Lope Posted September 25, 2017 Posted September 25, 2017 I'm testing the nightly image: Armbian_5.32.170704_Nanopineo2_Ubuntu_xenial_dev_4.11.8.img I've soldered 2x female A USB ports to the NanoPi Neo2 as per the pinout http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO2#Diagram.2C_Layout_and_Dimension When I plugged in wifi dongles or USB flash drives, their light comes on, but I get nothing on lsusb and dmesg. Then I realized I had D+ and D- reversed, so I swapped them for each port, but there's still absolutely nothing when connecting devices to these ports. (I know that having D+ and D- swapped doesn't cause any damage) Do I need to somehow enable the USB ports in a fex file or in the kernel etc?
Igor Posted September 25, 2017 Posted September 25, 2017 1 minute ago, Lope said: Do I need to somehow enable the USB ports Yes. https://docs.armbian.com/User-Guide_Allwinner_overlays/ Untested - not for end users yet.
Lope Posted September 25, 2017 Author Posted September 25, 2017 Thanks for the quick reply Igor, amazing. I found /boot/dtb/allwinner/overlay sun50i-h5-usbhost0.dtbo sun50i-h5-usbhost2.dtbo sun50i-h5-usbhost3.dtbo These 3 files are all in binary format. Any more hints will be appreciated. Is there a similar board I can look at for an example? I'm busy working through the link you gave I've read through /boot/dtb/allwinner/overlay/README.sun50i-h5-overlays but just mentions the above 3 usb host ports (a bit strange because the h5 has at least 4 usb ports that I know of) ... unless the microUSB port is not included in these.
Igor Posted September 25, 2017 Posted September 25, 2017 6 minutes ago, Lope said: Any more hints will be appreciated. Just read the documentation.
Lope Posted September 25, 2017 Author Posted September 25, 2017 Thanks, I added overlays=usbhost0 usbhost2 usbhost3 to /boot/armbianEnv.txt so it looks like this verbosity=1 console=both overlay_prefix=sun50i-h5 rootdev=UUID=c9cfe2c8-bfa6-421a-badc-4e58e9288de2 rootfstype=ext4 overlays=usbhost0 usbhost2 usbhost3 And uboot showed U-boot loaded from SD Boot script loaded from mmc 152 bytes read in 151 ms (1000 Bytes/s) 24232 bytes read in 354 ms (66.4 KiB/s) 385 bytes read in 407 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost0.dtbo 385 bytes read in 399 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo 385 bytes read in 390 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost3.dtbo 4179 bytes read in 369 ms (10.7 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 5001817 bytes read in 440 ms (10.8 MiB/s) 12285960 bytes read in 869 ms (13.5 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... And now when I plugin USB devices into the female USB A cables I've soldered to the PCB as per http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO2#Diagram.2C_Layout_and_Dimension to the port labelled "USB1" I get nothing, but for the port labelled "USB2" I get [ 156.201286] usb 5-1: device descriptor read/64, error -62 [ 156.497302] usb 5-1: device descriptor read/64, error -62 [ 156.973314] usb 5-1: device descriptor read/64, error -62 [ 157.269327] usb 5-1: device descriptor read/64, error -62 [ 157.977369] usb 5-1: device not accepting address 20, error -62 [ 158.577391] usb 5-1: device not accepting address 21, error -62 [ 158.583375] usb usb5-port1: unable to enumerate USB device So at least there are signs of life for one USB port. I'm going to check my solder joints again. ==== microUSB port didn't work When powering the NanoPi2 via the UART 5v line from USB (it was a bit underpowered, voltage sagged down to 4.64) I plugged a (tested working) USB OTG cable into the microUSB and nothing I connected showed up in dmesg. (for all other tests, the board was powered with 2A microUSB) The "USB1" (as shown in the pinout diagram) headers were unresponsive in all cases. How to know that your D+ and D- are backwards I noticed my soldering had left a bit of flux behind on the board, after scratching it off I got a different error in dmesg [ 115.875561] usb 5-1: new low-speed USB device number 2 using ohci-platform [ 116.059563] usb 5-1: device descriptor read/64, error -62 [ 116.355565] usb 5-1: device descriptor read/64, error -62 [ 116.647578] usb 5-1: new low-speed USB device number 3 using ohci-platform [ 116.831581] usb 5-1: device descriptor read/64, error -62 [ 117.127593] usb 5-1: device descriptor