ずっと一人 Posted May 26 Posted May 26 I have built and used it with the latest source and still HDMI audio and analog audio does not work. Is there any way to get HDMI audio to work other than using the vendor kernel? 0 Quote
Werner Posted May 26 Posted May 26 May work once rockchip64 has been bumped to 6.15 https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md 0 Quote
Guest Posted May 26 Posted May 26 The hardware driver support listed at Collabora in the Linux kernel will have nothing to do with the Linux distro base, like Debian or Ubuntu? 0 Quote
ずっと一人 Posted May 27 Author Posted May 27 I built and tested it with the rc version of kernel 6.15 it works. Waiting for Armbian to support 6.15😄 0 Quote
ricardo_brz Posted June 1 Posted June 1 Armbian already is! uname -a Linux orangepi5-plus 6.15.0-edge-rockchip64 #1 SMP PREEMPT Sun May 25 23:09:23 UTC 2025 aarch64 GNU/Linux Itś on edge, but it's working fine here, apart from the analog audio... 0 Quote
EricaLina Posted June 4 Posted June 4 That doesn't work then. The point is to get audio working. We still have a bit of a wait until a proper 6.15 kernel is there. 0 Quote
Werner Posted June 4 Posted June 4 HDMI audio has been merged into 6.15. Board may need additional device tree nodes to make it work. Analog audio should work already as well bug may also need additional nodes. Collabora sent for Rock5B and 5B+ only upstream. https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md 0 Quote
ricardo_brz Posted June 6 Posted June 6 (edited) I think I wasn't clear: HDMI audio is working, built-in audio is not. I'm using the latest edge image from Armbian that is 6.15. It's strange that I can see in Gnome Config the audio ports correctly HDMI and Built-In. Edited June 6 by ricardo_brz 0 Quote
Igor Posted June 6 Posted June 6 19 minutes ago, ricardo_brz said: built-in audio is not I think this is handled with overlay "audio" "analogue" or something similar. https://docs.armbian.com/User-Guide_Armbian-Config/System/#device-tree-overlays 0 Quote
The Tall Man Posted August 16 Posted August 16 (edited) ES-8388 Analog Audio Works At Fractional Volume (a possible solution) The issue of no ES-8388 analog audio output has been dragging on for months, and in all three kernel flavors (vendor, mainline, edge). I've discovered, at least with the latest edge kernel (as of Armbian 25.8.1 today), that the audio through the ES-8388 IS actually coming out, and the sound is clear. It's just that the volume that can be heard is extremely low and barely perceptible if all volume controls are maxed out and the audio file itself is at full volume range. This Bug Is From The Kernel / Driver Development Before It Gets To Armbian This is not new, I'd discovered this earlier and on other operating systems as well. So I know the issue is coming from the kernel / driver development, before it gets to Armbian. My Thought: The Audio Is Bit-Shifted by 7 or 8 bits I would venture an educated guess that the audio is 1/128 or 1/256 the correct levels (i.e. bit-shifted by 7 or 8 bits). This could be caused by, for example, a 24-bit audio integer value being copied into a 32-bit integer buffer without bit-shifting by 8 bits to align the MSBs (most significant bytes). The sign bit could be why it may be 7 instead of 8. The Easy Fix (for someone familiar w/ the source code) If this is the case, then someone familiar with the source code, who knows where this is - it would be a real simple fix. On Fedora KDE, I was able to crank up the volume even beyond max settings to try to make it louder, and it got clamped instead. My thought is that this confirms that the issue is the final mix is going to the device, which would make sense. Edited August 16 by The Tall Man 0 Quote
