Евгений Загребельный Posted December 6, 2024 Posted December 6, 2024 Hello guys. I have Banana Pi BPI-M2-Ultra v1.1 board with A40i chip I download img from armbian "Armbian_community_25.2.0-trunk.86_Bananapim2ultra_noble_current_6.6.62_xfce_desktop.img.xz" and write it on microSD(HC) 32Gb A1 10 class with balena etcher. Then plug it in a board and turn on. Here is uart debug output 11:14:41.598 -> 11:14:42.396 -> U-Boot SPL 2024.01-armbian-2024.01-S866c-Pb2fe-H0429-V0f9a-Bda0a-R448a (Nov 17 2024 - 03:22:36 +0000) 11:14:42.429 -> DRAM: 2048 MiB 11:14:42.429 -> Trying to boot from MMC1 11:14:42.728 -> ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 11:14:42.728 -> 11:14:42.728 -> 11:14:42.728 -> U-Boot 2024.01-armbian-2024.01-S866c-Pb2fe-H0429-V0f9a-Bda0a-R448a (Nov 17 2024 - 03:22:36 +0000) Allwinner Technology 11:14:42.761 -> 11:14:42.761 -> CPU: Allwinner R40 (SUN8I 1701) 11:14:42.761 -> Model: Banana Pi BPI-M2-Ultra 11:14:42.761 -> DRAM: 2 GiB 11:14:42.795 -> sunxi-pinctrl pinctrl@1c20800: pinctrl_select_state_full: pinctrl_config_one: err=-38 11:14:42.795 -> Core: 66 devices, 23 uclasses, devicetree: separate 11:14:42.828 -> WDT: Not starting watchdog@1c20c90 11:14:42.828 -> MMC: gpio_sunxi pinctrl@1c20800: pinctrl_select_state_full: pinctrl_config_one: err=-38 11:14:42.828 -> mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 11:14:42.861 -> Loading Environment from FAT... Unable to use mmc 0:1... 11:14:42.861 -> In: serial@1c28000 11:14:42.894 -> Out: serial@1c28000 11:14:42.894 -> Err: serial@1c28000 11:14:42.927 -> Net: eth0: ethernet@1c50000 11:14:42.927 -> starting USB... 11:14:42.927 -> Bus usb@1c19000: Port not available. 11:14:42.961 -> Bus usb@1c19400: Port not available. 11:14:42.961 -> Bus usb@1c1c000: Port not available. 11:14:42.961 -> Bus usb@1c1c400: Port not available. 11:14:42.994 -> Autoboot in 1 seconds, press <Space> to stop 11:14:43.991 -> switch to partitions #0, OK 11:14:44.024 -> mmc0 is current device 11:14:44.024 -> Scanning mmc 0:1... 11:14:44.024 -> Found U-Boot script /boot/boot.scr 11:14:44.024 -> 5442 bytes read in 3 ms (1.7 MiB/s) 11:14:44.024 -> ## Executing script at 43100000 11:14:44.057 -> U-boot loaded from SD 11:14:44.057 -> 154 bytes read in 3 ms (49.8 KiB/s) 11:14:44.057 -> Unknown command ':' - try 'help' 11:14:44.655 -> 14529165 bytes read in 604 ms (22.9 MiB/s) 11:14:45.053 -> 8992608 bytes read in 375 ms (22.9 MiB/s) 11:14:45.053 -> Found mainline kernel configuration 11:14:45.053 -> 38747 bytes read in 7 ms (5.3 MiB/s) 11:14:45.053 -> Load fdt: /boot/dtb/sun8i-r40-bananapi-m2-ultra.dtb 11:14:45.086 -> Working FDT set to 43000000 11:14:45.086 -> Failed to load '/boot/dtb/overlay/sun8i-r40-fixup.scr' 11:14:45.086 -> Kernel image @ 0x42000000 [ 0x000000 - 0x893760 ] 11:14:45.086 -> ## Loading init Ramdisk from Legacy Image at 43400000 ... 11:14:45.086 -> Image Name: uInitrd 11:14:45.086 -> Image Type: ARM Linux RAMDisk Image (gzip compressed) 11:14:45.120 -> Data Size: 14529101 Bytes = 13.9 MiB 11:14:45.120 -> Load Address: 00000000 11:14:45.120 -> Entry Point: 00000000 11:14:45.120 -> Verifying Checksum ... OK 11:14:45.219 -> ## Flattened Device Tree blob at 43000000 11:14:45.219 -> Booting using the fdt blob at 0x43000000 11:14:45.252 -> Working FDT set to 43000000 11:14:45.252 -> Loading Ramdisk to 49224000, end 49fff24d ... OK 11:14:45.286 -> Loading Device Tree to 491b2000, end 49223fff ... OK 11:14:45.286 -> Working FDT set to 491b2000 11:14:45.286 -> 11:14:45.286 -> Starting kernel ... 11:14:45.286 -> 11:14:50.135 -> done. 11:14:50.135 -> Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. 11:14:50.135 -> Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems so thats all. it stops on it. Before it i tryed to use ubuntu MATE 16.04 (from sd card and install to emmc). and it works any ideas how to run armbian? 0 Quote
Werner Posted December 6, 2024 Posted December 6, 2024 Try adjust armbianEnv.txt for once set verbosity to 7 and for the other make sure the UUID matches the one from the sdcard. 0 Quote
going Posted December 6, 2024 Posted December 6, 2024 8 часов назад, Евгений Загребельный сказал: any ideas how to run armbian? You can try to assemble the image yourself. 8 часов назад, Евгений Загребельный сказал: 11:14:50.135 -> Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems so thats all. it stops on it. How many minutes did you wait for the invitation at the first launch? Your SD card is 32GB. At the first launch, the script stretches the system partition over the entire card and this is a long process. What will the use of the Linux system utilities show if you insert the SD card into the USB-CD adapter and run the checks on another computer? 0 Quote