read/64, error -62 [ 117.419605] usb 5-1: new low-speed USB device number 4 using ohci-platform [ 117.835618] usb 5-1: device not accepting address 4, error -62 [ 118.019628] usb 5-1: new low-speed USB device number 5 using ohci-platform [ 118.435638] usb 5-1: device not accepting address 5, error -62 [ 118.441516] usb usb5-port1: unable to enumerate USB device Then I swapped D+ and D- and the "USB2" port worked! Having 2 working USB ports is enough progress for me, for now. I'm going to leave this issue as is for now. ==== BTW I also found that with a 5 meter USB extension cable and a hub on the end of it, I couldn't connect 2 wifi adapters to the female USB A port. But if I connect the hub directly to the port I can connect 2 wifi adapters. 1
guidol Posted October 27, 2017 Posted October 27, 2017 @Lope did wrote: I found /boot/dtb/allwinner/overlay sun50i-h5-usbhost0.dtbo sun50i-h5-usbhost2.dtbo sun50i-h5-usbhost3.dtbo I've read through /boot/dtb/allwinner/overlay/README.sun50i-h5-overlays but just mentions the above 3 usb host ports (a bit strange because the h5 has at least 4 usb ports that I know of) ... unless the microUSB port is not included in these. The "USB1" (as shown in the pinout diagram) headers were unresponsive in all cases. @Igor at https://github.com/armbian/sunxi-DT-overlays/tree/master/sun50i-h5 is stated that there could be also a sun50i-h5-usbhost1 but at this page are only .dts files. Do you know where I could find the sun50i-h5-usbhost1.dtbo (isnt in /boot/dtb/allwinner/overlay) because at the NAS Station from FriendlyARM there is in the front a USB Port which doenst seems to be activated) and I think this could the the USB1-Port. FriendlyARM has a Neo2 NAS Image ( http://www.mediafire.com/file/sgdbfv004jihb6e/nanopi-neo2_debian-nas-jessie_4.11.2_20170904.img.zip ) , but it seems that there all dtb's in one: sun50i-h5-nanopi-neo2.dtb because inside the binary I could see as ASCI usb0 usb1 usb2 and usb3
guidol Posted October 27, 2017 Posted October 27, 2017 I did a binary compare to the file sun50i-h5-usbhost0.dtbo <==> sun50i-h5-usbhost2.dtbo and sun50i-h5-usbhost0.dtbo <==> sun50i-h5-usbhost3.dtbo with diff -y <(sun50i-h5-usbhost0.dtbo) <(sun50i-h5-usbhost2.dtbo) | colordiff and they did differ only 2 times in the file with the current usb-number. So I did create (with a hex-editor) a file with USB1 = sun50i-h5-usbhost1.dtbo copied this over to the Neo2 and added it to the /boot/armbianEnv.txt In the serial log I did see that u-boot is accessing the new file, but the Neo2 doesnt recognize the USB-Gadgets on this port Devices now get power at this port - but not more signs of life.... Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 220 ms (13.7 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 210 bytes read in 191 ms (1000 Bytes/s) 28577 bytes read in 471 ms (58.6 KiB/s) 504 bytes read in 473 ms (1000 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost0.dtbo 504 bytes read in 699 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost1.dtbo 504 bytes read in 464 ms (1000 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo 504 bytes read in 456 ms (1000 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost3.dtbo 4179 bytes read in 436 ms (8.8 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 5258115 bytes read in 504 ms (9.9 MiB/s) 12957704 bytes read in 942 ms (13.1 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... root@nanoneo2:/boot/dtb-4.13.9-sunxi64/allwinner/overlay# diff -y <(xxd sun50i-h5-usbhost0.dtbo) <(xxd sun50i-h5-usbhost2.dtbo) | colordiff sun50i-h5-usbhost0.dtbo <==> sun50i-h5-usbhost2.dtbo 000001e0: 6174 7573 0075 7362 7068 7900 6568 6369 atus.usbph 000001e0: 6174 7573 0075 7362 7068 7900 6568 6369 atus.usbph 000001f0: 3000 6f68 6369 3000 0.ohci0. | 000001f0: 3200 6f68 6369 3200 2.ohci2. sun50i-h5-usbhost0.dtbo <==> sun50i-h5-usbhost3.dtbo 000001e0: 6174 7573 0075 7362 7068 7900 6568 6369 atus.usbph 000001e0: 6174 7573 0075 7362 7068 7900 6568 6369 atus.usbph 000001f0: 3000 6f68 6369 3000 0.ohci0. | 000001f0: 3300 6f68 6369 3300 3.ohci3. sun50i-h5-usbhost1.dtbo