Igor Posted August 16 Posted August 16 51 minutes ago, The Tall Man said: on other operating systems as well 51 minutes ago, The Tall Man said: Before It Gets To Armbian Armbian is Debian or Ubuntu with focus into hardware support. https://docs.armbian.com/#what-is-armbian Many operating systems in this segment are derived or use Armbian kernel (development & support) maintained by our team and surrounding community. I do agree with your findings, but this is expected in this world. Achieving and keeping full functionality on custom hardware is hard without substantiation investments or big enough crowd of volunteers / random people that knows special stuff. Both is limited. 51 minutes ago, The Tall Man said: I would venture an educated guess that the audio is 1/128 or 1/256 the correct levels ALSA is a complex part of engineering that I only understand to some small degree. For most people, including me - is hard to comment. I hope your findings are valuable for someone that knows where to look. 51 minutes ago, The Tall Man said: then someone familiar with the source code, who knows where this is - it would be a real simple fix Isn't always like this? Sadly, in most cases, problems are solved by investing time for research - code / structure complexity is often extreme, also for people that live source code. Welcome to Armbian forum! 0 Quote
The Tall Man Posted August 17 Posted August 17 (edited) On 8/16/2025 at 2:20 AM, Igor said: Welcome to Armbian forum! Thanks!! On 8/16/2025 at 2:20 AM, Igor said: Armbian is Debian or Ubuntu with focus into hardware support. https://docs.armbian.com/#what-is-armbian Many operating systems in this segment are derived or use Armbian kernel (development & support) maintained by our team and surrounding community. Thanks for the overview. ES8388 Codec Driver Something to add to my previous comment here (2 comments up). I've noticed that, with the edge kernel, ALSA calls the ES8388 the 8328 instead. I've also seen the 8328 referenced in the devicetree .dtb file (via a hex viewer). I happened across where it appears to be, in two repositories: https://github.com/armbian/linux-rockchip/tree/rk-6.1-rkr5.1/sound/soc/codecs https://github.com/torvalds/linux/tree/master/sound/soc/codecs In both of those directories, there is an es8328.c, es8328.h and other es-... numbers in that range, but no es8388 file. To any developer reading this, it might be worthwhile to create es8388.h and es8388.c as copies of their respective es8328 counterparts, then have the es8388 files used in the build and referenced in the devicetrees instead of the es8328. This would create the clear (and correct) workspace to make the necessary modification(s) to fix the issue (of the volume apparently being right-shifted by 7 or 8 bits - re my previous comment). I've noticed in the es8328.h file, there are several configuration constants defined. It could be as simple as modifying one of those in the es8388.h to match the actual es8388 codec. Hardware Datasheets / Schematics While these are likely more low-level and off the path than practically useful for the simple fix that's likely needed here, it's good to have the datasheets available in one's toolbox: Everest-Semi (ES) Hardware Datasheet For ES8388: http://www.everest-semi.com/pdf/ES8388 DS.pdf Orange PI 5 Plus Schematic: I don't see how the way they have this schematic formatted would be of much practical use to anyone, but the ES8388 is on page 29. I didn't find any interface between it and the RK3588 there or on any other pages. There's a link to the schematic on this page, under Official Resources: http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-Pi-5-plus-32GB.html Edited August 17 by The Tall Man 0 Quote
dimaxus Posted Friday at 08:30 PM Posted Friday at 08:30 PM The most interesting thing is that everything works fine for joshua-riek Ubuntu 24.04 with the 6.1 kernel https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html 0 Quote
The Tall Man Posted Friday at 09:54 PM Posted Friday at 09:54 PM 1 hour ago, dimaxus said: The most interesting thing is that everything works fine for joshua-riek Ubuntu 24.04 with the 6.1 kernel Thanks, I am aware of that. But that's an Ubuntu that's using the barebones vendor kernel. I need a fuller kernel than that, and Debian. As it turns out, in looking at recent updates here, it looks like the audio issue has been addressed within the past few days, and that it's an easy fix (as I thought it would be): https://patchwork.kernel.org/project/linux-rockchip/list/ I have yet to try that out, but it looks like I can either wait for the update in the bleeding edge kernel (if it's not already present) or modify the devicetree myself with the fix they discovered. 0 Quote
dimaxus Posted Saturday at 11:16 AM Posted Saturday at 11:16 AM If you can solve the problem, please share it with the community. 0 Quote
