Igor Posted December 8, 2019 Author Posted December 8, 2019 3 hours ago, vore76 said: Anybody who can give some hints? Manual work to adjust patches is required since there were many changes since. If you don't know how, perhaps try to hire people to do that for you. 0 Quote
Werner Posted December 9, 2019 Posted December 9, 2019 9 hours ago, vore76 said: scripts/Makefile.lib:308: recipe for target 'arch/arm/dts/sun7i-a20-bananapi.dtb' failed dts/Makefile:38: recipe for target 'arch-dtbs' failed Makefile:1061: recipe for target 'dts/dt.dtb' failed [ error ] ERROR in function compile_uboot [ compilation.sh:204 ] [ error ] U-boot compilation failed [ o.k. ] Process terminated Go to your output/debug/ folder and check the log files for more detailed information. 0 Quote
Guest Posted December 9, 2019 Posted December 9, 2019 14 hours ago, Werner said: Go to your output/debug/ folder and check the log files for more detailed information. Hello! The only useful stuff I can find is in "compilation.log" Error: arch/arm/dts/.sun7i-a20-bananapi.dtb.pre.tmp:378.3-11 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [arch/arm/dts/sun7i-a20-bananapi.dtb] Error 1 make[1]: *** [arch-dtbs] Error 2 make: *** [dts/dt.dtb] Error 2 I'm using this for my private stuff. I can't afford to hire a person for this. But I will donate some money to the project as I already did in the past. If it's impossible to build something with the new kernel it's Ok. 0 Quote
Igor Posted December 9, 2019 Author Posted December 9, 2019 Donations give you nothing in return. You support what you already get. They current ly cover less than 0.5% of project costs. Now think again what you are asking ...Wrote on mobile 0 Quote
Werner Posted December 10, 2019 Posted December 10, 2019 Which makes any donation not less value, don't you think? Anyway. I try to build a kernel package on current (5.3.x) on my own to verify. What I have notice so far is that general-sunxi-overlays.patch did not apply properly. I'll check back on this later this day. Edit: Built was successful. 0 Quote
danielcharles Posted February 20, 2021 Posted February 20, 2021 Hi, The majority of users that are interested in building their own kernel are doing so because they have installed Ubuntu on their system and they wish to make a small change to the kernel for that system. In many cases the user just wants to make a kernel configuration change. The purpose of this page is to give that user a minimum amount of information for them to meet the goal of making a simple change to the kernel, building it and installing their kernel. It is not intended to be the definitive guide to doing Ubuntu kernel development. 0 Quote
Igor Posted February 22, 2021 Author Posted February 22, 2021 On 2/20/2021 at 7:45 AM, danielcharles said: The purpose of this page https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
kentAVR Posted July 4, 2021 Posted July 4, 2021 On 11/16/2018 at 12:25 AM, Igor said: We spent several years to learn and several years to make this system https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-kernel-config "If file userpatches/sources/$LINUXFAMILY.conf exists, it will be used in addition to the default one from config/sources." But there is no "sources" folder on userpatches! 0 Quote
lanefu Posted July 4, 2021 Posted July 4, 2021 1 hour ago, kentAVR said: But there is no "sources" folder on userpatches! Make the folder. https://github.com/armbian/build/blob/master/lib/configuration.sh#L125 0 Quote
kentAVR Posted July 4, 2021 Posted July 4, 2021 21 hours ago, lanefu said: Make the folder. https://github.com/armbian/build/blob/master/lib/configuration.sh#L125 You are not right, I shouldn't create any sources folder. This is stranch code from build/lib/configuration.sh if [[ -f $USERPATCHES_PATH/sources/families/$LINUXFAMILY.conf ]]; then display_alert "Adding user provided $LINUXFAMILY overrides" source "$USERPATCHES_PATH/sources/families/${LINUXFAMILY}.conf" fi But true code are in build/lib/compilation.sh if [[ -f $USERPATCHES_PATH/$LINUXCONFIG.config ]]; then display_alert "Using kernel config provided by user" "userpatches/$LINUXCONFIG.config" "info" cp "${USERPATCHES_PATH}/${LINUXCONFIG}.config" .config else display_alert "Using kernel config file" "config/kernel/$LINUXCONFIG.config" "info" cp "${SRC}/config/kernel/${LINUXCONFIG}.config" .config fi So for my Orange Pi 4 with my build script ./compile.sh BOARD=orangepi4 BRANCH=current RELEASE=hirsute BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=yes COMPRESS_OUTPUTIMAGE=sha,gpg,img BSPFREEZE=yes REPOSITORY_INSTALL="" EXTERNAL=no EXTRAWIFI=no AUFS=no WIREGUARD=no INSTALL_KSRC=yes OFFLINE_WORK=yes BSPFREEZE=yes I need put linux-rockchip64-current.config into build/userpatches. To check that armbian get my file I look at console Using kernel config provided by user linux-rockchip64-current.config 0 Quote
lanefu Posted July 4, 2021 Posted July 4, 2021 hi @kentAVR Sorry I see that the confusion was now. It was around user provided Kernel Configuration vs user provide Kernel Source Config. here's an example of a kernel source config you could override.. https://github.com/armbian/build/blob/master/config/sources/families/rockchip64.conf and yes, yourre correct, the pattern for providing a kernel build config in the top of the userpatches/ folder following the appropriate naming convention. 1 Quote