guidol Posted October 28, 2017 Posted October 28, 2017 to check that my Neo2 hardware isnt defective - I did try the NAS Image from FriendlyARM/-Elec and the right USB Port in the Front does work with their image.... With their image debian is counting 9 usb-bus: [ 0.024594] usbcore: registered new interface driver usbfs [ 0.024630] usbcore: registered new interface driver hub [ 0.024686] usbcore: registered new device driver usb [ 1.340478] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.352368] ehci-platform 1c1a000.usb: EHCI Host Controller [ 1.357959] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 [ 1.366055] ehci-platform 1c1a000.usb: irq 11, io mem 0x01c1a000 [ 1.386236] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 [ 1.392984] hub 1-0:1.0: USB hub found [ 1.401229] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.412794] ohci-platform 1c1a400.usb: Generic Platform OHCI controller [ 1.419426] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 [ 1.427348] ohci-platform 1c1a400.usb: irq 12, io mem 0x01c1a400 [ 1.494797] hub 2-0:1.0: USB hub found [ 1.503044] usbcore: registered new interface driver uas [ 1.508432] usbcore: registered new interface driver usb-storage [ 1.650596] usbcore: registered new interface driver usbhid [ 1.656179] usbhid: USB HID core driver [ 1.961907] ehci-platform 1c1b000.usb: EHCI Host Controller [ 1.967512] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 [ 1.975507] ehci-platform 1c1b000.usb: irq 13, io mem 0x01c1b000 [ 1.994232] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 [ 2.000969] hub 3-0:1.0: USB hub found [ 2.009173] ehci-platform 1c1c000.usb: EHCI Host Controller [ 2.014771] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 [ 2.022702] ehci-platform 1c1c000.usb: irq 15, io mem 0x01c1c000 [ 2.042241] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 2.048826] hub 4-0:1.0: USB hub found [ 2.056986] ehci-platform 1c1d000.usb: EHCI Host Controller [ 2.062575] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5 [ 2.070487] ehci-platform 1c1d000.usb: irq 17, io mem 0x01c1d000 [ 2.090240] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 [ 2.090737] hub 5-0:1.0: USB hub found [ 2.091197] ohci-platform 1c1b400.usb: Generic Platform OHCI controller [ 2.091213] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 [ 2.091337] ohci-platform 1c1b400.usb: irq 14, io mem 0x01c1b400 [ 2.154723] hub 6-0:1.0: USB hub found [ 2.162889] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 2.169520] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7 [ 2.177389] ohci-platform 1c1c400.usb: irq 16, io mem 0x01c1c400 [ 2.246741] hub 7-0:1.0: USB hub found [ 2.254900] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 2.261533] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8 [ 2.269425] ohci-platform 1c1d400.usb: irq 18, io mem 0x01c1d400 [ 2.334244] usb 3-1: new high-speed USB device number 2 using ehci-platform [ 2.345763] hub 8-0:1.0: USB hub found [ 2.354028] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 2.364988] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 2.370746] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9 [ 2.379112] hub 9-0:1.0: USB hub found [ 2.405776] usb0-vbus: disabling root@FriendlyELEC:/mnt/harddisc/SMB_DATA_SHARE# lsusb Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub and with armbian we do "only" count 7 of 9 usb-bus: [ 0.000000] Kernel command line: root=UUID=27557920-6eb8-4277-8ed1-d112daa16d02 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 panic=10 consoleblank=0 loglevel=1 ubootpart=28528764-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory swapaccount=1 [ 1.274603] usbcore: registered new interface driver usbfs [ 1.274638] usbcore: registered new interface driver hub [ 1.274689] usbcore: registered new device driver usb [ 1.649961] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.650102] ehci-platform 1c1a000.usb: EHCI Host Controller [ 1.650125] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 [ 1.650562] ehci-platform 1c1a000.usb: irq 9, io mem 0x01c1a000 [ 1.663948] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 [ 1.664629] hub 1-0:1.0: USB hub found [ 1.665129] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.665287] ohci-platform 1c1a400.usb: Generic Platform OHCI controller [ 1.665306] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 [ 1.665479] ohci-platform 1c1a400.usb: irq 10, io mem 0x01c1a400 [ 1.728531] hub 2-0:1.0: USB hub found [ 1.729062] usbcore: registered new interface driver usb-storage [ 1.776909] usbcore: registered new interface driver usbhid [ 1.776912] usbhid: USB HID core driver [ 