armbuilder Posted June 10, 2025 Posted June 10, 2025 FYI latest image for rock 5B+ in downloads section is broken (Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop) Wont boot at all, previous 25.2.2 images works fine. 0 Quote
Werner Posted June 10, 2025 Posted June 10, 2025 39 minutes ago, armbuilder said: Wont boot at all https://debug.armbian.de 0 Quote
Igor Posted June 10, 2025 Posted June 10, 2025 Yeah, it was reported at GH too: https://github.com/armbian/build/issues/8227 Probably related: https://github.com/armbian/build/issues/8269 No solution yet. 0 Quote
armbuilder Posted June 10, 2025 Author Posted June 10, 2025 Are platinum supported boards not tested on actual hardware before posting images? FYI we are on of radxas big partners that paid for the platinum membership so there is better support for this board, not sure if all the USB/wifi related driver issues were fixed? 0 Quote
Igor Posted June 10, 2025 Posted June 10, 2025 1 hour ago, armbuilder said: Are platinum supported boards not tested on actual hardware before posting images? Yes, that is the main idea, but sometimes things slipped trough. Images were tested (we aim to have two people on one platinum target to be able to provide better service, but perfection is still not possible), but here we ran into weird problem that CI compilation silently broke on u-boot recompilation, while local build works. We have a problem with build framework / compiler internals, unrelated to this specific hardware and problem only manifest on some u-boot variants. Right now, I don't have a clear picture, but we are working on it. This was introduced while moving framework to Noble, which is mandatory for some targets and there are some Python libraries troubles ... which are sometimes used for u-boot / ATF compile. Its a mess. 1 hour ago, armbuilder said: not sure if all the USB/wifi related driver issues were fixed? Software maintenance within such extreme complexity is job that is never done. Generally speaking. 0 Quote
meco Posted June 10, 2025 Posted June 10, 2025 2 hours ago, armbuilder said: not sure if all the USB/wifi related driver issues were fixed 5B+ on vendor (6.1.115) has all I/O related stuff fixed (since 6.1.84) as far as my testing (the one reported in the https://www.armbian.com/rock-5b-plus/ description). Looking into the broken gnome image though and will update here! 0 Quote
meco Posted June 11, 2025 Posted June 11, 2025 @Igor Just tried with the latest image on https://dl.armbian.com/rock-5b-plus/Noble_vendor_gnome. This 100% works as I had tested, so either @armbuilder has a broken flash storage or had an error while writing to the storage medium. Gnome Desktop is working too 0 Quote
meco Posted June 14, 2025 Posted June 14, 2025 So I was able to reproduce the issue when trying to boot via NVMe after using armbian-config to switch from emmc. Using rkdeveloptool to flash the SPI with https://dl.radxa.com/rock5/sw/images/loader/rock-5b+/release/rock-5b+-spi-image-8ea7ee4-20240730.img (short guide in the spoiler) Spoiler rkdeveloptool cs 9 rkdeveloptool ef rkdeveloptool wl 0 rock-5b+-spi-image-8ea7ee4-20240730.img rkdeveloptool rd I was able to boot into the NVMe. Looking into fixing the broken SPI installation 0 Quote
armbuilder Posted June 18, 2025 Author Posted June 18, 2025 Has a fixed image been posted? Just upgraded to 25.5 from 25.2, so havent tested a new image download yet. 0 Quote
Dann Posted September 12, 2025 Posted September 12, 2025 sha256sum Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz 1b5b3f8e9f136772dd0e3b80990f7cd2ed305e34db7510ea4f4fd83d3f40b5f0 cat Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz.sha 8ebcc156f53bf8a826bba4291e8ff3fce8037be64c02b4ca59f6befbe361586c xz -t Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz xz: Armbian_25.5.1_Rock-5b_noble_vendor_6.1.115_gnome_desktop.img.xz: Unexpected end of input I tried many mirrors. It has been like this since it's May release. Torrent download also fails keeps rejecting fragments presumably due mismatching checks. Is suspect the file got corrupted somehow 0 Quote
laibsch Posted September 17, 2025 Posted September 17, 2025 @Dann https://dl.armbian.com/rock-5b-plus/Noble_vendor_gnome verifies fine for me. Try https://netcup-03.armbian.com/dl/rock-5b-plus/archive/Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop.img.xz and https://netcup-03.armbian.com/dl/rock-5b-plus/archive/Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop.img.xz.sha 0 Quote
e.j. Frölich Posted October 2, 2025 Posted October 2, 2025 (edited) I burned the image with Balena Etcher and verified it. After the first attempt it did not boot. Downloaded and burned the image a second time on a different SD card, again not booting. The green light on the board stays on. I'm a fan of Armbian. Never had issues on my RPI5. I hoped this new powerfull SBC would be the same but no, Armbian is not working and the RADXA OS also is giving me lots of problems. Sorry to say, I'm a little dissapointed... Ernst-Jan Edited October 2, 2025 by e.j. Frölich 0 Quote
Werner Posted October 3, 2025 Posted October 3, 2025 9 hours ago, e.j. Frölich said: Balena Etcher https://docs.armbian.com/User-Guide_Getting-Started/#flash-to-sd-card Quote Due to known issues, balenaEtcher can no longer be recommended as an alternative at this time. 0 Quote
e.j. Frölich Posted October 3, 2025 Posted October 3, 2025 I use Balena Etcher on my laptop running Linux Mint. It never let me down before. I understand balena Etcher on an Arm SBC is not recomended. Ernst-Jan 0 Quote
e.j. Frölich Posted November 11, 2025 Posted November 11, 2025 (edited) The Armbian Debian 12 bookworm XFCE version workes fine, also after an update! Almost everything, including the fan is working. Video is working fine except for ytube. ytube is not playable even in the lowest, 144p, framerate. it's useless. I read about 3D acceleration but I'm not sure how to get on with this. Ernst-Jan Edited November 11, 2025 by e.j. Frölich typo's 0 Quote
armbuilder Posted November 16, 2025 Author Posted November 16, 2025 Any update here? Same broken image is still linked from back in may and no update to these images since then? 0 Quote
Igor Posted November 17, 2025 Posted November 17, 2025 Try from here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ (this is going to be next release - first test build). 0 Quote