Igor Posted December 6, 2024 Posted December 6, 2024 Also try some older builds. We have one of this board in the automated test system and it works fine. https://armbian.atomonetworks.com/archive/bananapim2ultra/archive/ 0 Quote
Евгений Загребельный Posted December 7, 2024 Author Posted December 7, 2024 23 часа назад, Werner сказал: Try adjust armbianEnv.txt for once set verbosity to 7 and for the other make sure the UUID matches the one from the sdcard. as i understand this file on SD card? or this envs change from uboot (interrupt loading with uart debug)? and where UUID match? (in armbianEnv.txt too?) 0 Quote
Евгений Загребельный Posted December 7, 2024 Author Posted December 7, 2024 18 часов назад, going сказал: You can try to assemble the image yourself. is there help steps for this method? 18 часов назад, going сказал: How many minutes did you wait for the invitation at the first launch? Your SD card is 32GB. At the first launch, the script stretches the system partition over the entire card and this is a long process. What will the use of the Linux system utilities show if you insert the SD card into the USB-CD adapter and run the checks on another computer? i leaved it for a night :))) and nothing changed 0 Quote
Евгений Загребельный Posted December 7, 2024 Author Posted December 7, 2024 13 часов назад, Igor сказал: Also try some older builds. We have one of this board in the automated test system and it works fine. https://armbian.atomonetworks.com/archive/bananapim2ultra/archive/ thanks, will try 0 Quote
going Posted December 7, 2024 Posted December 7, 2024 2 часа назад, Евгений Загребельный сказал: i leaved it for a night :))) and nothing changed 10 - 20 minutes is enough. I've come across this kind of behavior. One of the possible reasons is the SD card from the manufacturer SAMSUNG. I have a "fast" SD card if it is formatted as FAT32. If I format it into any other file system, it starts to work very very slowly. The built-in SD card controller cannot cope. P.S. It seems the problem is not with the card. If you download another operating system and it works. 0 Quote
eselarm Posted December 9, 2024 Posted December 9, 2024 (edited) There is an issue with SD-card interfacing in the 'noble_current_6.6.62' images I think. I see the same: Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems and is is because after the kernel is loaded and starting to run (doing scripts from initramfs etc), the SD-card/MMC interfacing get flaky or so. That endless wait is just that initrd can't find the rootfs. It also happened in an earlier phase that communication with the SD-card gets into trouble. Then many block I/O errors. It seems on older slower card 1 out of 4 powercycles it works, and then also no problem at all. The successful run I managed to setup the full system KDE neon desktop. But now it always fails, so I took a complete image of the SD-card and will try later. In my case it is a ROCK3A so different SoC. A Radxa Debian11 CLI image gives no problems. I will make an own topic later when I know more. Edited December 9, 2024 by eselarm 1 Quote
eselarm Posted December 11, 2024 Posted December 11, 2024 I am almost sure now that the reason I saw: 'Running /scripts/local-premount ... Scanning for Btrfs filesystems' is power supply or circuitry related. What exactly is a question still. If I want to know, I have to go back to the situation on the day before yesterday when I tried to boot the new ROCK3A v1.31 with the original downloaded noble 6.2.62 based images. Radxa wiki mentions 5V/2A is needed, so I took a known-to-work PSU (used for diskless RPi4B) rated 5V/2.4A, added my https://www.fnirsi.com/products/fnb48s and with HDMI, serial console, RJ45 connected as well. The FNB48S displayed values well below 5V/2A. What worries me is that several strange things happened: - with 2 different brand SD-cards, the board went in a low-power state, stalled. Disconnect and then reconnect USB-c power cable made it boot further mostly, until 1 time full success - the HDMI monitor sometimes shows a shaky flash. That is the most strange; I suspect a loop in cabling somehow, but it isn't there (in theory). The workaround is to make sure no loops, so no HDMI, serial console connected laptop on batteries - around kernel/systemd messaging about NPU power also something changed, either stall or success. In the end, as stated already, Radxa Debian11 CLI image worked. But also the Armbian Bookworm minimal IoT image with kernel 6.6.62. So I used the latter one to set up some basic