1.916597] ehci-platform 1c1c000.usb: EHCI Host Controller [ 1.916622] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3 [ 1.916839] ehci-platform 1c1c000.usb: irq 11, io mem 0x01c1c000 [ 1.931950] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 1.932477] hub 3-0:1.0: USB hub found [ 1.932942] ehci-platform 1c1d000.usb: EHCI Host Controller [ 1.932959] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4 [ 1.933119] ehci-platform 1c1d000.usb: irq 13, io mem 0x01c1d000 [ 1.947946] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00 [ 1.948365] hub 4-0:1.0: USB hub found [ 1.948763] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 1.948779] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 5 [ 1.948886] ohci-platform 1c1c400.usb: irq 12, io mem 0x01c1c400 [ 2.021642] hub 5-0:1.0: USB hub found [ 2.023259] ohci-platform 1c1d400.usb: Generic Platform OHCI controller [ 2.023301] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 6 [ 2.023527] ohci-platform 1c1d400.usb: irq 14, io mem 0x01c1d400 [ 2.084927] hub 6-0:1.0: USB hub found [ 2.086245] usb0-vbus: disabling [ 2.264017] usb 3-1: new high-speed USB device number 2 using ehci-platform [ 2.557267] usbcore: registered new interface driver uas [ 7.329770] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 7.330299] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 7.330316] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 7 [ 7.331824] hub 7-0:1.0: USB hub found root@nanoneo2:~# lsusb Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub counting/activating is a bit differnet because on debian (from FriedlyARM) the JMircro HDD controller is on Bus 4, while with armbian the controller (JMicron JMS567) is connected to Bus 3 (but also device 2) and musb-hdrc Bus 9 against Bus 7 For the HDD mass-storage armbian is using the newer uas-module (USB Attached SCSI) while FriendlyArm is using libcomposite/g_mass_storage/usb_f_mass_storage. UAS: http://linux-sunxi.org/USB/UAS
tkaiser Posted October 28, 2017 Posted October 28, 2017 19 hours ago, guidol said: binary compare What about using dtc (package device-tree-compiler)? Different count of USB ports is most probably related to usb0 (OTG) not enabled by Armbian while FriendlyELEC's 4.11 kernel added the necessary patches and DT bits)
guidol Posted October 28, 2017 Posted October 28, 2017 1 hour ago, tkaiser said: What about using dtc (package device-tree-compiler)? Different count of USB ports is most probably related to usb0 (OTG) not enabled by Armbian while FriendlyELEC's 4.11 kernel added the necessary patches and DT bits) Is usbhost0 <> usb0? As overlay usbhost0 is loaded: Applying kernel provided DT overlay sun50i-h5-usbhost0.dtbo 385 bytes read in 399 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo 385 bytes read in 390 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost3.dtbo 4179 bytes read in 369 ms (10.7 KiB/s) but not usbhost1 (OTG?) I did take a look athttps://github.com/armbian/sunxi-DT-overlays/tree/master/sun50i-h5 and https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-h5-nanopi-neo2.dts Impotant seems to be the part &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; status = "okay"; }; &usb_otg { dr_mode = "otg"; status = "okay"; }; &usbphy { /* USB Type-A port's VBUS is always on */ usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ usb0_vbus-supply = <®_usb0_vbus>; status = "okay"; }; but as I aslo did read otg (or a part) seems alread be enabled because of [ 7.330299] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 7.330316] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 7 [ 7.331824] hub 7-0:1.0: USB hub found I have no experience with kernel-baking and patches
Lope Posted October 31, 2017 Author Posted October 31, 2017 @guidol nice work. Don't be afraid of compiling the kernel. I've compiled kernels with modified drivers for x86_64 tons of times, never for ARM but it's just a matter of changing architecture. There must be tons of guides around. Once you've got the source tree it's a simple matter of finding the source and changing it, then compiling. It's best to cross compile from a fast PC because if you compile on an H5 etc it'll be a lot slower. On a crappy old dual core 2nd gen i7 I compiled the 4.x kernel in about 20 mins. I'd love to have 3/4 USB ports (instead of just 2/4) working but I can't get involved with it at the moment.
