November 4, 20242 yr I'm having an issue where the prebuilt images dowloaded from https://www.armbian.com/radxa-rock-5c/ (released on Oct 12, 2024) works fine, including WiFi connectivity, even after reboots, but the moment I updgrade the packages (apt update && apt upgrade) and reboot the system, the WiFi network interface (wlan0) simply disappears and can I no longer search or connect to any wireless network.I've flashed both Bookworm Minimal/IOT and Server/CLI Bookworm, e the issue always occur after upgradin packages. the wlan0 does not appear on iwctl neither ip address commands, but the device (AIC Wlan) still appears on lsusb command: $ lsusb Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 004: ID a69c:8d80 aicsemi AIC Wlan Bus 005 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub armbianmonitor output: https://paste.armbian.com/oqewipobin I don't know if there is an issue with the newest kernel update, or if there is some overlay or kernel module for the AIC Wlan chip that is being erased/disabled during the kernel update process. Is there something I can try to reenable the wlan0 interface? or is it just a bronken update? Edited November 4, 20242 yr by oqewipobin Fix hyperlink
November 5, 20242 yr Author Solution Looks like installing/reinstalling the Radxa provided packages for aic8800 (https://github.com/radxa-pkg/aic8800/releases) kernel modules AFTER the kernel update makes the WiFi module work again.
November 6, 20242 yr What packages did you install? The release page from Radxa contains several packages and I am not sure, which should I use.
November 18, 20241 yr Same for me. Installed Quote Armbian_24.8.4_Rock-5c_bookworm_vendor_6.1.75-backported-mesa.img to eMMc card, installation / configuration for 1st time without problem also with using WIFI connection. List of modules after installation: Then after apt update/upgrade wifi stop working, module was not found or somehow broken. What I found out, that upgrade Armbian deletes all aic8800 modules: After rebooting system, modules were not loaded and modprobe of them don't work either. Upgrade installs newer versions of Quote linux-headers-vendor-rk35xx linux-image-vendor-rk35xx linux-dtb-vendor-rk35xx to version 24.11.1 from 24.8.4 Edited November 18, 20241 yr by tom_i
November 18, 20241 yr dmesg found it.. but [ 12.854279] usb 7-1.3: New USB device found, idVendor=a69c, idProduct=8d80, bcdDevice= 1.00 [ 12.854323] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 12.854353] usb 7-1.3: Product: AIC Wlan [ 12.854378] usb 7-1.3: Manufacturer: aicsemi [ 12.854403] usb 7-1.3: SerialNumber: 20220103 ... [ 14.555712] aicbsp_init [ 14.555720] RELEASE_DATE:2024_0109_ec460377 [ 14.555724] aicbsp_resv_mem_init [ 14.557550] systemd[1]: Starting systemd-sysusers.service - Create System Users... [ 14.567717] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1 [ 14.567736] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI [ 14.567741] aicbsp: aicbsp_platform_power_on
November 18, 20241 yr 7 hours ago, tom_i said: Installed Test most recent builds: (still in testing) https://rsync.armbian.com/incoming/schwar3kat/rock-5c/archive/
November 18, 20241 yr I've just tried Armbian_24.11.1_Rock-5c_bookworm_edge_6.11.7_minimal.img wlan works. No ZFS, however. Building zfs-dkms fails, from /var/lib/dkms/zfs/2.2.5/build/make.log: 93 | #error "Unsupported kernel" According to https://github.com/openzfs/zfs/releases: zfs-2.2.5 is compatible with 4.18 - 6.9 kernels zfs-2.2.6 is compatible with 4.18 - 6.10 kernels zfs-2.3.0 would be compatible with Linux kernels 4.18 - 6.11 Armbian_24.8.4_Rock-5c_bookworm_vendor_6.1.75_minimal.img - ZFS OK, wlan after 'apt upgrade' not anymore. But $ /sudo dkms install aic8800-usb/3.0+git20240327.3561b08f-2 does the trick. ------- Sign command: /lib/modules/6.1.75-vendor-rk35xx/build/scripts/sign-file Binary /lib/modules/6.1.75-vendor-rk35xx/build/scripts/sign-file not found, modules won't be signed Creating symlink /var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/source -> /usr/src/aic8800-usb-3.0+git20240327.3561b08f-2 Building module: Cleaning build area...(bad exit status: 2) make -j8 KERNELRELEASE=6.1.75-vendor-rk35xx -C /lib/modules/6.1.75-vendor-rk35xx/build M=/var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/build/USB/driver_fw/drivers/aic8800 && make -C /lib/modules/6.1.75-vendor-rk35xx/build M=/var/lib/dkms/aic8800-usb/3.0+git20240327.3561b08f-2/build/USB/driver_fw/drivers/aic_btusb....... .... depmod... -------- root@rock-5c:~# iw phy0 info Wiphy phy0 wiphy index: 0 max # scan SSIDs: 3 max scan IEs length: 200 bytes max # sched scan SSIDs: 0 max # match sets: 0 Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Device supports RSN-IBSS. Device supports AP-side u-APSD. Supported Ciphers: * WEP40 (00-0f-ac:1) * WEP104 (00-0f-ac:5) * TKIP (00-0f-ac:2) .... Regards, Chris
December 8, 20241 yr I can confirm this issue. Tested on the following images: * Armbian_24.11.1_Rock-5c_noble_vendor_6.1.75_gnome-kisak_desktop.img.xz * Custom build image (vendor kernel 6.1 + GNOME) When updating the kernel, the aic8800-usb DKMS driver is removed from the old kernel, but not reinstalled on the new kernel. This can easily be fixed afterwards by running the following command: `sudo dpkg-reconfigure aic8800-usb-dkms`, which will recompile and install the kernel module again. I was playing around with Radxa's own Debian based image as well. When compiling a custom kernel with their `bsp` tool and installing it, the same thing happens. Therefore I believe this to be an upstream issue with the aic8800 deb packages. Maybe with the way they register the driver using DKMS... Edited December 8, 20241 yr by Sander de Leeuw
February 26, 20251 yr @Sander de Leeuw thx for the solution, one thing is strange after applying it, an additional device apears which is not the wifi adapter of the rockt 5c p2p-dev-wlan0: disconnected "p2p-dev-wlan0" wifi-p2p, hw