things like ssh access and keys and correct MAC/IP address (networkd fails somehow with DNS in my homelan, so purged netplan and (re-)installed NM). And the converted the whole rootfs of-line to Btrfs with btrfs-convert, put SD-card back in and it still worked. Yesterday, the day after, I swapped the 5V/2.4A+FNB48S for just a new RaspberryPi 5V/5A PSU (not that the 5A matters) but was new/unused and also got 2 the other already setup noble rootfs systems onto extra partitions on the same SD-card. No issues, although now it is kernel 6.6.63 or 6.6.64 already as I put it on the beta repo. My use-case was replacing an old dead Intel Asrock server board handling a large SATA HDD, so I needed the 6.1.84 vendor kernel which now includes a SATA overlay and that works (kernel sees it at least). So my guess is I have/had some (GND)loop or whatever. I always can run the whole setup via an off-grid standalone 12V car-battery, in case I want some 'proof'. it was late in the evening, too tired as well I guess. 1 Quote
technik007_cz Posted Monday at 09:55 AM Posted Monday at 09:55 AM (edited) I can confirm the situation with the latest Armbian Noble system image for M2U, which is Armbian_community_26.2.0-trunk.703_Bananapim2ultra_noble_current_6.18.21_xfce_desktop.img.xz. lead to the same result and it hangs at messages: Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems For those which looking for a functional system, I found 2 : Armbian_23.05.0-trunk_Bananapim2ultra_jammy_current_6.1.24.img.xz Armbian_23.08.0-trunk_Bananapim2ultra_bookworm_current_6.1.37_xfce_desktop.img.xz However, if you upgrade the system on this image to the latest, it will result in an unbootable system again. So you need to prevent kernel and U-Boot from upgrades. Edited Monday at 09:55 AM by technik007_cz 0 Quote
eselarm Posted Monday at 10:26 AM Posted Monday at 10:26 AM (edited) @technik007_cz I see I also posted here, I initially thought the problem was in kernel or initrd or armbian scripts, but it turned out HW related (power). Is all sorted now and all understood and also situation for my ROCK3A is very different now. And also ROCK3A is Rockchip, BPiM2ultra is Allwinner. What is common it seems is that the storage device where the rootfs is on is unavailable to the kernel+initrd. If you have a running Armbian system and you do apt update && apt full-upgrade, you get new kernel and new u-boot if those packages are updated. BUT, the U-Boot blob is not written to storage device automatically, so this seems like a problem as I have had and seen various times before: older U-Boot and newer kernel. As you also it have a non-working with a pre-installed/pre-generated image, the problem is also there its seems. However, it needs more details. You need U-Boot log and kernel log posting here. Attach a serial console cable and set kernel loglevel to 7 Just for (my) reference, the board is this: https://wiki.banana-pi.org/Getting_Started_with_M2_Ultra_%26_Berry Edited Monday at 10:28 AM by eselarm 0 Quote
technik007_cz Posted Monday at 10:54 AM Posted Monday at 10:54 AM I is not looking like a powering issue, see the first pic. 0 Quote
technik007_cz Posted Monday at 01:06 PM Posted Monday at 01:06 PM (edited) Just found out after upgrading everything on Armbian_23.05.0-trunk_Bananapim2ultra_jammy_current_6.1.24.img.xz, there is no way back once it stops booting. Tried the lowest legacy kernel and also sunxi u-boot and legacy u-boot, everything in chroot, and no success. So I need to start again, reflash the image and prevent the kernel and u-boot upgrades via armbian-config. Is it everything after kernel 6.1.24 when it breaks? Actually, it should be after 6.1.37, which is part of another functional system image. Edited Monday at 01:09 PM by technik007_cz 0 Quote
technik007_cz Posted Monday at 02:33 PM Posted Monday at 02:33 PM Just doing upgrades 2nd time on the same image, and it upgraded u-boot and linux-image regardless of armbian-utility put them on hold... I will try to get the kernel from the original image, but if it fails due to the u-boot version difference, I will need to flash it 3rd time, and then I will prevent it from upgrades on these essential packages, like Back In Time. 0 Quote
technik007_cz Posted Monday at 02:48 PM Posted Monday at 02:48 PM (edited) When I replaced 6.12.58-current-sunxi with armbian-utility to 6.6.16-current-sunxi It did not fully boot up again. Hopefully, replacing the whole content of /boot with the 6.1.24-sunxi kernel from the original image worked and brought m2u back to life. Also, the related modules folder was transferred. So it looks like it is a kernel problem. Edited Monday at 02:48 PM by technik007_cz 0 Quote
