September 29, 20251 yr Radxa-cubie-a5e second Ethernet port not work after update Armbian 25.11.0-trunk.259. Quote [ 22.495764] sun55i-gmac200 4510000.ethernet: deferred probe timeout, ignoring dependency [ 22.495788] sun55i-gmac200 4510000.ethernet: probe with driver sun55i-gmac200 failed with error -110 Edited September 29, 20251 yr by Samixa
September 29, 20251 yr Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
September 30, 20251 yr Author Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti
October 7, 20251 yr same problem, and 25.11.0-trunk.129 img dont work Edited October 7, 20251 yr by Nob0dy
October 8, 20251 yr Author On 10/7/2025 at 7:40 PM, Nob0dy said: same problem, and 25.11.0-trunk.129 img dont work Hello Nob0dy , If you use 25.11.0-trunk.129 after cold reboot you must make soft reboot then second Ethernet port work.
October 9, 20251 yr Author 4 hours ago, Nob0dy said: Ok, it works, but is there a solution to this problem? Maybe this -> https://github.com/torvalds/linux/commit/a15f095b590bcc1968fbf2ced8fe87fbd8d012e0
October 31, 20251 yr Hi, if you compile your kernel with "CONFIG_SUN55I_PCK600" set, you'll have the second ethernet port. But you'll loose the wifi adapter, just like in the trunk.129.
November 16, 2025Nov 16 I've just tried https://dl.armbian.com/radxa-cubie-a5e/Trixie_edge_minimal Ethernet-Port besides USB-C blinks if connected, but looks like no IP requested. The other keeps dark if connected, pressing Button for long does nothing. I don't understand where other images to find, A5E not in: https://armbian.atomonetworks.com/dl/ What image ist know working, what is SSH Login Thank You
November 16, 2025Nov 16 1 hour ago, iwl said: I don't understand where other images to find There are no other images available at the moment. Regarding this, there is some initial but incomplete work in progress here: https://github.com/armbian/build/pull/8831 We can’t merge it in its current state, as it still requires a significant amount of additional work and refinement. Unfortunately, this means there isn’t a quick solution right now, so we’ll need to wait until the implementation is completed and validated.