The Tall Man Posted Saturday at 08:35 PM Posted Saturday at 08:35 PM 9 hours ago, dimaxus said: If you can solve the problem, please share it with the community. It's already been my intention to do so. 0 Quote
Solution The Tall Man Posted yesterday at 07:40 AM Solution Posted yesterday at 07:40 AM (edited) I Did It! I Got It Working!! ES8388 Analog Audio Output Here's How (this is very easy to do): It just involves making one simple modification to the devicetree. Note: I did this with the Edge kernel. My guess is that it will also work with the Current kernel. You can also try the Vendor kernel if its devicetree has the same code. Update: I've addressed the Current and Vendor kernels in this comment below: https://forum.armbian.com/topic/52118-hdmi-audio-and-analog-audio-do-not-work-on-opi5plus/#findComment-225009 I manually applied this patch: https://patchwork.kernel.org/project/linux-rockchip/patch/20250823-orangepi5-v1-1-ae77dd0e06d7@hotmail.com/ If you scroll to the bottom where it gives the patch, the GPIO_ACTIVE_LOW needs to be changed to GPIO_ACTIVE_HIGH in the given section of the devicetree. Here's the simple / quick way to fix it, without having to go through any lengthy (re)builds. Modify the already installed devicetree file (/boot/dtb/rockchip/rk3588-orangepi-5-plus.dtb). 1. Install the package: device-tree-compiler 2. Backup the original, and convert to .dts format as follows: # Go to your devicetree directory cd /boot/dtb/rockchip/ # Make a backup of your original devicetree: sudo cp rk3588-orangepi-5-plus.dtb rk3588-orangepi-5-plus.dtb.bak # Use device-tree-compiler to convert the file from the binary .dtb format to source (text) .dts format (ignore the warnings) sudo dtc -I dtb -O dts -o rk3588-orangepi-5-plus.dts rk3588-orangepi-5-plus.dtb # Safety-Check Part 1: Convert right back to .dtb format (another filename), ignore the warnings. sudo dtc -O dtb -I dts -o rk3588-orangepi-5-plus-test.dtb rk3588-orangepi-5-plus.dts # Safety-Check Part 2: Compare the newly converted file with the original. They should be identical (this command should produce no output) cmp -l rk3588-orangepi-5-plus-test.dtb rk3588-orangepi-5-plus.dtb 3. Using a text editor in sudo mode, edit the source (text) file: rk3588-orangepi-5-plus.dts Search for this phrase: simple-audio-card,hp-det-gpios I should appear exactly once in the file. # Here is what that line looks like (for me): simple-audio-card,hp-det-gpios = <0x133 0x1b 0x01>; # This is that same line before original compilation simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; 4. Notice between the brackets, there are 3 values, separated by spaces. The third value is the value to modify from GPIO_ACTIVE_LOW to GPIO_ACTIVE_HIGH, or for us, from 0x01 to 0x00. 5. Convert your modified .dts file to a .dtb file (ignore the warnings): sudo dtc -O dtb -I dts -o rk3588-orangepi-5-plus-fixed.dtb rk3588-orangepi-5-plus.dts # Optional: Quick Comparison Check (this should output exactly 1 line with 3 numbers: [big number] 0 1) cmp -l rk3588-orangepi-5-plus-fixed.dtb rk3588-orangepi-5-plus.dtb 6. Copy the new fixed file to (overwriting) your original: sudo cp rk3588-orangepi-5-plus-fixed.dtb rk3588-orangepi-5-plus.dtb 7. Reboot (and have ES8388 analog audio out). Note: Whenever you do a kernel change or update, you will need to repeat this process until the Armbian kernel updates catch up with this patch. Here's the lengthier explanation (this is repeatable if you want to check it out yourself) 1. I downloaded the source code for version 25.8.1: https://github.com/armbian/build/releases/tag/v25.8.1 2. I extracted the archive and started the building process (./compile.sh) with the edge kernel (and a desktop image). It would not build because it rejected two of the kernel patches, but it did download everything into the cache. 3. I then found the file described in the patch: ./build-25.8.1/cache/sources/linux-kernel-worktree/6.16__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts 4. In that file, I searched for the line indicated in the patch, just prior to the line to modify: simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; ...and found the appropriate section. I confirmed the line that followed matched the original (incorrect) version mentioned in the patch entry. 5. I then scrolled to the top of the .dts file and looked at the files #included, to find where the GPIO_ACTIVE_LOW macro was defined. I figured dt-bindings/gpio/gpio.h was a reasonable place to look first. I found it here: ./build-25.8.1/cache/sources/linux-kernel-worktree/6.16__rockchip64__arm64/include/dt-bindings/gpio/gpio.h Near the top of the file were these #defines: /* Bit 0 express polarity */ #define GPIO_ACTIVE_HIGH 0 #define GPIO_ACTIVE_LOW 1 6. See the simple fix above for the rest. Tags: @Werner, @Igor, @laibsch @dimaxus, @EricaLina, @ricardo_brz, @eselarm Edited 9 hours ago by The Tall Man 1 Quote
