Posted (edited)
I updated to Armbian 26.2.1 on OPi5, and it can't boot from MTD (rootfs at NVMe), and I have to use SD card to boot to NVMe as workaround.
After looking into this issue, I found rkspi_loader.img is no longer available for current (6.18.8 kernel) u-boot pkg and armbian-config flashes u-boot-rockchip-spi.bin ( or similar sata version) to /dev/mtdblock0 and I think this is wrong image for MTD bootloader. If I use older vendor image, which u-boot pkg has rkspi_loader.img, system can boot to NVMe rootfs and I notice that /dev/mtdblock0 has several gpt partitions including u-boot one, and flashing u-boot-rockchip-spi.bin erases partitions in SPI flash.
I noticed that several related changes were introduced since 25.11, such as https://github.com/armbian/build/commit/e5b845f9432abb0408287599bba5889a86e6d068 , but I couldn't do quick fix to bring back working rkspi_loader.img because I am not familiar with whole armbian build.
One thing to note that if board was flashed with old rkspi_loader.img and not updated with 26.2 MTD image, it still boots to NVMe  rootfs, but I have other issues such as video playback not working with 6.18 kernel likely due to mismatch u-boot and kernel version leading to wrong HW initialization.
BTW, I checked 26.2 u-boot pkg for Rock 5B (similar rk3588 board), and rkspi_loader.img is still included.
Edited by zjd
  • zjd changed the title to Armbian 26.2.1 can't boot from MTD on OrangePi5
After digging into more details, I think Armbian has moved to use new U-Boot generated FIT image u-boot-rockchip-spi.bin for SPI boot, however, it doesn't work to boot NVMe rootfs and sometimes breaks the board and I have to erase SPI to get SD card booting. Couldn't find more information how Armbian does MTD boot now.
Note that older vendor SPI bootloader can boot kernel 6.18.8 but I ran into other issue like freezing system for a couple of minutes so that I'd say to avoid use old MTD image with 26.2 6.18 kernel.
I connected UART today and did some debugging, and it looks like that this u-boot 2025.10 for Armbian 26.02 doesn't see NVMe drive, i.e. 'nvme scan' returns nothing.
Is OPi5 NVMe support included in upstream mainline u-boot?
If you have flashed working rkspi_loader.img to MTD before, i.e. from previous releases, you can keep using it with vendor kernel w/o updating MTD.
The 26.2.1 image with vendor kernel uses new FIT u-boot loader as well, I doubt it will work with NVMe.
BTW, I need 6.18 kernel and new u-boot and noticed that 26.2.1 image default to vendor kernel instead of 6.18 kernel now.
On 2/27/2026 at 7:28 PM, xsetiadi said:
but still using vendor kernel?
Vendor kernel will stay for awhile (this year for sure) as mainline is not on this level yet.
10 minutes ago, xsetiadi said:
orangepi5: bump u-boot to v2026.04-rc3
This part might not be part of the release - you can grab it from nightly release - but most likely it won't have any affect to this topic.
Posted (edited)
Oh damn, wish I would have read this before I tried to install (26.2 with vendor kernel build on the 9th) from SD to Nvme...
How can I reflash MTD if I only have a MacBook available?
Note to self and the next one hitting that wall:
Going to maskrom mode kinda fixed it, after that I started again from a mSD and from that running ArmBian I flashed the same img to the Nvme on the board. Another reboot and it was started from the SSD 😉
Edited by mircsicz
Fixed it
so today im finally reinstall my opi5, and when choose mtd to flash i got two option, i guess the sata version is if im using sata ssd instead of nvme ssd?
correct
i find it is very convenient now, not only able to choose boot from nvme or sata ssd. but can also install the image from armbian-config. last time im installing armbian i need to dd the image manualy into nvme. very nice work for armbian team:thumbup:
Well the only thing armbian-config does, is calling "armbian-install" which has been there for ages :)
Hi everyone,
I just got an Orange Pi 5 and am experiencing the same issue as the OP. I've since then installed the bootloader on the SD card and the rootfs on the NVME drive. I don't really understand what came out of the discussion here: is it possible to boot from the MTD?
Thanks a lot!
EV
Booting from mtd/nvme should just work.
Most common problems:
- dirty mtd/emmc. vendor/unmatching boot loader can cause issues.
- mixup between m.2 sata and actual nvme. Correct overlay/dt must be used
- wrong rootfs uuid in armbianEnv.txt after running armbian-install (after done, do not reboot but mount freshly written nvme to a random folder and check if the uuid is correct)
Thank you very much for your reply, Werner - and indeed for all the tremendous work you do!
The drive is listed as an /dev/nvme0n1p1, so I think I did choose the right overlay. Rootfs UUID is correct.
I tested SPI/MTD boot with Armbian 26.2.1, rootfs on NVMe.
I erased and reflashed the SPI flash manually:
``` shell
sudo flash_eraseall /dev/mtd0
sudo dd if=/usr/lib/linux-u-boot-vendor-orangepi5/u-boot-rockchip-spi.bin \
  of=/dev/mtdblock0 bs=1M conv=fsync status=progress
sync
I then verified that the running system was still using /boot from the SD card:
``` shell
findmnt /boot
which returned:
``` shell
/boot  /dev/mmcblk1p1[/boot]
I mounted the NVMe rootfs and compared /boot on SD vs NVMe:
``` shell
sudo mkdir -p /mnt/nvme
sudo mount /dev/nvme0n1p1 /mnt/nvme
ls -la /boot
ls -la /mnt/nvme/boot
The NVMe /boot contents were older/stale compared with the SD /boot, so I synchronized them:
``` shell
sudo rsync -aHAX --delete /boot/ /mnt/nvme/boot/
sync
I then powered the board off completely, removed the SD card, and tested booting from SPI + NVMe again but it still won't boot without the SD card.
I watched your video on UART debugging, but unfortunately, my serial cable is too slow, so I'll get one of those you recommend and try again.
Thanks again!
