the board equipped with the thermal zone? I haven't yet discovered the means controlling the board components temperature, what worries me, as CPU may heat significantly even under average rated loads.
chrisf Posted April 3, 2018 Posted April 3, 2018 7 hours ago, y52 said: Does the board schematics wire the LED as gpio capable? At the same time, is the board equipped with the thermal zone? I haven't yet discovered the means controlling the board components temperature, what worries me, as CPU may heat significantly even under average rated loads. The green power LED is wired directly to the input power rail. The schematic is available from http://wiki.espressobin.net/tiki-index.php?page=Schematics