pzw Posted November 1, 2017 Posted November 1, 2017 Can you post a picture of your wiring etc? Usb ports are differential connections which require non-standard wiring to work reliably. You might get lucky using breadboard wiring (DuPont wires) but when it's not working do not assume your wiring is good enough...
tkaiser Posted November 1, 2017 Posted November 1, 2017 On 25.9.2017 at 3:32 PM, Lope said: overlays=usbhost0 usbhost2 usbhost3 The above is what you would do on an Orange Pi Zero or on a NanoPi Duo. On a NEO usb3 is already active so you need overlays=usbhost1 usbhost2 to get the 2 USB ports on pin headers working. For the Micro USB port please follow discussion here: https://forum.armbian.com/topic/5558-default-overlays/?tab=comments#comment-42525
guidol Posted November 1, 2017 Posted November 1, 2017 Today I did a manual compare of the USB-entrys of the dmesg. Sorting the USB-entrys to EHCI,OHCI and i-mem-address - while ignoring the usb and hub numbers (they just count upwards). And only the follwing was different, what in the other dmesg isnt included armbian <==> friendlyARM: This is only in the friendlyarm dmesg: EHCI Host Controller io mem 0x01c1b000 OHCI controller io mem 0x01c1b400 but also the chronological sequence is another ("register driver uas" and "usb0-vbus: disabling") - maybe it isnt the otg? and only the sequence loading the drivers gives a different "usb-layout"? Because in the NAS-schematic http://wiki.friendlyarm.com/wiki/images/7/7b/SCHEMATIC_1-bay_NAS_Dock_v1.2.pdf I could only found 2 USB-Ports USB-1-(Plus/Minus) and USB-2-(Plus/Minus) Also the Neo2 Pin-Out shows me for the Connection to the NAS-Board only 2 USB-Ports and the NAS-Board hasnt any additional USB-Chips on the board. This 2 code-snippets are best viewed side-by-side. armbian: usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb USB 2.0 EHCI io mem 0x01c1a000 USB 1.0 OHCI io mem 0x01c1a400 usbcore: registered new interface driver usb-storage usbcore: registered new interface driver usbhid USB 2.0 EHCI io mem 0x01c1c000 USB 2.0 EHCI io mem 0x01c1d000 USB 1.0 OHCI io mem 0x01c1c400 USB 1.0 OHCI io mem 0x01c1d400 usb0-vbus: disabling usb 3-1: new high-speed USB device number 2 using ehci-platform usbcore: registered new interface driver uas usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto found, using dummy regulator musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver musb-hdrc musb-hdrc.1.auto: new USB bus registered USB hub found and the friendlyarm-image: usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb USB 2.0 EHCI io mem 0x01c1a000 USB 1.1 OHCI io mem 0x01c1a400 usbcore: registered new interface driver uas usbcore: registered new interface driver usb-storage usbcore: registered new interface driver usbhid USB 2.0 EHCI io mem 0x01c1b000 USB 2.0 EHCI io mem 0x01c1c000 USB 2.0 EHCI io mem 0x01c1d000 USB 1.0 OHCI io mem 0x01c1b400 USB 1.0 OHCI io mem 0x01c1c400 USB 1.0 OHCI io mem 0x01c1d400 usb 3-1: new high-speed USB device number 2 using ehci-platform usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver musb-hdrc musb-hdrc.1.auto: new USB bus registered USB hub found usb0-vbus: disabling
tkaiser Posted November 1, 2017 Posted November 1, 2017 1 hour ago, guidol said: EHCI Host Controller io mem 0x01c1b000 https://github.com/friendlyarm/linux/blob/sunxi-4.11.y/arch/arm/boot/dts/sunxi-h3-h5.dtsi#L281-L290 1 hour ago, guidol said: OHCI controller io mem 0x01c1b400 https://github.com/friendlyarm/linux/blob/sunxi-4.11.y/arch/arm/boot/dts/sunxi-h3-h5.dtsi#L292-L302 That's usb1 and for whatever reasons neither @Lope nor you want to load the respective usbhost1 DT overlay in /boot/armbianEnv.txt. BTW: I hope with latest commit this will be fixed on future Armbian images. Edit: Though usb1 is disabled in sunxi-h3-h5.dtsi (as requested by sunxi kernel maintainers for reasons I really don't understand) it's enabled by FriendlyELEC in the device DT settings: https://github.com/friendlyarm/linux/blob/sunxi-4.11.y/arch/arm64/boot/dts/allwinner/sun50i-h5-nanopi-neo2.dts (and the same can be done using the usbhost1 DT overlay in Armbian)