laibsch Posted 19 hours ago Posted 19 hours ago Wow, that is awesome and thank you so much for sharing your findings. Let's get this applied in our repo for the benefit of all Armbian users. 1 Quote
laibsch Posted 15 hours ago Posted 15 hours ago Anybody here with the Opi 5 Pro? Does it need the same change? https://github.com/armbian/build/pull/8568 1 Quote
The Tall Man Posted 13 hours ago Posted 13 hours ago (edited) 8 hours ago, laibsch said: Let's get this applied in our repo for the benefit of all Armbian users. Awesome! Thanks so much!! 8 hours ago, laibsch said: Wow, that is awesome and thank you so much for sharing your findings. You're welcome! 5 hours ago, laibsch said: https://github.com/armbian/build/pull/8568 The kernel.org audio patch by Maud Spierings is as follows: Source: https://patchwork.kernel.org/project/linux-rockchip/patch/20250823-orangepi5-v1-1-ae77dd0e06d7@hotmail.com/ ./arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts &analog_sound { pinctrl-names = "default"; pinctrl-0 = <&hp_detect>; simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; - simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; + simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; simple-audio-card,widgets = "Microphone", "Onboard Microphone", "Microphone", "Microphone Jack", Edited 10 hours ago by The Tall Man 0 Quote
laibsch Posted 12 hours ago Posted 12 hours ago Thank you for having a look and catching my mistake. I have marked the PR as still work-in-progress for now while I look into where to patch this correctly in Armbian itself. 1 Quote
The Tall Man Posted 12 hours ago Posted 12 hours ago (edited) 27 minutes ago, laibsch said: Thank you for having a look and catching my mistake. I have marked the PR as still work-in-progress for now while I look into where to patch this correctly in Armbian itself. Well that's one thing that confuses me with Linux source code - is having so many different versions of the same file, how to tell which one: location, version type, and especially which repository. Thanks so much for acting right away to get this fix into the Armbian!! Edited 12 hours ago by The Tall Man 0 Quote
The Tall Man Posted 9 hours ago Posted 9 hours ago (edited) Additional Info: The "Current" Kernel I found the equivalent code in the Current kernel. It is a clearly a different version of the file, but it looks like the same error is present. I have not tested it. Snippet Source: ./build/cache/sources/linux-kernel-worktree/6.12__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts &analog_sound { pinctrl-names = "default"; pinctrl-0 = <&hp_detect>; simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; // This line here: Change GPIO_ACTIVE_LOW to GPIO_ACTIVE_HIGH simple-audio-card,widgets = "Microphone", "Onboard Microphone", "Microphone", "Microphone Jack", "Speaker", "Speaker", "Headphone", "Headphones"; The "Vendor" Kernel I found the equivalent code in the Vendor kernel's devicetree. It is also a clearly different version of the file from the other two kernel trees. But it looks like this particular coding error (for the audio) is not present here. The headphone detection level is set to GPIO_ACTIVE_HIGH. Source: ./build/cache/sources/linux-kernel-worktree/6.1__rk35xx__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts However in my experience (tested again just now with version 28.5.1), the Vendor kernel seems a bit crippled: No GPU or video acceleration, and no ES8388 analog audio whatsoever (not even at the ultra-low volume I was getting with the Edge kernel). At least the screen, keyboard, mouse, and ethernet works, but with no video acceleration the video is slow and clumsy (in gnome). I suspect that the best place to look for the audio issue with the Vendor kernel is not to focus on the audio, so much as to focus on what broke on an apparently deeper level. Edited 8 hours ago by The Tall Man 0 Quote
