zeljko Posted September 18, 2017 Posted September 18, 2017 install to Orange pi zero plus2 H5 Armbian_5.32.170706_Orangepizeroplus2-h5_Ubuntu_xenial_dev_4.11.8.img install tasksel and lubuntu and LXDE #: speaker-test NOT WORK AUDIO HDMI work to audo board #: applay -l card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 please my help!
Igor Posted September 18, 2017 Posted September 18, 2017 We can't help. Not developed or implemented yet.
Muhammad Rizqi E Posted February 3, 2018 Posted February 3, 2018 yea, I had that issues too, my audio is not working even tried both HDMI and 3.5mm port. but I found out the solution that my sound is working using USB sound card. give it a try! 1
guidol Posted February 3, 2018 Posted February 3, 2018 On 18/09/2017 at 9:14 PM, Igor said: We can't help. Not developed or implemented yet. Is the analog Audio on the Orange pi zero plus2 H5 not the same as on the Orange Pi Zero Plus(without2) H5? On my Orange Pi Zero Plus(without2) H5 I got also: root@opi-zeroplus:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 My /etc/asound.conf is: pcm.!default { type hw card 0 device 0 } ctl.!default { type hw card 0 } I activated the analog audio (named analog-codec) in armbian-config --> system --> hardware and save/reboot to activate. (has to be done, because normally there is no audio port...only after adding the additionall USB/Audio/Video-Dock) After installing espeak (apt install espeak) I could let the H5 talk via: espeak -w /tmp/espeak.wav -s150 "Hello how are you today?"; aplay -D plughw:0,0 /tmp/espeak.wav 2>/dev/null So analog sound should work with the H3 Audio Codec on a H5 device HDMI couldnt be checked by me, because my Orange Pi Zero Plus(without2) H5 hasnt HDMI-Audio/Video