guidol Posted November 1, 2017 Posted November 1, 2017 3 hours ago, tkaiser said: https://github.com/friendlyarm/linux/blob/sunxi-4.11.y/arch/arm/boot/dts/sunxi-h3-h5.dtsi#L281-L290 https://github.com/friendlyarm/linux/blob/sunxi-4.11.y/arch/arm/boot/dts/sunxi-h3-h5.dtsi#L292-L302 That's usb1 and for whatever reasons neither @Lope nor you want to load the respective usbhost1 DT overlay in /boot/armbianEnv.txt. BTW: I hope with latest commit this will be fixed on future Armbian images. Edit: Though usb1 is disabled in sunxi-h3-h5.dtsi (as requested by sunxi kernel maintainers for reasons I really don't understand) it's enabled by FriendlyELEC in the device DT settings: https://github.com/friendlyarm/linux/blob/sunxi-4.11.y/arch/arm64/boot/dts/allwinner/sun50i-h5-nanopi-neo2.dts (and the same can be done using the usbhost1 DT overlay in Armbian) yes - the .dtsi files above looks very fine.... I did try usbhost1 via /boot/armbianEnv.txt Applying kernel provided DT overlay sun50i-h5-usbhost1.dtbo 504 bytes read in 464 ms (1000 Bytes/s) but without success Would be fun to test the new "latest commit" when they arrive as binary We would see the difference between the sunxi maintainers ans FriendlyELEC.. PS: In near future I will use one Neo2-NAS with armbian and one with FriendlyELEC-Image, because I ordered for my 2nd Neo2 also the NAS-case For the price is a very good countervalue
tkaiser Posted November 1, 2017 Posted November 1, 2017 1 hour ago, guidol said: but without success That's bad. Thanks for reporting. Unfortunately I'm close to clueless wrt the overlay implementation so maybe we get some insights once @zador.blood.stained might look into. 1 hour ago, guidol said: Would be fun to test the new "latest commit" when they arrive as binary No, that was just adding usbhost1 to armbianEnv.txt so if your manual change followed by a reboot doesn't work the 'fix' is none (or just a preparation)
zador.blood.stained Posted November 1, 2017 Posted November 1, 2017 34 minutes ago, tkaiser said: Unfortunately I'm close to clueless wrt the overlay implementation so maybe we get some insights once @zador.blood.stained might look into. Hm. According to schematics Opi Zero+2 H5 doesn't wire USB port 1 anywhere, and Opi PC2 and Prime have USB1 enabled by default. And since I also don't see anything that would resemble an amrbianmonitor -u support link and a serial console log from u-boot I don't think I have anything I can look into. It is possible to check that overlays are applied correctly in /proc/device-tree and probably somewhere in /sys too. 1
zador.blood.stained Posted November 1, 2017 Posted November 1, 2017 OPi Zero+2 H5 overlays=usbhost2 usbhost3 root@orangepizeroplus2:~# lsusb -t /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M root@orangepizeroplus2:~# overlays=usbhost1 usbhost2 usbhost3 root@orangepizeroplus2:~# lsusb -t /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M root@orangepizeroplus2:~# Exposed ports seem to work fine for me (used a PC rear panel USB extension bracket) [ 111.555851] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 111.710539] usb-storage 2-1:1.0: USB Mass Storage device detected [ 111.711437] scsi host0: usb-storage 2-1:1.0 [ 111.726915] usbcore: registered new interface driver uas [ 113.052187] scsi 0:0:0:0: Direct-Access JetFlash Transcend 8GB 1100 PQ: 0 ANSI: 6 [ 113.053239] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 113.053709] sd 0:0:0:0: [sda] 15425536 512-byte logical blocks: (7.90 GB/7.36 GiB) [ 113.054545] sd 0:0:0:0: [sda] Write Protect is off [ 113.054557] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 113.055409] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 113.064741] sda: sda1 [ 113.068921] sd 0:0:0:0: [sda] Attached SCSI removable disk [ 113.227899] BTRFS: device fsid 00083559-80b8-4b9d-9b56-e34e6a7452b4 devid 1 transid 152 /dev/sda1
pzw Posted November 1, 2017 Posted November 1, 2017 14 hours ago, pzw said: Can you post a picture of your wiring etc? Usb ports are differential connections which require non-standard wiring to work reliably. You might get lucky using breadboard wiring (DuPont wires) but when it's not working do not assume your wiring is good enough... Can you take a photograph of your wiring?
