hunglingho Posted September 3, 2024 Posted September 3, 2024 when updating my orange pi 5, I got the following error. What can I do to fix it? ``` update-initramfs: Armbian: Symlinking /boot/uInitrd-5.10.160-legacy-rk35xx to /boot/uInitrd ln: failed to create symbolic link '/boot/uInitrd': Operation not permitted update-initramfs: Symlink failed, moving /boot/uInitrd-5.10.160-legacy-rk35xx to /boot/uInitrd renamed '/boot/uInitrd-5.10.160-legacy-rk35xx' -> '/boot/uInitrd' update-initramfs: Armbian: done. ``` 0 Quote
Werner Posted September 4, 2024 Posted September 4, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
hunglingho Posted September 4, 2024 Author Posted September 4, 2024 https://paste.armbian.com/uqihegagec 0 Quote
Igor Posted September 4, 2024 Posted September 4, 2024 This must be one of early images with FAT boot partition. I think its safe to ignore ... scripts can't do symbolic links on FAT. 0 Quote
SteeMan Posted September 4, 2024 Posted September 4, 2024 On 9/3/2024 at 10:34 AM, hunglingho said: update-initramfs: Armbian: Symlinking /boot/uInitrd-5.10.160-legacy-rk35xx to /boot/uInitrd ln: failed to create symbolic link '/boot/uInitrd': Operation not permitted update-initramfs: Symlink failed, moving /boot/uInitrd-5.10.160-legacy-rk35xx to /boot/uInitrd renamed '/boot/uInitrd-5.10.160-legacy-rk35xx' -> '/boot/uInitrd' update-initramfs: Armbian: done. As Igor says, I'm assuming you have a separate /boot partition that is FAT separate from your / root partition. In that case, this would be a normal 'warning' message for a system that has a FAT /boot partition. All of my devices fall in that category (with a FAT /boot partition) and I see this message for every update. 0 Quote