technik007_cz Posted 16 hours ago Posted 16 hours ago I am getting closer to resolving this issue ... I took the latest image Armbian_community_26.2.0-trunk.732_Bananapim2ultra_noble_current_6.18.22_xfce_desktop.img.xz, flashed it, and it hung on Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems Removed microsd and replaced file sun8i-r40-bananapi-m2-ultra.dtb in /boot-dtb folder with file supplied with linux-image-6.1.24-sunxi kernel. And do you know what ? It successfully booted up after this change! 0 Quote
eselarm Posted 7 hours ago Posted 7 hours ago It would save you (and others) a lot of time if you would have a USB serial console/debug cable and with verbosity=7 in armbianEnv.txt I actually only got triggered because of 'Btrfs' in the topic title, but it might be a totally unrelated issue. Also note that besides the kernel provided .dtb file (is in /boot/dtb but and same file is also somewhere in /usr/lib/linux-image-<KVER> ), U-Boot has its own DeviceTree version/variant. Might be older, newer, broken, incomplete, vendor, mainline, patched, custom. So what U-Boot is loaded/used, also is important to know. Extract that info from SD-card where the U-Boot blob is written (sits at fixed sector offset, between partition table and 1st partition). You can look into U-Boot writing scripts to get to know the offset for Allwinner, but something like this is quicker: Quote sudo dd if=/dev/mmcblk0 count=32k | strings | grep "U-Boot SPL" 0 Quote
technik007_cz Posted 6 hours ago Posted 6 hours ago root@bpim2u:~# sudo dd if=/dev/mmcblk0 count=32k | strings | grep "U-Boot SPL" U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Hadc5-Vc46c-B2eb2-R448a (Feb 20 2026 - 04:58:43 +0000) 0 Quote
eselarm Posted 5 hours ago Posted 5 hours ago (edited) 21 minutes ago, technik007_cz said: U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Hadc5-Vc46c-B2eb2-R448a (Feb 20 2026 - 04:58:43 +0000) That is at least the same base release (2024.01) from U-Boot as my Allwinner H3 boards, but old 32-bit ones. If it would be something like 2017.09 that would point to vendor legacy as older Rockchips might still use that. So I think you would need to look at live kernel logs at power-on and see where it stalls. It might be for example a swap in mmcblk numbers (SD-card v.s. eMMC), just an example. I have also seen many things related to powering as well, or some clock wrong (maybe too high for storage HW, whatever). USB serial console/debug cables cost about 1 euro nowadays, so I once just ordered 10-pack, standard connected one to most SBC's. Edited 5 hours ago by eselarm 0 Quote
technik007_cz Posted 4 hours ago Posted 4 hours ago (edited) Bootlog with non-working and working dtb file. bootlog-OK.txt bootlog-NOK.txt Edited 4 hours ago by technik007_cz 0 Quote
technik007_cz Posted 4 hours ago Posted 4 hours ago (edited) After inspecting the differences between those 2 bootlogs, it looks like it hangs up for some reason when trying to check the root filesystem for errors. Edited 4 hours ago by technik007_cz 0 Quote
eselarm Posted 3 hours ago Posted 3 hours ago 1 hour ago, technik007_cz said: Bootlog with non-working and working dtb file. The bootlog-OK.txt shows: [ 10.796728] Unable to handle kernel NULL pointer dereference at virtual address 00000000 when read which is not good at all. I also think you think you still not have set verbosity=7 in armbianEnv.txt, else the both the OK and NOK logs would show more and that is needed as a start for further investigation. 0 Quote
technik007_cz Posted 3 hours ago Posted 3 hours ago logs with verbosity=7 BOOTLOG-NOK.TXT BOOTLOG-OK.TXT 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago Both logs show initial timestamped text, then the same again non-timestamped. That is something fundamentally wrong. You can de-compile and compared DTB files but it might not reveal why it fails. Btrfs might by just un-related. I see in the NOK log a disabling of an LDO, might be on purpose but also because code is just corrupted somehow. I do not have this BPIM2U board, so no way to see if same would happen for me. Hope someone else can reproduce, else use older kernel that does not fail. 0 Quote
technik007_cz Posted 1 hour ago Posted 1 hour ago For that dts file must be changelog somewhere explaining changes. I decompiled both dts files but it is hard for me to decode changes in short time. 0 Quote
eselarm Posted 1 hour ago Posted 1 hour ago You need to look into github changes then, everything is traceable, but certainly not an easy and quick thing to do. 0 Quote