guidol Posted November 2, 2017 Posted November 2, 2017 Here the differences by a Neo2 with 1-Bay-NAS: armbian has loaded as module: musb_hdrc, uas EHCI Bus ? - 0x01c1b000 MISSING (usbhost1 not available or hex-patched usbhost1 loaded but port not activated) EHCI Bus 3 - 0x01c1c000 FriendlyELEC has loaded the follwoing moduls for storage: libcomposite, g_mass_storage, usb_f_mass_storage but shows also musb-hdrc and uas in dmesg EHCI Bus 3 - 0x01c1b000 EHCI Bus 4 - 0x01c1c000 armbian: lsusb -t armbian (overlay usbhost2 usbhost3) root@nanoneo2:~# lsusb -t /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M [ 1.920677] ehci-platform 1c1c000.usb: EHCI Host Controller [ 1.920703] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3 [ 1.920919] ehci-platform 1c1c000.usb: irq 11, io mem 0x01c1c000 [ 1.935956] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 Module Size Used by fuse 98304 2 sun8i_codec_analog 28672 0 snd_soc_core 151552 1 sun8i_codec_analog snd_pcm_dmaengine 16384 1 snd_soc_core sun4i_gpadc_iio 16384 0 iio_hwmon 16384 0 sunxi 20480 0 musb_hdrc 94208 1 sunxi industrialio 65536 2 iio_hwmon,sun4i_gpadc_iio uas 24576 1 friendlyarm: root@FriendlyELEC:~# lsusb -t /: Bus 09.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M [ 1.961748] ehci-platform 1c1b000.usb: EHCI Host Controller [ 1.967353] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 [ 1.975350] ehci-platform 1c1b000.usb: irq 13, io mem 0x01c1b000 [ 1.994357] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 [ 2.009218] ehci-platform 1c1c000.usb: EHCI Host Controller [ 2.014815] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4 [ 2.022752] ehci-platform 1c1c000.usb: irq 15, io mem 0x01c1c000 [ 2.042369] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 root@FriendlyELEC:~# lsusb Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 058f:9380 Alcor Micro Corp. Flash Drive Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@FriendlyELEC:~# lsmod Module Size Used by ir_lirc_codec 16384 0 lirc_dev 20480 1 ir_lirc_codec sunxi_cir 16384 0 rc_core 32768 4 ir_lirc_codec,lirc_dev,sunxi_cir rtc_ds1307 20480 0 g_mass_storage 16384 0 usb_f_mass_storage 36864 2 g_mass_storage libcomposite 45056 2 g_mass_storage,usb_f_mass_storage fuse 90112 1
tkaiser Posted November 2, 2017 Posted November 2, 2017 3 minutes ago, guidol said: overlay usbhost2 usbhost3 Why? I explained a few times in the meantime that with NanoPi NEO usbhost1 is needed while usbhost3 is enabled by default anyway. And please remember what @zador.blood.stained said: 13 hours ago, zador.blood.stained said: I also don't see anything that would resemble an amrbianmonitor -u support link and a serial console log from u-boot I don't think I have anything I can look into. It is possible to check that overlays are applied correctly in /proc/device-tree and probably somewhere in /sys too
zador.blood.stained Posted November 2, 2017 Posted November 2, 2017 7 minutes ago, tkaiser said: 13 hours ago, zador.blood.stained said: It is possible to check that overlays are applied correctly in /proc/device-tree and probably somewhere in /sys too root@orangepizeroplus2:~# cat /proc/device-tree/soc/usb@01c1b000/status; echo okay root@orangepizeroplus2:~# cat /proc/device-tree/soc/usb@01c1b400/status; echo okay root@orangepizeroplus2:~#