kentAVR Posted July 7, 2021 Posted July 7, 2021 menuconfig is strange magic! Look! 1) I set my settings of kernel. 2) I save my settings of kernel to file /home/a/Documents/myArmbians/8armbian/linux-rockchip64-current.config 3) I load settings from /home/a/Documents/myArmbians/8armbian/linux-rockchip64-current.config 4) I verify settings and its ok 5) I do Exit, armbian save my settings (and block file) and write me [ o.k. ] Exporting new kernel config [ /home/a/Documents/myArmbians/8armbian/build/output/config/linux-rockchip64-current.config ] 6) I am going to file from 5) and verify and... My settings is reseted! WTF? So right magic way is: 1) I set my settings of kernel. 2) I save my settings of kernel to file /home/a/Documents/myArmbians/8armbian/linux-rockchip64-current.config 3) Exit and STOP (Ctrl+Z) armbian build system. 4) put file from step 2) to /home/a/Documents/myArmbians/8armbian/build/userpatches/linux-rockchip64-current.config 5) wating message from armbian [ o.k. ] Exporting new kernel config [ /home/a/Documents/myArmbians/8armbian/build/output/config/linux-rockchip64-current.config ] 6) do not stop build! Just go to this file and verify. Usually it contains my settings. P.S. I use Orange Pi 4B 0 Quote
MikePooh Posted December 8, 2021 Posted December 8, 2021 (edited) I am trying to build U-Boot from source with docker using this guide. The Armbian commit hash is 3c4b890ead32720fbfc77356c9600c4ff08a91a3 ./compile.sh docker-shell RELEASE=focal BOARD=orangepipcplus BRANCH=current Than ./compile.sh 'prepare_host && compile_sunxi_tools && install_rkbin_tools' And dot error: /root/armbian/lib/main.sh: line 576: compile_sunxi_tools: command not found Could someone help with the issue? Thanks in advance. Edited December 8, 2021 by MikePooh Armbian commit hash added 0 Quote
Igor Posted December 8, 2021 Author Posted December 8, 2021 3 hours ago, MikePooh said: I am trying to build U-Boot from source with docker using this guide. This documentation is deprecated for around 48h. Not sure when we will be able to understand how this affects on reality. Not that optimal, but you will be able to proceed: ./compile.sh docker RELEASE=focal BOARD=orangepipcplus BRANCH=current KERNEL_ONLY=yes KERNEL_CONFIGURE=yes REPOSITORY_INSTALL="kernel,armbian-config,armbian-firmware" 0 Quote
MikePooh Posted December 8, 2021 Posted December 8, 2021 22 минуты назад, Igor сказал: KERNEL_CONFIGURE=yes And is there any way to call U-Boot menuconfig? 0 Quote
Werner Posted December 8, 2021 Posted December 8, 2021 34 minutes ago, MikePooh said: And is there any way to call U-Boot menuconfig? No. 0 Quote
MikePooh Posted December 9, 2021 Posted December 9, 2021 So only the way to change U-Boot config is to use: ./compile.sh CREATE_PATCHES=yes Am I right? 0 Quote
MikePooh Posted December 9, 2021 Posted December 9, 2021 Answering my own question. I was needed to change U-Boot configuration during Armbian build. According to this manual, and answers given above I've run following command: ./compile.sh docker RELEASE=focal BOARD=orangepipcplus BRANCH=current KERNEL_ONLY=yes KERNEL_CONFIGURE=no CREATE_PATCHES=yes REPOSITORY_INSTALL="kernel,armbian-config,armbian-firmware" Just before U-Boot build step patch looking dialog appears. Than I've put needed settings to my boards U-Boot defconfig file /armbian/cache/sources/u-boot/v2021.10/configs/orangepi_pc_plus_defconfig CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_EXT4_DEVICE_AND_PART="1:1" CONFIG_ENV_EXT4_FILE="/boot/uboot.env" CONFIG_ENV_EXT4_INTERFACE="mmc" Than pressed Enter in build terminal. Patch has been applied and I've got U-Boot with desired params. 0 Quote
Igor Posted December 9, 2021 Author Posted December 9, 2021 21 hours ago, MikePooh said: And is there any way to call U-Boot menuconfig? This could also be implemented - it should not be difficult. Its very rare used, which is why we never did that or have plans to do it. 0 Quote
haajee Posted February 13, 2022 Posted February 13, 2022 I read a few instructions for building a kernel. But because better safe than sorry. I want to upgrade the kernel of my Orange Pi 4 to a newer one. it runs now: 4-OrangePi:~:# uname -a Linux 4-OrangePi 5.10.63-rockchip64 #21.08.2 SMP PREEMPT Wed Sep 8 10:57:23 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux So, for me as beginner with my headless setup it's: 1. run compile.sh 2. Choose U-boot and kernel packages 3. Do not change the kernel configuration 4. Choose the board. Orange Pi 4 5. There we go. Output goes to output/debs/ 6. Copy all the debs files to my Orange Pi 4 and run sudo dpkg -i *.deb 0 Quote
ioncube Posted August 15, 2024 Posted August 15, 2024 (edited) I am building custom img for OrangePi 3b v2.1. Now the board config file located here use BOOT_FDT_FILE="rockchip/rk3566-orangepi-3b.dtb" I should change it to BOOT_FDT_FILE="rockchip/rk3566-orangepi-3b-v2.dtb" Now I have the dtb file where should I place it if img to be build for 5.xx legacy kernel? Are there any other things I should take care beforehand. I must say v2.1 do use a different WIFI/BT chip, broadcom AP6256 ...any additions to config files I can do beforehand? Edited August 15, 2024 by ioncube 0 Quote
pberki Posted September 18 Posted September 18 Hi, In the documentation (https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-kernel-config) it says: "User provided kernel config: If the file userpatches/linux-$LINUXFAMILY-$BRANCH.config exists, it will be used instead of the default one from config." Is there a way to define only the desired changes to the kernel parameters? 0 Quote
