OleksandrK Posted 8 hours ago Posted 8 hours ago I know this sounds strange, but I cannot get any of the images to boot. I have an R3S non-LTS + SD card. It works well with the stock images from FriendlyElec, but none of the Armbian images I tried will boot. I tried different tools to write the SD (BalenaEtcher, USBImager, Rufus), but nothing changed. When I tried to read the SD card with Armbian on my x86 laptop running Debian, the system didn’t recognize any proper partitions (maybe that’s normal, maybe not—I don’t know). But when I write an Armbian image for Allwinner NanoPi, the partitions are detected correctly. And finally, I can’t connect to the debug UART, so I can’t get any logs. I feel the solution should be simple, but I need help with this. 0 Quote
laibsch Posted 7 hours ago Posted 7 hours ago Armbian's archives can be uncompressed with 7-Zip on Windows, Keka on OS X and 7z on Linux. Images shall only be written with imaging tools that validate burning results. This saves you from corrupted SD card contents. Approved Tools: USBImager a lightweight cross-platform imaging tool Balena Etcher an electron / node.js based cross-platform imaging tool (may contain spyware) Did the validation of you burning the image succeed? 0 Quote
OleksandrK Posted 7 hours ago Author Posted 7 hours ago Yes, validation always succsess. I tried even different SD cards (brand new Sandisk). After Armbian fails to boot I write stock friendlyelec image by the same tool and stock image always properly boot 0 Quote
laibsch Posted 6 hours ago Posted 6 hours ago @c0rnelius is the maintainer of the board. Maybe he has something to say. 0 Quote
c0rnelius Posted 4 hours ago Posted 4 hours ago @OleksandrK 3 hours ago, OleksandrK said: the system didn’t recognize any proper partitions (maybe that’s normal, maybe not—I don’t know) I wrote both the Bookworm and Noble img and in both cases the partition table looked fine. I booted the Noble img; _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.8.1 for NanoPi R3S LTS running Armbian Linux 6.12.41-current-rockchip64 Packages: Ubuntu stable (noble) IPv4: (LAN) 10.0.0.xxx (WAN) xx.xxx.xxx.xx IPv6: 2601:xx:xxx:a200::b05b, 2601:xx:xxx:a200:510c:3033:d120:7b0d (WAN) 2601:xx:xxx:a200:e489:6cce:bd44:57dc Performance: Load: 25% Uptime: 1 min Memory usage: 8% of 1.92G CPU temp: 30°C Usage of /: 10% of 29G RX today: 127 KiB Commands: Configuration : armbian-config Monitoring : htop Last login: Fri Aug 22 09:00:15 2025 from 10.0.0.36 root@nanopi-r3s-lts:~# As asked before, did you decompress the img before writing? 0 Quote
OleksandrK Posted 3 hours ago Author Posted 3 hours ago (edited) 1 hour ago, c0rnelius said: As asked before, did you decompress the img before writing? Yes I tried. With no result. I even tried to write (decompressed) image by "gnome disks" graphic tool on Debian. With no result also. Board behaves like no system on SD (blink red led and no activity led on ethernets, except one on WAN). So the question is: if to insert properly recorded Armbian SD to x86 Debian, system have to recognize partition and read content of it, right? Edited 3 hours ago by OleksandrK 0 Quote
c0rnelius Posted 3 hours ago Posted 3 hours ago 3 minutes ago, OleksandrK said: system have to recognize partition and read content of it, right Yes. I also used gnome-disks and didn't bother to decompress, as it is not required to do so. Which img are you writing exactly? 0 Quote
OleksandrK Posted 2 hours ago Author Posted 2 hours ago (edited) 10 minutes ago, c0rnelius said: Yes. OK. So solution is to properly writing SD. 10 minutes ago, c0rnelius said: Which img are you writing exactly? Armbian_25.5.2_Nanopi-r3s-lts_bookworm_current_6.12.34_minimal and the same result Armbian_25.5.2_Nanopi-r3s-lts_noble_current_6.12.34. Edited 2 hours ago by OleksandrK 0 Quote
c0rnelius Posted 2 hours ago Posted 2 hours ago 4 minutes ago, OleksandrK said: Armbian_25.5.2_Nanopi-r3s-lts_bookworm_current_6.12.34_minimal Try the following: Armbian_25.8.1_Nanopi-r3s-lts_bookworm_current_6.12.41_minimal.img https://dl.armbian.com/nanopi-r3s-lts/Bookworm_current_minimal 0 Quote
Igor Posted 2 hours ago Posted 2 hours ago I have deployed Debian Trixie from download pages - with success. Moved my HA instance on it without any troubles. 0 Quote