guidol Posted November 2, 2017 Posted November 2, 2017 2 hours ago, tkaiser said: Why? I explained a few times in the meantime that with NanoPi NEO usbhost1 is needed while usbhost3 is enabled by default anyway. And please remember what @zador.blood.stained said: I did read it, but in the normal image isnt a usbhost1-overlay-file - that did I wrote more than one time. The hex-patchted usbhost1 from me is loaded via u-boot: Applying kernel provided DT overlay sun50i-h5-usbhost1.dtbo 504 bytes read in 464 ms (1000 Bytes/s) but the usbhost1 doesnt seems to be enabled: root@nanoneo2:~# cat /proc/device-tree/soc/usb@01c1b000/status; echo disabled root@nanoneo2:~# cat /proc/device-tree/soc/usb@01c1b400/status; echo disabled I also did try all usbhost alone - and could see that usbhost3 is also loaded without overlay-entry. The additional USB to usbhost3 is loaded with usbhost2 (sata JMS567), but -my- usbhost1 doesnt enbale anything (because it is disabled anywhere in the kernel) Neo2_u-boot.txt
zador.blood.stained Posted November 2, 2017 Posted November 2, 2017 33 minutes ago, guidol said: I did read it, but in the normal image isnt a usbhost1-overlay-file I just downloaded the latest (linux-dtb-next-sunxi64_5.34.171103_arm64.deb) and one of the previous (linux-dtb-next-sunxi64_5.34.171101_arm64.deb) nightly dtb packages from here and they both contain sun50i-h5-usbhost1.dtbo
guidol Posted November 2, 2017 Posted November 2, 2017 58 minutes ago, zador.blood.stained said: I just downloaded the latest (linux-dtb-next-sunxi64_5.34.171103_arm64.deb) and one of the previous (linux-dtb-next-sunxi64_5.34.171101_arm64.deb) nightly dtb packages from here and they both contain sun50i-h5-usbhost1.dtbo @zador.blood.stained Ahhhhh Well - All right! Now Iam VERY happy some time ago I downloaded the Install-Image and then updated it until 5.34.171029 nightly Ubuntu (without getting a usbhost1 via the update) After your Message I updated to 5.34.171103 nightly Ubuntu (normally I update often) and the usbhost1 is there - !and working! The frontright USB port is now working like on the FriendlyELEC Image root@nanoneo2:/# uname -a Linux nanoneo2 4.13.10-sunxi64 #89 SMP Thu Nov 2 01:57:43 CET 2017 aarch64 aarch64 aarch64 GNU/Linux root@nanoneo2:/# cat /proc/device-tree/soc/usb@01c1b000/status; echo okay root@nanoneo2:/# cat /proc/device-tree/soc/usb@01c1b400/status; echo okay root@nanoneo2:/# lsusb -t /: Bus 09.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M [ 1.934068] ehci-platform 1c1b000.usb: EHCI Host Controller [ 1.934103] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3 [ 1.934356] ehci-platform 1c1b000.usb: irq 11, io mem 0x01c1b000 [ 1.948854] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00 [ 1.981702] ohci-platform 1c1b400.usb: Generic Platform OHCI controller [ 1.981723] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6 [ 1.981850] ohci-platform 1c1b400.usb: irq 12, io mem 0x01c1b400 MANY MANY Thanks to all who have this made possible Now its time for me to spend AGAIN some money to the armbian-project @Igor [DONE!] 1
usego Posted November 15, 2017 Posted November 15, 2017 Guys, I see you are discussing something connected to the topic I'm very interested in, but unfortunately I'm not very fluent in all those things. Our project at this moment is based on NanoPi Neo2 Plus boards. We have a requirement to be able to connect NanoPi to PC directly using USB cable and organize datatransfer to/from device somehow. Is it possible for this device to act as a mass storage device or even g_ether(?) so PC could connect to Nano?
